  3. ESP8266 MQTT gateway SSL connection
1 Posts 1 Posters 3.1k Views 3 Watching
  • monteM
    monteM
    monte
    wrote on last edited by monte
    There are couple old topics on this forum about secure connection to external MQTT broker, but neither of solutions described there aren't working now. Not so long ago the pull request was added on PubSubClient github which provides SSL connection code available only for esp8266: https://github.com/knolleary/pubsubclient/pull/251. It isn't merged yet, but you can manually install proposed patch from here https://github.com/knolleary/pubsubclient/pull/251/commits/bc9995ba2f7d0a42959685bdae51a014e03514bd.
    Another thing you have to do is to modify MyGatewayTransportMQTTClient.cpp in /core folder of your MySensors library. I hope soon someone will make changes to source code, so it won't be necessary.
    I'm not experienced programmer, so i guess there has to be a better way to add changes to this code, but this way it works at least :
    * Copyright (C) 2013-2016 Sensnology AB
    // Topic structure: MY_MQTT_PUBLISH_TOPIC_PREFIX/NODE-ID/SENSOR-ID/CMD-TYPE/ACK-FLAG/SUB-TYPE
    #include "MyGatewayTransport.h"
    #if defined MY_CONTROLLER_IP_ADDRESS
    IPAddress _brokerIp(MY_CONTROLLER_IP_ADDRESS);
    #if defined(MY_GATEWAY_ESP8266)
    #define EthernetClient WiFiClient
    #if defined(MY_IP_ADDRESS)
    IPAddress _gatewayIp(MY_IP_GATEWAY_ADDRESS);
    IPAddress _subnetIp(MY_IP_SUBNET_ADDRESS);
    #elif defined(MY_GATEWAY_LINUX)
    // Nothing to do here
    #elif defined(MY_GATEWAY_ESP8266_SECURE)
    #define EthernetClient WiFiClientSecure
    #else
    uint8_t _MQTT_clientMAC[] = { MY_MAC_ADDRESS };
    IPAddress _MQTT_clientIp(MY_IP_ADDRESS);
    #if defined(MY_SSL_FINGERPRINT)
    const char* fingerprint = MY_SSL_FINGERPRINT;
    static EthernetClient _MQTT_ethClient;
    #if defined(MY_GATEWAY_ESP8266_SECURE)
    static PubSubClient _MQTT_client(_MQTT_ethClient, fingerprint);
    #else
    static PubSubClient _MQTT_client(_MQTT_ethClient);
    static bool _MQTT_connecting = true;
    static bool _MQTT_available = false;
    static MyMessage _MQTT_msg;
    bool gatewayTransportSend(MyMessage &message)
    	if (!_MQTT_client.connected()) {
    		return false;
    	setIndication(INDICATION_GW_TX);
    	char *topic = protocolFormatMQTTTopic(MY_MQTT_PUBLISH_TOPIC_PREFIX, message);
    	debug(PSTR("Sending message on topic: %s\n"), topic);
    	return _MQTT_client.publish(topic, message.getString(_convBuffer));
    void incomingMQTT(char* topic, uint8_t* payload, unsigned int length)
    	debug(PSTR("Message arrived on topic: %s\n"), topic);
    	_MQTT_available = protocolMQTTParse(_MQTT_msg, topic, payload, length);
    bool reconnectMQTT(void)
    	debug(PSTR("Attempting MQTT connection...\n"));
    	// Attempt to connect
    	if (_MQTT_client.connect(MY_MQTT_CLIENT_ID
    #if defined(MY_MQTT_USER) && defined(MY_MQTT_PASSWORD)
    	                         , MY_MQTT_USER, MY_MQTT_PASSWORD
    		debug(PSTR("MQTT connected\n"));
    		// Send presentation of locally attached sensors (and node if applicable)
    		presentNode();
    		// Once connected, publish an announcement...
    		//_MQTT_client.publish("outTopic","hello world");
    		// ... and resubscribe
    		_MQTT_client.subscribe(MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "/+/+/+/+/+");
    		return true;
    	return false;
    bool gatewayTransportConnect(void)
    	while (WiFi.status() != WL_CONNECTED) {
    		wait(500);
    		MY_SERIALDEVICE.print(F("."));
    	MY_SERIALDEVICE.print(F("IP: "));
    	MY_SERIALDEVICE.println(WiFi.localIP());
    		wait(500);
    	//TODO
    #else
    #ifdef MY_IP_ADDRESS
    	Ethernet.begin(_MQTT_clientMAC, _MQTT_clientIp);
    #else
    	// Get IP address from DHCP
    	if (!Ethernet.begin(_MQTT_clientMAC)) {
    		MY_SERIALDEVICE.print(F("DHCP FAILURE..."));
    		_MQTT_connecting = false;
    		return false;
    	MY_SERIALDEVICE.println(Ethernet.localIP());
    	// give the Ethernet interface a second to initialize
    	delay(1000);
    	return true;
    bool gatewayTransportInit(void)
    #if defined(MY_CONTROLLER_IP_ADDRESS)
    	_MQTT_client.setServer(_brokerIp, MY_PORT);
    #else
    	_MQTT_client.setServer(MY_CONTROLLER_URL_ADDRESS, MY_PORT);
    	_MQTT_client.setCallback(incomingMQTT);
    	// Turn off access point
    	WiFi.mode(WIFI_STA);
    #if defined(MY_ESP8266_HOSTNAME)
    	WiFi.hostname(MY_ESP8266_HOSTNAME);
    	(void)WiFi.begin(MY_ESP8266_SSID, MY_ESP8266_PASSWORD);
    	WiFi.config(_MQTT_clientIp, _gatewayIp, _subnetIp);
    	gatewayTransportConnect();
    	return true;
    bool gatewayTransportAvailable(void)
    	if (_MQTT_connecting) {
    		return false;
    	//keep lease on dhcp address
    	//Ethernet.maintain();
    		//reinitialise client
    		if (gatewayTransportConnect()) {
    			reconnectMQTT();
    		return false;
    	_MQTT_client.loop();
    	return _MQTT_available;
    MyMessage & gatewayTransportReceive(void)
    	// Return the last parsed message
    	return _MQTT_msg;
    So i added definition of MY_GATEWAY_ESP8266_SECURE option because we need to use WiFiClientSecure method for connection for SSL to work. Also we'll need SSL fingerprint of your MQTT broker, so you'll need to define this option in the code of your gateway. Else changes are duplicating code for MY_GATEWAY_ESP8266 to accommodate new option.
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266_SECURE
    // Set MQTT client id
    #define MY_MQTT_USER "user"
    #define MY_MQTT_PASSWORD "password"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "ssid"
    #define MY_ESP8266_PASSWORD "Wi-Fi password"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    //#define MY_IP_ADDRESS 192,168,2,197
    //#define MY_IP_GATEWAY_ADDRESS 192,168,2,1
    // MQTT broker ip address.
    #define MY_CONTROLLER_URL_ADDRESS "URL of your MQTT broker"
    #define MY_PORT SSL-port
    #define MY_SSL_FINGERPRINT "ssl fingerprint of your MQTT broker"
    #include <ESP8266WiFi.h>
    	// Send locally attech sensors data here
    Let me know what do you think about it.
