  3. Multi relay with two Binary switches
2 Posts 1 Posters 1.1k Views 1 Watching
  • DickD
    DickD
    Dick
    I created 2 project where I need 5 relays and 2 buttons. If I put the number of relays on 5, I only see 3 in my Domoticz. The switches are visible in Domoticz without problems. How can I fix the relay issue?
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #define RELAY_1 A0 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 5 // Total number of attached relays
    #define RELAY_ON 0 // GPIO value to write to turn on attached relay
    #define RELAY_OFF 1 // GPIO value to write to turn off attached relay
    #define CHILD_ID_IRBIN 3
    #define CHILD_ID_IRBUI 4
    #define IRBIN_PIN 3 // Arduino Digital I/O pin for button/reed switch
    #define IRBUI_PIN 4
    Bounce debouncerIRBIN = Bounce();
    Bounce debouncerIRBUI = Bounce();
    int oldValue_IRBIN = -1;
    int oldValue_IRBUI = -1;
    MyMessage msgIRBIN(CHILD_ID_IRBIN, V_TRIPPED);
    MyMessage msgIRBUI(CHILD_ID_IRBUI, V_TRIPPED);
    void before()
    pinMode(pin, OUTPUT);
    // Setup the button1
    pinMode(IRBIN_PIN, INPUT);
    debouncerIRBIN.attach(IRBIN_PIN);
    debouncerIRBIN.interval(5);
    digitalWrite(IRBIN_PIN, HIGH);
    // Setup the button2
    pinMode(IRBUI_PIN, INPUT);
    debouncerIRBUI.attach(IRBUI_PIN);
    debouncerIRBUI.interval(5);
    digitalWrite(IRBUI_PIN, HIGH);
    present(CHILD_ID_IRBIN, S_DOOR);
    present(CHILD_ID_IRBUI, S_DOOR);
    	present(sensor, S_BINARY);
    debouncerIRBIN.update();
    // Get the update value
    int valueIRBIN = debouncerIRBIN.read();
    if (valueIRBIN != oldValue_IRBIN) {
    // Send in the new value
    send(msgIRBIN.set(valueIRBIN == HIGH ? 1 : 0));
    oldValue_IRBIN = valueIRBIN;
    debouncerIRBUI.update();
    int valueIRBUI = debouncerIRBUI.read();
    if (valueIRBUI != oldValue_IRBUI) {
    send(msgIRBUI.set(valueIRBUI == HIGH ? 1 : 0));
    oldValue_IRBUI = valueIRBUI;
    if (message.type==V_STATUS) {
    // Change relay state
    // Store state in eeprom
    // Write some debug info
    Serial.print(message.sensor);
    DickD 1 Reply Last reply
    • DickD Dick
      #define IRBUI_PIN 4
      void before()
      DickD
      DickD
      Dick
      @dick said in Multi relay with two Binary switches:
      #define IRBUI_PIN 4
      void before()
      Sorry, add my questions two times
