  3. Domoticz
  4. Add radio NRF24 to sketch
2 Posts 2 Posters 1.4k Views 1 Watching
  • J Offline
    J Offline
    jordantheripper
    Hi people. I have a little question to ask. Today I made this sketch for arduino uno. This sketch let me read temperature and humidity on a lcd i2c and it works great. But in this way, it works alone. I would like to connect it to domoticz. So I have to add radio and relative child id
    (#define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1)
    to the sketch to connect it in Domoticz.
    this is the sketch:
    //Libraries
    #include <DHT.h>
    #include <Wire.h>
    #include <LCD.h>
    //Constants
    #define DHTPIN 4 // what pin we're connected to
    #define DHTTYPE DHT22 // DHT 22 (AM2302)
    DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
    //ALWAYS USE THIS WITH LCD I2C and Addres 0x3F
    #define I2C_ADDR 0x3F
    #define BACKLIGHT_PIN 3
    #define En_pin 2
    #define Rw_pin 1
    #define Rs_pin 0
    #define D4_pin 4
    #define D5_pin 5
    #define D6_pin 6
    #define D7_pin 7
    LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
    //Variables
    int chk;
    float hum; //Stores humidity value
    float temp; //Stores temperature value
    Serial.begin(9600);
    dht.begin();
    lcd.begin(16,2);
    lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
    lcd.setBacklight(HIGH);
    delay(2000);
    //Read data and store it to variables hum and temp
    hum = dht.readHumidity();
    temp = dht.readTemperature();
    //Print temp and humidity values to serial monitor
    Serial.print("Humidity: ");
    Serial.print(hum);
    Serial.print(" %, Temp: ");
    Serial.print(temp);
    Serial.println(" Celsius");
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("Temp: ");
    lcd.print(temp);
    lcd.print(" ");
    lcd.print((char)223);
    lcd.print("C");
    lcd.setCursor(0,1);
    lcd.print("Hum: ");
    lcd.print(hum);
    lcd.print(" %");
    delay(2000); //Delay 2 sec.
    so, can you help me to add radio NRF24 and connect it to domoticz?
    Thanks so much from Italy
    S 1 Reply Last reply
    • J jordantheripper
      this is the sketch:
      //Libraries
      #include <DHT.h>
      #include <Wire.h>
      #include <LCD.h>
      //Constants
      #define En_pin 2
      #define Rw_pin 1
      #define Rs_pin 0
      #define D4_pin 4
      #define D5_pin 5
      #define D6_pin 6
      #define D7_pin 7
      //Variables
      int chk;
      Serial.begin(9600);
      dht.begin();
      lcd.begin(16,2);
      delay(2000);
      Serial.print(hum);
      Serial.print(temp);
      lcd.clear();
      lcd.setCursor(0,0);
      lcd.print(temp);
      lcd.print(" ");
      lcd.print("C");
      lcd.setCursor(0,1);
      lcd.print("Hum: ");
      lcd.print(hum);
      lcd.print(" %");
      @jordantheripper Hi!
      Check this out: https://www.mysensors.org/about/arduino#basic-structure-of-sketches
      You can also check out any example in https://www.mysensors.org/build to get an idea how it should be written.
      Its very easy, just give it a try.
