  3. [SOLVED] ESP8266 MySensors 2.2.0 problem with static ip configuration
1 Posts 1 Posters 1.2k Views 1 Watching
  • ehomeE
    ehomeE
    ehome
    Hi all,
    EDIT 2018/06/10: Solution:
    It seems that some old wifi settings on my ESP8266 module has conflicted with the MySensors gateway sketch. I was able to set an static ip address after an complete erase of sketch and flash through Arduino IDE. - Thanks!
    If I try to configure my very basic (nearly plain) new ESP8266 MySensors 2.2.0 gateway with an static ip address then I get in serial monitor the following repeating output:
    (Log parser do not have further information for this specific error?)
    48 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0
    91 TSF:LRT:OK
    106 TSM:INIT
    119 TSF:WUR:MS=0
    139 TSM:INIT:TSP OK
    160 TSM:INIT:GW MODE
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    connected with SSID, channel 5
    dhcp client start...
    331 TSM:READY:ID=0,PAR=0,DIS=0
    364 MCO:REG:NOT NEEDED
    scandone
    889 GWT:TPC:CONNECTING...
    1416 GWT:TPC:CONNECTING...
    1944 GWT:TPC:CONNECTING...
    2472 GWT:TPC:CONNECTING...
    3000 GWT:TPC:CONNECTING...
    3528 GWT:TPC:CONNECTING...
    4056 GWT:TPC:CONNECTING...
    4584 GWT:TPC:CONNECTING...
    5112 GWT:TPC:CONNECTING...
    5640 GWT:TPC:CONNECTING...
    6168 GWT:TPC:CONNECTING...
    6696 GWT:TPC:CONNECTING...
    7224 GWT:TPC:CONNECTING...
    7752 GWT:TPC:CONNECTING...
    8280 GWT:TPC:CONNECTING...
    If I switch to dhcp then everything is working like expected.
    And of course the ip is not already assigned by an different device ;-)
    What I am doing wrong?
    ␀�/��␝���48 MCO:BGN:INIT GW,CP=RRNGE---,VER=2.2.0
    91 TSF:LRT:OK
    105 TSM:INIT
    119 TSF:WUR:MS=0
    139 TSM:INIT:TSP OK
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    connected with SSID channel 5
    363 MCO:REG:NOT NEEDED
    scandone
    ip:10.0.8.160,mask:255.255.255.0,gw:10.0.8.253
    3556 GWT:TPC:IP=10.0.8.160
    3584 MCO:BGN:STP
    -- STA (client) informations --
    Hostname: mqtt-sensor-gateway1
    Connected to: SSID (xx:xx:xx:xx:xx:xx), -45dBm
    IP address: 10.0.8.160
    Gateway address: 10.0.8.253
    Subnet mask: 255.255.255.0
    MAC STA address: xx:xx:xx:xx:xx:xx
    -- AP (server) informations --
    Soft IP address: 0.0.0.0
    MAC AP address: xx:xx:xx:xx:xx:xx
    3826 MCO:BGN:INIT OK,TSP=1
    3986 GWT:TPC:IP=10.0.8.160
    4014 GWT:RMQ:MQTT RECONNECT
    4058 GWT:RMQ:MQTT CONNECTED
    4087 GWT:TPS:TOPIC=ehome/gateway1-out/0/255/0/0/18,MSG SENT
    pm open,type:2 0
    Sketch:
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    //#define MY_RADIO_RFM95
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ // Set your frequency here
    //#define MY_IS_RFM69HW // Omit if your RFM is not "H"
    #define MY_RF69_IRQ_PIN D1
    #define MY_RF69_IRQ_NUM MY_RF69_IRQ_PIN
    #define MY_RFM69_CS_PIN D8 // NSS. Use MY_RF69_SPI_CS for older versions (before 2.2.0)
    #define MY_RFM69_NETWORKID 200 // Default is 100 in lib. Uncomment it and set your preferred network id if needed
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "ehome/gateway1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "ehome/gateway1-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "ehome-gw-1"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "MySSID"
    #define MY_ESP8266_PASSWORD "MyPassword"
    #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway1"
    #define MY_IP_ADDRESS 10, 0, 8, 200
    #define MY_IP_GATEWAY_ADDRESS 10, 0, 8, 253
    #define MY_IP_SUBNET_ADDRESS 255, 255, 255, 0
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 10, 0, 12, 200
    // Enable these if your MQTT broker requires username/password
    #define MY_MQTT_USER "MyUsername"
    #define MY_MQTT_PASSWORD "MyPassword"
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
    #include <ArduinoOTA.h>
    #if defined MY_DEBUG
      if (WiFi.status() != WL_CONNECTED)
        Serial.println("Not connected to WiFi");
      else
        Serial.println("");
        Serial.println("-- STA (client) informations --");
        Serial.print("Hostname: ");
        Serial.println(WiFi.hostname());
        Serial.print("Connected to: ");
        Serial.print(WiFi.SSID());
        Serial.print(" (");
        Serial.print(WiFi.BSSIDstr());
        Serial.print("), ");
        Serial.print(WiFi.RSSI());
        Serial.println("dBm");
        Serial.print("IP address: ");
        Serial.println(WiFi.localIP());
        Serial.print("Gateway address: ");
        Serial.println(WiFi.gatewayIP());
        Serial.print("Subnet mask: ");
        Serial.println(WiFi.subnetMask());
        Serial.print("MAC STA address: ");
        Serial.println(WiFi.macAddress());
        Serial.println("-- AP (server) informations --");
        Serial.print("Soft IP address: ");
        Serial.println(WiFi.softAPIP());
        Serial.print("MAC AP address: ");
        Serial.println(WiFi.softAPmacAddress());
        Serial.println("----");
        Serial.println("");
      ArduinoOTA.onStart([]() {
        Serial.println("ArduinoOTA start");
      ArduinoOTA.onEnd([]() {
        Serial.println("\nArduinoOTA end");
      ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
        Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
      ArduinoOTA.onError([](ota_error_t error) {
        Serial.printf("Error[%u]: ", error);
        if (error == OTA_AUTH_ERROR)
          Serial.println("Auth Failed");
        else if (error == OTA_BEGIN_ERROR)
          Serial.println("Begin Failed");
        else if (error == OTA_CONNECT_ERROR)
          Serial.println("Connect Failed");
        else if (error == OTA_RECEIVE_ERROR)
          Serial.println("Receive Failed");
        else if (error == OTA_END_ERROR)
          Serial.println("End Failed");
      ArduinoOTA.begin();
      // Send locally attech sensors data here
      ArduinoOTA.handle();
