  3. 💬 RFM69(H)W Arduino Mini Pro Shield v2
rfm69arduino pro minishieldrfm69hw
8 Posts 6 Posters 1.2k Views 5 Watching
  • openhardware.ioO Offline
    openhardware.io
    https://www.openhardware.io/view/615/RFM69HW-Arduino-Mini-Pro-Shield-v2
    • 5 Offline
      5 Offline
      556duckvader
      I really like this design and looking forward to the final working product. I am interested in this for a project where I need to place multiple temp/humidity sensors in multiple containers and I am looking to design and 3D print a small case that would hold an 18650 battery, Arduino pro mini, RFM69, and temp sensor.
      • S Offline
        salfare
        has this ever be tested ? Just ordered some boards and noticed that VCC of the PCB is wired to DIO5 instead of 3.3V of the RFM69HW module.
        • E Offline
          E Offline
          evb
          @jlaraujo, I'm searching a more reliable way to connect the RFM69HW module to the Pro Mini.
          I'm aware that this project is already 2 years old.
          You didn't answer to the question of user @salfare, maybe you didn't see his question?
          I'm very limited in height for what I'm trying to build, what is the height of the two stacked?
          • electrikE Offline
            electrikE Offline
            electrik
            I have tested this board and @salfare observation was right. I had to add a wire to VCC in order to make it work. Just to be sure, I have also cut the connection to DIO5.
            The result is a very compact board.
            E 1 Reply Last reply
            • electrikE electrik
              E Offline
              E Offline
              evb
              Hi @electrik,
              Maybe you can answer my question: What is the height of the two stacked together?
              Like said, I'm very limited in height, so I did not take the risk to order this board (yet)...
              • electrikE Offline
                electrikE Offline
                electrik
                Here the picture of the assembled board. The top board is a temperature sensor so not necessarily needed.
                • K Offline
                  K Offline
                  kiesel
                  Does anybody have a link to a fixed version of this board? It's exactly what I am looking for form-wise, but I'd be nice if VCC was wired to 3.3v out of the box. Thanks!!
