  3. sendHeartbeat not work right
6 Posts 2 Posters 1.3k Views 4 Watching
  • Ivan ZI
    Ivan ZI
    Ivan Z
    I send Heartbeat, but receive in system I_DISCOVER_RESPONSE
    Sketch code
       unsigned long tick = millis();
       if (tick - previsionTime > HeartBitInterval) {
         previsionTime = tick;
         sendHeartbeat();
    Node log
    __  __       ____
            |___/                      2.3.0
    16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    14960 TSF:MSG:SEND,115-115-0-0,s=2,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
    48934 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    48941 TSF:MSG:BC
    49762 TSF:MSG:SEND,115-115-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
    49772 TSF:MSG:READ,0-5-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    49780 TSF:MSG:BC
    49782 TSF:MSG:READ,0-6-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    49788 TSF:MSG:BC
    1254332 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    1254340 TSF:MSG:BC
    1255313 TSF:MSG:SEND,115-115-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
    1255323 TSF:MSG:READ,0-5-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
    1255331 TSF:MSG:BC
    Log in system: MajorDomo
    2018-11-29 10:26:19 699 >> 3:Internal; Gate:1; Node:115; Sensor:255; Ack:0; Sub:21:I_DISCOVER_RESPONSE; Msg:0
    2018-11-29 10:25:47 133 >> 1:Set; Gate:1; Node:115; Sensor:2; Ack:0; Sub:2:V_STATUS; Msg:1
    • rejoe2R
      rejoe2R
      rejoe2
      @ivan-z said in sendHeartbeat not work right:
      Not quite sure, but imo the node doesn't enter loop() at all. Sure it is registered to the controller?
      You may add some serial output when loop() is processed the first time (or use setup() routine)
      • Ivan ZI
        Ivan ZI
        Ivan Z
        This is only part of the code.
        Full version sketch
        https://github.com/Shagrat2/MSMDLed/blob/master/MSMDLed.ino
        rejoe2R 1 Reply Last reply
        • Ivan ZI Ivan Z
          Full version sketch
          rejoe2R
          rejoe2R
          rejoe2
          @ivan-z Wow, looks great!
          Nevertheless make sure, loop() is effectively entered.
          So first step for debugging might be to add a
          Serial.println("Entering  - before()");
          at the beginning of the corresponding subroutine (do this for before(), presentation() and setup() and at the end of setup(), I'd recommend an additional Serial.println("exiting setup()";.
          • Ivan ZI
            Ivan ZI
            Ivan Z
            before = work
            presentation = work
            setup = work
            • rejoe2R
              rejoe2R
              rejoe2
              Is setup() also exiting correctly or only entering?
              If all this happens, add a one-time routine in loop().
