💬 Building a MQTT Gateway
  • I thought that the gateway could be done only with the ESP8266 module.
  • If you're using an ESP8266 and you find it "SOFT WDT resetting" whenever a node tries to send a message, try moving the wire from GPIO4 to GPIO5 - There are a few esp12E boards which have been incorrectly screen printed - worked for me with this board!
    https://twitter.com/bdcatalin/status/663434209265078272
  • Regarding ACK flag in MQTT.
    If a sensor sends data to the gateway, and it requests an ACK.
    It is the gateway that responds with an ACK, not the controller.
    How do one utilize the ACK flag in MQTT?
    Or rather, how do one get the ACK to display in a MQTT message?
    int value = debouncer.read();
    //We only expect one type of message from controller. But we better check anyway.
     if (message.isAck()) {
    Should I write a codesnippet like the above but one that sends a message back to the gateway, that the ACK was received?
    And also, if an ACK was not received that the sensor should try to send the message again.
  • I have set up an MQTT gateway running on a Wemos D1, and a motion sensor running on an arduino nano.
    It seems to work successfully, but I had to define MY_NODE_ID in the sensor sketch because the negotiation for this is done by the controller. Presumably, I'm going to have to program my controller to respond to the mqtt message being sent to negiotiate the id, but I cannot find any documentation on the correct reply. Does someone have a link?
    The mqtt message being sent to negotiate the node id was
    mygateway1-out/255/255/3/0/3 (null)
  • I believe the node id will always be 0 for gateways so the examples are a little misleading. For example the output shows connections with a node id of 2 (e.g. mygateway1-out/2/1/1/0/49 55.722519;13.018121;13)
  • Can this be used with RabbitMQ as broker?
  • Not sure if you want to leave the GPS on there unless that isn't your house with the double hot tub in tha back garden 🙂
  • Hi, is it possible to configure the MQTT gateway to let me in to port 5003 via telnet and read the communication message (not MQTT payloads) there also?
  • Not sure if this helps but for debugging I use MQTT spy (https://github.com/eclipse/paho.mqtt-spy/wiki) for tracking the comms
    There is also mqtt fx that can be used to see what's going on on the mqtt server
  • I know what is going on the MQTT server and I am subscribed to the topics the Mysensors gateway created and publish data to it.
    But, I want to know what is going on the GATEWAY as well. I'd like to see messages like these when I telnet to the gateway on port 5003 (that's the default as I remember)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.0.109
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    There is the tool MYSController that connects to the gateway and shows all the messages
    My gateway seems to be constantly repeating the following on the serial monitor:
    IP: 192.168.0.22
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;Sending message on topic: Gateway1-out/0/255/0/0/18
    0;255;3;0;9;Message arrived on topic: Gateway1-in/4/1/1/0/2
    0;255;3;0;9;TSF:MSG:SEND,0-0-4-4,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    IP: 192.168.0.22
    IP: 192.168.0.22
    Does this look like its in a reset loop or would you say there is some other issue going on?
    If needed, my config is a Arduino Mega 2560 witha w5100 shield on top. I have specified the IP address of itself, the subnet, gateway, mqtt client IP (Controller), the mqtt topics, port, changed my LED pins.
    I have a node with a button next to me, when i press it the message is picked up by the gateway. Below is what happens in the serial monitor when i press the node button.
    IP: 192.168.0.22
    0;255;3;0;9;TSF:MSG:READ,3-3-0,s=3,c=1,t=2,pt=2,l=2,sg=0:1
    0;255;3;0;9;Sending message on topic: Gateway1-out/3/3/1/0/2
    I'm a little confused at what point to troubleshoot here because I seem to think that for some reason it keeps refreshing its connection to the MQTT server. Not too sure why it is pushing a message to the topic of "Gateway1-out/0/255/0/0/18" either.
    @Samuel235 see if the solution suggested by tekka in https://forum.mysensors.org/post/47225 can help (downgrade board definitions to 1.6.11)
    In case anyone needs to know where to downgrade: Tools -> Boards ->Boards Manager -> Select version for Arduini AVR Boards.
    @mfalkvidd - It is still seeming to repeatedly reconnect to the MQTT server. I've issued a ping command to the arduino from the mqtt server and its constantly pinging without an issue, even while the serial monitor shows that its reconnecting. I'de be interested to know if anyone else is running the MQTT client gateway with MySensors V2.1. I used to run it when it was first introduced into the development environment in 1.6 and its been fine for over a year, but i upgraded to V2.1 and now i get this. So, i don't actually know if it is supposed to keep reconnecting to the MQTT server. I have read somewhere here that it sends a wake/refresh packet/message to the mqtt server just to keep it alive, but they said that was every 15 seconds by default. This is happening every 5/6 seconds.
    IP: 192.168.0.22
    IP: 192.168.0.22
    IP: 192.168.0.22
    i think you need to post your code just to make more complete info.
    I would like to know if anyone else's MQTT Gateway does this?
    If this is the normal procedure I can carry on with config work for the nodes. Its pretty weird, the serial monitor is showing this but the gateway seems to be functioning. Nodes are talking to it. I'm not sure on that output topic though, why would it be sending something to Gateway1-out/0/255/0/0/18?
    @gohan - I have not touched the MySensors.h or MyConfig.h but the sketch is below:
     * Version 1.0 - Henrik Ekblad
     * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "Gateway1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "Gateway1-in"
    // Set MQTT client id
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    #define MY_IP_ADDRESS 192,168,0,22
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 21
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 11  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  12  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  13  // the PCB, on board LED
    #include <Ethernet.h>
    EDIT: My issue was resting on the MQTT Server, had OpenHAB and MySensors gateway using same ClientID.
  • @Gabor-Bognar I also need to be able to do this.
    Is there a solution to have a port 1883 for MQTT and port 5003 for telnet?
    There is a missing parameter in your sketch :
    // Note that most of the Ardunio examples use "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0x90, 0xA2, 0xDA, 0x10, 0xEB, 0x1D
    In normal way, this line is note really important.
    But if you want to use two separate MQTT on the same network, you should add this line and modify the mac adress on the two MQTT...
    Bye
  • Is it possible to have a single device acting as a ethernet gateway and an mqtt gateway?
    No, but if you really really need the 2 connections you could use node-red to read data from the ethernet gateway and mirror them to mqtt
  • I am wondering why you cannot built the ethernet gateway and combine the mqtt client sketch into it? I am trying to shift towards mqtt (experiment) while still having sensors available in Vera. I have the MQTT plugin on vera but have not yet figured out how to use the child device to control devices via MQTT. It seems like a waste to control the MQTT device only through Vera and I would never be able to shift away from vera that way. I'm new to this so I am still trying to understand the entire picture.
    @scottdube my guess is that nobody with sufficient knowledge has had enough motivation and time to see if it can be done - especially since other solutions (nodered, myscontroller) already exist.
  • @mfalkvidd I am missing something, the reason I want it to do both is that I want the flexibility to use Node Red and my Vera controller. I was thinking that as I built new sensors they would run through node red but be available to vera as well. I'm sure I just don't yet understand how people are designing their hybrid systems yet. My solution was to have the mysensors gateway also put the sensors values out to the mqtt broker and vice versa but there must be another way I am not seeing yet...
    maybe it is time to switch away from Vera to something else that still uses zwave?
  • @gohan Maybe that is the answer, I'll research that a bit... That was what I was hoping to do over time with my strategy...
  • I'd like to have a very simple (intra-home) web page in my raspberry PI that would be updated with all of my nodes information and that could also turn on/off nodes with actuators (basically I don't want to have a fancy controller).
    If I understood correctly, with this MQTT Ethernet Gateway I could implement this by running Mosquito that would subscribe information from each node, through this MQTT gateway.
    Does this mean I can avoid having a controller?
    Cheers,
    Technically speaking yes but I don't see the point in reinventing the wheel
  • I rebuilt my serial gateway to a MQTT gateway. FWIW I had to connect 5V to my WizNET (W5100) Ethernet module (3.3V did not work) I couldn't make DHCP work so I used a fixed IP. Finally I had to replace the capacitor over the radio power feed from 4.7 uF capacitor to a 100 uF capacitor (That made a big difference!). Works great now.
  • It should have:
    sendSketchInfo("Gateway node", "1.0");
    In order to show the right topology in some tools, i.e. mycontroller.org
  • Hi, is there any case for this gateway ? I wouldn't want all those wires to lay around in plain view..
    @sionut "this gateway" is a bit ambiguous. The mqtt gateway can be based on different Arduinos and use different expansion boards, which will make a big difference for casing. Which variant are you planning to build?
  • That's a good question. 🙂 I didn't realize that the arduino board is not specified (neither in this tutorial nor in the ethernet one).
    However, I see that the ethernet gateway project (https://www.mysensors.org/build/ethernet_gateway) mentions that any arduino board would be fine. Since I'm only a beginner, I don't know what board would suffice for this kind of project. Could you recommend me the cheapest Arduino board that can do the job ?
    @sionut if you have wifi, I would suggest esp8266 (wemos d1 mini if you want a specific board recommendation). It has built-in wifi so you don’t need an expansion board. Guide: https://www.mysensors.org/build/esp8266_gateway It can be run in mqtt mode if you prefer mqtt over plain tcp.
    If you prefer ethernet, the Arduino Uno seems to be the one that matches the W5100 shield.
  • Great. I have wifi, so I will use the esp8266. I think I will continue with this board here as it's something I can find in a local store nearby.
    I just need one more clarification though: in the ESP8266 gateway page I see the following paragraph:
    Just connect the radio, install gateway software and you're good to go.
    Now, considering that the board already has WIFI, why do I need the radio ?
    @sionut the "normal" use of a MySensors network is to have multiple nodes using a cheap radio (nrf24) and a low-power microcontroller (Arduino Pro Mini is much more power efficient than the esp8266).
    The gateway connects the nodes (using nrf24) to your controller. Without a radio, the gateway can't talk to the nodes. See this page in the gatting started guide for a more complete explanation.
    However, if you don't need battery-powered nodes you could get a bunch of esp8266 and configure them all as gateways without adding radios to them.
  • Is it feasible to have MySensors talking to an MQTT Broker like Mosquito (running on a rpi) via radio so using say a USB gateway AND also have WiFi modules talking to Mosquito and then having Mosquito talking to HomeAssistant? I see where this is doable via MySensors and radio links OR it can be done using WiFi modules but what if you want both?
  • Yes that is possible. Mysensors connects through the gateway to MQTT and the WiFi modules to mosquitto directly. You can use the mysensors protocol also over the WiFi modules I believe.
    I'm not sure if it is possible with an usb gateway though, but for sure with a WiFi based gateway like ESP 32.
    Once you are on mqtt you can connect to and from all devices/controllers that support it.
    @alaskadiy I'd make a raspberry gateway with radio directly on the raspberry, much cleaner solution
  • @gohan With a radio directly on the rPi would mosquito talk to both the radio and WiFi? I assume it would, I would think mosquito would just be a service that the radio or WiFi sends/receives data to but have not seen anyone talk about it.
  • @electrik Sounds like what I want to do can be done, thanks.
    @alaskadiy no. The gateway (running as a service) would talk to the radio and to mosquitto. Mosquitto is unable to talk directly to the radio.
  • Hi guys. I'm using an Arduino Uno+5100 based MQTT gateway. It works fine for it's gateway function but I'm not beeing able to send local sensor data. Is that possible?
    @guillermo-schimmel it should be possible to call present() and send() just like on a regular node. Could you share your sketch and the debug output?
  • @mfalkvidd thanks. I just did that on a dedicated post. It's driving me crazy.
    https://forum.mysensors.org/topic/10109/ethernet-mqtt-gateway-slow-to-connect
    @guillermo-schimmel ok, lets discuss there then so we don't split the effort and information in separate threads.
  • Hi, receiving an upvote on a relatively old topic of mine, did remember me that this information could help others searching to build a MQTT gateway with a RFM69 radio, a W5100 Ethernet shield and a simple Arduino UNO R3.
    https://forum.mysensors.org/topic/10358/solved-mqtt-gateway-based-on-arduino-uno-uno-compatible-w5100-ethernet-shield-rfm69hw-radio
    People starting with MySensors, normally read as first step, the documentation available.
    Every open source project is structurally a bit different and sometimes it is difficult to know how to contribute to the project.
    For example, the open source project HomeAssistant (a possible controller for MySensors) uses a standard git repository for its documentation where anyone can make a pull request with their contribution. The moderators then review each contribution and either accept it or not. You have the official documentation and the 'user guides' documentation.
    @mfalkvidd, maybe a workflow to consider? It can help to keep the documentation up to date faster and assess contributions better and faster.
    Most open source projects run on volunteers who spend their free time on these projects, so I'm happy to return some knowledge.
    In the meantime, I've learned here and realized that under every documentation page, there is a forum topic.
    Unfortunately, documentation is usually not really up to date and the topic can be very long. Very hard to read for beginners. 😞
    That's why I created some forum topics with my first steps in the Mysensors world to overcome some outdated documentation. But of course these are hard to find among all the other topics and if you don't know anything about their existence, it's even harder.
    And like everything, my topic is also already outdated, because, if I am correct, today a W5200 Ethernet shield is existing...
    (for your information, my mqtt gateway is still alive and kicking 😉 )
  • Does anyone know if it would be possible to add static information that would be available over HTTP (default port 80)?
    My idea is to put some kind of description/useful information in the MQTT GW itself. So in case Controller fails. There is some information resource what is the purpose, functionality and how to use it in some limited/emergency way eg. from phone or any computer.
    EDIT: Thinking of it - it might also provide some kind of configuration interface...
  • @tssk Nice idea! This should work, at the cost of some other feature which doesn't fit into ATMega's flash anymore.
    Here's my gateway:
    #define BUILD_MQTT_GATEWAY // either build mqtt gateway or ethernet gateway
    // #define USE_SIGNING
    #define MY_RADIO_RF24
    // #define MY_RADIO_RFM69
    #define WEBFRONTEND // provide a webfrontend at port 80 that shows gateway config
    #define SN "MySensors W5100 Gateway"
    #define SV "0.2"
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mysgw1-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mysgw1-in"
    #define MY_MQTT_CLIENT_ID "mysgw1"
    #define MY_MQTT_CONTROLLER_IP_ADDRESS 192, 168, 99, 20
    #define MY_MQTT_PORT 1883
    #define MY_MYSGW_PORT 5003
    #define MY_IP_ADDRESS 192,168,99,13
    #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBA, 0xBE, 0x99, 0x13
    #define MY_RFM69_NETWORKID (200)
    #define MY_RFM69_TX_POWER_DBM 20
    #define MY_SERIALDEVICE Serial
      #define MY_SOFTSPI
      #define MY_SOFT_SPI_SCK_PIN (14)
      #define MY_SOFT_SPI_MISO_PIN (16)
      #define MY_SOFT_SPI_MOSI_PIN (15)
    #ifdef MY_RADIO_RF24
      #define MY_RF24_CE_PIN (5)
      #define MY_RF24_CS_PIN (6)
    #elif defined MY_RADIO_RFM69
      #define MY_IS_RFM69HW
      #define MY_RFM69_NEW_DRIVER
      #define MY_RF69_SPI_CS (14)
      #error "only rfm24 or rf69 supported"
    #ifdef BUILD_MQTT_GATEWAY
      #define MY_PORT MY_MQTT_PORT
      #define MY_CONTROLLER_IP_ADDRESS MY_MQTT_CONTROLLER_IP_ADDRESS
      #define MY_GATEWAY_W5100
      #define MY_PORT MY_MYSGW_PORT
    #ifdef USE_SIGNING
      #define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
    void printIpAddress ( Stream &s, uint8_t a, uint8_t b, uint8_t c, uint8_t d )
      s.print ( a );
      s.print ( "." );
      s.print ( b );
      s.print ( "." );
      s.print ( c );
      s.print ( "." );
      s.print ( d );
    void printMacAddress ( Stream &s, uint8_t a, uint8_t b, uint8_t c, uint8_t d, uint8_t e, uint8_t f )
      s.print ( a, HEX );
      s.print ( ":" );
      s.print ( b, HEX );
      s.print ( ":" );
      s.print ( c, HEX );
      s.print ( ":" );
      s.print ( d, HEX );
      s.print ( ":" );
      s.print ( e, HEX );
      s.print ( ":" );
      s.print ( f, HEX );
    void printConfig ( Stream &s, char * lineBreak )
      s.print ( F ( "***********************************************" ) );
      s.print ( lineBreak );
      s.print ( SN );
      s.print ( "Version " );
      s.print ( SV );
      s.print ( F("own mac address: ") );
      printMacAddress ( s, MY_MAC_ADDRESS );
      s.print ( F("own network address: ") );
      printIpAddress ( s, MY_IP_ADDRESS );
        s.print ( F("Gateway type: mqtt" ) );
        s.print ( F ( "mqtt controller address: " ) );
        printIpAddress ( s, MY_CONTROLLER_IP_ADDRESS );
        s.print ( F ( "mqtt controller port: " ) );
        s.print ( MY_MQTT_PORT );
        s.print ( F ( "mqtt client id: " ) );
        s.print ( MY_MQTT_CLIENT_ID );
        s.print ( F ( "mqtt publish prefix: " ) );
        s.print ( MY_MQTT_PUBLISH_TOPIC_PREFIX );
        s.print ( F ( "mqtt subscribe prefix: " ) );
        s.print ( MY_MQTT_SUBSCRIBE_TOPIC_PREFIX );
        s.print ( F ( "Gateway type: MysGW" ) );
        s.print ( F ( "network port: " ) );
        s.print ( MY_MYSGW_PORT );
      s.print ( F ( "Radio type: " ) );
        s.print ( F ( "NRF24" ) );
        s.print ( F (  "RFM69" ) );
        s.print ( F ( "network id: " ) );
        s.print ( MY_RFM69_NETWORKID );
        s.print ( F ( "bad radio defined" ) );
      s.print ( F ( "signing: " ) );
    #ifdef USE_SIGNING
        s.print ( "yes" );
        s.print ( "no" );
    #ifdef WEBFRONTEND
      byte mac[] = { MY_MAC_ADDRESS };
      IPAddress ip ( 192,168,99,13 );
      EthernetServer server ( 80 );
      uint32_t enter = hwMillis();
      while (hwMillis() - enter < (uint32_t)500);
      while(!MY_SERIALDEVICE); // For USB enabled devices, wait for USB enumeration before continuing
      printConfig( MY_SERIALDEVICE, "\n" );
    #ifdef WEBFRONTEND
      Ethernet.begin(mac, ip);
    void presentation() { }
    #ifdef WEBFRONTEND
      // listen for incoming clients
      EthernetClient client = server.available();
      if (client) {
        Serial.println("new client");
        // an http request ends with a blank line
        boolean currentLineIsBlank = true;
        while (client.connected()) {
          if (client.available()) {
            char c = client.read();
            Serial.write(c);
            // if you've gotten to the end of the line (received a newline
            // character) and the line is blank, the http request has ended,
            // so you can send a reply
            if (c == '\n' && currentLineIsBlank) {
              // send a standard http response header
              client.println("HTTP/1.1 200 OK");
              client.println("Content-Type: text/html");
              client.println("Connection: close");  // the connection will be closed after completion of the response
              client.println();
              client.println("<!DOCTYPE HTML>");
              client.println("<html>");
              printConfig ( client, "<br />" );
              client.println("</html>");
            if (c == '\n') {
              // you're starting a new line
            } else if (c != '\r') {
              // you've gotten a character on the current line
              currentLineIsBlank = false;
        // give the web browser time to receive the data
        delay(1);
        // close the connection:
        client.stop();
        Serial.println("client disconnected");
    It will deliver this website to the browser:
    Version 0.2
    own mac address: DE:AD:BA:BE:99:13
    own network address: 192.168.99.13
    Gateway type: mqtt
    mqtt controller address: 192.168.99.20
    mqtt controller port: 1883
    mqtt client id: mysgw1
    mqtt publish prefix: mysgw1-out
    mqtt subscribe prefix: mysgw1-in
    Radio type: NRF24
    signing: no
  • @frits Cool! So you already had this?
    I was exactly thinking of using most simple HTTP server example from Arduino examples (although you have it nicely dynamic using the defines etc.). But I was not sure if it would not interfere with mysensors library in some way or if maybe mysensors already had such functionality build-in (because if I remember correctly Ethernet gateway return some data to browser of you call the 5003 port).
  • @tssk said in 💬 Building a MQTT Gateway:
    no, not as a webserver. I only print some node information to Serial.
    Webserver seems to work and not to interfere with mysensors core. My (MQTT-)Gateway doesn't act as a server, so there's only one listener. But multiple listeners (webserver on port 80 and Ethernet Gateway on port 5003 for example) should also be possible. I've not tested this though.
    I'm new here so sorry if this is not the right place for this question.
    But I am trying to build Arduino MQTT GW to act as a relay/light controller and report/interact with HomeAssistant.
    I think I have worked out most of my problems and got it running as I wanted to, but I was testing failover senarios as the controller should be able to work independently of any other device as long it has power.
    My config is kind of simple Arduino Mega with W5500 Ethernet module configured as MQTT GW
    And the problem is that when network or HA/MQTT broker is unavailable when Arduino is restarted/booting it tries to reconnect to MQTT broker constantly and interupts the main loop everytime for around 3s which makes board basically unresponsive.
    00:45:07.094 -> 549536 !GWT:RMQ:FAIL
    00:45:07.094 -> Loop count = 179
    00:45:07.094 -> 549538 GWT:TPC:IP=192.168.11.111
    00:45:08.107 -> 550542 GWT:RMQ:CONNECTING...
    00:45:10.130 -> 552547 !GWT:RMQ:FAIL
    00:45:10.130 -> Loop count = 180
    00:45:10.130 -> 552550 GWT:TPC:IP=192.168.11.111
    Any ideas how I could disable reconnect function if that happens for example after 3 attempts? So the controller can work normally even if there is no connection to MQTT broker?
  • @linkinpio
    I don't have a solution, but I, too, may run into that problem. So I'm curious how it can be resolved.
    Perhaps post in the Hardware or Development sections. Fortunately, some really knowledgeable people (eg. @mfalkvidd and @NeverDie ) monitor pretty much all of the forum subjects.
    OSD
  • @linkinpio in the pubsubclient library, you can change the timeout on connecting to the mqtt broker. Default it is 15s, reducing it to e.g. 2s will increase the availability of the main loop.
    @OldSurferDude yes I have read it already. But unfortunately my impression is that my knowledge of how the code works is woefully insufficient.
  • @electrik thank you for your suggestion, but are you talking about MQTT_SOCKET_TIMEOUT ?
    If yes I did set this to 1s
    #define MQTT_SOCKET_TIMEOUT 1
    and did not change a thing
    21:32:05.081 -> Loop count = 153
    21:32:05.081 -> 471258 GWT:TPC:IP=192.168.11.111
    21:32:06.098 -> 472262 GWT:RMQ:CONNECTING...
    21:32:08.071 -> 474266 !GWT:RMQ:FAIL
    21:32:08.071 -> Loop count = 154
    If not please do let me know what you had in mind so I can check it out.
    @OldSurferDude thanks for confirming that I have not missed anything when doing a resarch on this matter, if there will be no new suggestions I think I might have to post it to Development as dont see anyone suggesting any good workaround or a solution.
  • No, you're right, it doesn't solve your issue. It does increase the availability of the main loop though.
  • @electrik
    Have you tested this in your enviroment/sketch?
    Did it increase availability for your sketch?
    If yes what was the single loop time before and after changing this?
    I did test is on my example and it does not increase the availability for the main loop for my sketch, also you can see the printout from the serial monitor, the loop is run in the same 3s intervals like before, so maybe I am doing something wrong?
  • Yes, that's what I meant. But the value seems to be 2 seconds in your log. Where have you placed the define?
    You can also use
    setSocketTimeout(1)
    On the pubsubclient object.
  • @electrik I've put the
    in the beginning where all other #defined constants are and it does not seeams to take this config.
    I tried to use
    setSocketTimeout(1)
    but I can't seems to get the sketch to work with <PubSubClient.h>
    I've added
    EthernetClient ethClient;
    PubSubClient client(ethClient);
    client.setSocketTimeout(1);
    but getting following error.
    GatewayW5x00MQTTClient.ino:172:1: error: 'client' does not name a type
    exit status 1
    Compilation error: 'client' does not name a type
    any ideas?
  • @linkinpio said in 💬 Building a MQTT Gateway:
    That is the right syntax, but you have to move the line in setup()
  • @electrik
    tried it but also no luck
    C:\Users\p.\Documents\Arduino\GatewayW5x00MQTTClient\GatewayW5x00MQTTClient.ino: In function 'void setup()':
    C:\Users\p.\Documents\Arduino\GatewayW5x00MQTTClient\GatewayW5x00MQTTClient.ino:213:10: error: 'class PubSubClient' has no member named 'setSocketTimeout'
    exit status 1
    Compilation error: 'class PubSubClient' has no member named 'setSocketTimeout'```
  • This looks like you're not using the latest (development) version of the mysensors library. That has the latest pubsubclient library included.
    Looking at the intervals between the errors again, I'm doubtful if it will make a big difference though. The mysensors library will need to be modified to fulfill your request I guess
  • I think I'm ussing the latest one
    but as you said I don't think it will fix my issue though.
    But looking at the examples I found that they have a connect function which then can be used to reconnect whenever needed not constantly like it happens now,
    But not sure how I could integrate that functionality in this sketch though, as I'm not that experienced with programming 😕
    To you think it will be possible?
     Reconnecting MQTT example - non-blocking
     This sketch demonstrates how to keep the client connected
     using a non-blocking reconnect function. If the client loses
     its connection, it attempts to reconnect every 5 seconds
     without blocking the main loop.
    #include <PubSubClient.h>
    // Update these with values suitable for your hardware/network.
    byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
    IPAddress ip(172, 16, 0, 100);
    IPAddress server(172, 16, 0, 2);
    void callback(char* topic, byte* payload, unsigned int length) {
      // handle message arrived
    long lastReconnectAttempt = 0;
    boolean reconnect() {
      if (client.connect("arduinoClient")) {
        // Once connected, publish an announcement...
        client.publish("outTopic","hello world");
        // ... and resubscribe
        client.subscribe("inTopic");
      return client.connected();
      client.setServer(server, 1883);
      client.setCallback(callback);
      delay(1500);
      if (!client.connected()) {
        long now = millis();
        if (now - lastReconnectAttempt > 5000) {
          lastReconnectAttempt = now;
          // Attempt to reconnect
          if (reconnect()) {
        // Client connected
        client.loop();
  • 163
  • 347
  • 584
