Washing machine state sensor
  • Hi all, I've been lurking a while here and finally made my first Gateway and Sensors last weekend. I couldn't beleive how easy it was to create and setup 👍
    Because my washing machine is up in the attic in a sound insulated room, I can't hear it, so I've created a sensor to detect the washing machine state.
    Basically it works as follows:
    The washing machine has an LED with three states:
    • On - Washing machine is Running
    • Flashing - Washing machine has finished the cycle and is Idle
    • Off - Washing machine is Off
    I have a simple light sensor stuck over the LED on the washing machine and have the following code:
    #define ID 0
    enum WashingMachineState {
    	Off,
    	Running,
    	Idle
    // these constants won't change:
    const int sensorPin = 7;    // the pin that the Light Sensor is attached to
    const int interval = 200;
    const int threshold = 300;
    const int triggerOnOffCount = 80;
    const int triggerIdleCount = 10;
    // Variables will change:
    int FlashValue = 0;
    int flashCounter = 0;   // counter for the number of flashes
    int offCounter = 0;
    int onCounter = 0;
    int lightState = 0;         // current state of the light
    int lastlightState = 0;     // previous state of the light
    WashingMachineState machineState;
    WashingMachineState lastMachineState;
    MyMessage msg(ID, V_VAR1);
    	gw.begin();
    	gw.present(ID, S_CUSTOM);
    	// initialize the button pin as a input:
    	pinMode(sensorPin, INPUT);
    	// Set default state
    	machineState = Off;
    	lastMachineState = Off;
    	delay(interval);
    	readLightStatus();
    	if (machineState == Idle && machineState != lastMachineState) {
    		lastMachineState = machineState;
    		// send notification
    		gw.send(msg.set("Idle"));
    	if (machineState == Off && machineState != lastMachineState) {
    		gw.send(msg.set("Off"));
    	if (machineState == Running && machineState != lastMachineState) {
    		gw.send(msg.set("Running"));
    void readLightStatus() {
    	// read the Light sensor input pin:
    	FlashValue = analogRead(sensorPin);
    	if (FlashValue > threshold)
    		// light On
    		lightState = 1;
    		// light off
    		lightState = 0;
    	incrementCounters();
    	// save the current state as the last state,
    	lastlightState = lightState;
    void incrementCounters(){
    	if (lightState == 1)
    		// light On
    		onCounter += 1;
    		offCounter = 0;
                    if (onCounter > triggerOnOffCount) { onCounter = triggerOnOffCount; }
    		// light off
    		offCounter += 1;
    		onCounter = 0;
                    if (offCounter > triggerOnOffCount) { offCounter = triggerOnOffCount; }
    	// compare the lightState to its previous state
    	if (lightState != lastlightState && lightState == 1) {
    		// if the state has changed to On, increment the flash counter
    		flashCounter++;
                    if (flashCounter > triggerIdleCount) { flashCounter = triggerIdleCount; }
    	// 10 Flashes counted, machine is now idle
    	if (flashCounter >= triggerIdleCount && machineState != Idle) {
    		machineState = Idle;
    		offCounter = 0;
    		onCounter = 0;
    	if (onCounter >= triggerOnOffCount && machineState != Running)
    		machineState = Running;
    		offCounter = 0;
    		flashCounter = 0;
    	if (offCounter >= triggerOnOffCount && machineState != Off)
    		machineState = Off;
    		onCounter = 0;
    		flashCounter = 0;
    		offCounter = triggerOnOffCount; // don't let the number increment any further
    	//Serial.println("flashCounter: " + String(flashCounter));
    	//Serial.println("onCounter:    " + String(onCounter));
    	//Serial.println("offCounter:   " + String(offCounter));
    It actually works great, but I've very little experience with Arduino programming (and even less with MySensors) and I'm sure that the code could be much better. Any pointers or tips would be very welcome.
    It's an omen! I was just thinking about it (not in general, this very minute) then i refreshed the browser and your post came in. I was thinking to try and listen for the annoying beeps its making when it finished. what controller are you using? what sensor type in the controller?
    I am no expert myself but would say to use gw.sleep instead of delay, although in your case it makes little difference because its wall powered sensor.
    also would make one
    if (machineState != lastMachineState) {
             gw.send(msg.set(state_array[machineState]));
    just to make it prettier (you should define state_array accordingly)
    all and all its a really neat code.
  • Thanks for the feedback and code improvement Moshe.
    I'm using a Nano with a simple photocell resistor. I'll post some pictures this evening if you like, it's still a bit ugly though 🙂
    The controller I'm using is HomeGenie.
    @mvdarend I wonder if domoticz has the S_CUSTOM sensor. will check.
    @ServiceXp looking for non intrusive. I have encountered problems last night with detecting the beeps as the cheap sound detector modules are, surprise surprise, not very good. I have ordered some better ones. Another option would be to monitor current (heaps of examples so it should be easy)
    @Moshe-Livne I tried a bunch of "wattage watching solutions" and non of them worked very well, but that was also using Vera as my controller (now using HomeSeer). We use 4 different cycles which may have caused some of those problems we encountered also.
    @ServiceXp I was thinking of having the logic in the arduino. should be simple, no? current drawn - in cycle. no current for 5 min - cycle ended. what am i missing?
    @Moshe-Livne With a current sensor you might even be able to profile each cycle.
    eg: current ~5amps for 3mins = rinse
    current ~8amps for 8mins = wash
    current ~10amps for spin
    No, not really necessary, but A+++ for cool factor!
    @gregl Oh super useful! predictive finishing! can calculate when the cycle will finish and by triangulating my position and using google maps calculate how long it will take me to arrive and let me know i am late for taking out the washing!
    Or it can do a prep talk to the dryer, getting it all worked out for the upcoming laundry 🙂
    I think it depends on your washers efficiency and the cycles you use. My washer is one of those HE machines that using adaptive cycle routines with-in the select load type. Creates a wattage watching nightmare. Couple that with Vera's instability, I just gave up and took a more direct approach.
    @ServiceXp
    I like this project, but since my washer and dryer have LEDs which indicate that cycle is complete too, I was thinking to optically sense that cycle was complete if I cannot get to the electronics easily (and maybe even void my warrantee). I'm going to try to find a very small sensor, perhaps.
    My real issue is how to get my wife excited about increasing our laundry efficiency 😉
    Tried the washer thing a year back...
    But it quickly got down-voted by my wife after some innocent "bugs" in the watt-algorithm. I was forced to stop the Sonos speakers to announce "Tvätten är klar" ( <-- Swedish) several times during the wash cycle.
    Hope to build enough confident to give it another try. But I suspect we got one of these eco-washers...
    I bought one this year and my wife is really happy with it 😉
  • Maybe a vibration sensor do the trick 😉
    like this one or similar: http://www.dfrobot.com/index.php?route=product/product&product_id=79#.VYM0i6O0N8E
    @BulldogLowell @ServiceXp Bosch in their infinite wisdom made the LED integral part of the start/stop button, putting a bit of a damper on optically sensing it. So far the 2 sound sensors I have are so bad that unless you do something really drastic like nuclear explosion they are very stoic about environmental beeps. they are ok for sensing knocks. now, I am not trying to sense Watt or try to profile the current use, as this is hopeless (my washing machine is also too smart for her own good). I am just going to watch for current draw above the "zero" over 5 min period. I think it would be safe enough but will not know until I get the sensors.....
    @kalle - got the vibration sensor in the mail yesterday! great minds, etc. but it is more complicated as while doing hot wash there are lengthy waits for the water to heat up.
    my plan is to use one of these powerboard things (http://www.mitre10.co.nz/shop/electrical_hardware/cords_powerboards/hpm_surge_protector_powerboard_6_way_106033/) and block the last two and use the space for the arduino and sensor to measure current on the last socket. I have excellent RCDs installed 🙂
    @hek - I use discreet notification using google hangouts....
  • @kalle, I actually tried the vibration sensor (based on this design) but I could only get it to perform properly by pressing a button to tell the Arduino that the cycle had started, which made it useless for when I wanted the machine to delay the start.
    I tried checking for vibrations as a trigger for 'Machine start' but it would trigger when loading the machine, and again when unloading... basically that was useless.
    @Moshe-Livne, I wanted to try sensing electricity usage, but when profiling the machine I found that when 'off' it was still consuming almost 5 watts, which is not a major problem if you define that as a threshold, but our machine sometimes just sits there doing nothing as far as I can see during the cycle. I was worried it would be a bit of a 'hit and miss' affair as @hek experienced.
    @ServiceXp, I looked at your solution also when browsing the forums and almost went that way. But I didn;t want to open my machine, I know that my wife would not be happy about that. And with three small kids I can't afford to take my time about it, we need the machine every day 🙂
  • @mvdarend hey I just stumbled across this post. I would like to draw your attention to something called as Power signature analysis.
    There are some automation systems using it, such as neurio.io
    I am still intrigued by it. Any electrical engineers here?
    @mvdarend you are a ray of sunshine, aren't you? I think power profiling is the way to go. although the washing machine will sit around doing nothing for a while (especially during pre-wash) I think it is still safe to say that there will be spikes of usage when heating, spinning, etc
    I am not too fussy about catching the machine the minute it finished so even 30 min with nothing over the threshold will be fine for me. I tend to leave the washing for DAYS in the machine 😞
    I now have 3 different vibration sensors. They do work for an extent but as you said - the number of false positives is a pain.
    @Prateek-Gupta I think that is a bit of over solving a washing machine problem 🙂
  • @Moshe-Livne Yes, I agree. But then this could be applied to a numerous electrical appliances across your home. Almost, all the devices have a unique power signature down to different operating modes.
  • Created a custom widget in HomeGenie and set it up to send PushBullet notifications. After running for a week I've noticed a few small problems.
    • If I leave the door open and the sun shines on the sensor, it's status changes to 'Running'. Increasing the threshold doesn't help so I'll need to protect the sensor from outside elements better. *
    • The LED on the machine also flashes just before it goes into running mode. I think I'll go with an extra status depending on the previous one (Off -> Flashing = 'stand by', Running -> flashing = 'Idle') or something like that.
    • My 3D printer is ordered and on its way, so I'll be able to create a custom holder. You guys are killing my finances 🙂
    @mvdarend While waiting for the current sensor (and also discovering that new powerboards have one way screws! evil people!), I have re-checked my vibration sensors. i am using this one http://www.aliexpress.com/item/1pc-lot-SW-420-Normally-Closed-Alarm-Vibration-Sensor-Module-Vibration-Switch-30512/32259757483.html which is better than the others i think.
    currently I am just monitoring 5 minute periods and if there is a vibration during this time I mark it as "active". my theory (that I can't check as I ran out of laundry) is that 3 periods of vibrations signal that a cycle is in progress. a period of quite means the cycle has finished. will post final results the minute the kids will produce enough dirty cloths.
  • @Moshe-Livne How is it working so far, have you been able to test it?
    @mvdarend so far so good. have added a bit of logic to my sketch and need another load to test it 🙂
    this is the current sketch:
    // Washing machine finished sketch
    #define CHILD_ID 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define SAMPLING_PERIOD 600000
    int oldValue=-1;
    unsigned long period_start = millis();
    int state = -1;
      gw.begin();
     // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      gw.present(CHILD_ID, S_DOOR);
    void report_state(int state)
    	  	Serial.print("reporting state: ");
    		Serial.println(state);
    	    gw.send(msg.set(state));
    int prev_state = -1;
    int prev_state_length = 0;
      // Get the update value
      int value = digitalRead(BUTTON_PIN);
      if (value == 1) {// 0 means vibration detected
      	state = 1;
      	Serial.println("setting state to 1");
      Serial.println(millis()-period_start);
      if (millis() - period_start > SAMPLING_PERIOD) {
        if (state != prev_state) {
      		if (state == 1 && prev_state_length > 2) { //a vibration period after long period of quit means a cycle started
      	    	report_state(state);
    	    	prev_state_length = 1;
      		} else if (state == 0 && prev_state_length > 2){ //a long quite period after a cycle means cycle finished
    	prev_state = state;
        state = 0;
      delay(100);
    will refine it once i verify it works through all the different cycles - this is not even a tested version, just to give you an idea about how it works. looks promising so far.
    found some flaws in the logic - updated and checking - do not use the code above
    @Moshe-Livne
    I think you can make this easier...
    It looks like you are looking for two motion events in the past two minutes to indicate washer is on?
    something like this (untested)
    #define CHILD_ID 3
    #define SAMPLING_PERIOD 600000UL
    unsigned long motionTime;
    unsigned long lastMotionTime = millis();
    boolean lastSensorState = false;
    boolean lastWasherState = false;
      gw.begin();
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      boolean sensorState = digitalRead(BUTTON_PIN);// Get the updated sensor value
      if (sensorState != lastSensorState && lastSensorState == true) //detect state change from true to false
        lastMotionTime = motionTime; //cascade time back
        motionTime = millis();
      lastSensorState = sensorState;
      boolean washerState = (motionTime - lastMotionTime < SAMPLING_PERIOD && motionTime - millis() < SAMPLING_PERIOD);
      if (washerState != lastWasherState)
        gw.send(msg.set(washerState));
      lastWasherState = washerState;
    @BulldogLowell It is slightly more complicated (but not much). the machine can idle for 5-10 min (well, not really idle, but idle enough so no vibrations will be felt). so, the current logic marks 5 minute periods. a vibration period marks the beginning of the cycle and 2 or 3 (yet to be determined) periods of quite marks end of cycle.
    @Moshe-Livne
    so if no vibration is sensed in the past five (configurable) minutes machine is OFF, otherwise machine is ON?
    likewise you want to indicate Washing when two vibrations are sensed in less than two or three (configurable) minutes?
    yes?
    @BulldogLowell re-reading your code, it would work well. the reason I made the "periods" was more to help me debug the scenario as I didn't want to sift through zillions of on/off.
    yeah, that is why it is important to just print() when there are state changes... added configuration and debug:
    #define CHILD_ID 3
    #define ONE_MINUTE 600000UL
      gw.begin();
      boolean washerState = ((motionTime - lastMotionTime < ONE_MINUTE * 2) && (motionTime - millis() < ONE_MINUTE * 5));
        Serial.print(F("Washer is "));
        Serial.println(washerState? F("ON") : F("OFF"));
      lastWasherState = sensorState;
    @BulldogLowell Alas, no. The sensors are on the edge of their capability, so you get some on, lots of off. an ON means a cycle started (I am not too worried about false positives from loading the machine for now. A quite period (no ON what so ever) of about 10 min means the cycle has finished. so basically its going to be eventually a very simple code like:
    if (sensorState == ON)
        cycleState=WASHING
    else period check and if long enough then cycleState = ENDED
    I am still checking through different cycles and the kids do not produce enough dirty cloths, just to annoy me i think. Anyone has cloths he needs to wash?
  • I bought one this year and i am really happy with it.
  • 90
  • 29
18
