Irrigation Controller (up to 16 valves with Shift Registers)
    @petewill
    I think waiting for the I2C piggyback will be worth the time, but you can debug with the Serial connection, I have all that in there.
    I would think that retrieving the latest times for the sprinklers could be brought back to once a day even, if you are that worried about traffic.
    Just curious, but how many valves will you end up controlling?
    PS my factory is in the north, and I won't be getting to the south this trip. Shenzhen is really the epicenter of hobby electronics plus, it is never a good thing to bring a lot of small electronic components, wires and sensors in your bags through airport security!
    Yeah, I'm thinking I can still get it partially working this weekend (hopefully) but I wish I could see the LCD. That is such a cool feature!
    I still need to think through the PLEG but I was hoping to do something like this...
    • If there has been rain in the past 5 days adjust the irrigation timing based on the amount.
    • Also, factor in the past high temperatures as well as the upcoming forecast.
    • If it is currently raining, stop the irrigation.
    I still need to think through it a little more but calculations like that would require the variables to be updated to the irrigation controller more than once a day (at least I think). That's why I was thinking it would be cool if it pulled the values before it ran each zone. It could still update every 5 hours or so though for the heartbeat. I really like that benefit!
    Currently only 5 but I will probably add 2 more in the next year or so.
    Haha, very true!
    @BulldogLowell is there a reason you're using pin 2 for the button/interrupt? That is normally wired up with the radio (although not currently used I believe). Is there a reason I shouldn't switch it to pin 3?
    Never mind. I forgot that interrupt numbers aren't pin numbers. I changed it to a 1 for pin 3 on my pro mini. What Arduino are you using?
    I cannot recall, but think I probably used a nano.
    @BulldogLowell I'm getting an error when I try to compile the code (I am finally getting to the point of uploading it). There are a long string of errors but they seem to be related to this:
        IrrigationController.ino:122:34: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
        In file included from IrrigationController.ino:59:0:
        C:\Users\petewill\Documents\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:53:4: error:   initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)' [-fpermissive]
        LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
    Here is the Arduino code:
    LiquidCrystal_I2C lcd(0x27, 16, 2);  // set the LCD I2C address to 0x27 (16 characters and 2 line display)
    I downloaded the 1.2.1 library from here: https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
    Is there something else I should be doing?
    Pete
    @petewill
    9:15am here in china!
    can you post what you are trying to compile? it looks like a library issue (as you figured out) but I want to make suer I can compile exactly what you have.
    @BulldogLowell 9am nice! I'm ready for bed 🙂
    Here is the code I'm trying to compile. I think it's pretty much what you have except a couple small additions like Child ID, Sketch Name etc.
    MySprinkler for MySensors
    Arduino Multi-Zone Sprinkler Control
    November, 2014
    *** Version 2.0
    *** Features 'raindrop' and 'clock' icons which indicate sensor is updating valve times and clock respectively
    your arduino will call to Vera once a minute and update accordingly.
    * Pushbutton activation to RUN_ALL_ZONES
    * LED status indicator
    INSTRUCTIONS:
    * Verify that each new device has a Variable1 and Variable2. Populate data accordingly with whole minutes for
    the RUN_ALL_ZONES routine and the RUN_SINGLE_ZONE routines.  The values entered may be zero.
    on the serial monitor.
    * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
    Contributed by Jim (BulldogLowell@gmail.com) and is released to the public domain
    #include <Time.h>
    #define NUMBER_OF_VALVES 5  // Change this to set your valve count up to 16.
    #define RADIO_ID AUTO // AUTO  // Change this to fix your Radio ID or use Auto
    //*Added sketch name and version
    #define SKETCH_VERSION "2.0"
    //*Added Child ID definition
    #define CHILD_ID_SPRINKLER 0
    #define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #define ALL_VALVES_OFF 0xFFFF
    #define ALL_VALVES_OFF 0U
    #ifdef DEBUG_ON
    typedef enum {
     STAND_BY_ALL_OFF, RUN_SINGLE_ZONE, RUN_ALL_ZONES, CYCLE_COMPLETE}
    SprinklerStates;
    SprinklerStates lastState;
    int allZoneTime [NUMBER_OF_VALVES + 1];
    int valveSoloTime [NUMBER_OF_VALVES + 1];
    int valveNumber;
    int lastValve;
    unsigned long startMillis;
    const int ledPin = 5;
    boolean buttonPushed = false;
    boolean showTime = true;
    boolean clockUpdating = false;
    boolean recentUpdate = true;
    const char *dayOfWeek[] = {
     "Null","Sunday ","Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "};
    time_t lastTimeRun = 0;
    //Setup Shift Register...
    const int latchPin = 8;
    const int clockPin = 4;
    const int dataPin  = 7;
    uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
    uint8_t raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
    MyMessage msg1valve(CHILD_ID_SPRINKLER,V_LIGHT);
    MyMessage var1valve(CHILD_ID_SPRINKLER,V_VAR1);
    MyMessage var2valve(CHILD_ID_SPRINKLER,V_VAR2);
     //*Not needed
     //Serial.begin(115200);
     delay(5000);
     lcd.init();
     lcd.clear();
     lcd.backlight();
     lcd.createChar(0, clock);
     lcd.createChar(1, raindrop);
     pinMode(latchPin, OUTPUT);
     pinMode(clockPin, OUTPUT);
     pinMode(dataPin, OUTPUT);
     pinMode(ledPin, OUTPUT);
     //*Changed for Pin 3 on the pro mini
     attachInterrupt(1, PushButton, CHANGE);
     digitalWrite (ledPin, HIGH);
     if (gw.loadState(0) == 0xFF); // EEPROM flag
        for (int i = 0; i < 4 ; i++)
         lastTimeRun = lastTimeRun | gw.loadState(i+1); // assemble 4 bytes into an ussigned long epoch timestamp
     gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
        gw.present(i, S_LIGHT);
     updateRelays(ALL_VALVES_OFF);
     digitalWrite (ledPin, LOW);
     DEBUG_PRINTLN(F("Ready..."));
     lcd.setCursor(0, 0);
     lcd.setCursor(15, 0);
     lcd.write(0);  //lcd.print(0, BYTE);
     lcd.setCursor(0, 1);
     int clockCounter = 0;
     while(timeStatus() == timeNotSet && clockCounter < 21)
        gw.requestTime(receiveTime);
        delay(1000);
        lcd.print(".");
        DEBUG_PRINT(F("."));
        clockCounter++;
        if (clockCounter > 16)
         lcd.clear();
         lcd.setCursor(0,1);
         delay(2000);
     lcd.clear();
     updateClock();
     updateDisplay();
     goGetValveTimes();
     if (buttonPushed)
        if (state != RUN_ALL_ZONES);
         state = RUN_ALL_ZONES;
         valveNumber = 1;
         gw.send(msg1valve.setSensor(0).set(true), false);
         startMillis = millis();
         for (byte i = 0; i < 5; i++)  // flash lcd backlight on button press
            lcd.noBacklight();
            delay(25);
            lcd.backlight();
         delay(50);
         fastClear();
         lcd.setCursor(0,0);
         lcd.print(F("*AllZone Active*"));
         lcd.setCursor(0,0);
         lcd.print(F(" Cycling  Zones "));
         delay(1000);
         DEBUG_PRINT(F("State = "));
         DEBUG_PRINTLN(state);
        slowToggleLED ();
        if (state != lastState)
            delay(50);
            gw.send(msg1valve.setSensor(i).set(false), false);
         lastValve = -1;
        if (lastValve != valveNumber)
             gw.send(msg1valve.setSensor(i).set(true), false);
        lastValve = valveNumber;
        fastToggleLed();
         valveNumber = 1;
         valveNumber++;
            state = CYCLE_COMPLETE;
            lastValve = -1;
            lastTimeRun = now();
        fastToggleLed();
         DEBUG_PRINT(F("Zone: "));
         DEBUG_PRINTLN(valveNumber);
         fastToggleLed();
     lastState = state;
    void updateRelays(int value)
     digitalWrite(latchPin, LOW);
     digitalWrite(latchPin, HIGH);
        buttonPushed = true;
    void fastToggleLed()
        fastLedTimer = millis ();
    void slowToggleLED ()
        slowLedTimer = millis ();
     boolean zoneTimeUpdate = false;
     if (message.isAck())
     for (byte i = 0; i<= NUMBER_OF_VALVES; i++)
        if (message.sensor == i)
         if (message.type == V_LIGHT)
            if (switchState == 0)
             if (i == 0)
                valveNumber = 1;
                state = RUN_SINGLE_ZONE;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" = "));
            DEBUG_PRINTLN(variable1);
             allZoneTime[i] = variable1;
             zoneTimeUpdate = true;
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(variable2);
             valveSoloTime[i] = variable2;
     if (zoneTimeUpdate)
         if (i != 0)
            DEBUG_PRINT(F("Zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINTLN(allZoneTime[i]);
        recentUpdate = false;
    void updateDisplay()
     static boolean displayToggle = false;
        switch (state){
        case STAND_BY_ALL_OFF:
         fastClear();
         lcd.setCursor(0,0);
         if (displayToggle)
            if (clockUpdating)
             lcd.setCursor(15,0);
             lcd.write(0);
            lcd.setCursor(0,1);
            lcd.print(hourFormat12());
            lcd.print(minute());
            lcd.print(F(" "));
            lcd.print(month() < 10? F("0") : F(""));
            lcd.print(month());
            lcd.print(day() < 10? F("/0") : F("/"));
            lcd.print(day());
            lcd.print(F("/"));
            lcd.print(year()%100);
            if (clockUpdating)
             lcd.write(0);
            lcd.setCursor(0,1);
            lcd.setCursor(11,1);
            lcd.print(day(lastTimeRun));
        case RUN_SINGLE_ZONE:
         fastClear();
         lcd.setCursor(0,0);
         if (displayToggle)
            lcd.setCursor(0,1);
            lcd.print(F(" Zone:"));
            lcd.print(valveNumber);
            lcd.print(F(" Active"));
            lcd.setCursor(0,1);
            lcd.print("min");
            lcd.print("sec  ");
        case RUN_ALL_ZONES:
         fastClear();
         lcd.setCursor(0,0);
         if (displayToggle)
            lcd.setCursor(0,1);
            lcd.print(F(" Active "));
            lcd.setCursor(0,1);
            lcd.print("min");
            lcd.print("sec  ");
        case CYCLE_COMPLETE:
         if (displayToggle)
            lcd.setCursor(0,0);
            lcd.setCursor(0,1);
            int totalTimeRan = 0;
            lcd.setCursor(0,0);
            lcd.setCursor(0,1);
            lcd.print(totalTimeRan);
            lcd.print(" Minutes   ");
        lastUpdateTime = millis();
     lastDisplayState = state;
     int lastSecond = second();
     int lastMinute = minute();
     int lastHour = hour();
     setTime(newTime);
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute());
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
        showTime = false;
    void fastClear()
     lcd.setCursor(0,0);
     lcd.setCursor(0,1);
    void updateClock()
     if (millis() - lastVeraGetTime >= 60000UL) // updates clock time and gets zone times from vera once every 10 minutes
        lcd.write(0);
        clockUpdating = true;
        lastVeraGetTime = millis();
     if (gw.loadState(0) != 0xFF)
        gw.saveState(0,0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
     for (int i = 1; i < 5; i++)
        gw.saveState(5-i, byte(theDate >> 8 * (i-1)));// store epoch datestamp in 4 bytes of EEPROM starting in location one
    void goGetValveTimes()
     static byte valveIndex = 1;
     if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
        DEBUG_PRINTLN(F("Calling for Valve Times..."));
        lcd.write(1);
        gw.request(valveIndex, V_VAR1);
        gw.request(valveIndex, V_VAR2);
        valveUpdateTime = millis();
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES+1)
         valveIndex = 1;
    @petewill
    meanwhile I tried to compile my old code with the latest Arduino IDE and get the same errors...
    It may take me some time, but meanwhile you can try Arduino board for I2C library for LCDs.
    sorry!
    @petewill said:
    Good to know. I have around 80 MySensors devices so I'm always thinking about keeping communication to a minimum. I may just run it as is and if I notice any issues I can look into adjusting the code.
    Holy cow, ~80 MySensor devices.. I'm surprised Vera handles all that traffic reliably... My Vera3 can't seem to handle my ~35 Z-Wave and ~ 15 MySensors devices reliably...
    I'm in the starting process of moving everything over to HomeSeer. I'm really hoping this solution works better.. The little I've done so far, I'm VERY impressed. I will not miss PLEG (It's a great plug-in but difficult to build and maintain for me), as the built in event system in HS3 Pro is amazing and I've only just scratch the surface...
    Depends on your definition of reliably 🙂 I'd say 98% of the time there are no issues but the other 2% can be annoying... I am continually amazed by how well MySensors works. I just keep adding devices and it keeps performing. Henrik and team are awesome!
    Vera can definitely be frustrating. The key for me is to limit the plugins. I am very careful what I install. I'm sure I'll have to switch from Vera one day (unless they start making more powerful hardware) but for now it works and it's cheap. What are you going to do with MySensors when you switch? I love MySensors too much!!
    Jim,
    I did some searching and modified the code a little. It will now compile but I haven't had time to figure out what the purpose of lcd.write(0) was for. I have to go to work so I won't be able to look into it until later. Here are the items of code I changed to get it to compile:
    //LiquidCrystal_I2C lcd(0x27, 16, 2);  // set the LCD I2C address to 0x27
    LiquidCrystal_I2C lcd(0x27);  // set the LCD I2C address to 0x27
     //*Added
    //*Removed
    // lcd.init();
    //*Removed 3 instances of:
    // lcd.write(0);
    Interestingly lcd.write(1); will compile. I also don't have an LCD to test with so I don't know if it will work.
    @petewill There is a MySensors plug-in for HS3, At the moment it is a bit limited, and has some bugs but the developer is working on it.
    @ServiceXp Good to know. I'll keep that in mind. Thanks for passing that on!
    @petewill
    lcd.write(0)
    Prints the '0' special character.
    There is a raindrop icon, which tells you times are downloading and a clock icon which designates clock updates.
    convert the hex to binary you can see the shape (5 X 7 pixels, so disregard the first three bits):
    00000000
    00001110
    00010101
    00010111
    00010001
    00001110
    00000000
    can you see the clock face at 3:00?
    00000100
    00000100
    00001010
    00001010
    00010001
    00010001
    00001110
    00000000
    Can you see the raindrop?
    they are created here:
    if you look at the video above, they appear from time to time.
    cool right?
    Ok, good to know. I'll see if I can do a little searching on that. Maybe there is a different way to implement them now?? It will be hard to test without an LCD but hopefully it will come soon and I can post back 🙂
    Speaking of testing I was able to control my relays last night from Vera! SO COOL!! This is one of the devices I have been wanting to add for a long time. I can't wait to be able to turn on my valves from my phone when I'm turning on my sprinkler system. It sure will beat sprinting to/from the basement...
    Thanks again for the awesome work!
    @petewill
    I edited above to give more detail...
    Ok, thanks. I did a little research and found this from the Arduino website:
    When referencing custom character "0", if it is not in a variable, you need to cast it as a byte, otherwise the compiler throws an error. See the example below.
    http://www.arduino.cc/en/Reference/LiquidCrystalCreateChar
    I changed the code to this:
    byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0};
    and this
    lcd.write(byte(0));
    and now it's compiling. But, I don't know if it's working.
    I'm still working on a couple of other small things I found. I'll post the code when I get it to a point where it's ready for your review.
    @BulldogLowell
    Here is the code with some changes. I have also attached a document with the changes highlighted. The most notable thing is I added some code to update the valve times when the device is first powered on. I hope that's ok.
    One thing I can't figure out, but hopefully you can, is the button is always acting like it's "pressed" when the Arduino is first powered on. This could be a problem as the power seems to go off in my house a couple of times a year (I don't want my irrigation to run when it's not supposed to). Any idea how to fix it? I've tried everything I could think of (which isn't much) and nothing worked.
    Anyway, here is the PDF with the changes Irrigation Controller Changes.pdf
    And the code:
    November, 2014
    *** Version 2.0
    INSTRUCTIONS:
    #include <Time.h>
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    int valveNumber;
    int lastValve;
    const int waterButtonPin = 3;
    byte clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // fetching time indicator
    byte raindrop[8] = {0x4,0x4,0xA,0xA,0x11,0xE,0x0,}; // fetching Valve Data indicator
      delay(5000);
     //*Added
    //*Removed
    // lcd.init();
     lcd.clear();
     lcd.backlight();
     attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
     lcd.write(byte(0));  //lcd.print(0, BYTE);
        delay(1000);
        lcd.print(".");
        //DEBUG_PRINT(F("."));
        clockCounter++;
         lcd.clear();
         lcd.setCursor(0,1);
         delay(2000);
     lcd.clear();
     //Update valve times when first powered on
     for(byte i = 0; i <= NUMBER_OF_VALVES; i++)
       allZoneTime[i]=-1;
       valveSoloTime[i]=-1;
       while((valveSoloTime[i]==-1 || allZoneTime[i]==-1) && clockCounter < 10)
         lcd.write(byte(1)); //lcd.write(1);
         gw.request(i, V_VAR1);
         gw.request(i, V_VAR2);
         delay(1000);
         clockCounter++;
         if (clockCounter > 10)
            DEBUG_PRINTLN(F("Failed initial valve synchronization!"));
            lcd.clear();
            lcd.print(F("  Failed Valve  "));
            lcd.setCursor(0,1);
     updateClock();
     updateDisplay();
     goGetValveTimes();
     if (buttonPushed)
         valveNumber = 1;
            lcd.noBacklight();
            delay(25);
            lcd.backlight();
         delay(50);
         fastClear();
         lcd.setCursor(0,0);
         lcd.setCursor(0,0);
         delay(1000);
          //valveNumber = 1;
          gw.send(msg1valve.setSensor(0).set(false), false);
            lcd.noBacklight();
            delay(25);
            lcd.backlight();
          delay(50);
          fastClear();
          lcd.setCursor(0,0);
          lcd.print(F("*AllZone Off*"));
          lcd.setCursor(0,0);
          lcd.print(F(" Stopping  Zones "));
          delay(1000);
        slowToggleLED ();
            delay(50);
         lastValve = -1;
        fastToggleLed();
         valveNumber = 1;
         valveNumber++;
            lastValve = -1;
        fastToggleLed();
         fastToggleLed();
     lastState = state;
             if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
     if (zoneTimeUpdate)
         if (i != 0)
            DEBUG_PRINT(i);
        switch (state){
         fastClear();
         lcd.setCursor(0,0);
         if (displayToggle)
            if (clockUpdating)
             lcd.write(byte(0));
            lcd.setCursor(0,1);
            lcd.print(F(" "));
            lcd.print(month());
            lcd.print(day());
            lcd.print(F("/"));
            if (clockUpdating)
             lcd.write(byte(0));
            lcd.setCursor(0,1);
         fastClear();
         lcd.setCursor(0,0);
         if (displayToggle)
            lcd.setCursor(0,1);
            lcd.setCursor(0,1);
            lcd.print("min");
            lcd.print("sec  ");
        case RUN_ALL_ZONES:
         fastClear();
         lcd.setCursor(0,0);
         if (displayToggle)
            lcd.setCursor(0,1);
            lcd.setCursor(0,1);
            lcd.print("min");
            lcd.print("sec  ");
         if (displayToggle)
            lcd.setCursor(0,0);
            lcd.setCursor(0,1);
            lcd.setCursor(0,0);
            lcd.setCursor(0,1);
     setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
     lcd.setCursor(0,0);
     lcd.setCursor(0,1);
    void updateClock()
        lcd.write(byte(0));
        valveIndex++;
         valveIndex = 1;
    You could try a bigger pullup resistor, maybe the pin floats for a brief moment or it is somehow energized... I've read about others having a problem like that. Alternatively, reverse the logic and pull pull the pin down to ground. I'd expect that one or both can correct that issue.
    Glad to have the improvements in the code, that's great! Always better to have another set of eyes on a project.
    Ok, I'll do some testing with that. I don't think I'll get the chance today but I should be able to do some tomorrow. It works perfectly after the first start up so hopefully a bigger resistor will help.
    @petewill
    yeah, I see in the code that the pushbutton is using interrupt pin, but still needs to be set to input
    pinMode(PushButton, INPUT_PULLUP);
    start there, sorry!
    I thought I added it already with this:
    Is that correct? Maybe that's my problem...
    were you not getting a compile error? on the PushButton variable being undeclared?
    Ok, I still think I have some things to learn about interrupts. I thought PushButton was the method being called when the interrupt was triggered. I didn't think it was the pin. I thought the pin was the first item 1 in this case. But, I thought 1 isn't even the pin. It's the interrupt number which is pin 3 in the case of a Pro Mini. I also thought I needed to declare the pinMode even if it's already in the interrupt. So confusing... Am I totally off?
    @petewill
    post deleted, my bad! your understanding is 100% correct!
    your PushButton is the ISR, so you are right
    Try the extra pullup or pull-down
    really sorry for confusing you! I'm mega jet lagged
    I'm mega jet lagged
    Totally understandable 🙂
    Ok, I'll try the other options discussed above and post back. Thanks.
    Well, I had almost no time to work on MySensors stuff this weekend. 😞 I did do a quick test last night and it seems the external pullup worked! I power cycled the node 3 times and each time it worked flawlessly. I'll continue to test but so far so good. Thank you!
    @petewill
    glad to hear that worked!
    @BulldogLowell Thanks for posting this. A sprinkler controller to replace my Rainbird controller is next on my list of projects.
    For those looking for a good and relatively cheap soil moisture sensor, these ones are pretty good and use a capacitive sensor: http://www.ebay.com/itm/261675851824. They transmit on 433 MHz. I currently use them with RFXCom and HomeSeer, but for those that don't have RFXCom, the protocol should be relatively easy to reverse engineer and then use directly with MySensors and a 433MHz receiver. I've also bought a few from here: https://www.plantcaretools.com/en/webshop/wireless-moisture-sensor-en-detail. Both sellers were good to deal with. The only drawback to them is that the antenna (and therefore range) is not very good, but there is an easy mod to improve that: http://www.domoticz.com/forum/viewtopic.php?f=13&t=2712
    Al
    Cool @hek!
    Well done @petewill So easy for folks to follow along your outstanding video!
    MySensors Community Rocks!
    Agreed!!! Thanks to both @BulldogLowell and @hek for making this possible. I love seeing it hanging on my wall every time I go into the basement 🙂
    Great Work Guys!!
  • @Sparkman I like the sensors, I just built some and was dbating the way to make smaller, what kind of battery life do those moisture sensors have?
    @petewill Time to change my current 16 valve arduino sprinklers to a little smarter version like yours! I love this community.
    You have been coming on with some awesome videos and contributions!
    @DrJeff I agree this is a great community! So much fun!
    Thanks for the kind words! All credit for this project goes to @BulldogLowell though. I just made the video 🙂
  • @BulldogLowell Sorry For not giving the credit where it is due! Major Props @BulldogLowell !
    They've been running for about 9 months on the first set of batteries (2xAAA) so far and are still going strong.
    Al
    Thanks @DrJeff
    I just made an irrigation controller... @petewill made it for everyone!
    just for inspiration, here's another irrigation controller video (no, it's not mine.. but one of my friends that made it)
    Arduino controlled garden watering system – 01:04
    — Nikolaj Rahbek
  • Wow 48 channels thats awesome
    @tbowmo WOW! What did he use that for??
  • @tbowmo Time for a Shower, Can you say body sprays! 🙂
    @petewill
    He recently planted a lot of trees, so instead of walking around and watering each one manually he made this
    Its a arduino with a nrf24 module, but not using the mysensors library (yet...)
    @tbowmo said:
    @petewill
    I guess so 🙂
    Cool!
    @treb0r
    here is a stab at modification for no shift register... not much changes.
    Not tested but it compiles...
    Let me know if you see anything in testing.
    June 30, 2015
    *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
    PARTS LIST:
    * Relays (8 channel)
    * NRF24L01 Radio
    * Arduino (I used a Pro Mini)
    * Capacitors (10uf and .1uf)
    * 3.3v voltage regulator
    * Resistors (270 & 10K)
    * Female Dupont Cables
    * LED
    * Push button
    * Shift Register (SN74HC595)
    * 18 gauge wire (for relay)
    INSTRUCTIONS:
    #include <Time.h>
    #include <LiquidCrystal.h>
    #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
    #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
    #define SKETCH_VERSION "2.0nsr"
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    const int relayPin[NUMBER_OF_VALVES] = {5,6,7,8};//<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
    byte menuState = 0;
    unsigned long menuTimer;
    byte countDownTime = 10;
    int valveNumber;
    int lastValve;
    const int ledPin = 4;//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< CHANGED THIS TOO
    String valveNickName[17] = {
    /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
      SERIAL_START(115200);
      /*  <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BLOCK
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      delay(500);
          lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
      lcd.write(byte(0));
        delay(1000);
        lcd.print(".");
        clockCounter++;
          lcd.clear();
          delay(2000);
      lcd.clear();
        pinMode(relayPin[i], OUTPUT);//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< ADDED PINMODE HERE
        lcd.print(F(" Updating  "));
        lcd.print(i);
        boolean flashIcon = false;
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F(" Data..."));
        while (gw.process() == false)
          flashIcon = !flashIcon;
          delay(100);
          delay(100);
          gw.request(i, V_VAR3);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
        menuTimer = millis();
          state = ZONE_SELECT_MENU;
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
      else if (state = ZONE_SELECT_MENU)
        displayMenu();
      lastState = state;
    void displayMenu(void)
      static int lastSecond;
        lcd.clear();
        lcd.print(F("Starting"));
        lcd.print(F("."));
        Serial.print(".");
      lastSecond = thisSecond;
        if (menuState == 0)
          valveNumber = 1;
          valveNumber = menuState;
      lastMenuState = menuState;
      /*<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  COMMENTED OUT THIS BLOCK BELOW
      //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<   ADDED THIS BLOCK BELOW
      for (byte i = 0; i < NUMBER_OF_VALVES; i++)
        digitalWrite(relayPin[i], bitRead(value, i));
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
            if (newMessage.length() == 0)
              DEBUG_PRINTLN(i);
            if (newMessage.length() > 16)
              newMessage.substring(0, 16);
            valveNickName[i] = "";
            DEBUG_PRINT(F("Recieved new name for zone "));
            DEBUG_PRINT(i);
            DEBUG_PRINT(F(" and it is now called: "));
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year() % 100);
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.setCursor(11, 1);
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
      setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
        gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
        DEBUG_PRINTLN(F("Calling for Valve Data..."));
        gw.request(valveIndex, V_VAR3);
        valveIndex++;
        if (valveIndex > NUMBER_OF_VALVES + 1)
          valveIndex = 1;
  • thank you for this modification. I will test it today. Shall it be working withou any problems with Domoticz on Raspberry Pi?
    I assume so. It is using S_LIGHT, one of the most used device types. I am unsure however if Domoticz supports V_VAR1 & V_VAR2 for that device type, so you may have to check with other forum members who use Domoticz.
    Do you think I I could use that kind of design in parallel of a static watering controller, so I could have the basic program with the controller, and manage extras with the arduino/mysensors ?
    Inspired by @BulldogLowell's controller, I've been working on a MySensors irrigation controller that works in parallel with my RainBird Controller. I'm using a double set of relays (one 5VDC set that's controlled by the Arduino and a 24VAC set that's controlled by the 5VDC relays and the RainBird). This way I can also sense in my HA system when the valves have been opened by the RainBird controller. I have the base functionality finished and working on some additional bells and whistles. Will post some details in a separate thread later today.
    Al
  • Regarding the Video presenting this irrigation project: is the 15 min time, which is counting down after starting the valve via pressing the button, programed somewhere in the arduino code? Or it is taken from timer set in the Vera (or Domoticz) controller?
    Well, it is not working. Domoticz finds 5 switches, but on LCD there is Message: Failed Clock Synchronisation, and the Updating Valves but still 0 😕 Is the problems with V_VAR1 & V_VAR2 variables?
    On my Vera controller (as demonstrated by @petewill ) you would edit the times under Variable1 and Variable2, which corresponds to V_VAR1 and V_VAR2 in the program.
    The video shows how to modify the values in the arduino by changing the values. I am not sure if Domoticz supports such dataflow. Does Domoticz support V_VAR1 and V_VAR2?
    does Domoticz support MySensors time function? That I do not know.
  • @BulldogLowell
    I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
    @treb0r This thread seems to imply that V_VAR1 etc are supported. I guess @AWI can say more about that.
    thanks for your help, @Moshe-Livne
    Do you know if Domoticz supports returning Unix timestamp using requestTime()?
    @BulldogLowell Sorry, I don't know.
    thanks @Moshe-Livne
    @treb0r said:
    @BulldogLowell
    @treb0r,
    If you can find out if V_VAR1 & V_VAR2 can work you can try that. Otherwise we can hard code the watering times by zone into the programming.
    If requestTime() isn't supported, we can attach a Real Time Clock (RTC) device to gain back the clock functionality.
    You can then use the Domoticz devices to start the ALL_ZONE sequence or individual zones...
    Let me know what you would like to do and I can modify the program for you.
  • @BulldogLowell
    requestTime() seems not be supported. A have rtc ds3231 or ds1307. They can use the same commands and libraries. If you would change the code that would perfect 🙂 As you proposed you would also include in the code the timers for zones, instead of requesting them from Domoticz. As I understand these timers are only for manuals starts (via button) right?
    @treb0r said:
    @BulldogLowell
    Well, those times will be used when you activate the device using the Domoticz on/off controls (or activate using 'scene' in Domotocz.
    Give me a day or so and I will try to code for you.
    @treb0r
    Would you like to try this, untested.
    Just to see if the RTC is working...
    June 30, 2015
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <DS1307RTC.h>
    #include <Time.h>
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    const int relayPin[NUMBER_OF_VALVES] = {5, 6, 7, 8}; //<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
    byte menuState = 0;
    int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 1, 1, 1, 1}; //minutes
    int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 2, 2, 2, 2};
    int valveNumber;
    int lastValve;
    const char *verboseDayOfWeek[] = {
      /*"Null",*/ "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      // RTC setup
      setSyncProvider(RTC.get);   // the function to get the time from the RTC
      if(timeStatus()!= timeSet)
         Serial.println("Unable to sync with the RTC");
         Serial.println("RTC has set the system time");
      delay(500);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
      lcd.clear();
      updateDisplay();
      goGetValveTimes();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(verboseDayOfWeek[weekday(lastTimeRun)]);
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
    void fastClear()
        valveIndex++;
          valveIndex = 1;
  • @BulldogLowell
    HI
    Thanks for the post. On LCD there is no info about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
    So I cant check if the RTC is working
    treb0r
    @treb0r
    did you get your RTC connected and tested?
  • @BulldogLowell
    Yes, RTC is connected and tested with different sketches (just to check if RTC work correctly). Works ok.
    With your correctes projects, as above mentioned: On LCD there is no info neither about Time Synchronisation, nor about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
    treb0r
    Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
    You should post serial output or show a video.
    Did you find out if Domoticz supports V_VAR1?
  • @BulldogLowell
    OK, I will post the video. If I will manage I will also post serial output
    treb0r
    @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
       if (message.type==V_VAR1) {
       	 Serial.println("got var1 answer");
    However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
    @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
    @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
    @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
    @epierre can you please link to the post?
    @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
    ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
  • Hello
    And thx for a nice forum, I did build the irrigation controller and tried to connect it to Domoticz. Everything just seems fine, LCD works, push button works and I can turn on the irrigation from Domoticz and it shows in the LCD.
    But the problem is that it doesn't switch the relays on, it just says "no valve time" and then go watering cycle complete.
    Any suggestions on what the problem might be...... Domoticz?
    Regards
    @moffen666
    I don't have Domoticz but I suspect that the callback isn't functioning.
    try populating the array with the desired times for each sequence. replace this:
    with something like this:
    int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
    int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
    This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
  • Thx Bulldog
    I will check asap and get back with the result.
    Regards
  • Hi
    I tried the code but it didn't compile, and I'm not good enough to be sure whats wrong.
    I did try change the code and I did get it to compile, but I don't know if I got it right. You can see the lame attempt below the colored line.
    upload-956d60c8-6d6d-44b7-abdb-015f701c65dc
    @moffen666
    Clearly you understand that you are to put the times for each of the valve zones, led by a zero into the array, and not copy my verbatim instructions...
    How many valves do you have? You need that many (plus one) integer numbers separated by commas...
    Example 8 valves:
    ...= {0,5,5,5,5,5,5,5,5};
    You've commented out the wrong lines.
  • Thx for the quick answer
    I use 4 valves atm, I tried your suggestion but it seems it wont work for me.
    upload-edb305b1-3dc3-4afd-ae02-e2e779452d18
    Regards
  • The inserted values in the array works from start, but it looks like the irrigation controller immediately starts to request valve data from the controller for variable1 and 2. As we cant set variable1 and 2 in Domoticz I guess it returns 0 and overwrite the inserted values in the arrays...or is it anything else happening?
    Initialising...
    send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    sensor started, id=7, parent=0, distance=1
    send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:MySprinkler
    send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=6,sg=0,st=ok:2.0nsr
    send: 7-7-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    send: 7-7-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    Ready...
    Calling for Valve 0 Data...
    send: 7-7-0-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=0,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:0 = 0
    send: 7-7-0-0 s=0,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=0,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:0 = 0
    send: 7-7-0-0 s=0,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=0,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 0
    Calling for Valve 1 Data...
    send: 7-7-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=1,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:1 = 0
    Zone 1 individual time: 1 group time: 0
    Zone 2 individual time: 1 group time: 1
    Zone 3 individual time: 1 group time: 1
    Zone 4 individual time: 1 group time: 1
    send: 7-7-0-0 s=1,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=1,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:1 = 0
    Zone 1 individual time: 0 group time: 0
    send: 7-7-0-0 s=1,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=1,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 1
    Calling for Valve 2 Data...
    send: 7-7-0-0 s=2,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=2,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:2 = 0
    Zone 2 individual time: 1 group time: 0
    send: 7-7-0-0 s=2,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=2,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:2 = 0
    Zone 2 individual time: 0 group time: 0
    send: 7-7-0-0 s=2,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=2,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 2
    Calling for Valve 3 Data...
    send: 7-7-0-0 s=3,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=3,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:3 = 0
    Zone 3 individual time: 1 group time: 0
    send: 7-7-0-0 s=3,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=3,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:3 = 0
    Zone 3 individual time: 0 group time: 0
    send: 7-7-0-0 s=3,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=3,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 3
    Calling for Valve 4 Data...
    send: 7-7-0-0 s=4,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=4,c=2,t=24,pt=0,l=0,sg=0:
    Recieved variable1 valve:4 = 0
    Zone 4 individual time: 1 group time: 0
    send: 7-7-0-0 s=4,c=2,t=25,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=4,c=2,t=25,pt=0,l=0,sg=0:
    Recieved variable2 valve:4 = 0
    Zone 4 individual time: 0 group time: 0
    send: 7-7-0-0 s=4,c=2,t=26,pt=0,l=0,sg=0,st=ok:
    read: 0-0-7 s=4,c=2,t=26,pt=0,l=0,sg=0:
    No Name Recieved for zone 4
    @moffen666
    try commenting out this in setup():
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
    and this in loop():
    //goGetValveTimes();
    That will disable those callbacks and you should be OK with a HardCoded time table for the valves and valve names.
  • Thx Bulldog for all the help, everything seems to be working as it should now.
    Keep up the good work 👍
    Updated code for Domoticz.
    May 31, 2015
    *** Version 2.0
    PARTS LIST:
    * NRF24L01 Radio
    * LED
    * Push button
    INSTRUCTIONS:
    #include <Time.h>
    #define SKETCH_NAME "MySprinkler Domoticz"
    //#define ACTIVE_LOW // comment out this line if your relays are active high
    #ifdef ACTIVE_LOW
    #ifdef DEBUG_ON
    typedef enum {
    SprinklerStates;
    byte menuState = 0;
    int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
    int valveNumber;
    int lastValve;
      //delay(5000);
      lcd.clear();
      lcd.backlight();
      delay(500);
      lcd.write(byte(0));
        delay(1000);
        lcd.print(".");
        clockCounter++;
          lcd.clear();
          delay(2000);
      lcd.clear();
        lcd.print(i);
        DEBUG_PRINT(i);
          delay(100);
          delay(100);
          delay(100);
      lcd.clear();
      updateClock();
      updateDisplay();
      if (buttonPushed)
          menuState = 0;
          menuState++;
            menuState = 0;
        slowToggleLED ();
            delay(50);
          lcd.clear();
          lcd.setCursor(0,0);
          lcd.setCursor(0,1);
          delay(2000);
          lastValve = -1;
        fastToggleLed();
          valveNumber = 1;
          valveNumber++;
            lastValve = -1;
        fastToggleLed();
          fastToggleLed();
        displayMenu();
      lastState = state;
        lcd.clear();
        lcd.print(F("."));
        Serial.print(".");
        if (menuState == 0)
          valveNumber = 1;
              if (i == 0)
                valveNumber = 1;
                valveNumber = i;
                DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
            DEBUG_PRINT(i);
              DEBUG_PRINTLN(i);
            DEBUG_PRINT(i);
      if (zoneTimeUpdate)
          if (i != 0)
            DEBUG_PRINT(i);
        switch (state) {
            fastClear();
            if (displayToggle)
              if (clockUpdating)
                lcd.write(byte(0));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              if (clockUpdating)
                lcd.write(byte(0));
            fastClear();
            if (displayToggle)
                lcd.print("min");
                lcd.print("sec  ");
          case RUN_ALL_ZONES:
            fastClear();
            if (displayToggle)
              lcd.print("min");
              lcd.print("sec  ");
            if (displayToggle)
      setTime(newTime);
        DEBUG_PRINT(day());
        showTime = false;
    void fastClear()
    void updateClock()
        lcd.write(byte(0));
        valveIndex++;
          valveIndex = 1;
    Hey Everyone,
    I just made a follow up video to this irrigation controller that shows my logic I'm using to save water. It's pretty specific to my environment but hopefully you can use some of the ideas to save water in your environment. I have attached the logic I used in my PLEG device.
    Pete
    PLEG Irrigation.pdf
    Automation to Adjust Irrigation Watering Time Based on Weather – 25:17
    — Pete B
    looking at the project, I'm wondering why you propose 3.3V only, is this for the shift register and the screen ? Why not stay in 5V ?
    @epierre Where did you see that I don't remember? Perhaps for the NRF radio?
    @petewill it is here: http://www.mysensors.org/build/irrigation
    it is hard to know the BOM from the page, so I was wondering why you would neeed the powering adaptation if you input 5V
    @epierre
    If you watch the video, you can see he's using the voltage regulator to supply power to the radio.
    Are you getting ready to build?
    @epierre
    I've ordered the 8 switch, I have soil moisture, leaf moisture, ground humidity, rain gauge and found some evapotranspiration algorithm so I have all inputs and now need to have outputs in parallel of my rainbird scheduler (too dumb...)
    So I'm ready to build as you say 😉
  • @hek said:
    Added your project to the main site togeter with @petewill excellent new video.
    https://youtu.be/l4GPRTsuHkI
    Excellent project.
    Can you help me with the android code, to send instrucctions from my cell phone to Arduino? like on-off light , bomb, etc.
    thanks for your time!
    best regards.
  • Excellent work. I need help with android code. Anybody can help me with this?
    thanks
    I made the circuit, but later i realize it required vera controller to sync all the data. Is there other way or idea to send data to the built system.
    @shemmozhipandian Sorry for the delayed reply. It does require a controller (like Vera) but there are free ones out there. Take a look here: http://www.mysensors.org/controller/
    I know Domoticz is free and seems to be fairly popular here. There are others as well. If you find one you like you may want to write a quick post to check compatibility. I personally use Vera so I'm not sure how the others work.
  • Hello Pete, thanks for your hard work on this. Superb!
    I want to build a irrigation controller like your project but can't figure out hows the wiring. On the wiki an image is shown but I can't see what the connections are in this "virtual proto board"
    Is there something clearer or like a pinout to pin list?
    I'm using an Arduino Nano, so things will be something different.
    Thank you very much.
    @Sergio Jim (@BulldogLowell) posted some more details above but here is my fritzing project as well. Hopefully you can zoom in where you need to see more.
    Fritzing Irrigation Controller Wiring.fzz
  • Mmm... I finally assembled the device. But I'm having problems with it. It doesn't activate/deactivates the relays. I'm getting the power for the relay board from the nano itself. Could that be the problem?
    Also, my domoticz doesn't receive the off signal from the controller. (doens't turn the light off) and sometimes throws some error telling that can't contact the node.
    BTW I tried to contac Bulldogloweel without success 😭
    Yes, that is most likely the problem. Most of the relays I have used need more power than what the arduino can supply. Try feeding it more power (like from a phone charger).
    Check the serial monitor with debug enabled. Does this happen every time? It could be radio issues. Do you have a 4.7uf cap on the radio? Is it close enough to your gateway?
  • @BulldogLowell
    I need to add a relay for a master valve. This will open when any zone valves open. I think it could be mapped to All On 0(1) but I am not sure how to accomplish this. I don't know the code for that or electrical connection. I also noticed we are about maxed out of data (99%) using ProMini. Any ideas?
    If you are worried about Program Space you can turn off Serial debug to rid yourself of a bunch of overhead in the sketch. I am not using String class so there is PLENTY of RAM and I've been using this for a while with no stack corruption issues:
    #define DEBUG_ON   // comment out to surpress serial monitor output
    if you propose to turn ON the master valve when each valve is cycled on, then I believe all you need to do is add that valve to the bitmask (logical OR) each time you updateRelays().
      if(value)
        value |= 0b0000000010000000;  // master is the eighth relay, there are 7 controlled in this example (active HIGH in this example)
    not tested
  • @BulldogLowell
    By commenting out the DEBUG, it went from 99% to 63% used memory.
    The modification to void updateRelays worked very nicely. I only wish the master control valve would remain ON during cycling through each valve (subjected to VALVE_RESET_TIME) as I am using it to control a chemical feed pump to prevent hydrogen proxide (30%) from entering my irrigation system.
    Awesome job and I am very pleased with your design.
    The only problem I had when building the controller was getting the LCD to communicate.
    I added this comment to my program under Instructions.
  • @BulldogLowell
    I ended up going a different approach. I modified the program so I could use Arduino digital pin6 as an output powering my master valve relay. I then added digitalWrite (masterValvePin, HIGH) where you have updateRelays(BITSHIFT_VALVE_NUMBER) to turn ON the valve. To turn off the valve I added a delay then digitalWrite (masterValvePin, LOW) to if (state == STAND_BY_ALL_OFF). This has tested perfectly for my situation.
    The only thing missing from the Controller is the ability to add the RainBird rain sensor to the board. I think the way of achieving this is an input to my Vera controller.
  • 90
