[contest] My 12 input high precision pulse counter (kWh/ W)
    For my meter cupboard I have installed simple digital meters with S0 output.. With the help of some creative public domain resources I managed to make a power metering system with accurate momentary power consumption and usage monitoring (here with Domoticz as controller).
    the project consists of two arduino's linked through serial. The first one is the high speed 12 input measuring device attached to the S0 meters (6 operational in my case). I have slightly changed the design of this Open Energy Project to spit out JSON records. Into a second Arduino which is responsible for connecting to the MySensors network/ converting units and addressing a local (I2C) 2x16 display of the meter readings. Below the prototype.. (the real thing is in production and hidden in the cupboard ;), except the display )
    upload-28fe7a85-c8ce-40fb-8499-f4f5943d0a03
    A few more pictures: Domoticz graphing for one of the meters. (good thing I can compensate with Solar) upload-7dab3b7d-0a78-430e-85b4-4f0a91782bfb
    Pulse meter used (€ 22 a piece). Take care, not a real hobby article to connect...
    @AWI Are those KWH DIN meters from Ebay or did you buy them locally? I was thinking of doing something similar a while back but was put off by the cost and inability to install them myself (not understanding much of mains installation and phases). Would be great to single out the heating system at least so I can have two groups. Not easy to make any serious graphs when the pump is pulling ~3kW once or twice an hour.
    @bjornhallberg I bought them locally but these things are available everywhere. Not difficult to install when you have a single phase mains. You can also put them in a separate box (piicture from the public domain.....). .
    upload-812b9f87-de2f-4358-8183-81502d355064
    After that you can play with a reliable "once per Wh" pulse..
    The pulse counter and codeupload-3fa9c75e-f258-4a59-a958-efdf1cb678a9
    The pulse counter produces a simple JSON string per S0 meter every 10 secondsupload-ba9d50ce-e940-43c4-96ab-3afb2445720a . The string shows the meter number. Number of counts (Wh ) since last send. Average period (duty cycle in ms) between pulses to calculate the current power (3,600,000,000/ period) and a pulse accumulation since the start of the counter. You can use this to keep things in sync when the serial connection or processing is not always stable.
    https://codebender.cc/sketch:86789
    for the sake of Codebender I have combined all in one file.
    The pulse counter can be attached to any serial port (using a UNO, Nano or FTDI) and used for all kinds applications and counting purposes. I will focus on MySensors...
    The main unit in production. I used a Nano or UNO for easy debugging/ programming and 5v USB charger. The rest is deep down in the closet in a 1 Euro housing (no need for fancy 3d printing). The display is fitted in bamboo left overs from IKEA boxes.
    upload-4db471b2-d055-4eae-a4e0-7802b7ac49a4
    (it displays time/ pressure from a left over BMP180 now)
    Another one with a 4x20 display, with room for some extra information
    upload-e644fd4a-812f-4a16-bdf6-021f0ba8848f
    And the code.
    https://codebender.cc/sketch:87047
    Parts list & build instruction (excluding radio...)
    upload-972620e1-b3fd-40e2-8052-83bb2a51898b
    upload-e450e360-24e1-429c-935d-e68495c2c312
    upload-7d9c8fb5-d554-48b2-b74a-4ec82c3751e2
    upload-1bdc2866-91b9-42e0-9c37-025b6256f1a7
    Price (estimate):
    2 x arduino (ali): Euro 5
    1 x I2C LCD (ali): ,, 4
    1 x rotary encoder ,, 2
    2 x 100nf ,, 0.4
    16 x screw terminals ,, 1.6
    wires ,, 1
    breadboard/ pcb ,, 2
    Total Euro 16
    The S0 meters will cost your more: Euro 12-30 / pcs, including (backlight) display, excluding installation.
    (eg. SDM120.pdf there are also types available which give you a MODBUS RS-485 interface and kWh, V, A, PF, F, kWh-r for around Euro 50/pcs)
  • This is great , exactly what i was looking for.
    I do have a few questions, is it possible to double the amount of inputs ?
    I "need" 24 or 25 inputs since i got so many meters like on the picture.
    Or is it possible to build 2 of these devices and that domoticz detect it ?
    Also, can you maybe tell me if it is possible to keep a log from all the sensors apart from each other ?
    So you can check what meter 1 has used for the amount of days/weeks/years ?
    Or it it all combined to 1 number ?
    @Vince Glad you like it. It is possible to extend the number of inputs but I would suggest to add another arduino for that purpose. The whole thing is timing critical. Especially in relation to "counting" the actual power. Every counter is logged separate and sent to the gateway controller.
  • Thanks Awi for the reply, i just noticed it and actually forgot to look.
    This is great news , i will start collecting some parts i need and a few Arduinos to make it hopefully work.
    Will report how it goes !
  • Great project, ive made this project, i had to declare the chars this was not done in your script? i had to declare:
    lcd.createChar(1, degCelcius);
    lcd.createChar(2, hecto);
    lcd.createChar(3, Pascal);
    lcd.createChar(4, Lux);
    lcd.createChar(5, visible);
    lcd.createChar(6, infrared);
    lcd.createChar(7, rel_humidity);
    i declared them for eg:
    uint8_t degCelcius[8] = {0x18,0x18,0x3,0x4,0x4,0x4,0x3};
    i had to change the display adress to 0x3F and tested this with a script to verify and this works, display SCL is connected to pin A5 and SDA is connected to A4.
    ive compiled it without errors and uploaded the sketsh to the arduino nano, when connecting the slave arduino (pro mini) board the Rx led will blink every 10seconds when the json data is received.
    but the display stays like this:
    http://forum.arduino.cc/index.php?action=dlattach;topic=157817.0;attach=40625
    on the top row only blocks are visible, any idea why?
    @RCF It was a long time ago.... can't remember the details. It could be that the display library does not work for your LCD. If I can find a minute I will review the sketch.
  • I have the same display as in your post > see the first display on this page: http://arduino-info.wikispaces.com/LCD-Blue-I2C#v1
    there is also a test script which works fine on adress 0x3F, but i did already change that adres in your script but the display shows blocks on the first line. the library is the same i believe.
    it would be grat if you could help :).
    by the way if i connect a RF module will the data sended be compatible with http://openenergymonitor.org/emon/guide the Emonbase unit?
  • Could you explain how to connect the sensors 2 pins?
    On http://openenergymonitor.org/emon/buildingblocks/12-input-pulse-counting they connect it like in the picture?
    Is it by this also like that?? Because i can't see the pull down resistors on yours..
    You noticed it right. I used the internal pull-up of the Arduino. Gnd is directly connected and input with the internal pull-up to vcc.
  • So i don't need the extra pulldown resistor and could connect everything like drawn down below?
    With the differance that i'm using a arduino mini wich runs on 3.3V and doesn't have a 5V point...
    @MarkV sounds good. I am reworking the master sketch a little to cope with the new libraries and MySensors 1.5
    Updated the master sketch... you need the load the latest libraries mentioned in the heading..(RotaryEncoder & arduinoJson). Adapt your settings to your display if needed (I2C address, etc.).
    The sketch depends on a "read/ get" from the controller for the last (or user filled) kWh values. Many controllers are lacking this functionality (i.e. Domoticz). I have a version without this (useful ) syncing capability under construction. This will allow local changes in the history by means of the rotary encoder.
     * MySensors interface to AWI 12 input usage/ power Meter               *
     *  meter generates Power/ Usage/ Cumm. usage for 12 independent chann. *
     * 16x2 (I2C) Display shows consumption                                 *
    // Licence: GNU GPL
    // Author: AWI 2015
    // Updates: AWI 20150815, new RotaryEncoder & ArduinoJson libraries
    // continuously:
    // 1. read JSON strings from Pulse12Counter slave , format {"m":meter,"c":count,"r":rate, "cA":countAccum}
    // 2. calculate real time Power from "rate"
    // 3. store values
    // 4. send to controller
    // Get consistency with controller - controller should only be updated when initial values have been received:
    // 1. read Wh values from controller (local last values should be in sync with controller)
    // 2. compare with stored readings. Action accordingly:
    //    - if controller Wh > stored last reading: new startup from counter, send new Wh increment and adjust readings.
    //    - if controller Wh < stored last reading: something went wrong with last update, send updated values from counter
    // Other:
    // 1. display on local LCD, time & energy values, usage can be shown as Daily & Total
    // 2. rotary encoder to browse the different displays
    // Caution: pulse meter is connected to std serial (pin D0), Serial.print can still be used
    //    Disconnect pulse meter when programming via FTDI! (sync error)
    #include <MySensor.h>                 // MySensors network
    #include <LiquidCrystal_I2C.h>        // display I2C
    #include <Time.h>
    #include <RotaryEncoder.h>          // RotaryEncoder to browse displays https://github.com/mathertel/RotaryEncoder
    #include <ArduinoJson.h>           // used to parse the simple JSON output of the pulse meter https://github.com/bblanchon/ArduinoJson
    // Constants
    #define NO_METERS  5                // number of meters used (max 12)
    #define NODE_ID    11             // fixed MySensors node ID
    #define ENCODER_PINA 3            // RotaryEncoder pins
    #define ENCODER_PINB 4
    // *** Global variables
    // stores LCD text
    //char lastLCD1[21] = "Line1 - first   ";
    //char lastLCD2[21] = "Line2 - second  ";
    class pulseMeter              // meter class, store all relevant data (equivalent to struct)
    public:
      unsigned long UsageWh;                  // last (current) usage (in W) from pulse counter
      unsigned long UsageAccumWh;               // usage accumulator (to keep in sync) from pulse counter
      unsigned long PowerW;                 // actual power, calculated from pulse "rate"
      unsigned long DayUsageWh;           // daily usage for display
      bool  Updated ;             // flag to check if update from controller is received
    pulseMeter pulseMeters[NO_METERS] ;     // define power meters
    RotaryEncoder encoder(ENCODER_PINA, ENCODER_PINB); //, 1, 1, 3000);    // instance of RotaryEncoder: (Pin1, Pin2, Multiplier(), Stepsize(), pause(ms)]
    // Json parser:  define parse object: <10> = number of tokens in JSON: ~10 per m (4 * [key, value] + key_total, value_total))
        char json[50]="{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";              // Storage for serial JSON string
    // flags & counters
    bool timeReceived = false;
    bool newDay = false;
    unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0, lastSyncKWH=0;  // loop timers for once in while events
    int display_no = 0;             // determines what is displayed on second line, first line = time display;
    int currentMeter = 0;           // actual meter for update & check, cycles through meters
    int lastRotary = 0;    // last rotary encoder position
    // *** Definition and initialisation
    // define the MySensor network
    MySensor gw;                    // pins used RFX24(default 9,10)
    // Initialize messages for sensor network
    MyMessage powerMsg(0,V_WATT);         // message to send power in W
    MyMessage usageMsg(0,V_KWH);        // message to send usage in kWH
    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
    // Temp Buffer to print readings on the LCD.
    char output_buffer[6];
    // OPTIONAL: Custom characters for display - Units (add W/ kWh?)
    byte degCelcius[8] = {
      B01000,
      B10100,
      B01000,
      B00111,
      B00100,
      B00100,
      B00111,
      B00000
    byte Pascal[8] = {
      B00000,
      B11100,
      B10100,
      B11100,
      B10010,
      B10111,
      B10101,
      B00000
    byte hecto[8] = {
      B00000,
      B00000,
      B00000,
      B00100,
      B00110,
      B00101,
      B00101,
      B00000
    byte Lux[8] = {
      B00000,
      B10000,
      B10101,
      B10010,
      B10010,
      B10101,
      B11100,
      B00000
    /*byte visible[8] = {
      B00000,
      B00000,
      B00001,
      B00000,
      B10101,
      B10101,
      B01001,
      B00000
    byte infrared[8] = {
      B00101,
      B00010,
      B10101,
      B00000,
      B10110,
      B10100,
      B10100,
      B00000,
    byte rel_humidity[8] = {
      B00101,
      B00010,
      B00101,
      B10000,
      B11000,
      B10100,
      B10100,
      B00000,
    void setup(void)
        //Serial in Sensor network = 115200
        gw.begin(incomingMessage, NODE_ID, false);  // this node is fixed, no repeat
        //Send the sensor node sketch version information to the gateway
        gw.sendSketchInfo("AWI-12ChannelPulse", "1.0");
        // Register all Pulse counters to gw (they will be created as child devices from 0 to MAX-1)
        for (int x = 0; x < NO_METERS; x++){
          gw.present(x, S_POWER);             // present power meters to gateway
        delay(100);                         // give it some time to process
        // Initializations
        Wire.begin();                 // I2C
        // Request latest time from controller at startup
        gw.requestTime(receiveTime);
          gw.request(x, V_KWH);             // for sync get current values from controller
          pulseMeters[x].Updated = false ;      // set meter status to not in sync
          gw.wait(100);                         // give it some time to process
        // ** LCD display **
        lcd.begin(16, 2);             // LCD 2 lines * 16 char.
        lcd.setBacklight(HIGH);
        // send custom characters to display
    //    lcd.createChar(5, visible);
    //    lcd.createChar(6, infrared);
        lcd.setCursor(0, 0);             // Reset cursor position
    void loop(void)
      unsigned long now = millis();       // Timer in loop for "once in a while" events
      gw.process() ;                      // process incoming messages
        // If no time has been received yet, request it every 10 second from controller
        // When time has been received, request update every hour
        if ((!timeReceived && now-lastRequest > 10*1000)
          || (timeReceived && now-lastRequest > 60*1000*60)) {
          // Request time from controller.
           Serial.println("requesting time");
           lastRequest = now;
      // Check if new day has started (hour == 0) and reset day usage counters of meters
      if (hour()==0 && !newDay){
        newDay = true;
          pulseMeters[x].DayUsageWh = 0 ;   // reset daily counters
        newDay = false;
      // check if RotaryEncoder action for display selection
      encoder.tick();
      int enc = encoder.getPosition();
      if( enc > lastRotary) {
        if (display_no++ >= NO_METERS-1 ) display_no = 0;
        lastRotary = enc ;
      else if (enc < lastRotary) {
        if (display_no-- <  0) display_no = NO_METERS - 1;
        lastRotary = enc ;
      // Update display every second (mainly for time display)
      if (now-lastUpdate > 1000) {
        LCD_local_display();
        lastUpdate = now;
      // If no "RotaryEncoder", Change display every 10 seconds
      //if (now-lastDisplay > 10000) {
      //  // change display
      //  display_no++;
      //  if (display_no >= NO_METERS){         // meter display for second line
      //    display_no = 0;
      //  lastDisplay = now ;
      // Every 10 seconds update one meter and check if controller is still in sync
      if (now-lastSyncKWH > 10000){
        // printPulsemeter(display_no);
        sendPowerUpdate(currentMeter);        // update the values for currentMeter
        if (currentMeter++ >= NO_METERS){     // increment and wrap current meter
          currentMeter = 0 ;
        // take care of synchronization
        gw.request(currentMeter, V_KWH);        // get current values from controller
        lastSyncKWH = now;
      // get readings from serial (sent every 10s)
      // format {"m":meter,"c":count,"r":rate, "cA":countAccum}
      // use JSON parser to process (could be replaced by simple split routine, but this works just fine)
      if(readLineJSON(Serial.read(), json, 80) > 0 ){   //dummySerial(), Serial.read()
      // if(readLineJSON(dummySerial(), json, 80) > 0 ){   //dummySerial(), Serial.read()
        Serial.println(json);
        storeMeterJSON(json);           //store the meter reading
        // Ok, set incoming time
        setTime(controllerTime); // this sets the clock to the time from controller - which we do want periodically
        timeReceived = true;
    // This is called when a kWh message is received
      // Expect few types of messages from controller, V_KWH for last value of kWh (for each meter)
      if (message.type==V_KWH) {
      // if message comes in, update the kWH reading for meter with value since last update
      Serial.print("Last reading for sensor: ");
      Serial.print(message.sensor);                 // kWh is float
      Serial.print(", Message: ");
      Serial.println(message.getFloat());
      unsigned long ControllerUsageWh = message.getFloat()*1000 ;   // update current values
      if (ControllerUsageWh > pulseMeters[message.sensor].UsageWh){   // if controller value > current: meter restarted
        pulseMeters[message.sensor].UsageWh = ControllerUsageWh ;   //  update with controller value
      } // else: do nothing meter value is higher and therefore more recent
      pulseMeters[message.sensor].Updated = true;   // set updated status flag. Only process meters if in sync (value received).
    void sendPowerUpdate(int currentMeter)
    // Sends update to controller for current meter
    // !! check needs to be implemented for Correct sync with controller...
      if  (pulseMeters[currentMeter].Updated){      // only send when there was a sync response from the controller
        gw.send(powerMsg.setSensor(currentMeter).set((int)pulseMeters[currentMeter].PowerW));
        gw.send(usageMsg.setSensor(currentMeter).set((float)pulseMeters[currentMeter].UsageWh/1000,3)); // send in kWh!
        printPulsemeter(currentMeter);
    void LCD_local_display(void)
    // prints variables on LCD display with units
        char buf[17]; // buffer for 16 char display
        // start with time on first line
        snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d", hour(), minute(), second(), day(), month());
        lcd.setCursor(0,0);               // LCD line 1
        lcd.print(buf);
      // print meter indicated by "display_no"
        snprintf(buf, sizeof buf, "m%2d %4dWh %4dW", display_no+1, (int)pulseMeters[display_no].DayUsageWh, (int)pulseMeters[display_no].PowerW );
      lcd.setCursor(0,1);               // LCD line 2
      lcd.print(buf);
    int storeMeterJSON(char *json)
    /* convert JSON to values and store in corresponding meter (if used)
     input: JSON string (can be wrong formatted), with length
     output: changed meter record number or -1 if error
     use JsonParser
      StaticJsonBuffer<50> jsonBuffer;
      // char njson[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}";
        JsonObject& root = jsonBuffer.parseObject(json);
      if (!root.success())
            Serial.println("JsonParser.parse() failed");
            return -1;
      int m = (long)root["m"];
      if (m > NO_METERS){                 // meter value out of range for used meters
        return -1 ;
      } else {                      // update meter values, Power is momentary, Usage is cumulative
        pulseMeters[m-1].UsageWh += (long)root["c"];    // pulsecount = Wh, accumulate
        pulseMeters[m-1].DayUsageWh += (long)root["c"];   // daily counter = Wh, accumulate
        pulseMeters[m-1].UsageAccumWh = (long)root["cA"]; // accumulated pulse count (only for sync and eventual error correction (serial))
        if ((long)root["r"] == 0){            // calculate power from pulse rate (ms) and truncate to whole Watts
          pulseMeters[m-1].PowerW = 0;
          pulseMeters[m-1].PowerW = int(3600000000 / (long)root["r"]); // rate in microseconds
        return m ;
    int readLineJSON(int readch, char *buffer, int len)
    /* checks for JSON and when started append char tot buffer and checks for line completion
    usage:
      static char buffer[80];
      if (readline(Serial.read(), buffer, 80) > 0) { // line complete}
      returns simple JSON
      static int pos = 0;
      int rpos;
      if (readch > 0) {
        switch (readch) {
          case '\n':                // Ignore new-lines
          case '\r':                // Return on CR
            rpos = pos;
            pos = 0;                  // Reset position index ready for next time
            return rpos;
          default:
            if (pos < len-1) {
              buffer[pos++] = readch;
              buffer[pos] = 0;
      // No end of line has been found, so return -1.
      return -1;
    int dummySerial()
    // Acts as a dummy JSON serial character generator for debugging
    // input: none
    // output: preset JSON string
      static int pos = 0;
      char json[] = "{\"m\":1,\"c\":12,\"r\":120000,\"cA\":12345}\r{\"m\":2,\"c\":212,\"r\":2120000,\"cA\":212345}\r{\"m\":3,\"c\":212,\"r\":2120000,\"cA\":212345}\n\r";
      if (pos++ >= strlen(json)){
        pos = 0;
      return json[pos] ;
    void printPulsemeter(int meter)
    // prints the Pulsemeter record to serial out
      Serial.print("m:");
      Serial.print(meter);
      Serial.print(", power: ");
      Serial.print(pulseMeters[meter].PowerW);
      Serial.print(", usage: ");
      Serial.print(pulseMeters[meter].UsageWh);
      Serial.print(", day usage: ");
      Serial.print(pulseMeters[meter].DayUsageWh );
      Serial.print(", Ca: ");
      Serial.println(pulseMeters[meter].UsageAccumWh);
  • Ive updated the libraries and uploaded it to my arduino nano, in the serial of my comport it says: radio init fail.
    is the radio module needed to get it working? and does it connect with the emonPI of emon base http://openenergymonitor.org/emon/guide ?
    now the display still shows blocks on the first line just like before, is this because the RF module is not present?
    @RCF The radio is needed to have the MySensors stuff working otherwise you will get the "radio init fail" message and block the execution of the code. This sketch is not meant for anything else than MySensors. If you want to connect it to emon or anything else it can serve as inspiration...
  • i just ordered one at ebay, where does your radio module communicated with? with a server ?
    i think it should also be possible to connect pin 9 and 10 to an ethernet module right? i would like to setup an emoncs server for openremote (openremote.org) on my Synology NAS
    @RCF Maybe you should start here -> http://www.mysensors.org/about
  • Yes i understand that this is for extra sensors http://www.mysensors.org/about/network but when i do not have any external sensors the radio module should be there anyway
  • I've uploaded both sketches without errors, but can't get any readings when i check the serial monitor? Also it doesn't say anything about the communication with the gateway.
    What's wrong? What should i check?
    @MarkV Hi Mark, good hear you are trying to get it working. You need two arduino's which one is not showing serial information? You first need to get the "measurement" arduino working. This one is supposed to spit out JSON strings. Second you try the "master".
  • I've connected everything, but it says:
    11-11-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=fail:1.5
    What does this mean?? What does the fail mean?
    Also the sensors don't show up in Domoticz.
    And now i'm getting al sort off strange signes:
    11-11-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    .W J‘õ11, parent=0, distance=1
    LLKLLKj‚šõ255,c=3,t=11,pt=0,l=18,sg=0,st=fail:AWI-12ChannelPulse
    LLKLLKj‚šõ255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
    LLKLLKj‚šõ0,c=0,t=13,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ1,c=0,t=13,pt=0,l=0,sg=0,st=fail:
    find parent
    LLKLLK¦SSIªªšõ255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    11-0-0 s=2,c=0,t=13,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ3,c=0,t=13,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ4,c=0,t=13,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ5,c=0,t=13,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ255,c=3,t=1,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ0,c=2,t=18,pt=0,l=0,sg=0,st=fail:
    find parent
    11-0-0 s=1,c=2,t=18,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ2,c=2,t=18,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ3,c=2,t=18,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ4,c=2,t=18,pt=0,l=0,sg=0,st=fail:
    LLKLLKj‚šõ5,c=2,t=18,pt=0,l=0,sg=0,st=fail:
    ¢¥µ•5
    find parent
    Y‹é 11-11-0-0 s=255,c=0,Y‹é 11-11-0-0 s=25óYk½É�started, id=11,equesting time
    ¢¥µ•5
    –‹é 11-11-0-0 s=25Í–‹é 11-11-255-255`¾ò–‹é 11-1Y‹é 11-ñequesting time
    @MarkV it sounds like the radio cannot make a connection to the gateway. In many cases this comes from the power supply of the radio. But it can also be distance to gateway etc. Do you have other sensors working?
  • Good evening,
    It took a while but i wanted to check everything and see what i can do about it by myself.
    And.... still no luck, except that i have a running ethernet GW, plus a DHT11 Humidity/temperature sensor up and running.
    My pulse counter is also running and i'm getting output on the usb, normal output haha.
    Also the gateway is able to see the counter.
    Domoticz sees the gateway, the only problem is, that it doesn't add the sensor to it.
    The strange part is that is does add the humidity/temperatuur arduino.
    I've pressed the "add new sensors for 5 minuts" button and still no luck.
    I've also installed MYScontroller and when i connect through tcp i get the following:
    Arduino Sketch serial monitor:
    What's wrong, what did i do wrong and what should i do to fix it??
    @MarkV Good morning 😉 the issue you are having is probably due to the fact that Domoticz sometimes creates sensors after actual data is received (i.s.o. when presenting). The original sketch won't start sending data until it receives something. (line 111 in code above). Also Domoticz is not able to to "send" data values, I had to tweak it myself...
    The whole dependency on the controller gave me a lot of headaches. Therefore I decided to rework the whole thing in an independent version. This one is running stable for a few weeks now with a "standard (beta)" version of Domoticz.
    The code and hardware is similar but requires some attention. i.e. you need different and the newest libraries. Just drop me a note if you need any assistance.
  • Thanks for the commet and i defently need some help.
    Sorry i didn't see your "new" post about the pulse counter.
    I'm uploading the sketches now.
    I only got one question, what should i uncomment in the sketches when i'm not using the display and counter?
    And when i got this working, is it possible to add to other sensors, a CNY70 (reflector sensor) to readout a water and gas meter? (but this is the next step 😉 )
    I also installed the beta version from domoticz.
    @MarkV Next to my reaction in the other post. I cannot be hard to add more (different) sensors to the sketch. As long as you do not attach LCD / rotary, you will only miss the information and interaction.
  • Merlin Gerin, Eaton, and Beger...quite the mix.
    I like the domoticz display....whats your overall opinion on it?
  • did anybody already upgraded the 12 Input pulse counter to 2.0? just asking :bowtie:
    @jeti If you are just asking. 😏 I have updated it to 2.0 beta
  • @AWI: 👍
    would you mind sharing the sketches? 😇
    @jeti Take a loot at git. The master sketch needs a little change (mysensors.h i.s.o. mysensor.h) The slave is not changed. I am a lttle disabled at the moment, so can't help you any furthe right now.
  • @AWI thanks alot, i will have a look 👍
    hopefully nothing serios... either way all the best 👍
  • Hi @AWI!
    The GIT link is broken. Can I find your sketch for this counter elsewhere?
    I would like to implement this counter as a "local sensor" on an ethernet gateway without radio. I guess this would require some tweaking but right now I'm confident. x)
    @NickBuilder soory but the transition to 2.0 gave me a little GIT headache and I broke some links.. I restored the pulse counter sketches. Be carefull with combining the sketch with ethernet functionality... Both eat a lot of RAM/ROM and are time critical.
    The sketch also stores a large amount of data in EEPROM. Be aware that the space there is more limited than the 256 bytes mentioned with saveState().
    Please share your progress
  • @AWI as did got get my modifcations 100% running I was pumped to see your latest update, but for reasons i do not understand i get an error while compiling:
    error: 'hour' was not declared in this scope
    same is the case for setTime, minute etc...
    i already tried some stuff with the time.h but it seems nothing has an impact, not even deleting the whole library (which should end in a "libraby not found" error, but only shows the errors described above)
    any idea what to look for?
    thanks
  • ok found the answer 😛
    the latest Time.h is only pointing to TimeLib.h so if I am calling TimeLib.h (instead of Time.h) directly it compiles
  • 90
  • 44
