Backlit Dimmable LED Mirror with Motion Sensor
    Hi Everyone,
    I have created backlit mirror based on Bruce Lacey's dimmable LED sketch. I have added a motion sensor and some on/off and fade up/down buttons. There is some logic in the code to save the dim level when the buttons are pressed. I have all my motion turn on/off logic in my Vera controller using PLEG. It could be easily adapted to control the on/off functionality in the Arduino code but I like to have my automation logic in one place (my Vera).
    This was a fun project to work on and although it looks pretty ugly from the back my wife loves the way it looks in our master bathroom. I tried to document as best I could but please let me know if you have any questions.
    Here is a list of the parts I used
    • Items from MySensors Store http://www.mysensors.org/store/
      • Female Pin Header Connector Strip
      • Prototype Universal Printed Circuit Boards (PCB)
      • NRF24L01 Radio
      • Arduino Pro Mini
      • FTDI USB to TTL Serial Adapter
      • Capacitors (10uf and .1uf)
      • 3.3v voltage regulator
      • 5v voltage regulator
      • IRLZ44N Logic Level Transistor MOSFET
      • 12v Transformer (power supply)
      • 5 Meter LED Strip (I used 3528)
      • HC-SR501 PIR Motion Sensor Module
    • 22-24 gauge wire or similar (I used Cat5/Cat6 cable)
    • 2 Pole 5mm Pitch PCB Mount Screw Terminal Block
    Here is a video explaining how to build it yourself.
    Arduino Backlit Dimmable LED Mirror with Motion Sensor using MySensors – 14:11
    — Pete B
    Here is the Fritzing (http://fritzing.org/) wiring diagram file if you want to view in more detail: Mirror LED Wiring Diagram.fzz
    https://codebender.cc/sketch:81486
  • @petewill
    Nice!
    I am curious about your power supply setup, do you mind sharing? e.g. Are you are running DC line through the attic (or crawlspace) and dropping within the walls? 12VDC? How many feeds, how long are your runs and what gauge wire are you using? I keep looking at my long dormant telephony wiring and wondering "what if...?"
    -Dwalt
    @Dwalt Thanks. Yep, I'm running DC through the walls/attic with 16 and 18 gauge wire (depending on amperage requirements). I think I have around 18 feeds of either 5v or 12v right now. I'm powering lights, blinds and MySensors devices. The longest length of wire is around 60 ft. I am lucky to have access to almost all my rooms via the basement or attic so for the most part it's relatively easy to pull lines.
    What gauge are your phone wires? Depending on gauge you could probably run some low draw sensors like motion, temp/humidity or door/window sensors.
  • @petewill under what version of mysensor library did you compile this sketch library 1.4 or 1.4.1? I compile you sketch under 1.4.1 and cannot get it to work
    Francois
    @Francois I'm still using 1.4.
    What compile error do you see? Did you use 1.4.1 on both GW and sensor?
    @petewill Somehow I missed this.. NICE JOB Pete!! I love it!!
    @petewill Also what kind of heat are you getting off that FET?
    @ServiceXp thanks! In my setup I'm not getting any noticeable heat on any of my LED projects. I have run it for hours at 100% and it's not even warm to the touch.
    this is one of those "I want one" projects, yes?
    a lot of cool ways to apply this.
  • @hek Yes I am using 1.4.1 on both the sensor. This the error I am getting on the sensor node: The sensor was working on a different node it also has cap on VCC and GRD.
    sensor started, id=25, parent=0, distance=2
    send: 25-25-0-0 s=255,c=0,t=17,pt=0,l=5,st=fail:1.4.1
    send: 25-25-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
    read: 0-0-25 s=255,c=3,t=6,pt=0,l=1:M
    send: 25-25-0-0 s=0,c=0,t=4,pt=0,l=5,st=fail:1.4.1
    send: 25-25-0-0 s=1,c=0,t=1,pt=0,l=5,st=fail:1.4.1
    send: 25-25-0-0 s=255,c=3,t=11,pt=0,l=10,st=fail:Mirror LED
    lost parent
    find parent
    send: 25-25-255-255 s=255,c=3,t=7,pt=0,l=0,st=bc:
    read: 0-0-25 s=255,c=3,t=8,pt=1,l=1:1
    new parent=0, d=2
    Strange. Looks like distance to gw is 2 but you're actually communicating to it directly.
  • @hek this is the sketch from about that that copy and recompile on 1.4.1. I did not used the codebender to compile the sketch.
    This is the serial info on the MQTT Gateway:
    0;0;3;0;9;read: 25-25-0 s=255,c=0,t=17,pt=0,l=5:1.4.1
    0;0;3;0;9;read: 25-25-0 s=255,c=3,t=6,pt=1,l=1:0
    0;0;3;0;9;send: 0-0-25-25 s=255,c=3,t=6,pt=0,l=1,st=ok:M
    0;0;3;0;9;read: 25-25-0 s=0,c=0,t=4,pt=0,l=5:1.4.1
    0;0;3;0;9;read: 25-25-0 s=1,c=0,t=1,pt=0,l=5:1.4.1
    0;0;3;0;9;read: 25-25-0 s=255,c=3,t=11,pt=0,l=10:Mirror LED
    MyMQTT/25/255/V_SKETCH_NAME
    30 27 00 1B 4D 79 4D 51 54 54 2F 32 35 2F 32 35 35 2F 56 5F 53 4B 45 54 43 48 5F 4E 41 4D 45 4D 69 72 72 6F 72 20 4C 45 44
    0;0;3;0;9;read: 25-25-255 s=255,c=3,t=7,pt=0,l=0:
    0;0;3;0;9;send: 0-0-25-25 s=255,c=3,t=8,pt=1,l=1,st=ok:1
    0;0;3;0;9;read: 0-25-25 s=255,c=3,t=8,pt=1,l=1:1
  • Hi I got this sketch to work. There must have being something wrong with MySensor library 1.4.1 once I re-install it and recompile the sketch it is working.
    @Francois Great to hear and thanks for letting us know!
  • @petewill I add a light sensor to your sketch and this now slow everything down what will the reason for this be? The motion sensor will not always pickup motion. I have another node with light and motion sensor and that is working right.
    Here is the code:
     * This sketch provides a Dimmable LED Light using PWM and based Henrik Ekblad
     * <henrik.ekblad@gmail.com> Vera Arduino Sensor project.
     * Developed by Bruce Lacey, inspired by Hek's MySensor's example sketches.
     * The circuit uses a MOSFET for Pulse-Wave-Modulation to dim the attached LED or LED strip.
     * The MOSFET Gate pin is connected to Arduino pin 3 (MIRROR_LED_PIN), the MOSFET Drain pin is connected
     * to the LED negative terminal and the MOSFET Source pin is connected to ground.
     * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
     * Version 1.0 - February 15, 2014 - Bruce Lacey
     * Version 1.1 - February 4, 2014 - Pete B - added buttons to control on/off and dim level and a motion sensor
    #define SN "Mirror LED with PIR and LDR"
    #define SV "1.2"
    #define NODE_ID 50  //change to a number to assign a specific ID
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #define MIRROR_LED_CHILD 0    //ID of the LED child
    #define MOTION_CHILD 1  //ID of the motion sensor child
    #define CHILD_ID_LIGHT 2 //ID for LDR sensor
    MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    #define MIRROR_LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
    #define UP_BUTTON_PIN 8  // Arduino Digital I/O pin number for the fade up button
    #define DOWN_BUTTON_PIN 7  // Arduino Digital I/O pin number for the fade down button
    #define POWER_BUTTON_PIN 4  // Arduino Digital I/O pin number for the power button
    #define MOTION_PIN  6  // Arduino pin tied to trigger pin on the motion sensor.
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define FADE_PERCENTAGE 10 //The percentage the fade level will be changed when a button is pressed
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
    //MySensor gw; //Don't need to define pins unless they are changing from the default
    static int currentLevel = 0;  // Current dim level...
    uint8_t fadeLevel = 0; //used to store the fade level when using the buttons
    uint8_t upPreviousValue;
    uint8_t downPreviousValue;
    uint8_t powerPreviousValue;
    Bounce upDebouncer = Bounce();
    Bounce downDebouncer = Bounce();
    Bounce powerDebouncer = Bounce();
    //motion sensor
    uint8_t lastMotion = 0;
    unsigned long previousMillis = 0; // last time update //see http://stackoverflow.com/questions/10773425/performing-a-function-after-x-time for more details on this
    unsigned long motionDelay = 10000; // interval at which to keep motion sensor trippped (milliseconds).  Used to prevent too frequent updates to Vera.
    unsigned long upPreviousMillis = 0;
    unsigned long downPreviousMillis = 0;
    unsigned long buttonFadeDelay = 200;
    int lastLightLevel;
    boolean metric = true;
    MyMessage motionMsg(MOTION_CHILD, V_TRIPPED);
    MyMessage dimmerMsg(MIRROR_LED_CHILD, V_DIMMER);
    //MyMessage lightMsg(LED_CHILD, V_LIGHT);  removed, updating with dimmer values only
     * Dimmable LED initialization method
      Serial.println( SN );
      gw.begin( incomingMessage,  NODE_ID);
      // Register the LED Dimmable Light with the gateway
      gw.present(MIRROR_LED_CHILD, S_DIMMER );
      gw.present(MOTION_CHILD, S_MOTION);
      gw.sendSketchInfo(SN, SV);
       // Setup the button
      pinMode(UP_BUTTON_PIN,INPUT);
      pinMode(DOWN_BUTTON_PIN,INPUT);
      pinMode(POWER_BUTTON_PIN,INPUT);
      // Activate internal pull-up
      digitalWrite(UP_BUTTON_PIN,HIGH);
      digitalWrite(DOWN_BUTTON_PIN,HIGH);
      digitalWrite(POWER_BUTTON_PIN,HIGH);
      upDebouncer.attach(UP_BUTTON_PIN);
      downDebouncer.attach(DOWN_BUTTON_PIN);
      powerDebouncer.attach(POWER_BUTTON_PIN);
      upDebouncer.interval(5);
      downDebouncer.interval(5);
      powerDebouncer.interval(5);
     *  Dimmable LED main processing loop
      //process the LED commands from gateway
     int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
     // Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      //motion sensor code
         if(currentMillis - previousMillis > motionDelay){
          uint8_t motionDetect = digitalRead(MOTION_PIN);
          if(motionDetect != lastMotion){
    //        Serial.print("motionDetect Value: ");
    //        Serial.println(motionDetect);
            gw.send(motionMsg.set(motionDetect));  // Send tripped value to gw
            if(motionDetect == 1){
              previousMillis = currentMillis;  //"Tripped" delay
            else{
              previousMillis = currentMillis - motionDelay + 1000; //"Not tripped" delay for 1 second to stop rapid "not tripped" and "tripped" updates to Vera
             lastMotion = motionDetect;
    There are 3 buttons attached to the mirror.  One is an on/off button and the other two will fade up/fade down.
    The sensor will remember the last fade state and fade the lights to that level next time they are turned on.
    If fade up or fade down button is pressed it should store that value into a variable and when the ON button is pressed
    it will fade to that previous value.
        upDebouncer.update();
        // Get the update value
        uint8_t upValue = upDebouncer.read();
        unsigned long upCurrentMillis = millis();
        if(upCurrentMillis - upPreviousMillis > buttonFadeDelay){
          if ((upValue == LOW) && (fadeLevel<100)) { //Because of the internal pullup resistors LOW = button is presssed
            fadeLevel += FADE_PERCENTAGE;
            fadeLevel = fadeLevel > 100 ? 100 : fadeLevel;
            fadeToLevel( fadeLevel );
          upPreviousMillis = upCurrentMillis;
        downDebouncer.update();
        uint8_t downValue = downDebouncer.read();
        unsigned long downCurrentMillis = millis();
        if(downCurrentMillis - downPreviousMillis > buttonFadeDelay){
          if ((downValue == LOW) && (fadeLevel>0)) {
            fadeLevel -= FADE_PERCENTAGE;
            fadeLevel = fadeLevel < 0 ? 0 : fadeLevel;
            //powerState = fadeLevel; //Remember fade level for when power button is pressed
          downPreviousMillis = downCurrentMillis;
        powerDebouncer.update();
        uint8_t powerValue = powerDebouncer.read();
        if(powerValue != powerPreviousValue){
          if (powerValue == LOW) {
          Serial.print("Power Button Pressed. fadeLevel is ");
          Serial.println(fadeLevel);
            if (currentLevel > 0) {
              fadeToLevel( 0 );
            else{
              if (fadeLevel == 0) {
                fadeToLevel(50);
                fadeLevel = 50;
              else{
                fadeToLevel(fadeLevel);
          powerPreviousValue = powerValue;
      if (message.type == V_LIGHT || message.type == V_DIMMER) {
    //    Serial.print( "Changing level to " );
    //    Serial.print( requestedLevel );
    //    Serial.print( ", from " );
    //    Serial.println( currentLevel );
        fadeToLevel( requestedLevel );
     *  This method provides a graceful fade up/down effect
    void fadeToLevel( int toLevel ) {
    //  Serial.print("toLevel Value: ");
    //  Serial.println(toLevel);
    //  Serial.print("currentLevel Value: ");
    //  Serial.println(currentLevel);
      int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
      while ( currentLevel != toLevel ) {
        currentLevel += delta;
        analogWrite( MIRROR_LED_PIN, (int)(currentLevel / 100. * 255) );
        delay( FADE_DELAY );
      //gw.send(lightMsg.set(currentLevel > 0 ? 1 : 0));  //used to send status of light (on/off) to Vera
      gw.send( dimmerMsg.set(currentLevel) );
    @Francois I usually put a "millis" delay for all of my sensors that don't need instant updates (temperature, humidity, light, etc). I have had some of my sensors updating too frequently and causing communication issues for the rest of my sensors. Maybe that's what's happening to you? Try adding some code so the light sensor only updates once per 10 seconds or what ever interval you feel is good. You can use my motion sensor code as an example for adding a delay with millis.
  • @petewill Just wanted to let you know that I've built two of these for my daughters but instead of putting them behind a mirror I put it under their bed. Works really good, thanks for sharing!
    @henno Cool idea!
    Scares away all the monsters? :trollface:
  • @henno That is too funny I was at a hotel and they had LEDs under the cabinets with motion sensors to light the floor. So when I came home I knew I saw some guy doing something similar to a mirror that I'm gonna steal for under my bed to walk at night without bumping my toes! Thanks Pete!
  • For those of us without a central 12v system do you know what the current draw is?
    What is your system setup? Thinking of doing the same.
    @csa02221862 Sorry for the delayed reply. Unfortunately I don't remember what the power draw is. I believe it is around 1.5A but can't say for sure.
    @csa02221862 Depending on what you want to run it may be a little under powered. For the last year and a half I have been using a hacked 300 watt PC power supply. I originally just set it up as a temporary measure but it has been working great. I have even made some stupid wiring mistakes and shorted it out a few times. Each time I just fix the mistake and it powers right back on. I need to make a video of how I set everything up but I have had so little time lately...
  • Thanks for the info. I may get this for use in the "lab" and see what you are doing with the computer power supply when you do the video. I believe many of us would like to have a 12v/5v power distribution system in the house.
    Your videos are OUTSTANDING!
  • Looking forward to the "whole house power" video.
    I'm building this for two mirrors as well as kitchen under counter and bookcase down lighting.
    Your Vera videos have been MOST helpful. You do great "practical" work.
    THANKS AGAIN!
    @csa02221862 Great! I have these all around my house in various places and I love them. All credit goes to @blacey.
    I do need to work on the power video. There are so many things I want to work on I have been focusing on making videos as I work on new sensors. It's so hard to find time these days...
  • @petewill ,
    I have a question on this project.
    I'm replicating it for a wider mirror and I was thinking about having two separate dimming zones ( left and right ). based on the sketch and the design: Do you think One arduino can control both sides or do I need 2 different arduinos (+ electronics) and one won't be enough.
    Happy to details more if needed.
    thanks in advance!
    Definitely. I have one pro mini controlling 3 different dimmers. You just need to make sure you use PWM pins for the outputs.
  • Cool, thanks for the quick reply.
    I'm going to test this this weekend and see if I can make it work 🙂
  • Do you have the Fitzing and code for the 3 zone? I have several places to use this. Any "max wattage" info, per channel and total?
    Richard
    @csa02221862
    Sorry it has been too long since I made this video and I don't remember the reference. If you're talking about my Arduino that dims three separate lights it's basically just the same wiring except you use 3 different PWM pins to the 3 different MOSFETs. The max wattage is determined by the MOSFET you use.
    If that's not what you're referring to, let me know.
  • @petewill Yes that's what I'm talking about. Just wondering how the code was modified to discretely control the 3 zones.
    you want with or without the buttons?
    If with, how would the buttons work?
    @csa02221862 Sorry for the delayed reply. Busy day yesterday. Here is my code that I'm running in my 1.4.1/1.5 environment.
     * The MOSFET Gate pin is connected to Arduino pin 3 (LED_PIN), the MOSFET Drain pin is connected
     * Version 1.1 - August 13, 2014 - Converted to 1.4 (hek)
     * Version 1.2 - January 22, 2015 - Created a seperate control for the basement LEDs
     * Version 1.3 - March 7, 2015 - Added coat closet LED
    #define SN "Basement LEDs"
    #define SV "1.3"
    #define NODE_ID AUTO //Change to a number to manually assign a node ID
    #define MASTER_WINDOW_LED_CHILD 0
    #define COAT_CLOSET_LED_CHILD 1
    #define UPSTAIRS_RAIL_LED_CHILD 30
    #define BASEMENT_DESK_LED_CHILD 40
    #define MASTER_WINDOW_LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
    #define UPSTAIRS_RAIL_LED_PIN 5
    #define BASEMENT_DESK_LED_PIN 6
    #define COAT_CLOSET_LED_PIN 9
    //MySensor gw;
    MySensor gw(4, 10);  //Change CE PIN to free up another PWM pin
    static int currentLevelUpstairsRail = 0;
    static int currentLevelBasementDesk = 0;
    static int currentLevelMasterWinLight = 0;
    static int currentLevelCoatCloset = 0;
      gw.present(UPSTAIRS_RAIL_LED_CHILD, S_DIMMER );
      gw.present(BASEMENT_DESK_LED_CHILD, S_DIMMER );
      gw.present(MASTER_WINDOW_LED_CHILD, S_DIMMER );
      gw.present(COAT_CLOSET_LED_CHILD, S_DIMMER );
    //    Serial.println( requestedLevel );
        //fadeToLevel( requestedLevel );//old code
        fadeToLevel( message.sensor, requestedLevel );
    void fadeToLevel(int ledChild, int toLevel ) {
    //    Serial.print( "In the FadeToLevel method.  ChildID: " );
    //    Serial.println( ledChild );
      int currentLevel;
      int ledPin;
      if(ledChild == UPSTAIRS_RAIL_LED_CHILD){
        currentLevel = currentLevelUpstairsRail;
        ledPin = UPSTAIRS_RAIL_LED_PIN;
      else if(ledChild == MASTER_WINDOW_LED_CHILD){
        currentLevel = currentLevelMasterWinLight;
        ledPin = MASTER_WINDOW_LED_PIN;
      else if(ledChild == COAT_CLOSET_LED_CHILD){
        currentLevel = currentLevelCoatCloset;
        ledPin = COAT_CLOSET_LED_PIN;
      else{
        currentLevel = currentLevelBasementDesk;
        ledPin = BASEMENT_DESK_LED_PIN;
        analogWrite(ledPin, (int)(currentLevel / 100. * 255) );
    //    Serial.println( ledPin );
        currentLevelUpstairsRail = toLevel;
        currentLevelMasterWinLight = toLevel;
        currentLevelCoatCloset = toLevel;
      else{
        currentLevelBasementDesk = toLevel;
        //gw.sendVariable( ledChild, V_LIGHT,  currentLevel > 0 ? 1 : 0 );
        //gw.sendVariable( ledChild, V_DIMMER, currentLevel );
        MyMessage dimmerMsg(ledChild,  V_DIMMER);
        gw.send(dimmerMsg.set(currentLevel));
  • Pete, thanks.
    This will work for most situations I need. Is there an option to add the buttons and motion to one or more of the led's?
    Hate to bother you again.
    Richard
    @csa02221862 It should be possible but I never added it. This is in my basement controlling various lights throughout my house so I don't need buttons very often (when I do I just use my phone). The motion sensors are run through a different node and all the logic happens through my controller.
  • @petewill Thanks for an awesome write up, I just recently ran across it! I am trying to get it working and downloaded the 1.4 library and tried uploading the sketch to my pro mini and got the following error:
    Sketch uses 18,642 bytes (130%) of program storage space. Maximum is 14,336 bytes.
    Global variables use 633 bytes (61%) of dynamic memory, leaving 391 bytes for local variables. Maximum is 1,024 bytes.
    processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
    at cc.arduino.Compiler.size(Compiler.java:315)
    at cc.arduino.Compiler.build(Compiler.java:156)
    at processing.app.Sketch.build(Sketch.java:1111)
    at processing.app.Sketch.exportApplet(Sketch.java:1146)
    at processing.app.Sketch.exportApplet(Sketch.java:1132)
    at processing.app.Editor$DefaultExportHandler.run(Editor.java:2409)
    at java.lang.Thread.run(Thread.java:745)
    Any suggestions on what I might be doing wrong? I am pretty new so I might be overlooking something really simple..
    @loralg Are you sure you're choosing the Pro Mini from the Tools > Boards menu? It should have around 32,000 bytes not 14,336.
    0_1470917364447_upload-d72f2ef7-0c3e-4a26-9f19-9a93903caee7
    @petewill there are atmega168-based pro minis. Using them with MySensors is hard though, because of their small flash size.
    @mfalkvidd Good point!
    @loralg do you have atmega168 or atmega328 Pro Minis? It should say in tiny print on the chip.
  • @petewill @mfalkvidd After looking I have the 168.. I already have some more ordered that are the 328 though. I should have looked closer when I ordered the first batch. Thanks for the help! I figured it was probably something simple I had overlooked on my end.
  • 90
  • 29
