My Slim 2AA Battery Node
    @Cliff-Karlsson Forgot to add that there is already a bootloader on that requires external crystal, you have to add it before to get it work.
  • Ok thanks for the info. So if I do not have any crystals it is not possible to burn the bootloader in any way?
    @m26872 said:
    @Cliff-Karlsson Forgot to add that IF there is already a bootloader on that requires external crystal, you have to add it before to get it work.
    (the important word "if" dropped out. )
    No, not if its fuses are set for external crystal.
    An ATMEGA328 coming from ATMEL is normally set to use the internal oscillator and has no bootloader. You will then have no need to put a crystal.
    I do this anyway on my breadboard (for the 28 pin DIP versions).
    If you have the SMD version of the atmega328 (the AU variant), I'm assuming it is set in the same default state (no crystal needed, running on internal oscillator).
  • @Cliff-Karlsson i added 10 Mhz and it worked as I didnt have 16 Mhz. Also tested with 20Mhz and worked
  • First node. Door sensor.
    Great boards :+
  • @ahmedadelhosni said:
    @meddie THanks for the answer.
    Can you please also explain your final result to reach 4uA. I have also the same problem and current is 90uA and sometimes drops to 20uA, then rises again. Thanks.
    Edit: I figured out that I was using the 3.3v from arduino UNO. CHanged to two 1.5 batteries. THe current drops to 1.4uA when contact is open but sometimes it is also 15 uA. And when contact is closed it is 60 uA, and sometimes drops. Don't know why it is not stable.
    Edit 26.1.2016: I managed to reach 1.4uA with door opened, and 15uA when closed. I guess the problem was with the wiring. DOn't really know but I used a battery holder instead. I will try to rechange the resistor value to 1Mohm and reupdate.
    Edit 27.1.2016: ok I created another node and connected the contact sensor in series with the 1Mohm and the output is the voltage divider. now it is 1.4uA when open and 4.6uA when closed.
    Yes, i used a 1 Mohm reisitor instead of the internall pull up. You can read this few messages above. This was a tip from GertSander
  • Hi, I build the board but I still have issues with burning ATMega328p chip.
    Can you describe and attach files that should work?
    The only success "burn" I had with burning bootloader was with hex and boards entry from first post using arduino uno and ips programer ( so it is like burning uno bootloader with your setup)
    After that I was trying to upload sketch but than it was not possible because of "?# in boards file but there is no such sign.
    I rewert file to stock and burn sketch like it would be standard uno board but using programer and not standard usb. No idea if it is corect so that is why I ask for more details.
    Thank you in advance
    Tomasz
    @Tomasz-Pazio Sounds more like some issue with the IDE and boards file than hw and fuses/bootloader. Have you tried different IDE versions?
  • @ahmedadelhosni
    what is it on the door? is that a plastic wrap?
  • @meddie
    The sensor is drawn by black rectangle. This is adhesive tape like this : http://2.imimg.com/data2/YX/UQ/MY-3910304/sale-bopp-clarity-adhesive-tape-250x250.jpg
    The other red rectangle on the door was old tape I didn't remove. Actually before getting my boards I used a bread board and a battery for testing, so I needed a tape for support and keeping it in place 🙂
  • @m26872 thanks for advice, bootloader burned on IDE 1.0.x and after that, sketches are uploaded properly on 1.6.x.
    One more question, how it should report battery state? I can not see any variable created for this in Vera.
    @Tomasz-Pazio Great! If I remember Vera correct, a variable should be created automaticly upon first message if you use the sendbatterylevel() fuction.
  • anyone care to write down the exact precedure of how to burn a new bootloader to the atmel chip? what files goes to what folders and so on.
    @Cliff-Karlsson I'm experimenting with several versions of Optiboot (various upload and upload combinations) for my board. Once that is done, I will add it to the documentation of my board. I'm extending the sketch found here:
    http://www.gammon.com.au/forum/?id=11635
  • OK, so finally I have received most of the parts I need to build a few of these sensors. I want to go with a temp sensor at first, the si7021. So I wanted to check what "other bits" I need (newb alert).
    0_1454624296448_upload-80039080-fce7-4484-b238-a54bdb2d28fd
    From there, do I need both 1 and 2? If so, what are these?
    0_1454624355650_upload-36748b2e-623b-4953-bdb4-394fbe264ef6
    From here, what are 3 and 4? Do I need both?
    Also, depending on the answers above, do I solder to exactly the same pins? Have I missed anything?
  • oh, yes! And you have to be carefully with them, because to set the fuses wrong, can destroy your µcontroller
  • Web-based fuse calculator
    Translation:
    apm96.upload.tool=avrdude
    apm96.upload.protocol=arduino
    apm96.upload.speed=9600
    apm96.bootloader.tool=avrdude
    apm96.build.mcu=atmega328p
    apm96.build.f_cpu=1000000L
    apm96.build.core=arduino
    apm96.build.variant=standard
  • @Cliff-Karlsson
  • @m26872 I am fairly sure that all methods work in normal cases but nothing worked for me fore some reason 🙂 .
    @Cliff-Karlsson
  • @Cliff-Karlsson
    @rsachoc
    like this:
    wooden look cable duct
    @AWI said:
    panelized design
    @AWI Sorry, can't help you with that. All Eagle here 😅
  • @Yveaux aha. I thought that this means multiple (same) design not different. Thanks 🙂
    Thanks @m26872
  • Hi
    1 x PDB board
    1 x ATMega328p 28pin PDIP
    1 x NRF24L01+ radio module
    2 x AA batteries
    Battery connector
    1 x senor of choice
    Extras needed
  • @Soloam
    and a flash module for OTA Sketch Uploads 🙂
    @Matt-Pitts
    avrdude: safemode: Fuses OK
    How can I got it working?
    Thank you
    Thomas
  • @Tom71
    I did two things:
  • @Tom71
  • @Matt-Pitts
  • @Tom71
  • @wergeld
  • Hello, I ordered it too yesterday 🙂 Can't wait to step forward from my breadboards with a lot wires to PCB without wires 😄
  • now I finally set up my first sensor board, and, as expected, I don´t receive any data from it on my gateway :suspect:
    The sketch should run, but it doesn´t. Any ideas how to troubleshoot now?
    @siod
    • Uno fuses and bootloader?
  • I just installed the NRF module at it´s desired place as well as the two capacitors and the resistors as described above. The crystal is only used for uploading the sketch to the Atmega328 chip, described here: https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
    edit: I´ve re-read your first post and also this thread http://forum.mysensors.org/topic/3018/tutorial-how-to-burn-1mhz-8mhz-bootloader-using-arduino-ide-1-6-5-r5/2 ...
    Do I have to burn the bootloader using 1MHz or 8 MHz? I don´t get why this makes a difference, only that the batteries would drain faster the higher the MHz rate is.
  • @Tom71
  • ok guys, I finally set up my first sensor and it´s communicating well. I´ve attached two reed switch which work fine, only my temp snesor DHT11 doesn´t work. Are there any known issues with this sensor?
    // Define Node ID
    #define MY_NODE_ID 1
    //Kontaktschalter
    //Tempsensor
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    //Kontaktschalter
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    int oldValueReed1=-1;
    int oldValueReed2=-1;
    //tempsensor
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Messages
    // Kontaktschalter
    //TempMessage
      //Tempsensor
    // Setup Kontaktschalter 1
      pinMode(BUTTON1_PIN,INPUT);
        // Activate internal pull-up
    // Setup Kontaktschalter 2
      pinMode(BUTTON2_PIN,INPUT);
      debouncer1.interval(5);
      debouncer2.interval(5);
      //Tempsensor
      //Kontakstschalter 1
      debouncer1.update();
      // Get the update value
         // Send in the new value
         oldValueReed1 = valueReed1;
      //Kontakstschalter 2
      debouncer2.update();
         oldValueReed2 = valueReed2;
     //Tempsensor
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
    edit2: I measured 0,02 Ampere consumption, isn´t that too much?
  • @siod
    Greets Eddie
  • 90
  • 44
