Robotic lawn mower supervisor
    Just dropping a small project i made here for the upcoming season.
    Its a motion and distance combined sensor sitting besides my robotic lawn mower. Whenever there is a movement it measures the distance, and therefore I can see if my mower is out or charging.
    Why not only a motion detector - well I have alot of other things happening in the shed as well (cats, children, rabbits) and i also wants to know if the mower is charging or out cutting gras.
    With a small lua script in Domoticz i hope to achieve a push notise whenever its trapped outside for to long.
    Its made of my EasyPCB, a Arduino Pro mini 5v, Nrf24l01+ radio, HC-SR04 distance sensor and HC-SR501 motion sensor.
    Code for 2.0
    // Enable debug prints
    // #define MY_NODE_ID 12
    #include <NewPing.h>
    #define CHILD_ID_DIST 2
    #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
    #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
    #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
    // Initialize motion message
    // Initialize distance message
    NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
    MyMessage msgdist(CHILD_ID_DIST, V_DISTANCE);
    int lastDist;
    boolean metric = true;
    int oldTripped = 0;
    int tripped = 0;
    unsigned long lastRequest = 0;
    void presentation()  {
      sendSketchInfo("Distance and Motion", "1.3");
      present(CHILD_ID, S_MOTION);
      delay(100);
      present(CHILD_ID_DIST, S_DISTANCE);
    void loop(){
    unsigned long now = millis();
    //Read digital motion value
    tripped = digitalRead(DIGITAL_INPUT_SENSOR);
    if (tripped != oldTripped){
      lastRequest = now;
      // Distance?
      int dist = metric?sonar.ping_cm():sonar.ping_in();
      Serial.print("Ping: ");
      Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
      Serial.println(metric?" cm":" in");
      if (dist == 0){
        return; //read again if 0, because 0 is error!
      if (dist != lastDist) {
          send(msgdist.set(dist));
          lastDist = dist;
       // Motion?
      oldTripped = tripped;
    if ((now - lastRequest) > (60UL * 1000UL * 60UL)){
    lastRequest = now;
    Serial.print("Heartbeat");
    sendHeartbeat();}
    Nice sensor on a stick @sundberg84 . I have ordered a robotic lawn mower to and was thinking I would monitor this exact same thing but with a sensbender and a microswitch.
    Thanks @korttoma! I was thinking about some switch, either mechanical or magnetic but the robot is not gentle at all when it enters the charging station so i descided to go with this that do not have any parts that needs to be close to eachother.
  • It's the same model I'm trying to fix the crappy rain detector, remember, we spoke about having a node on the mower that wakes and checks an external soil / rain sensor... I never did figure out the V_TEXT stuff 😉
    @Mark-Swift oh, strange - my rain sensors works just fine.
    Have you talked with the support? It can just be a software issue - look at robot-forums and get the support to send you a updated software version. Its easy to just download to a USB stick and connect to the robot.
  • @sundberg84 I sure have, in fact it's been replaced already, but has made little difference - looking around, it seems a fairly common issue. I've come to the conclusion Landroid just likes to take a shower 🙂
    @Mark-Swift Haha 😉 Yes - that can be the reason - its great you dont have to wash it that often then.
    I have heard the issue as well before... I hope you find a good sollution to your problem!
    I finally got my mower yesterday an as soon as I got home from work I just had to MySensor it.
    It is simply a Sensebender micro on a stick with a microswitch. So far it seems to work as expected.
  • Can you provide more details on wiring and more close ups of the circuit and the sensor itself?
