Rain Guage
    @BulldogLowell said:
    how about adding windspeed to the device?
    Cool device. Haven't seen that one before.
    @BulldogLowell Cool! Do you think it detects wind from all directions? Would this be better than the traditional spinning cup design?
    @hek
    @petewill
    A little progress on the device...
    electronics box:
  • @BulldogLowell this looks great once you complete it I will print it. Only problem our raining session is over till Dec. But I can start the build so long :).
    Nice. But I'm a bit worried about water finding its way into the electronics. Would it be possible to make a cavity for the electronics box in the bottom plate?
    @hek
    recessing the electronics into the bottom would be tough in this design. I was taking advantage on the two parts to use the smooth plate of the printer, and then make a gasket or even use silicone. lemme think about it. I could add a couple of deflectors on the bottom plate to glue on around where the weep holes are...
    PS enough room for 2 C sized cells
    bottom view:
    @BulldogLowell Awesome!
    I kind of wish I didn't have mine built already 🙂
    I may have missed it but did you have any mounting holes (for the side of a building or pole) What is your vision for that?
    It would also be cool to see some place to add a DHT22 in there. On mine I added one of those as well as a BH1750 for light. I'm not sure how long that will hold up though.
    I'll try to fit that in, if I can, but I'm really focusing on sealing up the electronics. A skirt around the electronics housing may be enough...
    I was thinking of a female 'flange-like' option for the unit to sit at the top of some galvanized pipe. It could be mounted that way on the side of a house, a fence or just a pole (back of your basketball backboard!). So, the yellow-brown part will be of two options to print.
    Of course, didn't think that long.
  • If you add a little edge around the holes, the water cannt flow into the electronic box.
    @BulldogLowell Awesome. I would love to get a 3d printer. Someday.
    @petewill
    As it happens, I am sort of turning the code on its head for this update. Do you want to use accumulated rain over X days as the trigger?
    I was thinking about storing the time on EEPROM and retrieving the stored rain values from VERA for each of the last 5 days after a power-up/restart. This saves from having to create too much EEPROM management, plus we can observe how much time has passed in the event of a power-off. That is, if the unit starts up, we test EEPROM to see what was the last day of rain recorded. If it hasn't been more than one, then we retrieve the values from VERA that were previously sent up. Sound OK to you?
    I would save an epoch timestamp once each day at midnight when we total today's rain and cascade the values back a day.
    As opposed to hours? I don't have too strong of an opinion either way. I think whatever is easier works. If they are both the same then maybe hours so we have a little more granular control?
    I like that it will simplify the EEPROM more and potentially prolong the life of the device (since it's not using as much EEPROM). One thought though, if there is a communication error between Vera and the rain gauge when it is first started is there a way to prevent the rain gauge from subsequently overwriting the values in Vera? I don't know too much about the "ack" portion of the communication but maybe that would make it so it's not an issue?
    I'm excited to see the new code. Keep up the good work!
    that's where we were with the 120 hour framework, so let's leave that. I'm not worried about EEPROM life, you get 100,000 writes and that is your lifetime++ using the circular buffer. I did the math on it but can't recall the exact number.
    So, we won't change EEPROM data, actually may need to add another 24hours. We just send to VERA the total of each of the past 5 days instead of the total accumulated rainfall over the past 24, 48, 72, 96 and 120 hours. This will be calendar days, we will verify by getting the time from VERA, and synchronize that a few times daily. the days will rollover at midnight, and the daily accumulation will be cascaded back accordingly.
    trigger for the sensor will still be total accumulation over so many hours.
    Yes?
    @BulldogLowell That sounds GREAT to me! This is your baby though (and you have much more experience with this stuff) so I trust what direction you go.
    @petewill
    here is some (untested) mods to update the 5 day rainfall history once per day at midnight. Take a look, let me know what you think (any problems issues). It turns out I was overthinking the problem and it really only needed minor mods...
     Arduino Tipping Bucket Rain Gauge
     April 26, 2015
     Version 1.4.1 alpha
     Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
     gateway you can measure and sense local rain.  This sketch will create two devices on your
     Vera controller.  One will display your total precipitation for the last 24, 48, 72, 96 and 120
     hours.  The other, a sensor that changes state if there is recent rain (up to last 120 hours)
     above a threshold.  Both these settings are user definable.
     * Allows you to set the rain threshold in mm
     * Allows you to determine the interval window up to 120 hours.
     * Displays the last 5 days of rain in Variable1 through Variable5
       of the Rain Sensor device
     * Configuration changes to Sensor device updated every hour
     * SHould run on any Arduino
     * Will retain Tripped/Not Tripped status and data in a power interruption, saving small ammount
       of data to EEPROM (Circular Buffer to maximize life of EEPROM)
     * LED status indicator
     by @BulldogLowell and @PeteWill for free public use
    #include <math.h>
    #include <Time.h>
    #define NODE_ID 24
    #define SKETCH_NAME "Rain Gauge"
    #define SKETCH_VERSION "1.4.1a"
    #define DWELL_TIME 125  // this allows for radio to come back to power after a transmission, ideally 0
    #define DEBUG_ON  // comment out this line to disable serial debug
    #define CHILD_ID_RAIN_LOG 3  // Keeps track of accumulated rainfall
    #define CHILD_ID_TRIPPED_INDICATOR 4  // Indicates Tripped when rain detected
    #define EEPROM_STATE_LOCATION 0 // location to save state to EEPROM
    #define EEPROM_BUFFER_LOCATION 1  // location of the EEPROM circular buffer
    #define BUFFER_LENGTH 121
    #define CALIBRATE_FACTOR 100 // e.g. 5 is .05mm (or 5 hundredths of an inch if imperial) per tip
    #ifdef  DEBUG_ON
    MyMessage msgRainRate(CHILD_ID_RAIN_LOG, V_RAINRATE);
    MyMessage msgRain(CHILD_ID_RAIN_LOG, V_RAIN);
    MyMessage msgRainVAR1(CHILD_ID_RAIN_LOG, V_VAR1);
    MyMessage msgRainVAR2(CHILD_ID_RAIN_LOG, V_VAR2);
    MyMessage msgRainVAR3(CHILD_ID_RAIN_LOG, V_VAR3);
    MyMessage msgRainVAR4(CHILD_ID_RAIN_LOG, V_VAR4);
    MyMessage msgRainVAR5(CHILD_ID_RAIN_LOG, V_VAR5);
    MyMessage msgTripped(CHILD_ID_TRIPPED_INDICATOR, V_TRIPPED);
    MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
    MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
    boolean metric = true;
    int eepromIndex;
    int tipSensorPin = 3; // Must be interrupt capable pin
    int ledPin = 5; // PWM capable pin required
    unsigned long dataMillis;
    const unsigned long serialInterval = 10000UL;
    const unsigned long oneHour = 3600000UL;
    unsigned long lastTipTime;
    unsigned long startMillis;
    unsigned int rainBucket [24] ; /* 24 hours = 1 day of data */
    unsigned int rainRate = 0;
    volatile int wasTippedBuffer = 0;
    byte rainWindow = 72;         //default rain window in hours
    int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
    byte state = 0;
    byte oldState = -1;
    int lastRainRate = 0;
    int lastMeasure = 0;
    boolean gotTime = false;
    byte lastHour;
      SERIAL_START(115200);
      // Set up the IO
      pinMode(tipSensorPin, INPUT_PULLUP);
      attachInterrupt (1, sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
      pinMode(ledPin, OUTPUT);
      digitalWrite(ledPin, HIGH);
      //Let's get the controller talking to the Arduino
      gw.begin(getVariables, NODE_ID);
      delay(DWELL_TIME);
      gw.present(CHILD_ID_RAIN_LOG, S_RAIN);
      delay(DWELL_TIME);
      gw.present(CHILD_ID_TRIPPED_INDICATOR, S_MOTION);
      delay(DWELL_TIME);
      state = gw.loadState(EEPROM_STATE_LOCATION); //retreive prior state from EEPROM
      DEBUG_PRINT(F("Previous Tripped State (from EEPROM): "));
      DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
      gw.send(msgTripped.set(state));
      delay(DWELL_TIME);
      //Sync time with the server, this will be called hourly in order to keep time from creeping with the crystal
      while(timeStatus() == timeNotSet)
        gw.requestTime(receiveTime);
        Serial.println("getting Time");
        delay(1000); // call once per second
        Serial.print(".");
      //retrieve from EEPROM stored values on a power cycle.
      boolean isDataOnEeprom = false;
      for (int i = 0; i < BUFFER_LENGTH; i++)
        byte locator = gw.loadState(EEPROM_BUFFER_LOCATION + 2 * i); //<<<<<<<<<<<
        if (locator == 0xFF)  // found the EEPROM circular buffer index
          eepromIndex = EEPROM_BUFFER_LOCATION + 2 * i;
          //Now that we have the buffer index let's populate the rainBucket[] with data from eeprom
          loadRainArray(eepromIndex);
          isDataOnEeprom = true;
          DEBUG_PRINT("EEPROM Index ");
          DEBUG_PRINTLN(eepromIndex);
      if (!isDataOnEeprom) // Added for the first time it is run on a new arduino
        eepromIndex = 1;
        gw.saveState(eepromIndex, 0xFF); // store the EEPROM index marker...
        gw.saveState(eepromIndex + 1, 0xFF);
      dataMillis = millis();
      startMillis = millis();
      lastTipTime = millis() - oneHour;
      //Get sensor time window and threshold from controller
      gw.request(CHILD_ID_TRIPPED_INDICATOR, V_VAR1);
      delay(DWELL_TIME);
      gw.request(CHILD_ID_TRIPPED_INDICATOR, V_VAR2);
      delay(DWELL_TIME);
      DEBUG_PRINTLN(F("Radio Setup Complete!"));
      if (state)
        prettyFade();  // breathe if tripped
        slowFlash();   // blink if not tripped
    #ifdef DEBUG_ON  // Serial Debug Block
      if ( (millis() - dataMillis) >= serialInterval)
        for (int i = 24; i <= 120; i = i + 24)
          updateSerialData(i);
      // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
      int measure = 0; // Check to see if we need to show sensor tripped in this block
      for (int i = 0; i < rainWindow; i++)
        measure += rainBucket [i];
        if (measure != lastMeasure)
          DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
          DEBUG_PRINTLN(measure);
          lastMeasure = measure;
      state = (measure >= rainSensorThreshold);
      if (state != oldState)
        delay(DWELL_TIME);
        gw.saveState(EEPROM_STATE_LOCATION, state); //New Code
        DEBUG_PRINT(F("New Sensor State... Sensor: "));
        DEBUG_PRINTLN(state? "Tripped" : "Not Tripped");
        oldState = state;
      unsigned long tipDelay = millis() - lastTipTime;
      if (wasTippedBuffer) // if was tipped, then update the 24hour total and transmit to Vera
        DEBUG_PRINTLN(F("Sensor Tipped"));
        DEBUG_PRINT(F("rainBucket [0] value: "));
        DEBUG_PRINTLN(rainBucket [0]);
        int dayTotal = 0;
        for (int i = 0; i < 24; i++)
          dayTotal = dayTotal + rainBucket [i];
        DEBUG_PRINT(F("dayTotal value: "));
        DEBUG_PRINTLN(dayTotal);
        gw.send(msgRain.set(dayTotal, 1));
        delay(DWELL_TIME);
        wasTippedBuffer--;
        rainRate = ((oneHour) / tipDelay);
        if (rainRate != lastRainRate)
          gw.send(msgRainRate.set(rainRate, 1));
          delay(DWELL_TIME);
          DEBUG_PRINT(F("RainRate= "));
          DEBUG_PRINTLN(rainRate);
          lastRainRate = rainRate;
      if (tipDelay > oneHour)
        rainRate = 0;
      if (millis() - startMillis >= oneHour)
        DEBUG_PRINTLN(F("One hour elapsed."));
        for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values back into the array
          rainBucket [i + 1] = rainBucket [i];
        rainBucket[0] = 0;
        gw.send(msgRain.set(rainTotal(24), 1)); // send 24hr tips
        delay(DWELL_TIME);
        delay(DWELL_TIME);
        delay(DWELL_TIME);
        gw.saveState(eepromIndex, highByte(rainBucket[0]));
        gw.saveState(eepromIndex + 1, lowByte(rainBucket[0]));
        eepromIndex++;
        if (eepromIndex > EEPROM_BUFFER_LOCATION + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER_LOCATION;
        DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
        gw.requestTime(receiveTime); // sync the time every hour
        delay(DWELL_TIME);
      if (hour() == 0 and lastHour == 23)
        transmitRainData();
      lastHour = hour();
    void sensorTipped()
      unsigned long thisTipTime = millis();
      if (thisTipTime - lastTipTime > 100UL)
        rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
        wasTippedBuffer++;
      lastTipTime = thisTipTime;
    int rainTotal(int hours)
      int total = 0;
      for ( int i = 0; i < hours; i++)
        total += rainBucket [i];
      return total;
    void updateSerialData(int x)
      DEBUG_PRINT(F("Tips last "));
      DEBUG_PRINT(x);
      DEBUG_PRINTLN(F(" hours: "));
      int tipCount = 0;
      for (int i = 0; i < x; i++)
        tipCount = tipCount + rainBucket [i];
      DEBUG_PRINTLN(tipCount);
    void loadRainArray(int value) // load stored rain array from EEPROM on powerup
      for (int i = 0; i < BUFFER_LENGTH - 1; i++)
        value--;
        DEBUG_PRINT("EEPROM location: ");
        DEBUG_PRINTLN(value);
        if (value < EEPROM_BUFFER_LOCATION)
          value = EEPROM_BUFFER_LOCATION + BUFFER_LENGTH;
        byte rainValueHigh = gw.loadState(value);
        byte rainValueLow = gw.loadState(value + 1);
        int rainValue = (rainValueHigh << 8) & rainValueLow;
        rainBucket[i] = rainValue;
        DEBUG_PRINT(F("rainBucket[ value: "));
        DEBUG_PRINT(i);
        DEBUG_PRINT(F("] value: "));
        DEBUG_PRINTLN(rainBucket[i]);
    void transmitRainData(void)
      int rainUpdateTotal = 0;
        rainUpdateTotal += rainBucket[i];
      gw.send(msgRainVAR1.set(( float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 24; i < 48; i++)
      gw.send(msgRainVAR2.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 48; i < 72; i++)
      gw.send(msgRainVAR3.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 72; i < 96; i++)
      gw.send(msgRainVAR4.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      for (int i = 96; i < 120; i++)
      gw.send(msgRainVAR5.set( (float) rainUpdateTotal / 100.0 , 1));
      delay(DWELL_TIME);
      if (message.sensor == CHILD_ID_RAIN_LOG)
        // nothing to do here
      else if (message.sensor == CHILD_ID_TRIPPED_INDICATOR)
        if (message.type == V_VAR1)
          rainWindow = atoi(message.data);
          if (rainWindow > 120)
            rainWindow = 120;
          else if (rainWindow < 1)
            rainWindow = 1;
          if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
            gw.send(msgTrippedVar1.set(rainWindow));
          rainSensorThreshold = atoi(message.data);
          if (rainSensorThreshold > 10000)
            rainSensorThreshold = 10000;
          else if (rainSensorThreshold < 1)
            rainSensorThreshold = 1;
          if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
            gw.send(msgTrippedVar2.set(rainSensorThreshold));
    void prettyFade(void)
      float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
      analogWrite(ledPin, val);
    void slowFlash(void)
      static boolean ledState = true;
      static unsigned long pulseStart = millis();
      if (millis() - pulseStart < 100UL)
        digitalWrite(ledPin, !ledState);
      DEBUG_PRINTLN(F("Time received from controller..."));
      setTime(time);
      char theTime[26];
      sprintf(theTime, "The current time is %d:%2d", hour(), minute());
      DEBUG_PRINTLN(theTime);
    @BulldogLowell
    Wow, just wow man.... that is a thing of beauty!!
    @ServiceXp
    waiting for the 3D prints from China, I'll post when I get them!
    I would love to see the .stl files for this.
    It has turned into something really amazing imho.
    I'll post, but I wanted to print and check first...
    @marceltrapman here you go...
    Posted to GoogleDrive
  • @BulldogLowell this has been quite a project to watch unfold and develop into just the greatest project. I am learning more just following you programing wizards, than I learn surfing . Thanks for the project and the inside tracks on programming etc.
    I have got my tripping gage back from my local 3d hub shop and the job looks good I hope to have it running hardware and soft before I return to and take it to Florida this fall.
    @BulldogLowell , @petewill
    A page for your new creation has been deployed here:
    http://www.mysensors.org/build/rain
    Please let me know if I missed something or spelling needs to be corrected.
    @hek Looks great! Thanks!
    @petewill - another outstanding tutorial video.
    @blacey Thanks! Couldn't have done it without @BulldogLowell and @hek
    @petewill, @BulldogLowell
    Received my off the shelf tipping bucket sensor today. http://www.ebay.com/itm/331525977548?rmvSB=true
    To my surprise it contained a dummy 2xAAA battery compartment. It might be possible to squeeze in a sensebender and nrf-radio (with some slight modification).
    @hek Cool! Looks like you may even have some room on the other side if you can figure out a way to waterproof it?
    @hek
    Did you ever wire this up with sensebender & radio squeezed in?
    I have this same guage I want to use with sensebender
    No, never had time to finish my rain gauge this summer.
    But it should be doable. But the big pcb in there has to be modified, or even better is probably to move the reed switch directly to the sensebender.
    ok thanks
  • Hi.
    i'm having some trouble whit my rain gauge...
    My rain gauge is a Aercus KW9015, using the code provided i'm getting rain count every hour whit no rain at all.
    I don't know what to do to fix this.
    Over the rain gauge i have 4 connections.
    1 - GND
    2 - TX1 --- Temperature sensor
    3 - TX2 --- Rain sensor
    4 - VCC
    Why i'm i getting reads of rain ever 1h when there is no rain ?
    Can anyone help me whit this problem ?
    @mrc-core
    Are you actually getting a rain value or is it just sending 0? The code is designed to send an update to your gateway every hour with the total rain for the day whether there is rain or not.
  • Some times i do get value 0 but other times i get rain value a big rain value for example values above 10mm of rain.
    The update is made every hour. Yesterday the rain value was 148mm when there was no rain at all. It doesn't rain for the last month.
    Ill try today reassembling the arduino, clear cd rom and flash again the rain gauge code.
    But i don't understand why i get this values.
    I even beleaved that the sensor was sendind data because off the wind... but it's not the problem.
    @mrc-core
    how is it connected electronically?
  • At the rain gauge i have an arduino nano conneting PIN "d3" to TX2 over the rain gauge circuit, the arduino is powered at pins VIN and GND.
    The rain gauge gets its power from the 3.3V over the arduino.
    im posting two images from the rain gauge circuit:
    IMG_1
    IMG_2
    Starting to believe i had connect someting rong like for example had switched TX1 and TX2 at the rain gauge
  • Looking over the IMG_2 should i connect arduino pin d3 to T1 just above the reed switch?
    Or i'm i correct using the TX2 connection.
    @mrc-core
    No PULLUP or PULLDOWN resistor?
  • no i cant find any pullup or pulldown resistor.
    You can see the images from de interior of the rain gauge hi have.
  • Which resistor do i pu between the 5v and the D3 pin ???
    @mrc-core
    if you don't pull up/down the signal, you may get floating voltages and spurious interrupts occurring.
    try to use the internal pullup
    pinMode(yourInterruptPin, INPUT_PULLUP);
    if that does not work try an external 10kOhm resistor to pull it up/down for your switch.
  • Going to put the 10kOhm resistor. the internall pullup did not work.
    One question. the resistor i put it between de 5v and the D3 pin
    @mrc-core
    to PULL UP, yes.
  • Thanks going to try it now. And today is a good day since its raining.
    No luck... now i'm getting only "0"
    What i have done until now:
    Put a resistor 10kOhm between the GND and D3 Pin from arduino and connect it to TX2 over rthe rain gauge.
    And connected the 5V from arduino to the VCC over the rain gauge.
    But i'm only getting 0 ...
    send: 4-4-0-0 s=3,c=1,t=28,pt=7,l=5,sg=0,st=fail:-0.2
    read: 5-5-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    send: 4-4-0-0 s=4,c=1,t=16,pt=1,l=1,sg=0,st=ok:0
    New Sensor State... Sensor: Not Tripped
    read: 3-3-0 s=0,c=1,t=38,pt=7,l=5,sg=0:4.748
    read: 0-0-4 s=4,c=2,t=24,pt=0,l=1,sg=0:1
    @mrc-core
    I guess I'd need to see a schematic or a good photo.
    can you generate a simple interrupt with a pushbutton and a resistor?
  • Hi. yesterday i disassembled the rain gauge circuit removed from it the reed switch and created a new circuit.
    I have connnected the reed switch to GND and PIN3 whit 10kOhm resistor.
    I'll post an image tonight.
    Up until now the values i'me getting from this new circuit is:
    rain gauge log
    Values i'm getting from serial port:
    Rain last 24 hours:
    1.80
    Rain last 48 hours:
    12481.94
    Rain last 72 hours:
    28210.34
    Rain last 96 hours:
    43938.74
    Rain last 120 hours:
    59667.14
    read and drop: 6-6-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    read and drop: 5-5-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    Seeing the graphic and this values it seems the problem i was having is fixed...
    But tonight i'm going do spread some water over the bucket to see if i get any values and not just 0
    MI-SOL Rain Guage has CALIBRATE_FACTOR = 36
    Sensor manufacturer has sent information about the sensor. 0.3 mm to 1 tick
    @Ivan-Z 👍 Thanks for the info.
  • Hey guys,
    Sorry if this is a stupid question but how does the Arduino interact with the tipping bucket to detect rain?
    @Theekshana There is a magnet on the tipping bucket and a reed switch that detects the magnet each time it passes by. So each time the bucket tips it will trigger to the Arduino and it can count from there.
  • Has anyone converted this sketch to Mysensors 2.0 already? I've tried but received following error when compiling:
    Rain-gauge.ino: In function 'void setup()':
    Rain-gauge.ino:151:28: error: too many arguments to function 'void requestTime()'
    In file included from D:\Programs\Arduino\Sketchbook\libraries\libraries\MySensors/MySensors.h:293:0,
                 from Rain-gauge.ino:71:
    D:\Programs\Arduino\Sketchbook\libraries\libraries\MySensors/core/MySensorsCore.cpp:296:6: note: declared here
     void requestTime() {
    Rain-gauge.ino: In function 'void loop()':
    Rain-gauge.ino:323:28: error: too many arguments to function 'void requestTime()'
    Modified sketch below:
     April 26, 2015
     Version 1.4.1 alpha
     Vera controller.  One will display your total precipitation for the last 5 days.  The other,
     a sensor that changes state if there is recent rain (up to last 120 hours)  above a threshold.
     There is a build overview video here: https://youtu.be/1eMfKQaLROo
     * Allows you to determine the tripped indicator window up to 120 hours.
     * Should run on any Arduino
     * Will retain Tripped/Not Tripped status and data in a power interruption, saving small amount
     * Optional Temp/Humidity (DHT-22 or DHT-11) and Light LUX (BH1750) sensors. To use, uncomment
       #define DHT_ON  and/or #define LUX_ON
     * Optionally send total accumulation of each day's rainfall or send only individual days rainfall totals.
       Comment out #define USE_DAILY to display individual daily rainfall.
    #include <math.h>
    #include <Time.h>
    //#define NODE_ID AUTO //or AUTO to let controller assign
    //#define DEBUG_ON  // comment out this line to disable serial debug
    //#define DHT_ON // uncomment out this line to enable DHT sensor
    //#define LUX_ON // uncomment out this line to enable BH1750 sensor
    //#define USE_DAILY // displays each time segment as an accumulation of prior periods inclusive.  Comment out to display individual daily rainfall totals in the variables sent to your controller.
    #define CALIBRATE_FACTOR 60 // amount of rain per rain bucket tip e.g. 5 is .05mm
    #define DHT_LUX_DELAY 300000  //Delay in milliseconds that the DHT and LUX sensors will wait before sending data
    #define EEPROM_BUFFER_LOCATION 0  // location of the EEPROM circular buffer
    #define E_BUFFER_LENGTH 240
    #define RAIN_BUCKET_SIZE 120
    #ifdef  DEBUG_ON
    #ifdef DHT_ON
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      #define HUMIDITY_SENSOR_DIGITAL_PIN 8
      DHT dht;
      float lastTemp;
      float lastHum;
    #ifdef LUX_ON
      //BH1750 is connected to SCL (analog input A5) and SDA (analog input A4)
      #include <BH1750.h>
      #define CHILD_ID_LIGHT 2
      BH1750 lightSensor;
      unsigned int lastlux;
      byte heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
    unsigned long sensorPreviousMillis;
    int eepromIndex;
    int tipSensorPin = 3; // Pin the tipping bucket is connected to. Must be interrupt capable pin
    int ledPin = 5; // Pin the LED is connected to.  PWM capable pin required
    unsigned long serialInterval = 600000UL;
    unsigned long lastRainTime; //Used for rainRate calculation
    unsigned int rainBucket [RAIN_BUCKET_SIZE] ; /* 24 hours x 5 Days = 120 hours */
    byte rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
    byte state = 0;
    byte oldState = -1;
    byte lastHour;
    byte currentHour;
      // Set up the IO
      //begin(getVariables, NODE_ID);
      unsigned long functionTimeout = millis();
      while (timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL)
    //    process();
        DEBUG_PRINTLN(F("Getting Time"));
        wait(1000); // call once per second
        DEBUG_PRINTLN(F("."));
      currentHour = hour();
      lastHour = hour();
      for (int i = 0; i < E_BUFFER_LENGTH; i++)
        byte locator = loadState(EEPROM_BUFFER_LOCATION + i);
        if (locator == 0xFE)  // found the EEPROM circular buffer index
          eepromIndex = EEPROM_BUFFER_LOCATION + i;
          DEBUG_PRINT(F("EEPROM Index "));
      if (!isDataOnEeprom) // Added for the first time it is run on a new Arduino
        DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
        saveState(eepromIndex, 0xFE);
        saveState(eepromIndex + 1, 0xFE);
        //then I will clear out any bad data
        for (int i = 2; i <= E_BUFFER_LENGTH; i++)
          saveState(i, 0x00);
      lastTipTime = millis() - oneHour; //why is this -oneHour?? Doesn't millis() start at 0 when first powered on?
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef DHT_ON
      present(CHILD_ID_HUM, S_HUM);
      wait(DWELL_TIME);
      wait(DWELL_TIME);
      .wait(DWELL_TIME);
    #ifdef LUX_ON
      wait(DWELL_TIME);
      lightSensor.begin();
      transmitRainData();
      wait(DWELL_TIME);
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    //  process();
      if (state)
          //      DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
          //      DEBUG_PRINTLN(measure);
      state = (measure >= (rainSensorThreshold * 100));
        wait(DWELL_TIME);
        oldState = state;
      unsigned long tipDelay = millis() - lastRainTime;
        send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); //Calculate the total rain for the day
        wait(DWELL_TIME);
        wasTippedBuffer--;
          wait(DWELL_TIME);
        lastRainTime = lastTipTime;
      if (currentHour != lastHour)
        send(msgRain.set((float)rainTotal(currentHour) / 100, 1)); // send today's rainfall
        wait(DWELL_TIME);
        DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
        DEBUG_PRINTLN(rainBucket[0]);
        for (int i = RAIN_BUCKET_SIZE - 1; i >= 0; i--)//cascade an hour of values back into the array
        wait(DWELL_TIME);
        wait(DWELL_TIME);
        rainBucket[0] = 0;
        eepromIndex = eepromIndex + 2;
        if (eepromIndex > EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH)
        wait(DWELL_TIME);
        transmitRainData();
        rainRate = 0;
        wait(DWELL_TIME);
        DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
        lastHour = currentHour;
      if (millis() - sensorPreviousMillis > DHT_LUX_DELAY)
        #ifdef DHT_ON  //DHT Code
          doDHT();
        #ifdef LUX_ON
          doLUX();
        sensorPreviousMillis = millis();
    #ifdef DHT_ON
    void doDHT(void)
        if (isnan(temperature))
          DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
        } else if (temperature != lastTemp)
          lastTemp = temperature;
          if (!metric)
          gw.wait(DWELL_TIME);
          DEBUG_PRINT(F("Temperature is: "));
          DEBUG_PRINTLN(temperature);
        float humidity = dht.getHumidity();;
        if (isnan(humidity))
          DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
        } else if (humidity != lastHum)
          lastHum = humidity;
          DEBUG_PRINT(F("Humidity is: "));
          DEBUG_PRINTLN(humidity);
    #ifdef LUX_ON
    void doLUX(void)
      unsigned int lux = lightSensor.readLightLevel();// Get Lux value
      DEBUG_PRINT(F("Current LUX Level: "));
      DEBUG_PRINTLN(lux);
      heartbeat++;
      if (lux != lastlux || heartbeat > 10)
        gw.send(msg.set(lux));
        lastlux = lux;
      if (heartbeat > 10)
        heartbeat = 0;
    void sensorTipped()
        wasTippedBuffer++;
      int total = 0;
      for ( int i = 0; i <= hours; i++)
      return total;
      DEBUG_PRINT(F("Rain last "));
      DEBUG_PRINT(x);
      float tipCount = 0;
      tipCount = tipCount / 100;
    void loadRainArray(int value) // retrieve stored rain array from EEPROM on powerup
      for (int i = 0; i < RAIN_BUCKET_SIZE; i++)
        value = value - 2;
          value = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
        DEBUG_PRINT(F("EEPROM location: "));
        byte rainValueHigh = loadState(value);
        byte rainValueLow = loadState(value + 1);
        unsigned int rainValue = rainValueHigh << 8;
        rainValue |= rainValueLow;
        rainBucket[i + 1] = rainValue;
        DEBUG_PRINT(i + 1);
        DEBUG_PRINTLN(rainBucket[i + 1]);
      DEBUG_PRINT(F("In transmitRainData. currentHour = "));
      DEBUG_PRINTLN(currentHour);
      for (int i = currentHour; i >= 0; i--)
        DEBUG_PRINT(F("Adding rainBucket["));
        DEBUG_PRINT(i);
        DEBUG_PRINTLN(F("] to rainUpdateTotal."));
      DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
      DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
      send(msgRainVAR1.set((float)rainUpdateTotal / 100.0, 1)); //Send current day rain totals (resets at midnight)
      wait(DWELL_TIME);
    #ifdef USE_DAILY
      for (int i = currentHour + 24; i > currentHour; i--)
        DEBUG_PRINT(i);
      DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
      send(msgRainVAR2.set((float)rainUpdateTotal / 100.0, 1));
      wait(DWELL_TIME);
    #ifdef USE_DAILY
      for (int i = currentHour + 48; i > currentHour + 24; i--)
        DEBUG_PRINT(i);
      DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
      send(msgRainVAR3.set((float)rainUpdateTotal / 100.0, 1));
      wait(DWELL_TIME);
    #ifdef USE_DAILY
      for (int i = currentHour + 72; i > currentHour + 48; i--)
        DEBUG_PRINT(i);
      DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
      send(msgRainVAR4.set((float)rainUpdateTotal / 100.0, 1));
      wait(DWELL_TIME);
    #ifdef USE_DAILY
      for (int i = currentHour + 96; i > currentHour + 72; i--)
        DEBUG_PRINT(i);
      DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
      send(msgRainVAR5.set((float)rainUpdateTotal / 100.0, 1));
      wait(DWELL_TIME);
            rainWindow = 120;
            rainWindow = 1;
      DEBUG_PRINTLN(F("Time received..."));
      setTime(time);
      char theTime[6];
      sprintf(theTime, "%d:%2d", hour(), minute());
    @niccodemi syntax for time functions is:
    requestTime();						// Request latest time from controller
  • @AWI thank you. Sketch compiles now but after uploading it still doesn't work - serial monitor is blank (debug on).
  • Using the new code for version 2.0.0 i'm getting this errors:
    C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void setup()':
    RainGauge:145: error: 'timeStatus' was not declared in this scope
    RainGauge:145: error: 'timeNotSet' was not declared in this scope
    RainGauge:152: error: 'hour' was not declared in this scope
    C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void loop()':
    RainGauge:299: error: 'hour' was not declared in this scope
    C:\Users\marco\Documents\Arduino\Nova pasta\RainGauge\RainGauge.ino: In function 'void receiveTime(long unsigned int)':
    RainGauge:597: error: 'setTime' was not declared in this scope
    setTime(time);
    RainGauge:599: error: 'hour' was not declared in this scope
    RainGauge:599: error: 'minute' was not declared in this scope
    Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
    Using library SPI at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
    Using library Wire at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\Wire
    exit status 1
    Does anyone now how to fix this ??
  • @mrc-core is this the sketch you are using?
     April 26, 2015
     Version 1.4.1 alpha
    //#define MY_NODE_ID 7
    #include <math.h>
    #include <Time.h>
    #define TIP_SENSOR_PIN 3
    #ifdef  DEBUG_ON
    #ifdef DHT_ON
      DHT dht;
      float lastTemp;
      float lastHum;
    #ifdef LUX_ON
      #include <BH1750.h>
      BH1750 lightSensor;
    int eepromIndex;
    byte state = 0;
    byte oldState = -1;
    unsigned int lastRainRate = 0;
    byte lastHour;
    byte currentHour;
      // Set up the IO
      pinMode(TIP_SENSOR_PIN, INPUT_PULLUP);
      attachInterrupt (digitalPinToInterrupt(TIP_SENSOR_PIN), sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
        requestTime();
      lastHour = hour();
          saveState(i, 0x00);
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef DHT_ON
      wait(DWELL_TIME);
    #ifdef LUX_ON
      wait(DWELL_TIME);
      transmitRainData();
    void presentation()  {
      wait(DWELL_TIME);
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef DHT_ON
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef LUX_ON
      if (state)
        wait(DWELL_TIME);
        oldState = state;
        wait(DWELL_TIME);
        wasTippedBuffer--;
          wait(DWELL_TIME);
        wait(DWELL_TIME);
        wait(DWELL_TIME);
        wait(DWELL_TIME);
        rainBucket[0] = 0;
        requestTime(); // sync the time every hour
        wait(DWELL_TIME);
        transmitRainData();
        rainRate = 0;
        wait(DWELL_TIME);
          doDHT();
        #ifdef LUX_ON
          doLUX();
    #ifdef DHT_ON
    void doDHT(void)
          if (!metric)
          wait(DWELL_TIME);
          lastHum = humidity;
          wait(DWELL_TIME);
    #ifdef LUX_ON
    void doLUX(void)
      DEBUG_PRINTLN(lux);
      heartbeat++;
        send(msg.set(lux));
        lastlux = lux;
      if (heartbeat > 10)
        heartbeat = 0;
    void sensorTipped()
        wasTippedBuffer++;
      int total = 0;
      return total;
      DEBUG_PRINT(x);
      float tipCount = 0;
        value = value - 2;
        DEBUG_PRINT(i + 1);
        DEBUG_PRINT(i);
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        DEBUG_PRINT(i);
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        DEBUG_PRINT(i);
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        DEBUG_PRINT(i);
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        DEBUG_PRINT(i);
      wait(DWELL_TIME);
            rainWindow = 120;
            rainWindow = 1;
      setTime(time);
      char theTime[6];
    It compiles fine with Arduino IDE 1.6.5, Mysensors 2.0.0 and libraries (Time, BH1750).
  • Yes that's the one.
  • Using IDE 1.6.5 i get this:
    In file included from C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:10:0:
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:18:18: error: variable 'monthStr1' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr1[] PROGMEM = "January";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:19:18: error: variable 'monthStr2' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr2[] PROGMEM = "February";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:20:18: error: variable 'monthStr3' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr3[] PROGMEM = "March";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:21:18: error: variable 'monthStr4' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr4[] PROGMEM = "April";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:22:18: error: variable 'monthStr5' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr5[] PROGMEM = "May";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:23:18: error: variable 'monthStr6' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr6[] PROGMEM = "June";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:24:18: error: variable 'monthStr7' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr7[] PROGMEM = "July";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:25:18: error: variable 'monthStr8' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr8[] PROGMEM = "August";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:26:18: error: variable 'monthStr9' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr9[] PROGMEM = "September";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:27:19: error: variable 'monthStr10' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr10[] PROGMEM = "October";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:28:19: error: variable 'monthStr11' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr11[] PROGMEM = "November";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:29:19: error: variable 'monthStr12' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthStr12[] PROGMEM = "December";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:31:22: error: variable 'monthNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    PGM_P monthNames_P[] PROGMEM =
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:37:26: error: variable 'monthShortNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char monthShortNames_P[] PROGMEM = "ErrJanFebMarAprMayJunJulAugSepOctNovDec";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:39:16: error: variable 'dayStr0' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr0[] PROGMEM = "Err";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:40:16: error: variable 'dayStr1' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr1[] PROGMEM = "Sunday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:41:16: error: variable 'dayStr2' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr2[] PROGMEM = "Monday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:42:16: error: variable 'dayStr3' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr3[] PROGMEM = "Tuesday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:43:16: error: variable 'dayStr4' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr4[] PROGMEM = "Wednesday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:44:16: error: variable 'dayStr5' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr5[] PROGMEM = "Thursday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:45:16: error: variable 'dayStr6' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr6[] PROGMEM = "Friday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:46:16: error: variable 'dayStr7' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayStr7[] PROGMEM = "Saturday";
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:48:20: error: variable 'dayNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    PGM_P dayNames_P[] PROGMEM = { dayStr0,dayStr1,dayStr2,dayStr3,dayStr4,dayStr5,dayStr6,dayStr7};
    C:\Users\marco\Documents\Arduino\libraries\Time\DateStrings.cpp:49:24: error: variable 'dayShortNames_P' must be const in order to be put into read-only section by means of 'attribute((progmem))'
    char dayShortNames_P[] PROGMEM = "ErrSunMonTueWedThrFriSat";
    Erro ao compilar.
  • @mrc-core Remove folder "Time" from your libraries folder, then download the "MySensorsArduinoExamples" zip from this link and extract Time library to your libraries folder. Restart Arduino IDE and try again.
  • Hi All,
    Can you run this of 2 x AA batteries, does it go into sleep? It seems to fade the LED al the time, so I guess it will drain the batteries quick quickly? Does anyone have experience in powering this?
    Regards
    @esawyja No, currently this example is written to be powered by external power so it wouldn't work well with batteries.
  • Hi friends,
    here is my replica of Rain Guage MySensors project
    photos:
    https://goo.gl/photos/4kA7T4d8SsDBRrrS7
    The sketch is adopted for 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library' just uncomment both DHT_ON and DHT_ADAFRUIT and Yes, I'm using rfm69hw radio with encryption enabled 😉
    3d bucket model: proposal to split it on a 3 part (i split on 2 parts now and have some troubles)
    #define MY_RFM69_ENABLE_ENCRYPTION
     April 26, 2015
     Version 2.0
       Uncomment #define USE_DAILY to display individual daily rainfall.  If it is commented out it will display
       a cumulative total rainfall (day4 = day1+day2+day3+day4 etc)
    //#define MY_DEBUG_VERBOSE
    #define MY_NODE_ID AUTO
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_TX_POWER 31
    #include <math.h>
    #include <TimeLib.h>
    #define SKETCH_VERSION "2.0"
    #define DWELL_TIME 40  // this allows for radio to come back to power after a transmission, ideally 0
    //#define DEBUG_ON  // Rain gauge specific debug messages.
    // 20170621 by Enfeet
    #define DHT_ADAFRUIT // uncomment out this line to enable DHT with 'Adafruit Unified Sensor by Adafruit' + 'DHT sensor library'
    //#define DHTTYPE           DHT11     // DHT 11
    #define DHTTYPE           DHT22     // DHT 22 (AM2302)
    //#define DHTTYPE           DHT21     // DHT 21 (AM2301)
    // /20170621 by Enfeet
    //#define USE_DAILY // Uncomment to display individual daily rainfall totals in the variables sent to your controller. If it's commented it will add each day to the next for a cumulative total.
    //d=112 mm
    //11689.863832 mm2 =  116,89863832 cm2
    //42,77209787776081 mm
    //88 89 91 91 90 = 89,8
    //0,4763039852757329
    #define CALIBRATE_FACTOR 48 // amount of rain per rain bucket tip e.g. 5 is .05mm
      #ifdef  DEBUG_ON
        #define M_DEBUG_PRINT(x)   Serial.print(x)
        #define M_DEBUG_PRINTLN(x) Serial.println(x)
    #ifdef DHT_ON
      #ifdef DHT_ADAFRUIT
      #include <Adafruit_Sensor.h>
      #include <DHT_U.h>
      #ifndef DHT_ADAFRUIT // 20170621 by Enfeet
        DHT dht;
        DHT_Unified dht(HUMIDITY_SENSOR_DIGITAL_PIN, DHTTYPE);
        sensors_event_t event;
      #endif // /20170621 by Enfeet
      float lastTemp;
      float lastHum;
      bool metric = true;
    #ifdef LUX_ON
      #include <BH1750.h>
      BH1750 lightSensor;
      uint8_t heartbeat = 10; //Used to send the light lux to gateway as soon as the device is restarted and after the DHT_LUX_DELAY has happened 10 times
    int eepromIndex;
    #ifdef DEBUG_ON
    uint8_t rainWindow = 72;         //default rain window in hours.  Will be overwritten with msgTrippedVar1.
    uint8_t state = 0;
    uint8_t oldState = 2; //Setting the default to something other than 1 or 0
    bool gotTime = false;
    uint8_t lastHour;
    uint8_t currentHour;
      wait(DWELL_TIME);
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef DHT_ON
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef LUX_ON
      M_DEBUG_PRINTLN(F("Sensor Presentation Complete"));
      #ifndef MY_DEBUG
      SERIAL_START(115200);  //Start serial if MySensors debugging isn't enabled
      // Set up the IO
      pinMode(TIP_SENSOR_PIN, INPUT);
        requestTime();
        M_DEBUG_PRINTLN(F("Getting Time"));
        M_DEBUG_PRINTLN(F("."));
      lastHour = hour();
      bool isDataOnEeprom = false;
        uint8_t locator = loadState(EEPROM_BUFFER_LOCATION + i);
          M_DEBUG_PRINT(F("EEPROM Index "));
          M_DEBUG_PRINTLN(eepromIndex);
        M_DEBUG_PRINTLN(F("I didn't find valid EEPROM Index, so I'm writing one to location 0"));
          saveState(i, 0x00);
      #ifdef DEBUG_ON
      lastTipTime = millis();
      wait(DWELL_TIME);
      wait(DWELL_TIME);
    #ifdef DHT_ON
        dht.begin();
      wait(DWELL_TIME);
    #ifdef LUX_ON
      transmitRainData(); //Setup complete send any data loaded from eeprom to gateway
      if (state)
          //      M_DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
          //      M_DEBUG_PRINTLN(measure);
        wait(DWELL_TIME);
        M_DEBUG_PRINT(F("New Sensor State... Sensor: "));
        M_DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
        oldState = state;
        M_DEBUG_PRINTLN(F("Sensor Tipped"));
        M_DEBUG_PRINT(F("rainBucket [0] value: "));
        M_DEBUG_PRINTLN(rainBucket [0]);
        wait(DWELL_TIME);
        wasTippedBuffer--;
          wait(DWELL_TIME);
          M_DEBUG_PRINT(F("RainRate= "));
          M_DEBUG_PRINTLN(rainRate);
        M_DEBUG_PRINTLN(F("One hour elapsed."));
        wait(DWELL_TIME);
        M_DEBUG_PRINT(F("Saving rainBucket[0] to eeprom. rainBucket[0] = "));
        M_DEBUG_PRINTLN(rainBucket[0]);
        wait(DWELL_TIME);
        wait(DWELL_TIME);
        rainBucket[0] = 0;
        M_DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
        wait(DWELL_TIME);
        transmitRainData();
        rainRate = 0;
        wait(DWELL_TIME);
        M_DEBUG_PRINTLN(F("Sending rainRate is 0 to controller"));
        lastHour = hour();
          doDHT();
        #ifdef LUX_ON
          doLUX();
    #ifdef DHT_ON
    void doDHT(void)
        dht.temperature().getEvent(&event);
        float temperature = event.temperature;
        if (isnan(event.temperature))
          M_DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
            if (!metric)
          wait(DWELL_TIME);
          M_DEBUG_PRINT(F("Temperature is: "));
          M_DEBUG_PRINTLN(temperature);
        dht.humidity().getEvent(&event);
        float humidity = event.relative_humidity;
        if (isnan(event.relative_humidity))
          M_DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
          lastHum = humidity;
          wait(DWELL_TIME);
          M_DEBUG_PRINT(F("Humidity is: "));
          M_DEBUG_PRINTLN(humidity);
    #ifdef LUX_ON
    void doLUX(void)
      M_DEBUG_PRINT(F("Current LUX Level: "));
      M_DEBUG_PRINTLN(lux);
      heartbeat++;
        send(msg.set(lux));
        lastlux = lux;
      if (heartbeat > 10)
        heartbeat = 0;
    void sensorTipped()
        wasTippedBuffer++;
      int total = 0;
      return total;
    #ifdef DEBUG_ON
      M_DEBUG_PRINT(F("Rain last "));
      M_DEBUG_PRINT(x);
      M_DEBUG_PRINTLN(F(" hours: "));
      float tipCount = 0;
      M_DEBUG_PRINTLN(tipCount);
    void loadRainArray(int eValue) // retrieve stored rain array from EEPROM on powerup
      for (int i = 1; i < RAIN_BUCKET_SIZE; i++)
        eValue = eValue - 2;
        if (eValue < EEPROM_BUFFER_LOCATION)
          eValue = EEPROM_BUFFER_LOCATION + E_BUFFER_LENGTH;
        M_DEBUG_PRINT(F("EEPROM location: "));
        M_DEBUG_PRINTLN(eValue);
        uint8_t rainValueHigh = loadState(eValue);
        uint8_t rainValueLow = loadState(eValue + 1);
        M_DEBUG_PRINT(F("rainBucket[ value: "));
        M_DEBUG_PRINT(i);
        M_DEBUG_PRINT(F("] value: "));
        M_DEBUG_PRINTLN(rainBucket[i]);
      M_DEBUG_PRINT(F("In transmitRainData. currentHour = "));
      M_DEBUG_PRINTLN(currentHour);
        M_DEBUG_PRINT(F("Adding rainBucket["));
        M_DEBUG_PRINT(i);
        M_DEBUG_PRINTLN(F("] to rainUpdateTotal."));
      M_DEBUG_PRINT(F("TX Day 1: rainUpdateTotal = "));
      M_DEBUG_PRINTLN((float)rainUpdateTotal / 100.0);
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        M_DEBUG_PRINT(i);
      M_DEBUG_PRINT(F("TX Day 2: rainUpdateTotal = "));
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        M_DEBUG_PRINT(i);
      M_DEBUG_PRINT(F("TX Day 3: rainUpdateTotal = "));
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        M_DEBUG_PRINT(i);
      M_DEBUG_PRINT(F("TX Day 4: rainUpdateTotal = "));
      wait(DWELL_TIME);
    #ifdef USE_DAILY
        M_DEBUG_PRINT(i);
      M_DEBUG_PRINT(F("TX Day 5: rainUpdateTotal = "));
      wait(DWELL_TIME);
            rainWindow = 120;
            rainWindow = 1;
      static bool ledState = true;
    void receiveTime(unsigned long newTime)
      M_DEBUG_PRINTLN(F("Time received..."));
      setTime(newTime);
      char theTime[6];
      M_DEBUG_PRINTLN(theTime);
    SY
    Enfeet
  • @Enfeet I am interested in checking out your code (have not looked through it yet). I am to the point with my rain gauge design that I am ready to do the code for the sensor. Out of curiosity, what type of sensor did you use for your tipping bucket? I am using a magnetic reed switch. I had originally done a bucket design like the one you have, actually when I started my project, I modeled my original one off of that one. This is my modified design:
    0_1498328811307_upload-735a635e-b322-420b-b644-72ff206e6f3a
    0_1498328935089_upload-b2c2b597-4ca0-4954-8893-2052dcef28b8
    The magnet fits in the recessed hole in the side, no need to glue it in. The big difference is that the center divider is angled out to help better with the tipping action.
    Here is the rest of the sensor:
    0_1498329322457_upload-830ba455-dd6c-431a-a3af-2b730c468e26
    0_1498329349998_upload-65eaf66b-c81a-4ad0-bf56-b50be7294a55
    I just got the OpenSCAD file for the project cleaned up and I will be posting it to thingiverse later today.
  • @dbemowsk , i take an original .stl files from the link provided: https://drive.google.com/drive/folders/0B3KGTJHUgpw1fkwtM3RreEF2QWg4eUdsUHdSQjl6UWx2Q3dPS19WSGdqd0pZQ3hhQk1TMkE
    but in order to save a support material recreate and split it a little 😉
    The result are visible on photos (link in my previous post)
    here is an .scad code of my modifications on top of original files, also i print them up side down 😉
    $fn=300;
    difference(){
    translate([35,0,0])
    import("Can.stl");
    cube([210,150,150],center=true);
    translate([62,0,0])
    rotate([0,90,0])
    difference(){
    cylinder(d=10,h=3,center=true);
    cylinder(d=4,h=6,center=true);
    difference(){
    translate([-88,0,0])
    sphere(d=300);
    translate([-90,0,0])
    sphere(d=300);
    translate([61,0,0])
    rotate([0,90,0])
    cylinder(d=4,h=4,center=true);
    rotate([0,90,0])
    difference(){
    cylinder(d=310,h=208,center=true);
    cylinder(d=122.5+4,h=310,center=true);
    translate([54,0,0])
    rotate([0,90,0])
    difference(){
    cylinder(d=122.5+4,h=108,center=true);
    cylinder(d=122.5,h=310,center=true);
    $fn=300;
    difference(){
    translate([35,0,0])
    import("Can.stl");
    translate([62,0,0])
    rotate([0,90,0])
    difference(){
    difference(){
    sphere(d=300);
    sphere(d=300);
    translate([61,0,0])
    rotate([0,90,0])
    rotate([0,90,0])
    difference(){
    translate([54,0,0])
    rotate([0,90,0])
    difference(){
    cylinder(d=122.5+4,h=40
       ,center=true);
    translate([32,0,0])
    rotate([0,90,0])
    difference(){
    cylinder(d=122.5+4+4,h=8
       ,center=true);
    cylinder(d=122.5+4,h=9,center=true);
    The arduino code is also from original project (https://www.mysensors.org/build/rain) but i adopt it to Adafruit Unified Sensors Library and last version of Arduino IDE 1.8.3
    SY
    Enfeet
  • 44
