DHT and DOOR sensor
  • Hi
    Please assist, I am trying to combine the default straight from the examples, but the DHT give an error on compile
     * Version 1.0: Henrik EKblad
     * sensor using a DHT11/DHT-22.
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RS485
    #define DHT_DATA_PIN 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID 3
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    Bounce debouncer = Bounce();
    int oldValue=-1;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID, S_DOOR);
    	// Setup the button
    pinMode(BUTTON_PIN,INPUT);
    // Activate internal pull-up
    debouncer.attach(BUTTON_PIN);
    debouncer.interval(5);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
    		debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      sleep(UPDATE_INTERVAL);
    The error is below
    /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino: In function 'void loop()':
    /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino:129:22: error: no matching function for call to
    'DHT::readSensor(bool)'
    dht.readSensor(true);```
  • @terence-faul I'm probably wrong, but it looks to me like the sensor and the button are on the same pin.
    I'm only learning, so it's probably wise to wait for someone else to chime in.
    @homer you'll need to install the modified DHT library as described on https://www.mysensors.org/build/humidity#example
  • @mfalkvidd said in DHT and DOOR sensor:
    Thanks, but did I spot the issue with the pins correctly?
    @homer yes, they are using the same pin. Move one of them (doesn't matter which) to pin 2. On atmega328, only pins 2 and 3 have full interrupt functionality.
  • Hi
    I have sorted the pins and library problems, but now I get failed to read errors
    Updated Sketch
    #define MY_RX_MESSAGE_BUFFER_FEATURE
    #define MY_RF24_IRQ_PIN 2
    //#define MY_RS485
    #define DHT_DATA_PIN 4
    #define CHILD_ID 3
    float lastTemp;
    float lastHum;
    bool metric = true;
    DHT dht;
    int oldValue=-1;
      sendSketchInfo("Door/DHT", "1.1");
    	// Setup the button
        if (!metric) {
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        nNoUpdatesTemp++;
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        nNoUpdatesHum++;
    		debouncer.update();
         oldValue = value;
    and error snippet
    3534 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    3545 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
    3553 TSF:TDI:TSL
    3555 MCO:SLP:WUP=1
    3557 TSF:TRI:TSB
    3584 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    3592 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
    3602 TSF:TDI:TSL
    3604 MCO:SLP:WUP=1
    3606 TSF:TRI:TSB
    @terence-faul said in DHT and DOOR sensor:
    This means the DHT library is unable to read from the DHT sensor. Double-check that the DHT gets sufficient power and that it is wired correctly. If you have another DHT sensor, switch sensors and see if that helps.
  • Will give that a go. But if I load the DHT only sketch on the same node it reads fine.
    Could you check my sketch Iā€™m a bit of a noob with code
    @terence-faul the sketch looks good to me. Could you post your "dht only" sketch?
  • I can't believe I spotted am error in the code! I guess I'm starting to get a bit better at this! šŸ˜šŸ˜
    //#define MY_RS485
    float lastTemp;
    float lastHum;
    bool metric = true;
    DHT dht;
        if (!metric) {
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        nNoUpdatesTemp++;
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        nNoUpdatesHum++;
    Thanks @terence-faul
    I can't see any problem with the sketches.
  • @Terence-Faul The only thing I can say is that it is generally good practice to put all #include statements at the start of the code, then all the #define statements and finally all other items. At the moment you #define things before you #include the library and maybe that is an issue for the compiler?
    @skywatch while your recommendation is good in general, all MySensors defines (MY_*) must be defined before including MySensors.h. Otherwise the defines won't be available to the library, so the library will need to fall back on the default settings.
  • Thanks so much for the help, what is the next step then? create two sensors?
  • @terence-faul
    comment step by step blocks of code for DOOR switch and try when it start to work.
  • @mfalkvidd Ah yes, I forgot that bit!
  • Hi @terence-faul did you fix this?
    i'm also trying too merge a door & dht sketch but have not got a clue where too start
    if you have solved this can you post the working sketch
  • How much power are you feeding the sensor? I've had issues when I've fed too little power and it's resolved once I use more power.
