Ethernet gateway
  • Hi hope someone can assist
    I have a gateway with wiznet 5100 shield.
    I haver the sketch loaded and I get a IP address assigned
    Here is the sketch and I use Home assistant as a controller. The error is slow and just loops and loops
     * Version 1.0 - Henrik Ekblad
     * Contribution by a-lurker and Anticimex
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
     * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_HOSTNAME "MySensorsEth"
    //#define MY_DEBUG_VERBOSE_RF24
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    //#define MY_IP_ADDRESS 192,168,168,92
    //#define MY_IP_GATEWAY_ADDRESS 192,168,168,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    //#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Looping error
    pio device monitor --port /dev/cu.usbserial-14320 --baud 115200
    Tmac:Gateway terencefaul$ pio device monitor --port /dev/cu.usbserial-14320 --baud 115200
    --- Miniterm on /dev/cu.usbserial-14320  115200,8,N,1 ---
    --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
    0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    17 MCO:REG:NOT NEEDED
    4706 GWT:TIN:IP=192.168.1.92
    5709 MCO:BGN:STP
    5711 MCO:BGN:INIT OK,TSP=1
    5713 GWT:TSA:ETH OK
    5716 !GWT:TSA:ETH FAIL
    5719 TSM:READY:NWD REQ
    5755 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    5762 GWT:TSA:ETH OK
    5765 !GWT:TSA:ETH FAIL
    5767 GWT:TSA:ETH OK
    5770 !GWT:TSA:ETH FAIL
    5772 GWT:TSA:ETH OK
    5775 !GWT:TSA:ETH FAIL
    5777 GWT:TSA:ETH OK```
  • @terence-faul I'm only new to this myself, so I can't help with anything specific, but I did a search and found another thread where someone was having issues with a similar setup to you. Maybe you might find some info there that helps you. The thread is here :
    https://forum.mysensors.org/topic/5059/ethernet-gateway-with-w5100
