Garage door controller/checker
  • Time to think bout a new project.
    The comming months I am building a new garage . I want to controll and check the garage via my vera3. Option is to buy a universal sensor and fibaro relais , but why not with my sensor stuff?
    What does it need to do:
    -open en close the garage >> via a relais what closes the contacts momentarely ( 1 or 2 seconds)
    -checks if the garage is open , closed or in transit: via reed switches ; one on the open opsition and one on the closed position. >> sketch will be door sensor/siwtch.
    -sensor to check if the entrance/garage door is clear to close , or emergency stop when "the beam" is interupted. >> No idea what this is called , but I guess the sketch will be like the "door sensor/ switch" .
    -temperature sensor. >> ( Dallas DS18B20).
    What do you guys think? Is this possible? , on an arduino nano 3x reed switches and a temperature sensor?
    I allready have a sketch here for 1 temperature sensor and 1 reed switch:
    This one has not the IRQ pin on the radio connected , on pin 2 is a reed sensor. Can this sketch easily be adapted for 3 reedswitches and also have a relais attached?
    One of the reed switches needs to be "inversed", when the contact is closed, it actually has to say "garage open".
    Thanks,
    Cor
    // Example sketch showing how to send in OneWire temperature readings
    #include <OneWire.h>
    #define CHILD_ID_SWITCH 17
    #define BUTTON_PIN  2  // Arduino Digital I/O pin for button/reed switch
    OneWire oneWire(ONE_WIRE_BUS);
    int numSensors=0;
    boolean metric = true;
    int oldValue=-1;
    MyMessage msgTemp(0,V_TEMP);
    MyMessage msgButton(CHILD_ID_SWITCH,V_TRIPPED);
      // Startup OneWire
      sensors.begin();
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor", "1.0");
         gw.present(i, S_TEMP);
      // INIT SWITCH
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-up
      gw.present(CHILD_ID_SWITCH, S_DOOR);
      gw.process();
        if (lastTemperature[i] != temperature && temperature != -127.00) {
          gw.send(msgTemp.setSensor(i).set(temperature,1));
        // READ SWITCH STATUS
      // Get the update value
      int value = digitalRead(BUTTON_PIN);
      // Send in the new value
         gw.send(msgButton.set(value==HIGH ? 1 : 0));
      gw.sleep(BUTTON_PIN-2, CHANGE, SLEEP_TIME);
  • Hero Member
    I made a garagedoor node some time ago maybe you can find my post about it usefull.
    http://forum.micasaverde.com/index.php/topic,22334.0.html
    here is the current sketch I use.
    https://codebender.cc/sketch:44742
  • Awesome Kortoma,
    That is a very good start. Thanks for this.
    When I read through the sketch ( and what I understand from it), it is not possible to have the reed switches 1 "normal" and another one "inversed"? it is both switches have to act the same?
    Will it be difficult to add another switch to act as a "beam" to sense if the door is clear to close it?
    Can a temperature sensor be added?
    Thanks,
    Cor
  • I built this controller using the above code (plus atshasoft signing), and it works great when connected to computer's usb port, but doesn't work when connected to either a USB power adapter, a 12v input on the VIN pin, or 5V on the 5V pin. I'm not sure what could be the issue here. I'm using an arduino nano.
    EDIT:
    Ignore my stupidity. When you hook up the radio to the 5V instead of the 3.3v output only a PC has a low enough voltage for the (somehow not fried) radio to work. Connecting to the 3v3 works...
  • Contest Winner
    @jsondag said:
    somehow not fried
    lucky!
  • how about adding an ultrasonic sensor to tell if your car is IN the garage or not?
  • 8
  • 1
  • 90
  • 29
  • 1
