Consistent NACK + RPI Gateway
  • Hi all,
    Since I moved to RPI gateway (which I prefer), I've been having consistent NACK on some messages. I suspect it is related (but maybe not the cause) with some node reboots / battery drain.
    On one node, I always (and I ran multiple tests) NACK when sending the RSSI message, despite temperature and humidity never get NACK.
    I already tried sending RSSI before Temp and Hum, but it always get NACK.
    The MQTT server still receives the information.
    Any insight on why this is happening?
    Node debug log
    17:31:35.480 -> 32362 TSF:MSG:SEND,2-2-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=1,st=OK:24.00
    17:31:35.580 -> 32467 TSF:MSG:SEND,2-2-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:95.00
    17:31:37.836 -> 34721 !TSF:MSG:SEND,2-2-0-0,s=2,c=1,t=48,pt=2,l=2,sg=0,ft=0,st=NACK:-61
    Gateway log
    Jun 15 17:31:35 DEBUG TSF:MSG:READ,2-2-0,s=1,c=1,t=0,pt=7,l=5,sg=0:24.00
    Jun 15 17:31:35 DEBUG GWT:TPS:TOPIC=mygateway1-out/2/1/1/0/0,MSG SENT
    Jun 15 17:31:35 DEBUG TSF:MSG:READ,2-2-0,s=0,c=1,t=1,pt=7,l=5,sg=0:95.00
    Jun 15 17:31:35 DEBUG GWT:TPS:TOPIC=mygateway1-out/2/0/1/0/1,MSG SENT
    Jun 15 17:31:36 DEBUG TSF:MSG:READ,2-2-0,s=2,c=1,t=48,pt=2,l=2,sg=0:-61
    Jun 15 17:31:36 DEBUG TSF:MSG:ECHO REQ
    Jun 15 17:31:39 DEBUG !TSF:MSG:SEND,0-0-2-2,s=2,c=1,t=48,pt=2,l=2,sg=0,ft=0,st=NACK:-61
    Jun 15 17:31:39 DEBUG GWT:TPS:TOPIC=mygateway1-out/2/2/1/0/48,MSG SENT
    Node code
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    // Atualizar para nรณ esperado
    #define MY_NODE_ID 2
    // Novo driver para gateway RPI
    #define MY_RFM69_NEW_DRIVER
    //#define MY_RADIO_RF24
    #define MY_RADIO_RFM69
    //#define MY_RS485
    #define MY_RFM69_FREQUENCY RFM69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    // select the input pin for the battery sense point
    int BATTERY_SENSE_PIN = A0;
    int oldBatteryPcnt = 0;
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    static const uint64_t UPDATE_INTERVAL = 600000;
    static const uint8_t FORCE_UPDATE_N_READS = 5;
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_RSSI 2               //RSSI
    #define CHILD_ID_BAT 3               //BATTERY
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    int8_t rssiVal;               //RSSI
    char rssiStr[10];             //RSSI
    MyMessage msgRSSI(CHILD_ID_RSSI,V_CUSTOM);
    DHT dht;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      sendSketchInfo("Battery Meter", "1.0");
    ///  sendSketchInfo("DHT11-v05");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID_RSSI, S_CUSTOM);
      // Battery
        analogReference(INTERNAL1V1);
      #else
        analogReference(INTERNAL);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        send(msgTemp.set(temperature, 2));
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        send(msgHum.set(humidity, 2));
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
    //  rssiVal = _radio.readRSSI();  // Old Driver
      rssiVal = RFM69_getReceivingRSSI();  // New Driver
      send(msgRSSI.set(rssiVal), true);
      #ifdef MY_DEBUG
      Serial.print("RSSI: ");
      Serial.println(rssiVal);
      sleep(UPDATE_INTERVAL);
  • Mod
    @Oumuamua nice work on troubleshooting.
    The clear difference I see is that you request echo of the rssi message, but not for temp and hum.
    Could you try turning off the echo request and see if the NACK goes away? The behavior might give a clue to what the problem is.
  • Thanks for the hint @mfalkvidd
    After much research (mainly here and here), it does look like RFM69+RPI+Mysensors 2.3.x don't like each other very much.
    However, I updated my RPI code to the latest version (at RPI, move to MySensors directory, then "git pull", then make+install gateway again) and the NACK problem was completely solved. I also had many NACK during presentation, which all went away. Problem solved and it seems that the radio is performing faster (probably less time waiting ACK).
    I also tried to address the low RSSI at gateway (again, it seems a recurring problem for RFM69+RPI) using this code, but it didn't "make".
    Would you have any insight on the RSSI issue as well? It seems that you participated in some part of the discussion (here ๐Ÿ˜‰ ).
    Thanks!
  • Mod
    Sorry, I don't have any insights for the rssi issue.
  • Hi all,
    Should any one need, the fix mentioned in this page actually works.
    Thanks,
  • 24
  • 15
