  3. resend if st=fail
resend if st=fail
9 Posts 4 Posters 6.4k Views 1 Watching
  • n3roN Offline
    n3roN Offline
    n3ro
    Hello everybody,
    has anyone built a function that resend the signal, if "st=fail" is detected?
    I've already looked at the API and ACK. But have become not really smart of it.
    This would be great for some devices like relay, alarm, ....
    Best Regards,
    n3ro
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    AWIA 1 Reply Last reply
    • n3roN n3ro
      Hello everybody,
      Best Regards,
      n3ro
      AWIA Offline
      AWIA Offline
      AWI
      @n3ro you can use and catch the Ack value yourself and make sure the message arrives.
      n3roN 1 Reply Last reply
      • AWIA AWI
        n3roN Offline
        n3roN Offline
        n3ro
        @AWI do you have code example for me?
        • hekH Offline
          hekH Offline
          gw.send() returns false when no ack was received.
          • n3roN Offline
            n3roN Offline
            n3ro
            Hey :)
            I have just build this test function to resend a signal if failed.
            But i don't know how to execute the ge.send in the string ("// execute code").
            #define SENSOR_INFO "Test sensor"
            #define NODE_ID 200
            #define CHILD_ID 1
            #define OPEN 1
            #define CLOSE 0
              gw.begin(NULL, NODE_ID, false);
              gw.sendSketchInfo(SENSOR_INFO, "1.0");
              gw.present(CHILD_ID, S_DOOR);
              gwack("gw.send(msg.set(OPEN));");
              delay(500);
            void gwack(char code[])
              int repeat = 0;
              boolean sendOK = false;
              Serial.println(code); // string to execute
              while ((sendOK == false) or (repeat <= 10))
                if (code) // execute code
                  Serial.println("OK");
                  sendOK = true;
                else
                  Serial.println("NOT OK!!");
                  sendOK = false;
                repeat++;
            Any ideas? :)
            • R Offline
              R Offline
              rickmontana83
              That's not going to work the way you wrote it. That would require the Arduino to be able to compile code, which is asking a bit much of the little micro. :-)
              I would either do the retry-on-fail logic directly inline in your loop() function, or put the gw.send() call in gwack() and pass the msg value as a reference/pointer to gwack.
              • R rickmontana83
                n3roN Offline
                n3roN Offline
                n3ro
                What do you mean? :)
                Like this?
                //gw.send(msg.set(OPEN));
                  gwresend("msg.set","OPEN");
                  delay(500);
                void gwresend(char msgcode[],char option[])
                  int repeat = 0;
                    if (gw.send(msgcode(option)) // execute code
                      sendOK = true;
                    else
                      sendOK = false;
                    repeat++;
                (code is not working ;) )
                I'm very surprised that there is not already such a function.
                • R Offline
                  R Offline
                  rickmontana83
                  I'd be surprised if that even compiles. (Does it?)
                  I meant you should set up the message in loop, then pass the completed message to gwresend like:
                  msg.set(OPEN);
                  gwresend(msg);
                  The signature for gwresend will be something like:
                  void gwresend(MyMessage &msg)
                  The execute code line would then just be:
                  if (gw.send(msg)) { ...
                  Don't take this the wrong way, but this is more of a basic C++ language question. You might want to poke around on StackOverflow for examples to better understand the language (like the pass by reference that I suggested above, which, being from a C background, I've always found a bit scary.)
                  • n3roN Offline
                    n3roN Offline
                    n3ro
                    wrote on last edited by n3ro
                    Jeah now its working :)
                    #define NODE_ID 200
                    #define CHILD_ID 1
                    #define OPEN 1
                    #define CLOSE 0
                    int repeat = 0;
                    int repeatdelay = 0;
                      resend((msg.set(OPEN)), 5);
                    delay(500);
                    void resend(MyMessage &msg, int repeats)
                      int repeat = 1;
                      while ((sendOK == false) and (repeat < repeats)) {
                        if (gw.send(msg)) {
                          sendOK = true;
                        } else {
                          sendOK = false;
                          Serial.print("FEHLER ");
                          Serial.println(repeat);
                          repeatdelay += 250;
                        } repeat++; delay(repeatdelay);
                    113.2k
