  3. Wall mounted 'mood light'
23 Posts 10 Posters 20.5k Views 15 Watching
  • AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    (there is a sketch for MySensors v2 available)
    I received my 110v-230v AC to Mysensors PCB board last week en spent a few hours this weekend making 2 wall mounted mood lights.
    upload-12d13e93-9d8f-4244-b1a4-2e74d014587c
    I looks a little cheap from the backside but very luxurious on the wall ( < €20 total) and fully "MySensored".
    upload-cbbe7065-68b3-4108-b6c1-ebffc7cbdddb
    I did not use the relais on the board (and discarded some of the safety measures :blush: ). Very basic: a cut WS2812b strip, a few wires.
    Case is 12 mm MDF Board painted with Chalk paint (no primer needed, ready in half an hour ;-))
    Basic sketch with FastLED library (or Adafruit) with V_RBG.
    upload-1c215841-3f7f-4e6a-a856-f8d6f6435818
    upload-c7e90b81-b8b1-46b8-843d-b8c8007cd521 upload-1b906742-96fc-4b41-a24e-6fa302921d10
    • TheoLT
      TheoLT
      TheoL
      Love your project and good use of the wall mount PCB. You showed me that I really need to order a couple of those I'm tired of all the phone charger cables ;-)
      I couldn't really see it well on the photo's. But did you paint the back of light as well, the MDF part I mean? If not I would do it, because MDF has the tendency to bend when painted on one side only. That's why I use plywood or solid wood for almost all of my projects. Learned it the hard way, I made a cover for my radiator once out of MDF and painted only the outside. In just a day or two the cover started to bend. Which was really not funny after spending two weekends making it.
      If you decide to paint the back side as well I'd use a white paint, that reflects the light coming from the ledstrip better. Other colors tend to absorp the light more.
      I'm also really curious about how you mounted the MDF to the wall. It looks really great.
      AWIA 1 Reply Last reply
      • G
        G
        gloob
        Could you please post your Arduino sketch, as I want to build something similar?
        Thank you.
        • TheoLT TheoL
          AWIA
          AWIA
          AWI
          @TheoL Thank you for the tips. I painted the board on all sides. I would prefer real wood but MDF is really easy to model and I had a few sq meter left. I hate the dust though. For mounting i used a hook which fits in hole.
          upload-11a9a350-c01b-442e-b3a2-3e0c76805b15
          • G gloob
            Thank you.
            AWIA
            AWIA
            AWI
            @gloob I will post the sketch after cleaning it up. I need to add on/off/ scene button functionality.
            I allways try to make my nodes as autonomous as possible. That way i'm not fully controller dependent and it's more safe.
              mvdarend
              wrote on last edited by mvdarend
              @AWI said:
              ...and discarded some of the safety measures :blush:...
              I see you've got something soldered where the fuse should be, but for the rest I can't see what you've left out. Could you tell us which components you eventually ended up using? (or not using, whatever you prefer :))
              • M mvdarend
                AWIA
                AWIA
                AWI
                @mvdarend I have not used the SSR, the varistors and the fuse on the low voltage side...
                • AWIA
                  AWIA
                  AWI
                  I have updated the sketch to allow for independent operation and added a few light effects. The sketch can be used for any "Neopixel" (WS2812(B)) LED strip/ stick/ circle. Uses V_RBG and/ or V_STATUS and separate actuators (or the push button with long push) to switch the Pattern and Alarm. A few examples:
                  "Alarm"
                  https://www.youtube.com/watch?v=52YZD2pbYnQ
                  "Fireplace"
                  https://www.youtube.com/watch?v=-yx5zV5yQmo
                  "Candle light" and "Rainbow" mostly non blocking code. If somebody want to add please do so.
                  The sketch, heavily commented. Can always be improved
                   PROJECT: MySensors / RGB light NEOPIXEL
                   PROGRAMMER: AWI
                   DATE: october 10, 2015/ last update: october 14, 2015
                   FILE: AWI_RGB.ino
                   LICENSE: Public domain
                   Hardware: Nano and MySensors 1.5, Wall light 16 WS2812B leds (neopixel)
                   Special:
                  	uses Fastled library with NeoPixel (great & fast RBG/HSV universal library) 			https://github.com/FastLED/FastLED
                   SUMMARY:
                  	Different patterns and brightness settings
                  	Button switches on/off and cycles through all Color patterns on long press
                   Remarks:
                  	Fixed node-id
                  #include <FastLED.h>										// https://github.com/FastLED/FastLED
                  #include <Button.h>											// https://github.com/JChristensen/Button
                  const int stripPin = 5 ;									// pin where 2812 LED strip is connected
                  const int buttonPin = 4 ;									// push button
                  const int numPixel = 16 ;									// set to number of pixels (x top / y bottom)
                  const int NODE_ID = 62 ;									// fixed MySensors node id
                  const int RGB_LightChild = 0 ;								// Child Id's, standard light child on/off/ dim
                  const int RGB_RGBChild = 1 ;								// RGB light child (on/off/dim/color, if controller supports V_RBG))
                  const int RGB_SolidColorChild = 2 ;							// when set, node reads Color text from ColorTextChild
                  const int RGB_TextColorChild = 3 ;							// Holds Text value for color (custom colors from controller)
                  const int RGB_AlarmPatternChild = 4 ;						// Switches to alarm status
                  const int RGB_NextPatternChild = 5 ;						// Move to next pattern when set
                  CRGB leds[numPixel];
                  // Kelving colors: Light & daylight (in Fastled reference only)
                  /// 1900 Kelvin Candle=0xFF9329 /* 1900 K, 255, 147, 41 */,
                  /// 2600 Kelvin Tungsten40W=0xFFC58F /* 2600 K, 255, 197, 143 */,
                  /// 2850 Kelvin Tungsten100W=0xFFD6AA /* 2850 K, 255, 214, 170 */,
                  /// 3200 Kelvin	Halogen=0xFFF1E0 /* 3200 K, 255, 241, 224 */,
                  /// 5200 Kelvin CarbonArc=0xFFFAF4 /* 5200 K, 255, 250, 244 */,
                  /// 5400 Kelvin HighNoonSun=0xFFFFFB /* 5400 K, 255, 255, 251 */,
                  /// 6000 Kelvin DirectSunlight=0xFFFFFF /* 6000 K, 255, 255, 255 */,
                  /// 7000 Kelvin OvercastSky=0xC9E2FF /* 7000 K, 201, 226, 255 */,
                  /// 20000 Kelvin ClearBlueSky=0x409CFF /* 20000 K, 64, 156, 255 */
                  char controllerRGBvalue[] = "FFDEAD";		 				// Controller sent RGB value, default
                  uint16_t curBrightness, actualBrightness, controllerRGBbrightness = 0x7F ;	// Brightness globals
                  unsigned long updateBrightnessDelay, lastBrightnessUpdate ; // Brightness timers
                  int RGBonoff ;												// OnOff flag
                  enum { pSolid, pOff, pAlarm, pFire, pFire2, pCandle, pRainbow}  ;	// Pattern globals (stored in int for convenience)
                  const int lastPatternIdx = pRainbow + 1 ;					// use last pattern for patterncount
                  int curPattern ;											// current pattern
                  unsigned long updatePatternDelay, lastPatternUpdate ;		// Pattern timers
                  unsigned long idleTimer = millis() ;						// return to idle timer
                  int idleTime = 10000 ;										// return to idle after 10 secs
                  // initialize MySensors (MySensors 1.5 style)
                  MyTransportNRF24 transport(9, 10); 							// Ceech board, 3.3v (7,8)  (pin default 9,10)
                  MySensor gw(transport);
                  MyMessage lightRGBMsg(RGB_LightChild,  V_RGB);				// standard messages, light
                  MyMessage lightdimmerMsG(RGB_LightChild ,V_DIMMER);
                  MyMessage lightOnOffMessage(RGB_LightChild, V_STATUS);
                  Button myBtn(buttonPin, true, true, 20);					//Declare the button (pin, pull_up, invert, debounce_ms)
                  // Simple state machine for button state
                  enum {sIdle, sBrightness, sPattern} ;						 // simple state machine for button press
                  int State ;
                  	FastLED.addLeds<NEOPIXEL, stripPin >(leds, numPixel) ;	// initialize led strip .setCorrection(TypicalLEDStrip);
                  	gw.begin(incomingMessage, NODE_ID, false);				// initialize MySensors
                  	gw.sendSketchInfo("AWI RGB Wall 0", "1.0");
                  	gw.present(RGB_RGBChild, S_RGB_LIGHT, "RGB Wall RGB 0");// present to controller
                  	gw.present(RGB_LightChild, S_LIGHT, "RGB Wall Light 0");
                      gw.present(RGB_SolidColorChild, S_LIGHT, "RGB Set Solid color (text) 0");
                  	gw.present(RGB_TextColorChild, S_INFO, "RGB Wall textcolor 0");
                  	gw.present(RGB_AlarmPatternChild, S_BINARY, "RGB Wall Alarm 0");
                  	gw.present(RGB_NextPatternChild, S_BINARY, "RGB Wall Pattern 0");
                  	// initialize strip with color and show (strip expects long, so convert from String)
                  	for(int i = 0 ; i < 6 ; i++) {							// get color value from EEPROM (6 char)
                  		controllerRGBvalue[i] = gw.loadState(i) ;
                  	setLightPattern(pSolid, NULL) ;							// default controller Solid
                  	FastLED.show();
                  	State = sIdle ;											// Initial state
                  	//randomSeed(analogRead(0));
                  // read button and act accordingly
                  // short press: on/off
                  // longer press: set patterns with following short press
                  // long press: set brightness increase
                  	gw.process();											// wait for incoming messages
                  	myBtn.read();               							//Read the button (only read)
                  	unsigned long now = millis(); 							// loop timer reference
                  	switch (State) {
                  		case sIdle:											// default state, browse through patterns
                  			if (myBtn.wasReleased()){						// light on/ off in idle
                  				RGBonoff = !RGBonoff ;						// invert light state
                  				setLightPattern((RGBonoff == 1)?pOff:pSolid, 100);
                  				gw.send(lightOnOffMessage.set(RGBonoff));	// and update controller
                  			} else if (myBtn.pressedFor(500)){				// move to Pattern update state with long press
                  				idleTimer = now ;							// return to idle after ...
                  				State = sPattern ;
                  			break ;
                  		case sPattern:										// entered after long press
                  			if (myBtn.pressedFor(2000)){					// when press even longer move to Brightness update
                  				State = sBrightness ;
                  			} else if (myBtn.wasPressed()){
                  				setLightPattern((curPattern + 1) % lastPatternIdx, 500 ); // increase pattern and wrap
                  				idleTimer = now ;
                  			} else if ( now > idleTime + idleTimer  ){		// return to idle after ...
                  				State = sIdle ;
                  			break ;
                  		case sBrightness:									// entered after looong press
                  			if (myBtn.wasPressed()){							// if pressed again increase brightness
                  				setLightBrightness((curBrightness+1) % 0xFF, 0) ; // increase brightness and wrap (0..0xFF)
                  				idleTimer = now ;
                  				State = sIdle ;
                  			break ;
                  		default :
                  			State = sIdle ;
                  			break ;
                  	updateLightBrightness();								// update Brightness if time
                  	updateLightPattern();									// update Pattern if time
                  // Sets the light brightness, takes value and time (ms) as input
                  void setLightBrightness(int newBrightness, unsigned long updateTime){
                  	// global: curBrightness, actualBrightness, updateBrightnessDelay
                  	updateBrightnessDelay = updateTime / 0xFF ;				// delay = time / max steps
                  	actualBrightness = curBrightness ;						// assume curBrightness is actual
                  	curBrightness = newBrightness ;							// set curBrightness to new value, rest is done in update
                  // Update the light brightness if time
                  void updateLightBrightness(){
                  	// global: curBrightness, actualBrightness, updateBrightnessDelay, lastBrightnessUpdate ;
                  	unsigned long now = millis() ;
                  	if (now > lastBrightnessUpdate + updateBrightnessDelay){// check if time for update
                  		if ( actualBrightness > curBrightness) {
                  			FastLED.setBrightness( actualBrightness-- );
                  			FastLED.show();
                  		} else if ( actualBrightness < curBrightness){
                  			FastLED.setBrightness( actualBrightness++ );
                  			FastLED.show();
                  		lastBrightnessUpdate = now ;
                  // **** Pattern routines *****
                  // Sets and initializes the light pattern if nescessary
                  void setLightPattern( int newPattern, unsigned long updateDelay){
                  	// global: curPattern, updatePatternDelay
                  	curPattern = newPattern ;
                  	updatePatternDelay = updateDelay ;						// delay for next pattern update, can be changed in pattern
                  	switch(curPattern){
                  		case pSolid:										//  solid is controller value in all pixels
                  			for(int i = 0 ; i < numPixel ; i++) leds[i] = strtol( controllerRGBvalue, NULL, 16);
                  			FastLED.show();
                  			break ;
                  		case pOff:											//  off state all pixels off
                  			for(int i = 0 ; i < numPixel ; i++) leds[i] = 0 ;
                  			FastLED.show();
                  			break ;
                  		default :
                  			break ;
                  // Update the light pattern when time for it
                  void updateLightPattern(){
                  	// global: curPattern, updatePatternDelay, lastPatternUpdate
                  	if (now > lastPatternUpdate + updatePatternDelay){		// check if time for update
                  		switch (curPattern) {
                  			case pAlarm:									// flash light
                  				patternAlarm();
                  				break ;
                  			case pFire:										// wild fire
                  				patternFire();
                  				break ;
                  			case pFire2:									// cosy fire
                  				patternFire2();
                  				break ;
                  			case pCandle:									// flame
                  				patternCandle();
                  				break ;
                  			case pRainbow:									// rotating rainbow
                  				patternRainbow();
                  				break ;
                  			case pSolid:									// do nothing fall through
                  			case pOff:
                  			default	:										// def
                  				break ;
                  		lastPatternUpdate = now ;
                  // Define the different patterns
                  // Alarm - intermittent white and red color, full intensity, intermittent top & bottom half
                  void patternAlarm() {
                      static boolean topBot ;							// indicates direction for next entry
                  	const CRGB colorTop = CRGB(0xFF, 0, 0 );				// red color
                  	const CRGB colorBottom = CRGB(0xFF, 0xFF, 0xFF );		// white color
                  	FastLED.setBrightness(0xFF);							// set the strip brightness
                  	for(int i=0; i <= (numPixel / 2 - 1) ; i++) {					// for half of strip size
                  		leds[i] = topBot?colorTop:colorBottom ;
                  		leds[i+ (numPixel/2)] = topBot?colorBottom:colorTop ;
                  	topBot = !topBot ;										// switch direction
                  	FastLED.show();
                  // Simulate fire with red color, varying number of leds intensity & tempo
                  void patternFire() {
                      byte numberLeds = random(0,numPixel);					// start number and end of led's for flickering
                      byte lum = random(100,255);								// set brightness
                      CRGB color = CRGB(200, 50+random(1,180),0 );			// get red color with varying green
                      for(int i=0; i <= numberLeds; i++) {
                        leds[i] = color ;
                        FastLED.setBrightness(lum);							// set the strip brightness
                        FastLED.show();
                        gw.wait(random(0,10));
                      updatePatternDelay = 100 ;
                  // Simulate fire with red color and varying intensity & tempo
                  void patternFire2() {
                      CRGB color = CRGB(200, random(100,150),0);				// get red color with varying green
                      for (byte p=0; p < numPixel; p++) {
                        leds[p] = color;
                      FastLED.setBrightness(random(50,255));
                      FastLED.show();
                      updatePatternDelay = random(20,300);					// variable delay
                  // Simulate candle based on fire with red color, varying number of leds intensity & tempo
                  void patternCandle() {
                      byte lum = random(60, 80);								// set brightness
                      CRGB color = CRGB(200, 50+random(40,100),0 );			// get red color with varying green
                        leds[i] = color ;
                        FastLED.show();
                        gw.wait(random(5,10));
                  void patternRainbow() {
                  	static uint16_t hue ;								// starting color
                  	FastLED.clear();
                  	// for(hue=10; hue<255*3; hue++) {
                  	hue = (hue+1) % 0xFF ;									// incerease hue and wrap
                  	fill_rainbow( leds, numPixel , hue /*static hue value */, 5);// set a rainbow from hue to last in stepsize 5
                  	FastLED.show();
                  // Incoming messages from MySensors
                  	int ID = message.sensor;
                  	Serial.print("Sensor: ");
                  	Serial.println(ID);
                  	switch (ID){
                  		case RGB_LightChild:								// same behaviour as RGB child/ fall through
                  		case RGB_RGBChild:									// if controller can handle V_RGB
                  			if (message.type == V_RGB) {					// check for RGB type
                  				strcpy(controllerRGBvalue, message.getString());// get the payload
                  				setLightPattern(pSolid, NULL);				// and set solid pattern
                  			} else if (message.type == V_DIMMER) {			// if DIMMER type, adjust brightness
                  				controllerRGBbrightness = map(message.getLong(), 0, 100, 0, 255);
                  				setLightBrightness(controllerRGBbrightness, 2000) ;
                  			} else if (message.type == V_STATUS) {			// if on/off type, toggle brightness
                  				RGBonoff = message.getInt();
                  				setLightBrightness((RGBonoff == 1)?controllerRGBbrightness:0, 2000);
                  			break ;
                  		case RGB_SolidColorChild:							// request color from controller
                  			if (message.type == V_STATUS) {					// if get color from text child
                  				gw.request(RGB_TextColorChild, V_TEXT);
                  				setLightPattern(pSolid, NULL);					// and set solid pattern (if not alre)
                  			break ;
                  		case RGB_TextColorChild:							// Text color from controller
                  			if (message.type == V_TEXT) {					// if get color from text child
                  				for(int i = 0 ; i < 6 ; i++) {				// save color value to EEPROM (6 char)
                  					gw.saveState(i, controllerRGBvalue[i]) ;}// Save to EEPROM
                  			break ;
                  		case RGB_AlarmPatternChild:							// set Alarm pattern
                  				if (message.getInt() == 1){
                  					setLightPattern(pAlarm, 500);			// set slow alarm pattern
                  				} else {
                  					FastLED.setBrightness(curBrightness);
                  			break ;
                  		case RGB_NextPatternChild:							// next pattern
                  				if (message.getInt() == 1 ) {
                  			break ;
                      FastLED.show();
                  	dispRGBstat();
                  // debug
                  // display the status of all RGB: controller, requested, real
                  void dispRGBstat(void){
                      Serial.print(" Color: "); Serial.print(controllerRGBvalue);
                      Serial.print(" Brightness: "); Serial.println(controllerRGBbrightness);
                    mickaelr30
                    wrote on last edited by mickaelr30
                    hello,
                    i've problem with the sketch :+1 :
                    sketch_dec08a.ino: In function 'void setup()':
                    sketch_dec08a:89: error: 'S_INFO' was not declared in this scope
                    sketch_dec08a.ino: In function 'void incomingMessage(const MyMessage&)':
                    sketch_dec08a:308: error: 'V_TEXT' was not declared in this scope
                    sketch_dec08a:313: error: 'V_TEXT' was not declared in this scope
                    exit status 1
                      S_INFO inly exist in the dev branch.
                      That also means you have to convert the 1.5 sketch. Convert instructions here:
                      https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#
                      • A
                        A
                        Adam McCartney
                        @mickaelr30 , did you ever get this working with 1.5?
                        i've got the upgrade instructions, but struggling to reverse it so it works with my current setup. Don't think i'm quite ready to upgrade all my nodes to dev quite yet.
                        • A Adam McCartney
                          AWIA
                          AWIA
                          AWI
                          @Adam-McCartney add these lines in the header and you will have it working with the production version...
                          // V_TEXT & V_INFO when not using the DEVELOPMENT version
                          const byte V_TEXT = 47 ;					// values taken from development edition MyMessage.h
                          const byte S_INFO = 36 ;
                          • A
                            A
                            Adam McCartney
                            awesome, thanks!
                            I'm more of a butcher than a surgeon. I can quite happily take things apart, but fixing things usually goes right over my head!!
                              Mehdi HAMIDA
                              I really love this project.
                              May I can include it in all of my sensors (doorbell, thermostat, alarm,...).
                              Really sounds great, thanks
                                Mehdi HAMIDA
                                Is there a way to get your wiring schema ?
                                • M Mehdi HAMIDA
                                  AWIA
                                  AWIA
                                  AWI
                                  @Mehdi-HAMIDA There is nothing to it. A standard MySensors node (5v) with the strip connected to D5 and a button between ground and D4.
                                  M 1 Reply Last reply
                                  • AWIA AWI
                                    Mehdi HAMIDA
                                    @AWI OK, just ordered the PCB
                                    thx
                                      @AWI: Won't this part of your sketch create sort of an endless loop?
                                        AWIA
                                        AWIA
                                        AWI
                                        @mfalkvidd Good observation. Probably the the result of an 'efficient' copy/paste :flushed:
                                        The line
                                        I there with no reason, can be deleted...
                                        • Tore André RosanderT
                                          Tore André Rosander
                                          Im building the same light, but i use 12v LED strips controlled with mosfets. Is it possible to use the same scetch?
