  3. RFM69 temperature and how to check RFM69 is set to high power
9 Posts 2 Posters 5.4k Views 1 Watching
  • C Offline
    C Offline
    carlierd
    I am using RFM69HW and found how to use high power reading this post. I am now want to get the RFM69 temperature in my sketch and check if I am using high power mode.
    I found in the RFM69 library useful methods, but I don't know how to call them in my sketch ... I tried radio.readTemperature but it's not correct.
    Do you have an idea ?
    I am also interesting in getting the RSSI !
    Thanks,
    David.
    • H Offline
      H Offline
      wrote on last edited by hek
      Guess you would have to add something like this in your sketch:
      extern RFM69 _radio;
      And use use _radio.readTemperature()
      (in the development branch)
      In 1.5 the radio-object is a private member of the MySensors radio-driver class so you'd have to make it public to have access to it.
      C 1 Reply Last reply
      • H hek
        C Offline
        C Offline
        carlierd
        wrote on last edited by carlierd
        Thanks @hek !
        I modified the file "MyTransportRFM69.h" and moved RFM69 radio from private to public.
        I then added extern RFM69 _radio; in my sketch.
        And in the loop method, I also added _radio.readTemperature().
        But the compilation failed:
        SerialGateway.cpp.o: In function `loop':
        /Users/carlierd/SerialGateway.ino:130: undefined reference to `_radio'
        collect2: error: ld returned 1 exit status
        For the moment I prefer using the stable branch until I get something working.
        • H Offline
          H Offline
          You're mixing the two solutions.
          In 1.5 you would reach the public radio object by
          radio.radio.readTemperature()
          • C Offline
            C Offline
            carlierd
            Sorry @hek but it's still not clear for me ;)
            I am using 1.5, so I assume that I have to:
            • put radio as public in MyTransportRFM69.h
            • add radio.radio.readTemperature() in my sketch
            Thanks !
            • H Offline
              H Offline
              Yep, should work.
              • C Offline
                C Offline
                carlierd
                I got this error during compilation:
                SerialGateway.ino: In function 'void loop()':
                SerialGateway:128: error: 'radio' was not declared in this scope
                Any idea ?
                • H Offline
                  H Offline
                  transport.radio.getTemperature() then? O
                  • C Offline
                    C Offline
                    carlierd
                    It's perfect !! Thanks !
                    12.2k
