I can't find on google or on the forum how to make an esp8266 based gateway with a local relay connected report the state of the relay back to my controller(which is a vera, but that should't matter). Thanks for the help.
My current roller roller Shutter switch are two pushed buttons up and down. No stop button. When release the push button up or down, the shutter will stop. WIll it be compatible with this board or will i have to change the buttons ?
Sorry for the delay first of all, unfortunately I didn't get the notification of this thread If you are using a latching relay I'd recommend using SensorLatchingRelay1Pin or SensorLatchingRelay2Pins which should take better all the aspects of a latching relay. Then you can still use the safeguard for closing the door after a given timeframe. And yes you have to set a reporting interval even if not intuitive at all. This is because the safeguard is checked in the loop cycle which is called only if a reporting interval is set. So if you have a safeguard set to 1 minute, the report interval should be 1 minute or less. Thanks!
I have published all the documentation in a Github repository. If someone wants to make PCBs, I recommend that you wait a little longer until you receive my PCBs and try them.
https://github.com/giltesa/SmartHome
The send-function is used to send updates to the controller, in your case the physical-button-switch-change. Doing the send, does not control anything on the node itself.
Thanks for the reply. I am not looking to use an LCD, although that may be the best solution. For now, I plan on creating a simple set of LEDs and buttons.
I have looked over the code, and was wondering which part of the code is retrieving the status of a sensor? What if I have multiple motion sensors, how would I retrieve each unique value?
