  3. [SOLVED] Wifi gateway / motion sensor / value 1107296256 instead of tripped ?
16 Posts 4 Posters 5.4k Views 3 Watching
  • K
    K
    kr0815
    I changed a long existing motion sensor ( combined with DHT22) to send data to a newly installed WIFI-Gateway instead of the older LAN-Gateway
    I still get the right values for temperature and humidity, only the motion sensor sends ( or better the WIFI-Gateway receives)
    Any ideas ?
      Looks similar to this thread: http://forum.mysensors.org/topic/2737/2-channel-relais-with-2-buttons-sending-strange-values-for-on-off
      Haven't seen any solution yet though :(
      • N
        N
        netram
        I have the same problem with TRIPPED-messages and the Wifi gateway:
        http://forum.mysensors.org/topic/2878/messed-up-payload-from-binary-switch-sensor
          Please try the dev-branch gateway version and report back if the problem persist.
          • K
            K
            kr0815
            After long trying i managed to install the developer version.
            Now the gateway doesn´t receive any messages
            I see trough putty the comunication with FHEM, but no messages from the sensor laying next to the gateway
            The sensors definetly send, i see it on other wired gateway
            Are there any changes in the developer version regarding Channel / ID ?
              No it shouldn't be any changes in that regard.
              • K
                K
                kr0815
                That´s really strange, because 2 hours earlier, the gateway worked with the old version, only the problem of receiving numbers instead of v_tripped
                I´m using an NRF24L01 with external Antenna, i saw somewhere in the Code there are settings for TX-Power or similar ? Maybe that´s different in dev version ?
                Or any other ideas ?
                  Yes, you could try setting tx power to low. Add this before including MySensor.h in gateway.
                  #define MY_RF24_PA_LEVEL RF24_PA_MIN
                  Anything useful in the debug log?
                  • K
                    K
                    kr0815
                    You mean the output when connected with putty ?
                    There is nothing strange in it, i see the commands from my FHEM controller, but no errors
                    With the old version i saw also the messages from my sensor nodes
                    Is it possible to change debug level ?
                      Debug is enabled by default.
                      https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266/GatewayESP8266.ino#L72
                      You could perhaps have the gateway connected to your computer/Arduino IDE and open the serial monitor to see that sensor readings is picked up correctly.
                      • K
                        K
                        kr0815
                        Thats what i already did, that´s what i get after a diconnect / connect and then a inclusion-mode on / off in my controller software.
                        0;255;3;0;2;2.0.0-beta
                        0;255;3;0;5;1
                        0;255;3;0;5;0
                        But no messages from the sensors.
                        Should there be additional messages when in debug mode ?
                        So as there are no changes in Channel / ID, i see only the possibilities that i either damaged the NRF or that something is different with the Developer version
                        I´ll try to flash the old software again this evening
                        • K
                          K
                          kr0815
                          Got it working now, replaced the ampflified NRF with a regular one
                          Maybe i broke it, but can´t imagine how
                          In one of the many examples i found the following comment for myConfig.h:
                          #define RF24_PA_LEVEL_GW   RF24_PA_LOW  //Gateway PA Level, defaults to Sensor net PA Level.  Tune here if using an amplified nRF2401
                          Is there anything special about the amplified version ? Do they have like a register i have to switch on/ off ? or is it just an additional transistor and the antenna connection ?
                          N 1 Reply Last reply
                            It requires much more power. Do not feed it from the arduino directly. Especially if you turn up the transmit power level.
                            • K kr0815
                              N
                              N
                              netram
                              Now that you have the dev-branch WIFIgateway version up and running, did this solve the initial issue with the strange tripped-values?
                              • K
                                K
                                kr0815
                                Yes, the problem is solved now, no more strange values
                                • N
                                  N
                                  netram
                                  :thumbsup:
