  3. Serial gateway with several sensors connected to it
26 Posts 5 Posters 10.3k Views 5 Watching
  • S Offline
    skatun
    I am new to the mysensor enviroment, but I have been using arduino for a long time now.
    So I have a smarthome setup with openhab rpi connected to an arduino nano 328p on serial.
    Currently I have 3 sensors(not sure if you can rgb strip sensor though) connected to the nano (gateway) and another nano connected over software serial to the gateway(node 1). So currently I am not using RF at all.
    So I have taken baby step and written 4 independent sketches for my nano and tested them succsessfully, however I now need to integrate them into openhab and hence I turned to mysensor. I tried reading up on the API and tutorials: http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
    so below are my four independent codes:
    https://github.com/skatun/Openhab/blob/master/Bar3.ino
    https://github.com/skatun/Openhab/blob/master/power7.ino
    https://github.com/skatun/Openhab/blob/master/rgb.ino
    https://github.com/skatun/Openhab/blob/master/IRsend.ino
    So I need to rewrite the code to send out/read in the Serial API and this is where I am bit stuck.
    So currently my send method of the powerMeter looks like:
     Serial.print(power);
        Serial.print(' ');
        Serial.println(pulseCount * whPerPulse);  // watt hour elapsed
    but can I just rewrite this to:
    gw.send(power);
    the other 3 sketches does not send anything but just receives messages from my RPI.
    So can anyone point me in the right direction of how to modify my code to fit inside the mysensor enviroment, or is mysensor to much overhead for my setup that i rather should use a simpler approach?
    Any help and hint would be great:)
    • T Offline
      T Offline
      TimO
      Welcome to MySensors! ;-)
      There is no need to implement the serial API by yourself, just use the library.
      Start with this one: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerial/GatewaySerial.ino
      It is an example from the development branch, so you need the development library.
      If your node should be able to understand/receive MySensors implement the method "receive()":
      Have a look at: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/RelayActuator/RelayActuator.ino for an example on how to do that.
      Of course you need to strip the code from everything NRF related, because you won't need it, and will throw errors.
      S 1 Reply Last reply
      • T TimO
        skatun
        @TimO
        So I have made a sketch of my setup:
        I also started to modify the bar.ino code with the input from you:
        // Enable debug prints
        //#define MY_DEBUG
        #define CHILD_ID_SPRIT 0
        #define CHILD_ID_WINE 1
        #SLEEP_TIME 0
        //unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
        // constants won't change. They're used here to
        // set pin numbers:
        const int buttonPinSpritOpp = 9;     // the number of the pushbutton pin
        const int buttonPinSpritNed = 12;     // the number of the pushbutton pin
        const int buttonPinVinOpp = 10;     // the number of the pushbutton pin
        const int buttonPinVinNed = 11;     // the number of the pushbutton pin
        const int ledPinSpritOpp = 4;     // the number of the pushbutton pin
        const int ledPinSpritNed = 8;     // the number of the pushbutton pin
        const int ledPinVinOpp = 7;     // the number of the pushbutton pin
        const int ledPinVinNed = 3;     // the number of the pushbutton pin
        const int motorPinVin =  A3;      // the number of the motor pin
        const int motorPinOnVin =A1;
        const int motorPinOnSprit = A2;//
        const int motorPinSprit =  A0;      // the number of the motor pin
        int intCode =-1;
        MyMessage msgHum(CHILD_ID_SPRIT, V_STATUS);
        MyMessage msgTemp(CHILD_ID_WINE, V_STATUS);
          // initialize the motor pin as an output:
          pinMode(motorPinSprit, OUTPUT);
          pinMode(motorPinVin, OUTPUT);
          pinMode(motorPinOnSprit, OUTPUT);
          pinMode(motorPinOnVin, OUTPUT);
          // initialize the pushbutton pin as an input:
          pinMode(buttonPinSpritOpp, INPUT_PULLUP);
          pinMode(buttonPinSpritNed, INPUT_PULLUP);
          pinMode(buttonPinVinOpp, INPUT_PULLUP);
          pinMode(buttonPinVinNed, INPUT_PULLUP);
           // Default values
          digitalWrite(motorPinSprit,HIGH);
          digitalWrite(motorPinVin,HIGH);
          digitalWrite(motorPinOnSprit, HIGH);
          digitalWrite(motorPinOnVin, HIGH);
          sendSketchInfo("BAR", "1.0");
          present(CHILD_ID_SPRIT, S_BINARY);
          present(CHILD_ID_WINE, S_BINARY);
           if ((digitalRead(buttonPinSpritOpp) == HIGH && digitalRead(buttonPinSpritNed) == LOW) || intCode==1) {
            digitalWrite(motorPinSprit,LOW);
            digitalWrite(motorPinOnSprit,LOW);
            digitalWrite(ledPinSpritOpp,HIGH);
            digitalWrite(ledPinSpritNed,LOW);
            send(msg.set(0));
            #ifdef MY_DEBUG
            Serial.println("Sprit opp");
          else if ((digitalRead(buttonPinSpritOpp) == LOW && digitalRead(buttonPinSpritNed) == HIGH)|| intCode==2) {
            digitalWrite(ledPinSpritNed,HIGH);
            digitalWrite(ledPinSpritOpp,LOW);
            send(msg.set(1));
            #ifdef MY_DEBUG
            Serial.println("Sprit ned");
          else{
            digitalWrite(motorPinOnSprit,HIGH);
          if ((digitalRead(buttonPinVinOpp) == HIGH && digitalRead(buttonPinVinNed) == LOW) || intCode==3) {
            digitalWrite(motorPinOnVin,LOW);
            digitalWrite(motorPinVin,LOW);
            digitalWrite(ledPinVinOpp,HIGH);
            digitalWrite(ledPinVinNed,LOW);
            send(msg.set(0));
            #ifdef MY_DEBUG
            Serial.println("Vin opp");
          else if ((digitalRead(buttonPinVinOpp) == LOW && digitalRead(buttonPinVinNed) == HIGH)|| intCode==4) {
            digitalWrite(ledPinVinNed,HIGH);
            digitalWrite(ledPinVinOpp,LOW);
            send(msg.set(1));
            #ifdef MY_DEBUG
            Serial.println("Vin ned");
          else {
            digitalWrite(motorPinOnVin,HIGH);
          if (intCode==0){
            #ifdef MY_DEBUG
            Serial.println("Shutting off");
          sleep(SLEEP_TIME); //sleep a bit
          if (message.type==V_STATUS) {
             // Change relay state
             if message.sensor == CHILD_ID_SPRIT){
                 if message.getBool(){
                   intCode = 1;
                 else{
                   intCode = 2;
             if message.sensor == CHILD_ID_WINE){
                   intCode = 3;
                 else{
                   intCode = 4;
             // Store state in eeprom
             //saveState(message.sensor, message.getBool());
             // Write some debug info
             Serial.print(message.sensor);
        There are a few things unclear to me: How do I define the baudrate of the serial?
        Then its the actual sending to the gateway:
        send(msg.set(0));
        so how does this msg object work? I need two of these objects one for child node 1 and for child node 2 right?
        Then lets move to the RPI, This will then send out 1;2;3;0;2;1/n which then should send it to the gateway arduino which then parses this and send it out with baudrate 9600 on software serial on pin 11, which then will be received by the code above and the wine comes down.
        So how should my serial gateway sketch look like? And how do I get feedback from my node (rx pin 10 on due) back to RPI?
        Thanks for the tips so far:)
        A S 2 Replies Last reply
        • S skatun
          @TimO
          //#define MY_DEBUG
          #SLEEP_TIME 0
          // set pin numbers:
          int intCode =-1;
             // Default values
              send(msg.set(0));
              #ifdef MY_DEBUG
              send(msg.set(1));
              #ifdef MY_DEBUG
            else{
              send(msg.set(0));
              #ifdef MY_DEBUG
              send(msg.set(1));
              #ifdef MY_DEBUG
            else {
            if (intCode==0){
              #ifdef MY_DEBUG
                     intCode = 1;
                   else{
                     intCode = 2;
                     intCode = 3;
                   else{
                     intCode = 4;
          send(msg.set(0));
          A Offline
          A Offline
          AWI
          @skatun I don't now if I understand your question... but will give it a try. Basic setup
          1. The MySensors gateway should talk to your controller (OpenHab) making use of the Serial protocol. You can use an Rpi to host your controller.
          2. any sensors you want to connect the the MySensors network should talk via this gateway to you controller.
          3. The MySensors network was/is designed to communicate via Radio (nRF24L01 and others) between the nodes and gateway. Recently it has been made possible to use wired communication (RS485).
          4. Sensors will be connected to the nodes and communicate with the gateway. In the development edition of MySensors you can also connect the sensors directy to the gateway.
          So from there on...
          1. The baud rate of the (HW) serial is defined in the MySensors library (default 115200).
          2. You use the send message like "send(messageHum.set(humvalue))" to send values from the sensor to the gateway (which sends it to the controller)
          • S skatun
            @TimO
            //#define MY_DEBUG
            #SLEEP_TIME 0
            // set pin numbers:
            int intCode =-1;
               // Default values
                send(msg.set(0));
                #ifdef MY_DEBUG
                send(msg.set(1));
                #ifdef MY_DEBUG
              else{
                send(msg.set(0));
                #ifdef MY_DEBUG
                send(msg.set(1));
                #ifdef MY_DEBUG
              else {
              if (intCode==0){
                #ifdef MY_DEBUG
                       intCode = 1;
                     else{
                       intCode = 2;
                       intCode = 3;
                     else{
                       intCode = 4;
            send(msg.set(0));
            Its defined in MyConfig.h and is normal set to 115200.
            send(msg.set(0));
            You can read some more here: http://www.mysensors.org/download/sensor_api_15#the-full-api
            Also check out the examples to figure out how it works.
            Two childs can be coded like this for example:
            #define BARO_CHILD 0
            #define TEMP_CHILD 1
            MyMessage tempMsg(TEMP_CHILD, V_TEMP);
            MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
            MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
            gw.present(BARO_CHILD, S_BARO);
            gw.present(TEMP_CHILD, S_TEMP);
            gw.send(pressureMsg.set(pressure, 0));
            Edit, Sorry @AWI didnt see your post there :)
            • A AWI
              So from there on...
              skatun
              @AWI
              1: Yes it is, baudrate 115200
              2: OK
              3: I am using software serial at 9600(long cables) instead of 485 because then i dont need extra hardware.
              4: yes, LDR,6 rgb strip,IR sender,IR emitter are connected directly
              So from there on...
              1: How to modify the code to use software serial instead of radio/485?
              2:
              bar.ino should then have:
              MyMessage msgWine(CHILD_ID_SPRIT, V_STATUS);
              //and in the loop
              gw.send(msgWine.set(0));
                  #ifdef MY_DEBUG
              Now it will send that message out everytime the button is pressed, so I need to modify the code a bit to only send it out if it once every 12s(yes you need to hold the button for 12s to run the motor to the end.) I guess the best would be to rewrite the arduino code so that a single push on the button runs the motor for 12s instead of holding it in for 12s.
              Thanks for the help so far...
              A 1 Reply Last reply
              • S skatun
                @AWI
                2: OK
                So from there on...
                2:
                //and in the loop
                    #ifdef MY_DEBUG
                A Offline
                A Offline
                AWI
                @skatun I have never used a wired connection between two nodes but reading from the RS485 thread it sounds like this class is using the arduino HW serial implementation.
                Guess you will need to take a deep dive in the code to change this...
                • T Offline
                  T Offline
                  TimO
                  @skatun: Have a look at this example: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino
                  I don't think you have to change the code, just interconnect both Arduinos and keep in mind that PIN 2 is used by the library for DE-PIN management, which you don't need, but can't use for other things.
                  • T TimO
                    skatun
                    @TimO
                    From the link:
                    • Arduino Uno 9 8 10
                    Can I not use rx/tx on my node arduino? (Pin 0/1)
                    Same goes for my gateway, currently I am using pin 10/11. If I can fix this in software it would be better, then i dont have to resolder my setup, also what happens when you have two rs232 nodes connected to the gateway?
                    • T Offline
                      T Offline
                      TimO
                      In the example SoftSerial (a library) is used and not hardware serial (Pin 0/1).
                      The node could use hardware serial, if you disable debug and look into the thread about RS485. If I recall it correctly there is a hardware serial implementation but you have to implement it yourself, this is not covered by the library.
                      The GatewaySerialRS485 uses SoftSerial on the connection to the nodes and HardwareSerial on the connection to the controller.
                      Node <-- (SoftSerial) --> Gateway <-- (HardSerial) --> Controller
                      With RS485 you're able interconnect more than two devices and use DE_PIN before transmitting data. With RS232 you're limited to two devices or are in need of additional SoftSerial / HardSerial (and therefore additional PINs) depending on your hardware.
                      • T TimO
                        skatun
                        @TimO
                        I will look into it, however first I need to get the gateway up running.
                        So I am struggling to see how locally attached sensors work. I guess (reading several forum entry) that gw object is not needed. What is this inclusion mode? Is that part of the code needed?
                        However I can not get my code to compile:
                        // Enable serial gateway
                        #define MY_GATEWAY_SERIAL
                        // Flash leds on rx/tx/err
                        #define MY_LEDS_BLINKING_FEATURE
                        // Set blinking period
                        // Enable inclusion mode
                        #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                        #define PULSE_FACTOR 1000       // Nummber of blinks per KWH of your meeter
                        #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                        #define MAX_WATT 10000          // Max watt value to report. This filetrs outliers.
                        #define CHILD_ID 9              // Id of the sensor child
                        unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                        double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                        boolean pcReceived = false;
                        volatile unsigned long watt = 0;
                        unsigned long oldWatt = 0;
                        double oldKwh;
                        unsigned long lastSend;
                        MyMessage wattMsg(CHILD_ID,V_WATT);
                        MyMessage kwhMsg(CHILD_ID,V_KWH);
                            attachInterrupt(INTERRUPT, onPulse, RISING);
                            lastSend=millis();
                        void presentation() {
                            gw.present(CHILD_ID, S_POWER,"Energy Meter");
                          gw.process();
                          unsigned long now = millis();
                          bool sendTime = now - lastSend > SEND_FREQUENCY;
                          if (pcReceived && (SLEEP_MODE || sendTime)) {
                            // New watt value has been calculated
                            if (!SLEEP_MODE && watt != oldWatt) {
                              // Check that we dont get unresonable large watt value.
                              // could hapen when long wraps or false interrupt triggered
                              if (watt<((unsigned long)MAX_WATT)) {
                                gw.send(wattMsg.set(watt));  // Send watt value to gw
                              //Serial.print("Watt:");
                              //Serial.println(watt);
                              oldWatt = watt;
                            // Pulse cout has changed
                            if (pulseCount != oldPulseCount) {
                              //gw.send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                              double kwh = ((double)pulseCount/((double)PULSE_FACTOR));
                              oldPulseCount = pulseCount;
                              if (kwh != oldKwh) {
                                gw.send(kwhMsg.set(kwh, 4));  // Send kwh value to gw
                                oldKwh = kwh;
                            lastSend = now;
                          } else if (sendTime && !pcReceived) {
                            // No count received. Try requesting it again
                            request(CHILD_ID, V_VAR1);
                            lastSend=now;
                          if (SLEEP_MODE) {
                            sleep(SEND_FREQUENCY);
                          if (message.type==V_VAR1) {
                            //Serial.print("Received last pulse count from gw:");
                            //Serial.println(pulseCount);
                            pcReceived = true;
                        void onPulse()
                          if (!SLEEP_MODE) {
                            unsigned long interval = newBlink-lastBlink;
                            if (interval<10000L) { // Sometimes we get interrupt on RISING
                              return;
                            watt = (3600000000.0 /interval) / ppwh;
                            lastBlink = newBlink;
                          pulseCount++;
                        • S skatun
                          @TimO
                          double oldKwh;
                              lastSend=millis();
                            gw.process();
                                oldWatt = watt;
                                  oldKwh = kwh;
                              lastSend = now;
                              lastSend=now;
                            if (SLEEP_MODE) {
                              pcReceived = true;
                          void onPulse()
                            if (!SLEEP_MODE) {
                                return;
                            pulseCount++;
                          A Offline
                          A Offline
                          AWI
                          @skatun it looks like you are mixing the development version 2.0 and master branch 1.5 syntax. In development the "class" setup is removed and therefore for "gw." is not used anymore.
                          Most of the examples use the gw. Structure though. Look at the samples in the development branch as you will probably want/need the new functionality
                          • A AWI
                            skatun
                            @AWI
                            So I copied ower evrything in the library folder of the development branch. When i then try to compile the serial gateway i get this error:
                            Arduino: 1.6.7 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Serial, 115200, 4M (3M SPIFFS)"
                            In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\examples\SerialGateway\SerialGateway.ino:50:0:
                            C:\Program Files (x86)\Arduino\libraries\MySensors/MySensor.h:285:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                            In file included from C:\Program Files (x86)\Arduino\libraries\MySensors\examples\SerialGateway\SerialGateway.ino:52:0:
                            C:\Program Files (x86)\Arduino\libraries\PinChangeInt/PinChangeInt.h:103:19: fatal error: new.h: No such file or directory
                               #include <new.h>
                            compilation terminated.
                            exit status 1
                            Error compiling.
                              enabled in File > Preferences.
                            • S skatun
                              @AWI
                                 #include <new.h>
                              exit status 1
                              Error compiling.
                              A Offline
                              A Offline
                              AWI
                              @skatun It's hard to tell (for me ;-)) from the messages what is going wrong. Which Arduino are you programming for? Are you using the "GatewaySerial.ino" sketch from the development branch examples?
                              • A AWI
                                skatun
                                @AWI
                                I just copied all the files in libraries and hardware in the development zip into c:\program files\Arduino\
                                I am trying to get it to run on arduino due and yes I was trying the run the Serial gateway in Library\My Sensor\SerialGateway
                                • S skatun
                                  @AWI
                                  skatun
                                  @AWI How do I Install the development branch correctly? Does it only work with nano 328?
                                  • S Offline
                                    Hi @skatun did you check this http://www.mysensors.org/about/arduino#installing-the-sensor-libraries ? You install it the same way but download it from https://github.com/mysensors/Arduino (press Download ZIP) and make sure its Branch: Development.
                                    • S sundberg84
                                      skatun
                                      @sundberg84
                                      Well I tried to save it both here:
                                      C:\Program Files (x86)\Arduino\libraries\Mysensor
                                      C:\Program Files (x86)\Arduino\hardware\MySensors
                                      As well as here as described in your link:
                                      C:\Users\kim\Documents\Arduino
                                      But I get compile errors no matter where I try to compile serialgateway on due which I found in the C:\Program Files (x86)\Arduino\libraries\MySensors\examples\SerialGateway
                                      Cheers
                                      • S Offline
                                        @skatun having the files in multiple folders isnt a good idea.
                                        Maybe you should remove the IDE and all folders and start over?
                                        • S sundberg84
                                          skatun
                                          @sundberg84
                                          So the IDE by default get installed C:\Program Files (x86)\Arduino but the files folder get default set to this:
                                          I guess arduino made it that way so that you can load examples from C:\Program Files (x86)\Arduino then mess around with them and save them here C:\Users\kim\Documents\Arduino
                                          So I never had duplicate files, i tried both locations without sucsess. So which version of the IDE should I use? 1.6.7 is what I have now.
