  3. Newbie wants to do everything wired
17 Posts 7 Posters 2.6k Views 6 Watching
  • alowhumA
    alowhumA
    alowhum
    There's also a proposal to add PJON support: https://github.com/mysensors/MySensors/issues/1171
    As far as I can tell @tekka has even created some code to that effect. More no that here: https://github.com/mysensors/MySensors/pull/1278
    • F
      F
      feanor-anglin
      wrote on last edited by feanor-anglin
      If you are thinking about RS485 system, have a look at my hardware:
      https://www.openhardware.io/user/2098#view=projects
      If you like it, please feel free to contact me. We've made some significant progress, which is not published yet.
      C 1 Reply Last reply
      • F feanor-anglin
        C
        C
        cabat
        @feanor-anglin said in Newbie wants to do everything wired:
        I am also intresting in implementation of RS485 in my MySensors network, and i like yor hardware and use some of your ideas in my project Simple compact RS485 node (ATmega328 + MAX485) ,
        • T
          tweaker
          wrote on last edited by tweaker
          Thanks for the proposal.
          I have still one concern to use RS485:
          My topology would be star topology, but RS485 is not designed for that.
          Do someone have already experience with that?
          Will it work with a lower baudrathe around 19,2k?
          How big delay can I expect by using a motion detection sensor to switch on the lights?
          • T tweaker
            C
            C
            cabat
            @tweaker
            I'm also plan to use star topology, but still i build just one node :)
            Use 9600 baud rate, and i don't have delay on my experience on this day.
            • C cabat
              @tweaker
              tweaker
              @cabat : Thanks for sharing. When do you plan to connect more nodes? How long will be the cables?
              General Question: I saw as well the ESPhome.io which looks very nice for me. Is this something which can be combined with the mySensors protocol? I want to use NodeRed in the OrangePi Gateway to gather all the sensor values.
              • T tweaker
                C
                C
                cabat
                @tweaker said in Newbie wants to do everything wired:
                In fact now i have 2 nodes, but one of then only for testing purpose, sending temp every 15 seconds.
                The cable is about 10-15 meters.
                • T
                  tweaker
                  Do you have already more experience with more then 4-5 Sensors.
                  • T tweaker
                    C
                    C
                    cabat
                    wrote on last edited by cabat
                    @tweaker still not - not enough time to assemble additional nodes..
                    I have encountered problems that are still not clear to me when assembling the second board - it does not want to connect to the gateway.
                    I checked everything that is possible, but I haven’t found the reasons yet..
                    I will plan To assemble one more test node ..
                    • F
                      F
                      feanor-anglin
                      Star topology is not recommended to use with RS485, but it is not that it certainly won't work. You have to test it.
                      When it comes to experience, I have one with much more than 5 modules. It works pretty good, even if the modules are badly designed. To achieve top reliability though, you have to use well designed modules.
                      • F feanor-anglin
                        C
                        C
                        cabat
                        I know about it, but I hope that with a speed of 9600 and a small cable length it will work ..
