  3. 💬 Simple compact RS485 node (ATmega328 + MAX485)
20 Posts 4 Posters 2.8k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/692/Simple-compact-RS485-node-ATmega328-MAX485
    • C
      C
      cabat
      UPDATE: Tested in hardware now.
      • C
        C
        cabat
        Example of usage RS485 node: Light control module
        Light module
        Light module
        • C
          C
          cabat
          wrote on last edited by cabat
          Attention !!! Possible unstable work node with LP2950 LDO!
          I am don't understand yet, but one of the node don't work by powering of 12V using LP2950CZ-50 LDO.
          Temporary i am using AMS1117 on this node, and order HT7550-1 for testing.
          • F
            F
            fani625
            wrote on last edited by fani625
            Can you upload Pick And Place list and .brd file
            • dzjrD
              dzjrD
              dzjr
              wrote on last edited by dzjr
              it is also possible to order an assembled (RS-485) PCB, especially the SMD components.
              Please let me know!
              • C
                C
                cabat
                Soon a new revision of the board with the possibility of installing memory for OTA and fix some components footprints will be ready.
                dzjrD 1 Reply Last reply
                • C cabat
                  dzjrD
                  dzjrD
                  dzjr
                  @cabat then i will wait :)
                  C 1 Reply Last reply
                  • dzjrD dzjr
                    C
                    C
                    cabat
                    @dzjr I can upload new revision, but it still not tested in hardware, only ready to place order for PCB!
                    • C cabat
                      dzjrD
                      dzjrD
                      dzjr
                      @cabat
                      sorry I'm new to ordering PCBs hence maybe the stupid question ..
                      If I order the PCB do I get the separate PCB without SMD components?
                      or are the SMD components already on the PCB?
                      Soldering "normal" components is going to work, and I also have experience with it, but SMD components will be a new challenge, not that I don't want to, but I don't have the right stuff (yet).
                      • dzjrD dzjr
                        @cabat
                        C
                        C
                        cabat
                        @dzjr Ordering PCBs you will get only pcb, without components (no matter - SMD or TH). You may use PCB assebling service like JLCPCB or other, or you may solder SMD components yourself, it is not so hard, as you can think.
                        dzjrD 2 Replies Last reply
                        • C cabat
                          dzjrD
                          dzjrD
                          dzjr
                          @cabat Thanks,
                          i will give it a try!
                          • C cabat
                            dzjrD
                            dzjrD
                            dzjr
                            @cabat I have ordered four pcb's and the other components (resistors, capacitors, max485 and voltage regulator in china) and the ATmega at a german webshop.
                            do you have some advice for smd soldering?
                            • dzjrD dzjr
                              C
                              C
                              cabat
                              @dzjr I am using simple solder station like 936 with 900M-T-I iron tip, first solder the MCU and pin-headers, programm with USBASP using pads SCK, MISO, MOSI, RES, VCC ang GND, then solder other components (MAX485, resistors and capacitors).
                              • C cabat
                                dzjrD
                                dzjrD
                                dzjr
                                @cabat unfortunately i am still waiting for the pcb's so i could try it unfortunately ...
                                Still listed as "In Fabrication" hope it comes soon ...
                                in the meantime I have received all parts
                                C 2 Replies Last reply
                                • dzjrD dzjr
                                  C
                                  C
                                  cabat
                                  @dzjr I am ordered a new revision of this PCB at 2020.04.13, and the order status is "in fabrication" too, don't worry.
                                  • dzjrD dzjr
                                    C
                                    C
                                    cabat
                                    @dzjr This is terrible, but yesterday I received a message from PSBs.io that my order from 04/13/2020 is only sent ..
                                    • C cabat
                                      dzjrD
                                      dzjrD
                                      dzjr
                                      @cabat
                                      The PCB's i orderd are also send friday.
                                      So i hope is came this week!
                                      • C cabat
                                        dzjrD
                                        dzjrD
                                        dzjr
                                        @cabat The PCBs have been delivered !!
                                        only now the weather is very nice here, so I don't feel like hanging out in the workshop ...
                                        I'll let you know when I'm ready!
                                        • dzjrD dzjr
                                          C
                                          C
                                          cabat
                                          @dzjr Congrats! My works on hobby is not hard because of we have nice weather too :)
