  3. Wireless Peacefair PZEM-004T Energy Monitor on Audrino Web Server
7 Posts 5 Posters 16.6k Views 5 Watching
  • flywireF
    flywireF
    flywire
    I am a noob interested in a Peacefair PZEM-004T Energy Monitor but I can't find any good builds yet.
    The mypowermeter-v1-0 project seems to have died and I would really like to see some documentation on this Russian Power Meter. WiFi enabled Peacefair PZEM-004T EnergyMonitorWiFi enabled Peacefair PZEM-004T EnergyMonitor.
    There are also safety issues with the PZEM-004T module and I would like to connect multiple modules with a wifi link to an Audrino as a web server.
    Has anyone found anything along these lines?
    flywireF 1 Reply Last reply
    • flywireF flywire
      flywireF
      flywireF
      flywire
      • sinczeS
        sinczeS
        sincze
        MySensors Evangelist
        I received my unit today. Let's see if we can make the baby talk MySensors.
        • J
          J
          jaykumar
          Was anyone able to get this working with MySensor?
          Z 1 Reply Last reply
          • J jaykumar
            Z
            Z
            zampedro
            @jaykumar Yes,
            i built it a couple of years ago, but it's operative for about three months.
            I used :
            arduino mini pro 3.3v/8Mhz powered by a 3.7v 14500 Li-Ion battery
            NRF24L01
            PZEM-004T (modified to work at 3.3v)
            It's a simple watt/energy meter that sends data to the controller(domoticz) every 40 secs, the PZEM-004T does most of the work.
            K 1 Reply Last reply
            • Z zampedro
              @jaykumar Yes,
              I used :
              NRF24L01
              K
              K
              Karolis Kirna
              @zampedro Can you share the code and a picture of wiring?
              • K Karolis Kirna
                Z
                Z
                zampedro
                @Karolis-Kirna Just a bit late but here it is.
                arduino+nrf24l01+pzem_2.jpg pzem-004t_2a.jpgarduino mini 3.3v 8Mhz+NRF24L01.jpg meter_panel.jpg meter_log1.jpg
                The code:
                 * Send Watt and Kwh to gateway
                 * using PZEM-004t
                 * 26/8/2020  cambiato linea 45, 21-23
                /*++++++++++++++  Global Settings   +++++++++++++++++*/
                #define SN "PZEM Monitor"
                #define SV "0.4"
                #define MY_NODE_ID 9
                #define MY_PARENT_NODE_ID 11 // from domoticz log
                /*+++++++++++++  Local Settings  ++++++++++++++++++++*/
                #define SEND_ONLY_IF_CHANGED
                //#define DEBUG
                //#define TEST // Aggiunge codice di test da levare
                #if F_CPU == 8000000L
                #define MY_BAUD_RATE 9600
                #include <debugpaolo.h>
                //#include <SoftwareSerial.h> // Arduino IDE <1.6.6
                #include <PZEM004T.h>
                #define RX_PIN 4
                #define TX_PIN 5
                PZEM004T pzem(RX_PIN,TX_PIN);  // RX pin,TX pin
                IPAddress ip(192,168,1,1);
                #define CHILD_WATT_ID 0
                #define VOLTAGE_ID  1
                unsigned long lastSend=0;
                unsigned long SEND_FREQUENCY = 40000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                MyMessage wattMsg(CHILD_WATT_ID,V_WATT);
                MyMessage kWhMsg(CHILD_WATT_ID,V_KWH);
                //MyMessage kwhSaveMsg(CHILD_WATT_ID,V_VAR1);
                //MyMessage varMsg(CHILD_WATT_ID,V_VAR); // chi lo sa non va in domoticz
                double oldKwh=0.0;
                double oldwh=0.0;
                float oldwatt=0.0;
                #ifdef TEST
                  double whtest=0.0;
                #ifdef SEND_ONLY_IF_CHANGED
                  int kwh_counter;
                  #define KWH_COUNTER_MAX 33 //dopo 23 volte(15 min) invia comunque
                MyMessage msgVoltage(VOLTAGE_ID, V_VOLTAGE);
                float lastv=0;
                #define V_COUNTER_MAX 70
                int v_counter=0;
                int BATTERY_SENSE_PIN = A3;  // select the input pin for the battery sense point
                int oldBatteryPcnt = 0;
                #define MAX_BATTERY_CHECK    56  // 56*40 sec = 56 min circa
                int battery_check;
                #define VREF 1.106
                #define RBATT  5.73305  // ((1578+333.4)/333.4)?
                #define VFACTOR  RBATT*VREF/1023 //
                ++++++++++++++++   SETUP    +++++++++++++++++++++++++++++++++++++
                //  begin(incomingMessage);
                  analogReference(INTERNAL);
                  pzem.setAddress(ip);
                  battery_check = MAX_BATTERY_CHECK;
                ++++++++++++++++++   Presentation  ++++++++++++++++++++++++++++++
                void presentation()  {
                  sendSketchInfo(SN, SV);
                  present(CHILD_WATT_ID, S_POWER);
                  present(VOLTAGE_ID, S_MULTIMETER);
                +++++++++++++++++++++++++++++   Loop  +++++++++++++++++++++++++++
                   ++++    PZEM          section     +++++++++
                  float v = pzem.voltage(ip);
                  if (v < 0.5) {
                    delay(500);
                    // check v twice
                    if (v < 0.5 ) v = 0.0;
                  DEBUG_PRINT(v);DEBUG_PRINT("V; ");
                #ifdef DEBUG
                  float i = pzem.current(ip);
                  if(i >= 0.0){ DEBUG_PRINT(i);DEBUG_PRINT("A; "); }
                  float VA=v*i;
                  if(VA >= 0.0){ DEBUG_PRINT(VA);DEBUG_PRINTLN("VA; "); }
                 *------- Sezione potenza ----
                  float watt = pzem.power(ip);
                  #ifdef TEST
                    watt=kwh_counter*2;
                  DEBUG_PRINT(watt);DEBUG_PRINT("W ");DEBUG_PRINT(VA);DEBUG_PRINTLN("VA ");
                  if (watt <=0 ) {
                    DEBUG_PRINT(watt);DEBUG_PRINTLN("W. Sensore NC o assenza rete! ");
                    if ( oldwatt>0) {
                       watt =0;
                       send(wattMsg.set(watt,1));  // Send watt value to gw
                       oldwatt=0.0;
                  else {
                   if ( oldwatt==0.0) {
                    DEBUG_PRINT(watt);DEBUG_PRINTLN("Rete ritornata! ");
                    oldwatt = watt;
                   else {
                    DEBUG_PRINT(watt);DEBUG_PRINTLN("W; ");
                    float diffwatt=abs(watt-oldwatt);
                    if ( diffwatt >= 49.9 ) { // watt in aumento di 50watt
                        DEBUG_PRINT("Differenza ");DEBUG_PRINT(diffwatt);DEBUG_PRINTLN("W; ");
                        oldwatt = watt;
                    else {
                      float perc = 100.0*diffwatt/oldwatt; // oldwatt o watt?
                      DEBUG_PRINT("Perc ");DEBUG_PRINT(perc);DEBUG_PRINTLN("% ");
                      if ( perc >= 49.9 ) { // variazione del 50%
                        DEBUG_PRINT("Percentuale Diff ");DEBUG_PRINT(perc);DEBUG_PRINTLN("%; ");
                        oldwatt = watt;
                //        send(varMsg.set(watt,1));  // non va in domoticz
                      else {
                        if ( (perc >= 15.0) && (diffwatt>=8) ) {
                          DEBUG_PRINT("Diff ");DEBUG_PRINT(diffwatt);
                          DEBUG_PRINT("Perc ");DEBUG_PRINT(perc);DEBUG_PRINTLN("%; ");
                          oldwatt = watt;
                  //send(wattMsg.set(watt,1));  // Send watt value to gw
                 *------- Sezione energia ----
                  float wh = pzem.energy(ip);
                  #ifdef TEST
                    whtest+=10.0;
                    wh=whtest;
                  if(wh >= 0.0){ DEBUG_PRINT(wh);DEBUG_PRINT("Wh; "); }
                  else wh = 0.0;
                  DEBUG_PRINTLN();
                  if ( (kwh_counter==0) ||(abs(wh-oldwh) > 187) ) { // 100 wh
                  if ( wh > 0.0 ) {
                      double kwh = (double)wh/(double)1000.0;
                      send(kWhMsg.set(kwh, 3));  // Send kwh value to gw
                      oldwh=wh;
                      kwh_counter=0;
                  DEBUG_PRINT("kwh_counter=");
                  kwh_counter++;
                  DEBUG_PRINT(kwh_counter);DEBUG_PRINT(" ");
                  if (kwh_counter == KWH_COUNTER_MAX ) kwh_counter = 0;
                  DEBUG_PRINTLN();
                   ++++    Battery check section     +++++++++
                  if ( battery_check == MAX_BATTERY_CHECK) {
                    analogRead(BATTERY_SENSE_PIN); // needed for accuracy
                    DEBUG_PRINT("A0 Value = ");DEBUG_PRINTLN(sensorValue);
                    float batteryV  = sensorValue * VFACTOR;
                    // 100% 4.0v 0% 3.3v
                    int batteryPcnt = ( batteryV - 3.3) / (4.0 - 3.3) * 100;
                    batteryPcnt = (batteryPcnt > 100) ? 100 : batteryPcnt;
                    batteryPcnt = (batteryPcnt < 0) ? 0 : batteryPcnt;
                    DEBUG_PRINT("Battery Voltage: ");DEBUG_PRINT(batteryV);DEBUG_PRINTLN(" V");
                    DEBUG_PRINT("Battery Percent: ");DEBUG_PRINT(batteryPcnt);DEBUG_PRINTLN(" %");
                    //if (oldBatteryPcnt != batteryPcnt) {
                     oldBatteryPcnt = batteryPcnt;
                    battery_check=0;
                     battery_check++;
                     DEBUG_PRINT("Check = ");
                     DEBUG_PRINTLN(battery_check);
                   ++++    230 Voltage   section     +++++++++
                  float diffv= abs(v-lastv);
                  if ( ((v_counter == 0) || ( diffv > 3.50))  ) {
                    DEBUG_PRINT("v diff: ");DEBUG_PRINT(diffv);DEBUG_PRINTLN("V ");
                    if ( diffv > 3.50 ) v_counter = 0;
                    else v_counter++;
                    DEBUG_PRINT("v_counter : ");DEBUG_PRINTLN(v_counter);
                    send(msgVoltage.set(v, 1));
                    lastv = v;
                    v_counter++;
                    if (v_counter >= V_COUNTER_MAX ) v_counter = 0;
                  sleep(SEND_FREQUENCY);
                  delay(500); // ???
