  3. Security OTA Sketch
Security OTA Sketch
19 Posts 2 Posters 2.5k Views 2 Watching
  • AndurilA Anduril
    I have not yet enabled signing or encryption on the node that was running the personalizer with radio activated. Therefor I would expect it to give serial output mysensors started, find parent and so on. Nothing on the output after that security Execution result SUCCESS
    The gateway also has no security activated for now, as this node was the first one to test the personalizer with radio and OTA
    AnticimexA
    AnticimexA
    Anticimex
    @Anduril I believe the setup() function is hijacked by the personalizer so radio is not initialized properly, nor is the library.
    • AndurilA
      AndurilA
      Anduril
      that might be true... so it's kind of impossible I think to merge those.
      So I have to first upload the personalizer and directly after that the sketch with security enabled and OTA. Is the personalizer sketch the only way to find out its serial for whitelisting? Maybe I need this feature down the road so it's good to know how to get it later
      AnticimexA 1 Reply Last reply
      • AndurilA Anduril
        AnticimexA
        AnticimexA
        Anticimex
        @Anduril well, you can always rewrite the personalizer to not use a setup() function.
        • AndurilA
          AndurilA
          Anduril
          I think that's a little beyond my skills :-)
          • AndurilA
            AndurilA
            Anduril
            @Anticimex still the question: is there a way to find out a nodes whitelist serial later?
            • AndurilA Anduril
              AnticimexA
              AnticimexA
              Anticimex
              @Anduril that depend on your backend. For software signing the serial is stored in eeprom. For atsha204a it is only readable from the device itself.
              • AndurilA
                AndurilA
                Anduril
                that's sad.
                Maybe it would be possible to write a sketch to read out the atsha serial and transmit it via mysensors... I will be looking into this further when in need of whitelisting. Until then I will just leave it as it is and only use signing and maybe encryption.
                • AndurilA Anduril
                  that's sad.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @Anduril I'd prefer not as the serial is also considered a semi-secret to maintain the integrity of the security infrastructure. It should not be thrown around the network unprotected.
                  • AndurilA
                    AndurilA
                    Anduril
                    I understand that. Two questions:
                    what about updating via OTA with whitelisting enabled? Everyone could sniff the new hexfile and read the serial of the whitelisted node, correct?
                    what about activating encryption? Would that prevent both of these cases? No one could read the hexfile or the send serial without knowing the AES key before.
                    • AndurilA Anduril
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @Anduril if encrypted the data "cannot" be decoded. The serial is not stored in any firmware. The only exception being a personalizer sketch that will personalize for software signing.
                      For atsha204a based signing, serial is never stored in sketch, only in runtime.
                      • AndurilA
                        AndurilA
                        Anduril
                        Just in the rare case I want to use it later (and I have encryption enabled in the whole mysensors network) I could theoretically write a sketch inspired by the personalizer to read the serial and send this as a payload to the gateway without anyone out there able to read.
                        • AndurilA Anduril
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Anduril Well, its all opensource, so you are free to do whatever you want. Just remember that if you are starting to alter the behaviour and use of the security infrastructure, you could potentially compromise it for yourself and those that use your code.
