  3. 💬 NRF52832 1 channel control plate for in wall switch
5 Posts 3 Posters 661 Views 2 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/762/NRF52832-1-channel-control-plate-for-in-wall-switch
    • jeremushkaJ
      jeremushkaJ
      jeremushka
      Very nice project.
      Which kind of gateway do you use with this sensor?
      Have you built a specific one based on NRF52832?
      • mtiutiuM
        mtiutiuM
        mtiutiu
        @jeremushka
        It can be used in a MySensors network if desired. In my case it will be used as part of a Bluetooth mesh network.
        • jeremushkaJ
          jeremushkaJ
          jeremushka
          I got it. Do you use the same software that you built in the past for the livolo projects or you needed to adapt a new one for this full DIY no neutral wire project?
          mtiutiuM 1 Reply Last reply
          • jeremushkaJ jeremushka
            mtiutiuM
            mtiutiuM
            mtiutiu
            @jeremushka
            Same software can be used. The pin definitions need to be changed though.
