  3. Sensor board w/ liPo charger and fuel gauge +BMP180 +HTU21
37 Posts 10 Posters 27.0k Views 5 Watching
  • C ceech
    @AWI Which humidity sensor do you think would be more appropriate?
    I'll post a 3D picture with more detailed description of the current version of the board under its thread.
    AWIA
    AWIA
    AWI
    @ceech I realy like the HTU21 only worried about the price of the board...do you have an estimated price for the completed board?
    • AnticimexA Anticimex
      @ceech I am afraid not. I have just bought myself a pair of cells and that charger as a kickoff to investigate what power source I should use. I am also considering 9V cells and button cells. Solar power is not really available to me where I live at the moment so I have not consider that as a source yet I am afraid. Currently, I believe I am going for LiPo on the more "active" nodes (temp/humidity/motion) and a 9V cell for the more "passive" (soil/door/window). And I think I want to keep the charger off-board to keep the boards simple and see if I can get my theoretical sample based voltage measurement circuit to work independent of the source used.
      C
      C
      ceech
      @Anticimex You went all this way just to eliminate leaking? That is impressive. Are you going to implement this on your board or is this only a test? Did you also test the current leakage in voltage divider circuit connected all the time? What is the difference?
      AnticimexA 1 Reply Last reply
      • C ceech
        C
        C
        ceech
        @ceech I believe that the final price will be just below 20EUR.
        • C ceech
          AnticimexA
          AnticimexA
          Anticimex
          Well, it's not that complicated :)
          No, I have not made any comparisons whatsoever. But I am pretty confident it will be less leaky than a voltage divider. That I simply won't use because the higher resistance you use, the more noise you get, which will in the end translate into a meaningless measurement. But I have not made any real-world measurements for comparison, as this is so use-case dependent. Also for a voltage divider, the current draw is small, and depending on the nodes power consumption, that current may, or may not, be negligible.
          • bjornhallbergB
            bjornhallbergB
            bjornhallberg
            Why not just use ordinary Alkaline AA batteries? Cheap, available everywhere in any store, excellent self-discharge etc. Couple that with a suitable voltage regulator (boost/step-up) that can start as low as 0.6-0.7V and you should be good to go even with a single AA/AAA.
              AnticimexA
              AnticimexA
              Anticimex
              @bjornhallberg the impression I get on the forum from people doing that is that they get roughly one month of lifetime of a charge. To me that is simply not good enough. Not by a long shot.
                bjornhallbergB
                bjornhallbergB
                bjornhallberg
                @Anticimex I've run my sensors, including SR-501, DS18B20 and DHT22, on AA batteries for 4-6 months with little or no issues. And that is without a regulator. What happens eventually, with the DS18B20 for instance, is that the temp readings keep declining with the declining voltage. I'm actually very surprised that the SR-501 is still alive. The SR-501 sensor itself leaks like 50uA and I have a voltage divider to read the voltage (but I can't take the reading since the MQTT gateway doesn't seem to work). I read somewhere that that the SR-501 would produce massive false readings with the voltage drop but so far so good.
                With a proper regulator you should be good for 1-2 years.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @bjornhallberg Ok, well that sounds much more reasonable to me then :)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @ceech
                    Have you seen si7021? It's pin, and to a large extent software, compatible with htu21, but slightly cheaper at mouser
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @bjornhallberg Have you tried to compare regulated and non-regulated supply? It would be reasonable to assume you can get more out of the batteries if you can suck them down to 0.5-0.6V. But the step-up regulators are quite "leaky" so will that really translate to a longer runtime in the end? The regulator will be on even if the node is sleeping (and efficiency drops with current drop). So perhaps (depending on usage of course) a regulated supply will actually drain the batteries faster and the end result is that it causes shorter runtime even if more juice is pulled from the cells.
                      I have not yet set up a proper test environment for this myself.
                      I was considering having a regulator you could switch off. So that the Arduino itself runs unregulated but the sensors uses regulated power. Then you could turn off the regulator when sleeping. Like one of these.
                      A cool variant would be to have a regulator that turns itself on when battery voltage drops below a known safe level. The trick is to implement a power rail that can switch from unregulated to regulated supply. The switching can just be done with a comparator. But feedback between regulator output and input is a bad idea I suppose...
                      bjornhallbergB AWIA 2 Replies Last reply
                        bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        @Anticimex Sorry, I don't have any long time data to offer. So I also don't know if bothering with the SHDN / EN pins (where applicable) is actually worth it. Quiescent current is usually pretty low on some of the better regulators (like TPS61221, LTC3525 etc) so I wonder if it is worth tampering with?
                        I still think you will gain a few months of run-time using a regulator. Still, no big savings there. The main reason (for me at least) to explore regulators is to enable sensors that would otherwise malfunction as the voltage drops. I.e. most of the common sensor we use (DHT22, DS18B20, Motion). Particularly the DS18B20 has been spotty for me.
                        Another point is to be able to build really compact sensors that use only one AA/AAA. Not even the nrf24 / atmega would work at 1.5V (and dropping) after all.
                        Also, according to my latest calculations, a separate pcb with the TPS61221 will cost about $1.75 in materials. So, it wont break the bank.
                        I wish we could fast-track the entire project a bit and come up with a standard form factor like LowPowerLabs or Harizanov where we could make shields that just plug. Btw, did you see this on the topic of LiPo batteries:
                        http://lowpowerlab.com/blog/2015/02/03/chinese-lithium-cells-freezing/
                          AWIA
                          AWIA
                          AWI
                          wrote on last edited by AWI
                          @Anticimex Just thinking out loud. Looking at the schematics of the predecessor of this board. There is a mosfet circuit connected to D4. Couldn't you use this to power up an external. regulator or step-up? upload-fd7f3c2c-9061-4bb4-b31f-3e492c54bc29
                          • AWIA AWI
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @AWI yea, but the problem is not activating the regulator. That is a simple IO operation. The problem I think is the output of the regulator, if you want it to power the Arduino itself. And you probably do, since the Arduino packs up probably before your sensors. I need to study some more before I got a plan for that, but I also have a LOT of other things to do so don't expect me to provide the One Solution to it in the coming weeks ;)
                            AWIA 1 Reply Last reply
                              AWIA
                              AWIA
                              AWI
                              @Anticimex Switching the Arduino is probably not a good idea :) but powering up the voltage sensitive sensors with a mosfet switched step-up converter is an option?
                              • AWIA AWI
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @AWI yes, but why bother with a mosfet for enabling the regulator (if it already have an enable signal)?
                                • C
                                  C
                                  ceech
                                  wrote on last edited by ceech
                                  #22
                                  The main reason why I was dragged to the LTC4067 is the fact that it has so called Power path technology. It only uses the battery if there is no other available source of power. The benefit is much longer battery lifetime. It also has a proper 2A Lithium charger. Last but not least is the current monitoring, which can be translated into battery state of charge, which is another thing that interests me.
                                  I chose the voltage regulator for the fact that is fairly efficient and powerful even for ESP8266 modules and as simple as possible to implement. It only uses 35uA, which is as low as I ever saw. And the LTC4067 has Suspend mode that only uses a couple of uA as well.
                                  @tbowmo Prices for the HTU21 are lower, for me at least. And since the pinout is the same it is all for the better.
                                  I'll put some thought into the separate power options. The first thing that can be fairly simply done is to power the Atmega328 from the battery, and the sensors from the regulator.
                                  • C
                                    C
                                    ceech
                                    Which is more useful - an EEPROM or Flash memory chip?
                                    • AWIA
                                      AWIA
                                      AWI
                                      My vote is for flash memory, but no deal breaker
                                      • C
                                        C
                                        ceech
                                        #25
                                        Finally managed to put all things together and made the first two test boards. They look like this:
                                        Main new features are LTC4067 lithium battery charger and XC6210, a low consumption voltage regulator.
                                        The board comes with a Torex XC6210 3.3V voltage regulator . It has low power consumption of 35μA, while delivering at least 700mA. Voltage drop is 50mV @ 100mA.
                                        LTC4067 battery charger with Automatic Battery Charging/Load Switchover
                                        It provides power for the circuit and charges the backup single-cell lithium battery while greatly extends battery life. You can monitor the voltages and currents. It has suspend mode, which reduces current consumption to around 40μA. The power source is a small, 5V solar cell. Connections:
                                        analog input A1 on ATmega 328 is FAULT signal from LTC4067
                                        analog input A0 on ATmega328 is battery voltage
                                        analog input A2 is solar cell voltage
                                        analog input A6 is input current ( I=V/R x 1000 )
                                        analog input A7 is battery charge current ( I=V/R x 1000 )
                                        digital output A9 - drive it high to put LTC4067 in SUSPEND mode
                                        The two trimmer potentiometers are used to determine the current for both the input side - to better match the internal resistance of the solar cell - and for the battery charge current. At shipping they are both set to about 2.5kOhm, which set both currents to about 75mA. Please refer to technical data sheet of LTC4067 for more information. It is available here:
                                        Official web page for LTC4067
                                        Or, ask me.
                                        This is the back side of the board with place for BMP180, HTU21 and EEPROM chip:
                                        SparkmanS 1 Reply Last reply
                                        • L
                                          L
                                          lafleur
                                          It need an RFM69 radio on the board....??
                                          C 1 Reply Last reply
