  2. Announcements
  3. 💬 Building a Serial Gateway
52 Posts 21 Posters 32.9k Views 20 Watching
  • alowhumA alowhum
    @mfalkvidd Thanks. Would it be possible to generate that list somehow? Perhaps by listening to what nodes connect to it?
    It doesn't matter if they are offline or not, it doesn't have to be perfect.
    @alowhum yes. That's how a controller learns about the nodes :)
    • alowhumA
      alowhumA
      alowhum
      But could the gateway itself do it too? If so, do you have any suggestions on where I should start? How can I "hook into" the gateway to find out what devices are communicating with it? Is there example code of this?
      • alowhumA alowhum
        @alowhum yes you could build a controller into the gateway.
        The receive function will be called for each incoming message. You can react to the messages inside receive().
        • mfalkviddM
          These threads might be useful
          https://forum.mysensors.org/topic/1973/esp8266-as-wifi-gateway-controller-node
          https://forum.mysensors.org/topic/4528/esp8266-as-a-gateway-and-controller
          • alowhumA
            alowhumA
            alowhum
            Thanks!!
            • R
              R
              rodaman
              After 3 years of using RADIO_RF24 i replaced my all sensors with espeasy. It was just big battle with lost transmissions, disconnections, every day problems. Now for many days silence...Everything works.I still use mysensors in diferrent setup but NRF Radio is asking for trouble.
                maaaaaaaaaartin
                wrote on last edited by maaaaaaaaaartin
                #45
                I tried building a serial gateway using an Arduino Nano, but it never worked (both gateway and node start, but node keeps saying NO REPLY). I used the same NRF24 module directly on the Raspberry Pi, and built a Raspberry Pi gateway, it worked perfectly. Any idea on what might be going on? Thanks!
                • M maaaaaaaaaartin
                  @maaaaaaaaaartin most common problem is that the power source is not stable enough for the nrf24.
                  • A
                    APL2017
                    Can serial gateway be build on Atmel 168 chip instead of 328 in terms of memory? It compiles fine, but leaves little extra memory for variables.
                    • A APL2017
                      @APL2017 how much is left?
                      • A
                        APL2017
                        wrote on last edited by APL2017
                        #49
                        Sketch uses 13634 bytes (95%) of program storage space. Maximum is 14336 bytes. Global variables use 731 bytes (71%) of dynamic memory, leaving 293 bytes for local variables. Maximum is 1024 bytes.
                        I noticed parsing error in my controller log and switched to 328P. I bought 168P by mistake and wondering how I can use it. Does simple mySensors node require less ROM/RAM than gateway?
                        • A APL2017
                          @APL2017 a very simple node, yes. But a node using a sensor library can often need more flash and ram than a gateway. I have tried to fit things into the atmega168 (I also bought wrong devices) but gave up. Unless you think it is a fun and interesting challenge, it will not be worth the time.
                          A 1 Reply Last reply
                            APL2017
                            @mfalkvidd Thank you, I will donate 168P to some other Arduino enthusiast.
                              mariusl
                              Why would the gateway send a NACK to any node? The node only received one OK and then just NACK
                              17764 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                              22773 !TSM:FPAR:NO REPLY
                              22775 TSM:FPAR
                              29779 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=NACK:
                              34789 !TSM:FPAR:NO REPLY
                              34791 TSM:FPAR
