  3. cant add two relays in the Home assistant
3 Posts 3 Posters 545 Views 3 Watching
  • A
    alpha0101
    I need to add two basic relays to the home assistant with Mysensors .but unfortunately I can add only one relay please help me
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_REPEATER_FEATURE
    #define RELAY_PIN_1 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    void before()
        for (int sensor=1, pin=RELAY_PIN_1; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
            pinMode(pin, OUTPUT);
        sendSketchInfo("Relay", "1.0");
            present(sensor, S_BINARY);
        if (message.getType()==V_STATUS) {
            // Change relay state
            digitalWrite(message.getSensor()-1+RELAY_PIN_1, message.getBool()?RELAY_ON:RELAY_OFF);
            // Store state in eeprom
            saveState(message.getSensor(), message.getBool());
            Serial.print(message.getSensor());
    • Puneit ThukralP
      Puneit ThukralP
      Puneit Thukral
      Hello
      It could be a case of presentation being done too fast. Add a wait(50) like this
       // Present all relays to controller
        for (int sensor=CHILD_ID_RELAY, pin=RELAY_1; sensor<CHILD_ID_RELAY+NUMBER_OF_RELAYS;sensor++, pin++) {
          present(sensor, S_LIGHT);
           wait( 50 ); // <--- byTheo
      • electrikE
        electrikE
        electrik
        I believe you have to send a state also, to have it show up in home assistant.
        https://www.home-assistant.io/integrations/mysensors/
