  3. How to optimise a code (95% memory used)
7 Posts 4 Posters 1.0k Views 5 Watching
  • C
    C
    cwiekol
    i'm not a programmer almost at all, but i've managed to use some examples shared by a community to make a client that is receiveng from domoticz 3 variables (temperatures and status of one switch) and displaying it on 128x64px I2C v2 OLED display together with current time.
    Compilation and uploading of the sketch is being done correctly, however the following error is being displayed:
    Sketch uses 15906 bytes (51%) of program storage space. Maximum is 30720 bytes.
    Global variables use 1959 bytes (95%) of dynamic memory, leaving 89 bytes for local variables. Maximum is 2048 bytes.
    Low memory available, stability problems may occur.
    Invalid version '1.04' for library in: C:\Users\amc002c\Documents\Arduino\libraries\UIPEthernet
    The sketch usually is not working as should, but when i finally starts it is working correctly for even few hours. and then it is not refreshing values anymore, even though the clock is still working.
    I'm getting the following loop on DEBUG:
    Debug info - not possible to copy paste
    My first guess is that it is a memory issue. I've tried to optimise it by deleting splash screen from GFX library, but what else can i do? how to optimise further or what might be the other reason of such behaviour?
    Please support.
     * V_TEXT example with Domoticz (c) 2018 GizMoCuz
     * Note this is some quick code to demonstrate the workings
     * When the node has started and correctly been found by the controller,
     * you should have two new text sensors in Domoticz (if not, enable accept new hardware!)
     * Those two sensors have an IDX, for example 1063 and 1063
     * To update the first line call something line http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=1063&nvalue=0&svalue=Hello%20Line%201
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_NODE_ID 253
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #include <TimeLib.h>
    #define UV_SENSOR_ANALOG_PIN 0
    const byte LCD1_CHILD_ID = 8 ;         // LCD line 1
    const byte LCD2_CHILD_ID = 9 ;         // LCD line 2
    const byte LCD3_CHILD_ID = 7 ;         // LCD line 3
    char lastLCD1[7] = "Line1";   // define & init before first receive
    char lastLCD2[7] = "Line2";
    char lastLCD3[7] = "Line3";
    uint32_t ActTime = 0, DispTime=0;
    // timers for loop delays
    unsigned long lastUpdate=0, lastRequest=0;
    // Initialize messages for sensor network
    MyMessage textMsg(0, V_TEXT);
    #define OLED_RESET 4
    Adafruit_SSD1306 display(OLED_RESET);
    #define NUMFLAKES 10
    #define XPOS 0
    #define YPOS 1
    #define DELTAY 2
    #if (SSD1306_LCDHEIGHT != 64)
    #error("Height incorrect, please fix Adafruit_SSD1306.h!");
    void setup(void){
      // ** LCD display **
      Serial.begin(9600);
      display.clearDisplay();
      display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // 0x3C = 0x78 >> 1 (Arduino's )
      // init done
      display.display(); // show splashscreen
      delay(2000);
      display.clearDisplay();   // clears the screen and buffer
      // draw a single pixel
      display.drawPixel(20, 20, WHITE);
      display.println("script starting......");
      display.display();
      delay(2000);
      Serial.println("end setup");
      Serial.println("Sensor Started");
        sendSketchInfo("V_TEXT LCD Sensor", "1.1");
      Serial.println("presentantion");
      present(LCD1_CHILD_ID, S_INFO, "Text Line 1");
      present(LCD2_CHILD_ID, S_INFO, "Text Line 2");
      present(LCD3_CHILD_ID, S_INFO, "Text_Line_3");
      // Initializations
      requestTime();            // get the time from controller (handled by receiveTime)
      request(LCD1_CHILD_ID, V_TEXT, 0);           // request latest value from controller
      request(LCD2_CHILD_ID, V_TEXT, 0);          // request latest value from controller
      request(LCD3_CHILD_ID, V_TEXT, 0);          // request latest value from controller
      // timer for loop delays
      unsigned long now = millis();
    //  }// request time and latest value every 15 minutes from controller
      if (now-lastRequest > 15*60000)
        requestTime();
        lastRequest = now;
        Serial.println("request time from controler");
      // Update display every second
      if (now-lastUpdate > 1000) {
        LCD_local_display();
        lastUpdate = now;
    void receiveTime(uint32_t controllerTime)
      ActTime = controllerTime;
    void LCD_local_display()
      // take care of LCD display information
     char buf[20];
      DispTime=ActTime + (millis()-lastRequest)/1000;
      if (ActTime!=0) {
        // start with location & time on first line
        snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d-%04d", hour(DispTime), minute(DispTime), second(DispTime), day(DispTime), month(DispTime),year(DispTime));
       display.setTextSize(1);
       display.setTextColor(WHITE);
       display.setCursor(0,0);
       display.println("Termometry");
       display.setCursor(0,12);
       display.print("Dom: ");
       display.setTextSize(2);
       display.setCursor(50,12);
       display.println(lastLCD1);
       display.setCursor(0,32);
       display.print("Zewn: ");
       display.setCursor(0,42);
       display.print(lastLCD3);
       display.setCursor(50,32);
       display.println(lastLCD2);
       display.setCursor(0,55);
       display.println(buf);
       display.display();
      if (message.type!=V_TEXT) // Text messages only
        return;
      Serial.print("Message: ");
      Serial.print(", Message: ");
      if (message.sensor == LCD1_CHILD_ID ) {
        snprintf(lastLCD1, sizeof(lastLCD1), "%5s", message.getString());  // load text into LCD string
      else if (message.sensor == LCD2_CHILD_ID) {
        snprintf(lastLCD2, sizeof(lastLCD2), "%5s", message.getString());
      else if (message.sensor == LCD3_CHILD_ID) {
        snprintf(lastLCD3, sizeof(lastLCD3), "%5s", message.getString());
    • electrikE
      electrikE
      electrik
      A good start would be to move all the print strings to flash memory, and remove the debug prints as much as possible.
      To move strings, change:
      to:
      display.println(F("script starting......"));
      and do this for all prints. You should try not to exceed 70% memory usage.
      • mfalkviddM
        Here is how to disable the MySensors splash screen: https://www.mysensors.org/apidocs/group__SerialDebugGrpPub.html#gaf8039ebf2b71a3fd005ddd02b47721f3
        The next step would be to change the text strings to use the F macro. Guide: https://techexplorations.com/guides/arduino/programming/f-macro/ This works for all Serial.print and should also work for all display.print
        • C
          C
          cwiekol
          hello, i'm back and finally i can try to apply your advices. Thank you very much for them.
          I will come back later today with results. Hope that it will help.
          thanks.
          • C
            C
            cwiekol
            i've provide some changes and ended on 88%, however it is still not working.
            To find out what is going on, i've split code for the part related to mySensors and the one with LCD. I spot that there is something wrong with mySensors part.
            The code started two or three times and now it is not working at all.
            There is no prints on serial at all. The debug looks as below.
            Have no clue what is going on:(
            The code looks now as follow:
            #define MY_SERIAL_OUTPUT_SIZE (60u)
            void setup(void){
              Serial.println(F("Sensor Started"));
              Serial.println(F("presentantion"));
              // Initializations
                requestTime();
                lastRequest = now;
              //  Serial.println(F("request time from controler"));
                lastUpdate = now;
             char buf[20];
             // display.clearDisplay();
              DispTime=ActTime + (millis()-lastRequest)/10000;
              if (ActTime!=0) {
              Serial.println(buf);
              Serial.println(F("Dom: "));
              Serial.println(lastLCD1);
              Serial.println(lastLCD3);
              Serial.println(lastLCD2);
                return;
            and debug is repeating all the time like this:
            18:12:27.468 -> 0 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=16,REL=255,VER=2.3.2
            18:12:27.468 -> 4 TSM:INIT
            18:12:27.468 -> 5 TSF:WUR:MS=0
            18:12:27.468 -> 12 TSM:INIT:TSP OK
            18:12:27.468 -> 13 TSM:INIT:STATID=253
            18:12:27.468 -> 16 TSF:SID:OK,ID=253
            18:12:27.468 -> 17 TSM:FPAR
            18:12:29.274 -> 1832 ?TSF:MSG:SEND,253-253-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,f3840 !TSM:FPAR:NO REPLY
            18:12:31.292 -> 3842 TSM:FPAR
            18:12:33.098 -> 5657 ?TSF:MSG:SEND,253-253-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,f7664 !TSM:FPAR:NO REPLY
            18:12:35.115 -> 7666 TSM:FPAR
            18:12:36.923 -> 9482 ?TSF:MSG:SEND,253-253-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,f11489 !TSM:FPAR:NO REPLY
            18:12:38.938 -> 11491 TSM:FPAR
            18:12:40.746 -> 13307 ?TSF:MSG:SEND,253-253-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,f15315 !TSM:FPAR:FAIL
            18:12:42.762 -> 15318 TSM:FAIL:CNT=1
            18:12:42.762 -> 15320 TSM:FAIL:DIS
            18:12:42.762 -> 15322 TSF:TDI:TSL
            18:12:52.756 -> 25325 TSM:FAIL:RE-INIT
            18:12:52.756 -> 25327 TSM:INIT
            18:12:52.756 -> 25333 TSM:INIT:TSP OK
            18:12:52.756 -> 25335 TSM:INIT:STATID=253
            18:12:52.756 -> 25338 TSF:SID:OK,ID=253
            18:12:52.756 -> 25340 TSM:FPAR
            • C cwiekol
              void setup(void){
                // Initializations
                  requestTime();
                  lastRequest = now;
                  lastUpdate = now;
               char buf[20];
                if (ActTime!=0) {
                  return;
              Nice work @cwiekol !
              !TSM:FPAR:NO REPLY
              This means that the node is not able to reach the gateway? How far away is your gateway? Could you post the debug logs from your gateway?
              See also section #2:4 I only get Find parent in serial log for node at https://forum.mysensors.org/topic/666/read-this-first-it-could-save-you-a-lot-of-time/2
              • OldSurferDudeO
                OldSurferDudeO
                OldSurferDude
                I found that timelib.h uses a tremendous amount of memory. You avoid using it by getting time string from the controller.
                I have also found that when you're using that amount of memory that bad things happen, as you noted. I use global variables to avoid the transient nature of function variables.
                I'll be looking forward to other comments as, I, too, do not know all the tricks;)
                OSD
                12.5k
