  2. Announcements
  3. 💬 Building a wired RS485 sensor network
164 Posts 33 Posters 79.8k Views 35 Watching
  • R
    R
    rafal9318
    Hi all,
    I have a question about, How to use hardware serial on Arduino Uno (as a sensor) to communicate with gateway via RS485? I added #define MY_RS485_HWSERIAL Serial and it is only working when i turn on debugging (#define MY_DEBUG), how to use hardware serial without debugger ?
    • rejoe2R
      rejoe2R
      rejoe2
      @zrom69
      No real Problem in turning off debug output, at least in 2.3.1 this worked:
      //#define MY_DEBUG_LOCAL
      #define SN "Zwischenkeller"
      #define SV "0.2"
      // Enable RS485 transport layer
      #define MY_RS485
      // Define this to enables DE-pin management on defined pin
      #define MY_RS485_DE_PIN 2
      // Set RS485 baud rate to use
      #define MY_RS485_BAUD_RATE 19200 //57600 //38400 //9600
      #define MY_RS485_SOH_COUNT 1
      You may even swap around debugging output from hardware serial to software serial, see basic structure from this post in FHEM forum (german, but most is code).
      • R
        R
        rafal9318
        @rejoe2 Thank you. #define MY_SPLASH_SCREEN_DISABLED that was the missing line.
        Okey i understand now. Thank you again.
        • F
          F
          Flyer
          I am trying to build up a Mysensors with Wired ethernet to the gateway with W5100 and RS485 bewteen nodes, is there something that can help me with this configuration?
          Everything looks weel from the monitor serial but domoticz is not able to connect to the gateway!
          C 1 Reply Last reply
          • A
            ArduiSens
            @Flyer said in 💬 Building a wired RS485 sensor network:
            ng to build
            Hi Flyer, As far as I know this is not possible.
            MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
            • F Flyer
              C
              C
              cabat
              @Flyer Do you can ping the gateway on it IP?
              • A
                ArduiSens
                I see there is a possibility the combine Ethernet with RS485.
                Maybe you can check the setup as they did here:
                https://www.openhardware.io/view/649/RS485-Ethernet-Gateway#tabs-comments
                https://github.com/feanor-anglin/GetWired-Project/blob/master/GetWired Ethernet Gateway/Gateway.ino
                • G
                  G
                  gryzli133
                  You can also try using PJON - it has solved all the issues that I was facing with RS485 and other wired solutions (like all sensors on the Gateway). It will be released officially in MySensors 2.4.0, but you can test is already now (alpha):
                  https://github.com/tekka007/MySensors
                  You can read more here:
                  https://github.com/mysensors/MySensors/pull/1278
                  • G gryzli133
                    C
                    C
                    cabat
                    @gryzli133 I have a number of MySensors devices using RS485, it would be interesting to try to run PJON protocol over RS485, it seems like there is such an opportunity, but I could not figure out how to use it in the MySensors library.
                    • H
                      H
                      hypnosiss
                      yes, I am interested too as mysensors sometimes lost messages over rs485.
                      • H hypnosiss
                        C
                        C
                        cabat
                        @hypnosiss you may be interested in this https://forum.mysensors.org/topic/11814/rs485-transport-ack-support/6
                        H 1 Reply Last reply
                        • C cabat
                          H
                          H
                          hypnosiss
                          @cabat thank you. I have losts when number of messages are sent from HA to nodes(throught mqtt ethernet gateway) and in the same time nodes are sending messages to controller as well. I described issue on Home Assistant forum but without any response - https://community.home-assistant.io/t/lost-messages-sent-simultaneously/363904
                          • J
                            J
                            JeeLet
                            yes it's not easy, the loss of package is a difficult thing to
                            to counter, but not entirely.
                            and the multiple layers of a computer system do not help :)
                            some philosophy on collision avoidance
                            https://arduino.stackexchange.com/questions/24523/rs485-multimaster-communication-with-collision-avoidance
                            don't mix the Protocol (data encapsulation)
                            and the physical support (voltage frequency impendance / star or serial bus)
                            the ModBus protocol on a RS485 support
                            https://www.electroniclinic.com/arduino-modbus-rs485-arduino-rs485-master-and-slave/
                            a different explanation https://www.codrey.com/learn/rs-485-arduino-quick-primer/
                            for information
                            https://github.com/sonyarouje/Arduino_HardwareSerial_RS485
                            But the best solution (reliability and especially lightness of the sketch) is the CAN bus :)
                            I may have said some stupid things ;)
                            Translated with www.DeepL.com/Translator (free version)
                            • J
                              J
                              JeeLet
                              wrote on last edited by JeeLet
                              #163
                              a line of the examples given in the sketches for the use of RS485 can be a source of problem
                              (it's my case, I use Pin2 or3 for a long time :( )
                              (2 or 3 is an interrupt pin for a Uno)
                              avoided interrupt pins.
                              the pin 10 is a good thing :)
                              • H
                                H
                                hypnosiss
                                Thank you @JeeLet !
                                I've been struggling with missing msgs for years with my Arduino Mega
                                I changed pin and no issues! :D
                                In the pjon code I've reached to list of tested pins that communication works properly
                                https://github.com/gioblu/PJON/blob/38e36bb1228c1690143cfbf693a0bcb809514d6c/src/strategies/OverSampling/README.md?plain=1#L12
