  2. Announcements
  3. 💬 Building a MQTT Gateway
81 Posts 30 Posters 50.0k Views 28 Watching
  • L linkinpio
    I'm new here so sorry if this is not the right place for this question.
    But I am trying to build Arduino MQTT GW to act as a relay/light controller and report/interact with HomeAssistant.
    I think I have worked out most of my problems and got it running as I wanted to, but I was testing failover senarios as the controller should be able to work independently of any other device as long it has power.
    My config is kind of simple Arduino Mega with W5500 Ethernet module configured as MQTT GW
    And the problem is that when network or HA/MQTT broker is unavailable when Arduino is restarted/booting it tries to reconnect to MQTT broker constantly and interupts the main loop everytime for around 3s which makes board basically unresponsive.
    00:45:07.094 -> 549536 !GWT:RMQ:FAIL
    00:45:07.094 -> Loop count = 179
    00:45:07.094 -> 549538 GWT:TPC:IP=192.168.11.111
    00:45:08.107 -> 550542 GWT:RMQ:CONNECTING...
    00:45:10.130 -> 552547 !GWT:RMQ:FAIL
    00:45:10.130 -> Loop count = 180
    00:45:10.130 -> 552550 GWT:TPC:IP=192.168.11.111
    Any ideas how I could disable reconnect function if that happens for example after 3 attempts? So the controller can work normally even if there is no connection to MQTT broker?
    electrikE
    electrikE
    electrik
    @linkinpio in the pubsubclient library, you can change the timeout on connecting to the mqtt broker. Default it is 15s, reducing it to e.g. 2s will increase the availability of the main loop.
    L 1 Reply Last reply
      @linkinpio
      I don't have a solution, but I, too, may run into that problem. So I'm curious how it can be resolved.
      Perhaps post in the Hardware or Development sections. Fortunately, some really knowledgeable people (eg. @mfalkvidd and @NeverDie ) monitor pretty much all of the forum subjects.
      OSD
      #72
      @OldSurferDude yes I have read it already. But unfortunately my impression is that my knowledge of how the code works is woefully insufficient.
      • electrikE electrik
        L
        L
        linkinpio
        @electrik thank you for your suggestion, but are you talking about MQTT_SOCKET_TIMEOUT ?
        If yes I did set this to 1s
        #define MQTT_SOCKET_TIMEOUT 1
        and did not change a thing
        21:32:05.081 -> Loop count = 153
        21:32:05.081 -> 471258 GWT:TPC:IP=192.168.11.111
        21:32:06.098 -> 472262 GWT:RMQ:CONNECTING...
        21:32:08.071 -> 474266 !GWT:RMQ:FAIL
        21:32:08.071 -> Loop count = 154
        If not please do let me know what you had in mind so I can check it out.
        @OldSurferDude thanks for confirming that I have not missed anything when doing a resarch on this matter, if there will be no new suggestions I think I might have to post it to Development as dont see anyone suggesting any good workaround or a solution.
        • electrikE
          electrikE
          electrik
          No, you're right, it doesn't solve your issue. It does increase the availability of the main loop though.
            L
            L
            linkinpio
            @electrik
            Have you tested this in your enviroment/sketch?
            Did it increase availability for your sketch?
            If yes what was the single loop time before and after changing this?
            I did test is on my example and it does not increase the availability for the main loop for my sketch, also you can see the printout from the serial monitor, the loop is run in the same 3s intervals like before, so maybe I am doing something wrong?
            • electrikE
              electrikE
              electrik
              Yes, that's what I meant. But the value seems to be 2 seconds in your log. Where have you placed the define?
              You can also use
              setSocketTimeout(1)
              On the pubsubclient object.
                You can also use
                setSocketTimeout(1)
                L
                L
                linkinpio
                @electrik I've put the
                in the beginning where all other #defined constants are and it does not seeams to take this config.
                I tried to use
                setSocketTimeout(1)
                but I can't seems to get the sketch to work with <PubSubClient.h>
                I've added
                EthernetClient ethClient;
                PubSubClient client(ethClient);
                client.setSocketTimeout(1);
                but getting following error.
                GatewayW5x00MQTTClient.ino:172:1: error: 'client' does not name a type
                exit status 1
                Compilation error: 'client' does not name a type
                any ideas?
                • electrikE
                  electrikE
                  electrik
                  @linkinpio said in 💬 Building a MQTT Gateway:
                  That is the right syntax, but you have to move the line in setup()
                    L
                    L
                    linkinpio
                    @electrik
                    tried it but also no luck
                    C:\Users\p.\Documents\Arduino\GatewayW5x00MQTTClient\GatewayW5x00MQTTClient.ino: In function 'void setup()':
                    C:\Users\p.\Documents\Arduino\GatewayW5x00MQTTClient\GatewayW5x00MQTTClient.ino:213:10: error: 'class PubSubClient' has no member named 'setSocketTimeout'
                    exit status 1
                    Compilation error: 'class PubSubClient' has no member named 'setSocketTimeout'```
                    • electrikE
                      electrikE
                      electrik
                      This looks like you're not using the latest (development) version of the mysensors library. That has the latest pubsubclient library included.
                      Looking at the intervals between the errors again, I'm doubtful if it will make a big difference though. The mysensors library will need to be modified to fulfill your request I guess
                      • L
                        L
                        linkinpio
                        I think I'm ussing the latest one
                        but as you said I don't think it will fix my issue though.
                        But looking at the examples I found that they have a connect function which then can be used to reconnect whenever needed not constantly like it happens now,
                        But not sure how I could integrate that functionality in this sketch though, as I'm not that experienced with programming :/
                        To you think it will be possible?
                         Reconnecting MQTT example - non-blocking
                         This sketch demonstrates how to keep the client connected
                         using a non-blocking reconnect function. If the client loses
                         its connection, it attempts to reconnect every 5 seconds
                         without blocking the main loop.
                        #include <Ethernet.h>
                        #include <PubSubClient.h>
                        // Update these with values suitable for your hardware/network.
                        byte mac[]    = {  0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
                        IPAddress ip(172, 16, 0, 100);
                        IPAddress server(172, 16, 0, 2);
                        void callback(char* topic, byte* payload, unsigned int length) {
                          // handle message arrived
                        long lastReconnectAttempt = 0;
                        boolean reconnect() {
                          if (client.connect("arduinoClient")) {
                            // Once connected, publish an announcement...
                            client.publish("outTopic","hello world");
                            // ... and resubscribe
                            client.subscribe("inTopic");
                          return client.connected();
                          client.setServer(server, 1883);
                          client.setCallback(callback);
                          Ethernet.begin(mac, ip);
                          delay(1500);
                          if (!client.connected()) {
                            long now = millis();
                            if (now - lastReconnectAttempt > 5000) {
                              lastReconnectAttempt = now;
                              // Attempt to reconnect
                              if (reconnect()) {
                            // Client connected
                            client.loop();
