  3. MQTT Broker Gateway with ruby-mqtt
6 Posts 2 Posters 5.6k Views 1 Watching
  • M Offline
    M Offline
    mainali
    I am trying to write a ruby on rails app for controlling my house. I am using MQTT gateway from mysensor. I am able to send message using the ruby-mqtt (mqtt gem) and actuate a relay.
    The issue is I get 24 as return value for any message that I pass to the gateway. What is this '24' return value exactly. Please HELP
    • M mainali
      M Offline
      M Offline
      marceloaqno
      Code Contributor
      @mainali Could you show us some of your app code?
      • M Offline
        M Offline
        mainali
        The following is the code I am using.
        1. I am running the mqtt gateway code in an arduino with ethernet shield taken from mysensor library.(Only changes was to enable soft SPI)
        2. Using ruby gem mqtt from ruby-mqtt.
        3. Then I am creating a client as per the documentation.
          client = MQTT::Client.connect('192.168.1.234'). My Gateway is running at the given IP.
        4. Then following the gateway code example 'broker_prefix/node_id/sensor_id/sensor_type', message
        I am sending client.publish('MyMQTT/20/1/V_LIGHT', 1) which is actuating my relay. Everything fine till here
        but the issue is I get 24 as the return value when client.publish('MyMQTT/20/1/V_LIGHT', 1) is executed. The same value comes for any sensor_id or node_id.
        Is 24, which is returned is the default value for acknowledgement ? I was not able to find code which supports my assumption.
        • M mainali
          M Offline
          M Offline
          marceloaqno
          Code Contributor
          @mainali I am almost certain that 24 is the number of bytes ruby-mqtt sent to the gateway.
          • M Offline
            M Offline
            mainali
            MyMQTT/20/1/V_LIGHT.bytes returns me 19, If I add 1 also in the message I get 20. I don't know how it is arriving at number 24.
            • M mainali
              M Offline
              M Offline
              marceloaqno
              Code Contributor
              http://public.dhe.ibm.com/software/dw/webservices/ws-mqtt/mqtt-v3r1.html#publish
