  3. MYSBootloader 1.3 pre-release & MYSController 1.0.0beta
otamyscontrollermysbootloader
198 Posts 53 Posters 121.3k Views 58 Watching
  • Alan SalesA
    Alan SalesA
    Alan Sales
    Hi! Where can I download MYSBootloader 1.3 pre-release & MYSController 1.0.0beta? The given link is not working.
    F 1 Reply Last reply
    • Alan SalesA Alan Sales
      F
      F
      feanor-anglin
      @Alan-Sales it seems the project is abandoned. But I have it, so please use this link:
      https://www.dropbox.com/s/b0qls8a251ol4tc/MYSController.zip?dl=0
      @tekka maybe you could share the code somewhere? Maybe someone else could make a use of it or develop it further?
      • I
        I
        iguaan
        Anyone else experiencing crashing of the application after about 10seconds?
        • I iguaan
          tplet
          @iguaan The same applies to me. The application crashes after a few seconds after launching (Windows 10). No problem before on the same system, so I suspect a Windows update but I don't know which one.
            Mac65
            Hi all,
            I think I have found the problem, the program at startup makes a connection (probably to look for an update) to the following address 162.55.0.134 (port 80) but it fails, this blocks the program for several minutes, unfortunately without the sources it is not possible solve the problem.
            BR
            Angelo
            N 1 Reply Last reply
            • I
              I
              iguaan
              wrote on last edited by iguaan
              #190
              There's another somewhat way around:
              you just need to open prog and then close when it gets stuck and then clik try to restore or wait button few times:
              https://pasteboard.co/GQTHDnaQsawY.png
              then you should get this screen at some point and then press ok/ignore and it works
              (https://pasteboard.co/9iuz1LC7kgWC.png
              needs several tries.
              • N
                N
                nfj25
                MYSController is crashing me too... Are there any alternatives to update the firmware of mysensors nodes?
                • M Mac65
                  Hi all,
                  BR
                  Angelo
                  N
                  N
                  nfj25
                  @Mac65 Good catch! I blocked MYSController from acessing the network in the Windows Firewall and... it works! Only block TCP port 80 if you are connecting to a MySensors TCP gateway.
                  I 1 Reply Last reply
                  • N nfj25
                    I
                    I
                    iguaan
                    @nfj25 said in MYSBootloader 1.3 pre-release & MYSController 1.0.0beta:
                    Can't get it working that way, even if i block all the traffic on Myscontroller.
                    • I iguaan
                      I
                      I
                      iguaan
                      @iguaan said in MYSBootloader 1.3 pre-release & MYSController 1.0.0beta:
                      Got it working, I have program on onedrive and seemed that automatically generated path in rules didn't work:
                      "%USERPROFILE%\OneDrive\MYSController\MYSController.exe"
                      Had to change it to "C:\Users\user\OneDrive\MYSController" and it works now, great success.
                      • I
                        I
                        iguaan
                        Today I couldn't get it to work again unless I blocked all ports, ran program and then unblock again (to access GW).
                        Solution was to block myscontroller from accessing only that remote IP on all ports, letting me still connect to gateway without any fiddling in firewall settings on every program start.
                        Hope this solution stays for good :)
                        • I
                          I
                          iguaan
                          If anyone is getting "Property 'bootloader.tool.' is undefined" error with arduino 2.x when trying to burn bootloader, then you just have to add another row in bold below to boards.txt file
                          MYSBL.upload.tool=avrdude
                          MYSBL.upload.protocol=arduino
                          MYSBL.upload.maximum_size=30720
                          MYSBL.upload.maximum_data_size=2048
                          MYSBL.bootloader.tool=avrdude
                          MYSBL.bootloader.tool.default=avrdude
                          • N
                            N
                            nekitoss
                            wrote on last edited by nekitoss
                            #197
                            Today i suddenly find out, that Tekka updated app. Old app said "there is an update" and i've clicked link, which lead me to dropbox page.
                            So anyone, who previously blocked all traffic for program (@iguaan , @nfj25 , @Mac65 , @tplet) - you may want unblock it in your firewall and update.
                            I just replaced MYSController.exe and MYSController.ini files, leaving all other - it worked! Did not yet tested all functionality. But still make backup of all files for sure before dong that. Also you may need click on sensor and choose "settings->offline FOTA update" in order OTA to work. I'm wondering what does "online" version mean...
                            Thank you very much, Tekka!
                            • I
                              I
                              iguaan
                              @tekka
                              Is there any changelog to it also or it was just made officially available again?
                              although last online status was 22 AUG 2020, so anyone else can confirm anything about it?
                              I'd just be cautious without confirmation.
