  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.8k Views 30 Watching
  • sj44kS sj44k
    @mainali
    Does this help you? Sometimes a few pics say more than a 1000 words :)
    I made this pic from the Datasheet giving you the pinouts of the ATSHA204A in all known housings.
    And the way how to connect is (shamelessly stolen from the GW design of @Anticimex :) )
    AnticimexA
    AnticimexA
    Anticimex
    #66
    @sj44k @mainali Please note that that picture is incorrect. I have it connected to A3, not A7 (it is mentioned in the thread). Also note that in my design, I use a breakout board for ATSHA so the pin numbering on my breakout does NOT correspond to the SOT23-package.
      mainali
      Thanks a lot for all the Information
      • sj44kS
        sj44kS
        sj44k
        @Anticimex
        Thanks for that info, to me it is clear that depending on the used pin in the software one should connect the ATSHA204A corresponding with the software.
        Picture does show you being correct how simple it really is to embed the ATSHA204A hardware in the total setup.
        • D
          Dirk_H
          wrote on last edited by Dirk_H
          #69
          @phil83
          I fear you've already ordered the ATSHA204A ? I'm also in Germany so that would be easy.
          If not - I'd take 10 pcs. They cost close to nothing -> nice :)
          @Anticimex
          I don't agree with "This is an unlikely usecase because it is really no reason to sign sensor values. If you for some reason want to obfuscate sensor data, encryption is a better alternative."
          I think of Sensors used for Alarm-Systems. You need to trust the sensor reading because otherwise the attacker might jam the original Sensor and send his own Sensor data to let the alarm-system think the window is still closed (e.g.).
          One more question: Are the Serials in the ATSHA in ascending order (i.e. when you have a reel of ICs is each S/N old S/N+1 ?) If this is the case, would it be possible to steal a keyfob to get a valid signing device, read the serial, use that S/N +1, sign the message and get still access to the garage door? I.e. do something one could call "S/N spoofing"? (I know that it is much easier to just break the garage door with a crowbar, but I'm intrested in this - at least hypotheticaly :))
          Unfourtunately I don't have much time at the moment to try it out by myself, but I'm still really excited about your work and effort!
          AnticimexA 1 Reply Last reply
          • D Dirk_H
            @phil83
            @Anticimex
            AnticimexA
            AnticimexA
            Anticimex
            @Dirk_H The signing solution can be applied to both sensors and gateways. If you feel the need to have the gateway require signed messages from nodes, there is nothing to prevent it. I have already thought of that scenario and implemented support for it.
            Regarding jamming, no security system can prevent that.
            Regarding the generation of serials, you have to contact Atmel about that. And you still need to obtain the preshared key in order to generate properly signed messages. Neither the key nor the serial is ever sent over the air in clear text.
            • FotoFieberF
              FotoFieberF
              FotoFieber
              @Anticimex
              Thank you very much for this solution.
              I think your solution is the best compromise, if you don't want to transmit more data.
              The drawback is, that it isn't really as secure as AES 256 or above. It is a compromise.
              What about a solution
              • where the original message is untouched without a signature
              • a consumer requests an AES 256 signature of this message, if he really needs it
              • a second/third signature message is sent to the consumer with full AES 256 signature
              In this solution, you could use different keys for different nodes and the risk of stolen keys would be minimized.
              • FotoFieberF FotoFieber
                @Anticimex
                AnticimexA
                AnticimexA
                Anticimex
                #72
                @FotoFieber
                I think sha256 is pretty secure enough :)
                Regarding splitting signature and message, I am not too fond of that, because it opens up a lot of attack vectors and it also put requirements on the sender to be able to retain a sent message. Potentially a lot of nodes sends data back and forth, so what happens if, for instance, the gateway sends a message to one node, then sends another message to another node, and then the first node sends a message requesting a signature on a message the gateway no longer has. We have to remember that ram memory is very limited so there are limits in what we can do with message management, unfortunately.
                But all feedback is appreciated! Thanks!
                • FotoFieberF
                  FotoFieberF
                  FotoFieber
                  @Anticimex
                  sha256 is secure enough. But if I understand the implementation correctly, you use the space at the end of the payload for the signature and not the full signature.
                  Another thing to consider is that the strength of the signature is inversely proportional to the payload size.
                  If I calculate it right, the length of the signature is less or equal (23 bytes) 184 bit.
                  With a payload of 4 bytes, which would probably be the usual payload I have here, there would be left only 160 bit (20 bytes).
                  In comparison a HMAC_SHA256 uses 256 bit,
                  Or did I miss something?
                  It could be implemented quite simple:
                  1. Node sends data to gateway which in my case is published to MQTT
                  2. some consumer likes to have this signed and sends the node the message back with a sign request
                  3. the node looks at the message and checks, if the value inside the message is still valid. When ok, it sends a HMAC splitted in two messages. If not, it ignores the message or sends NOK.
                  The problem with this implementation would be, that the node hast to be active to get the singing request.
                  Maybe it would be better to just send two other messages with the HMAC after the data.
                  I would suggest to implement the check of the HMAC where it is needed, not in the gateway, In my case, this would be node-red.
                    @Anticimex
                    AnticimexA
                    AnticimexA
                    Anticimex
                    #74
                    @FotoFieber
                    Regarding the weakened security based on the message size, you are correct.
                    But I still disagree on splitting the messages because it will mean that some messages will fail to be signed (depending on network load) and it is no good to have a solution that adds uncertainty in that respect. And I definitely do not want to add restrictions on which types of nodes are capable on signing and which are not. Having the gateway signing messages is a very real application in use cases like locks and such.
                    The opposite is also equally valid, some nodes might send "important" data. The gateway needs to be able to authenticate such nodes (keyfobs etc).
                    We have to weigh complexity vs resources, and currently we are pretty much at the limit of our capabilities. An ethernet or mqtt gateway running on an Arduino nano can today barely fit HW support for signing. SW signing does not fit. So we can't really get more complex with the solution without also stepping up the HW platform we execute on.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      I should add that even if signature was separated in its own message, it still would not be full since the rf solution is only capable of sending 32 byte messages and some bytes are needed for routing info. So if "full" signature is required, some framing protocol will also be needed, and then things really get out of hand on a poor Arduino nano or pro mini.
                      I would suggest using RF69 with AES encryption if the signing scheme in place is inadequate.
                        Hi.
                        I am trying to design some boards. And I would like to have a little precision.
                        If I understand right, as signing is included in rfm69 radiohead library with mysensors, I don't need atsha? Atsha recommanded with nrf?
                        • scalzS scalz
                          Hi.
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @scalz
                          Well, it depends on what you want. In the first post I have outline my stance on the matter. I prefer signing before anything. RF69 offer optional encryption, not signing. If you are happy with just encryption, then you don't need ATSHA but have to use RF69 (or another circuit).
                            @Anticimex : you are right. I confused two different things!! So I think the best is combination of both.
                            Thank you for your precision and for sharing your work.
                            • scalzS scalz
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @scalz
                              Thanks and you are welcome :)
                              • scalzS scalz
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @scalz
                                For the record, I share your opinion on using a combination. I will probably go for that myself when I fully deploy my sensornetwork. RF69 with AES encryption on RF level, and ATSHA authentication on protocol level should be enough to protect against most deliberate non-physical mischief.
                                  @Anticimex : I totally agree with you. I am still defining my needs too. I have only some nrf nodes but I think Mysensors + RFM + Atsha + ota=Zwave killer! it might eliminate repeater needs.
                                  On my designs I put nrf and rfm footprints but I think I will move to rfm as soon as I can. I will share my designs when it will be tested. Hope there will be lots of boards for mysensors in the future.
                                  Have a good day!
                                  • scalzS scalz
                                    Have a good day!
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @scalz
                                    I have actually designed a board that supports both radios. I have just received them but have not mounted them with components yet so I have not been able to verify the design. But I will post it on the forum as soon as I have. It will be pin-compatible with Sensbender Micro but also support RF69. It is not intended to be replacing that board nor is it an "official" MySensor board. I have just designed it to fit my personal preferences and to serve as a generic multi-purpose sensor backend (it relies on modules and has a lot of headers to support many sensors in parallel on both 3.3 and 5V rails).
                                      #83
                                      wow. can't wait to see your creations! Seems interesting. Your board could be very helpful.
                                      I love Sensebender. But 0402, it was difficult to solder for me! So I am trying to use 0805 in my designs, easier for me.
                                      I am finishing to modify a moteino (0805 so a little bigger) to add nrf and atsha. I am waiting for others boards (not received yet) : uCurrent module, one power management optimization board (based on ulpnode idea), esp8266-07 with nrf, rfm and atsha (I will try to make sort of mqtt gateway), and a mysensors relay board. I have others idea too: dimmer for one main, hb100 (for barrier security), mgc3030 (for gesture. lot of stuff on this one I think). But before I must finish what I started. Hihi, mysensors and automation is addictive!
                                      I read in previous post that you advised not to use A6,A7 for atsha. But I imagine that I can use others pin (if i take care of datasheet of course)? I think it is doable, just have to modify pin ref in code next, isn't it? Anyway, I always try to keep mysensors reference design (A3), it is just for personal info.
                                      • scalzS scalz
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @scalz
                                        Then you'll be happy to hear that my board uses 0805 and 1206 and also has enlarged pads for hand soldering on all SMD footprints :)
                                        It also features a jumper for current measurement, three power connection options, switchable regulators for super low standby currents and some other features. But I will give the details in a separate post.
                                        • scalzS scalz
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @scalz
                                          Regarding pin, yes. You can freely choose any digital IO for ATSHA. A6 and A7 are not digital IO so they cannot be used. They are pure analog.
