  3. allow sensors to operate on voltage lower than 2.7v
3 Posts 3 Posters 3.0k Views 2 Watching
    Mickey
    wrote on last edited by Mickey
    Hi
    I made this boards as small as I could and would like to operate them on 3v coin battery - CR2032.
    I check them all and the range is excellent (more than 15 meter and behind 3 brick walls)
    but they will run out of power quite soon with this battery so what is the simplest and fastest way to change the arduino fuses so it can run down to 1.8v.
    If there is a need for external flash I have this one(is it good?):
    • SweebeeS
      SweebeeS
      Sweebee
      wrote on last edited by Sweebee
      You can use that AVRISP or use an other arduino as ISP. You have to change the BOD bit. Are you using windows or mac? On mac its quite easy with AVRFuses app. On windows you need AVR Studio.
      info for mac: http://www.leonardomiliani.com/en/2014/avrfuses-una-gui-per-modificare-i-fuse-delle-mcu-atmel-os-x/
      Windows: http://letsmakerobots.com/content/setting-arduino-fuses-manually-avr-studio
      You have to burn the fuses like this:
      LOW: 0xff
      HIGH: 0xda
      EXTENDED: 0x06
      I wrote some more battery information here: http://forum.pimatic.org/topic/383/tips-battery-powered-sensors
      • m26872M
        m26872M
        m26872
        @Mickey
        Any progress to share? Do you experience any issues with short battery life due to CR2032s high internal resistance, like reported here ?
