  3. Battery life of a relay actuator
11 Posts 5 Posters 5.2k Views 3 Watching
  • Moshe LivneM
    Moshe LivneM
    Moshe Livne
    Anyone has the relay node running off batteries? I have one that switch external lights on at sunset and off at sunrise but it is located in an awkward place and I am not sure I want to start re-wiring to get 220->5v plug in the box as well. Using Nano.
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      Unless you use a very big battery, it's not going to work. I did some testing with a battery powered relay node (2 AA) and it lasted ~18hrs with 4 activations of the relay.
      RJ_Make
      • J
        J
        Jan Gatzke
        Would this work with solid state relays? They should draw much less current.
        • FotoFieberF
          FotoFieberF
          FotoFieber
          SSR uses less power but is not as efficient on the load side
          If the relays are switching AC, you have the power there and I would recommend using it. I have used a charger like http://www.ebay.com/itm/321096550392?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT -> open case and use only the electronics.
          • FotoFieberF FotoFieber
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @FotoFieber hmmmm will do that. don't really like to get the 220v into the box but i guess thats life. would have been nice if the relays would work like the more advanced irrigation solenoids and "latch" in position so they take 0ma all the time other than a very short peak for flipping the relay and latching it in position.
            • J
              J
              Jan Gatzke
              Latching relays do exist. ;)
              • J Jan Gatzke
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @Jan-Gatzke yes, they do exist! silly of me to muse instead of googling. i see that they are all high voltage (12v-30v). is that why no one is using them? they seem to be perfect for relays that operate only once or twice a day. can Batteries produce such high voltage? I am sorry for the silly questions - I have very little understanding of electrical components
                • J
                  J
                  Jan Gatzke
                  Looks like Google and you are still not best friends. :P
                  http://www.ebay.com/itm/1-pc-Bistable-latching-2-coil-relay-5V-coil-16A-contact-SPDT-RT314F05-/361282277725
                  • J Jan Gatzke
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @Jan-Gatzke indeed. Sorry about that. I actually looked on aliexpress and things were either very very expensive or high voltage. will give this one a try... I guess I will need some kind of capacitor to allow it to have enough juice for the flip and latch. if it works it can be great, as I guess I am not the only one who tried to get as little 220v into the box. these little transformers also create a bit of heat.
                    SparkmanS 1 Reply Last reply
                    • Moshe LivneM Moshe Livne
                      SparkmanS
                      SparkmanS
                      Sparkman
                      wrote on last edited by Sparkman
                      @Moshe-Livne You'll want to add a diode such as the 1N4001 in parallel with the relay coil to prevent damage to the Arduino when the relay is turned off, and a transistor between the Arduino pin and the relay to switch the power to the relay as the Arduino typically can't supply enough current for the relay coil.
                      Al
                      EDIT: Here's an example of a circuit: http://www.ecs.umass.edu/ece/m5/images/relay_circuit_schematic_L.jpg
                      • SparkmanS Sparkman
                        Al
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @Sparkman ended up ordering http://www.aliexpress.com/item/Passive-Bistable-Latching-DPDT-8-Amp-Power-Relay-Module-5V-Version-RT424F05/2003476647.html as form factor is not really an issue where these relays will be but convenience is. I think it includes the diodes but not the transistor. Thanks!!!!
