  3. Camera as a sensor
Camera as a sensor
42 Posts 5 Posters 26.1k Views 1 Watching
    Mickey
    @Moshe-Livne said:
    @axillent Oh, still not used to thinking this way. This is beyond the (very limited) limits of my knowledge.... can be great.... total setup fee of ~15$
    I have an example of this just with tl-wr703n but the one I posted from aliexpress is just the same:
    openwrt webcam
    • M Mickey
      openwrt webcam
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @Mickey very good and detailed article. I have several of the GSM modems (that I now understand are not GSM modems at all) somewhere so i'll see if they can be flashed with openwrt. should be fuuuunnnn.
      • Moshe LivneM Moshe Livne
        Mickey
        wrote on last edited by Mickey
        #27
        Notice that the one I posted from aliexpress have its own procedure to flash openwrt on. Be careful not to brick your module...
        • axillentA axillent
          @bjornhallberg very nice setup! my congratulations!
          for DIY you did it pretty well
          but cost vise I do not see how this can be more efficient comparing to foscam
          bjornhallbergB
          bjornhallbergB
          bjornhallberg
          @axillent
          @Moshe-Livne
          Yeah, it is perhaps not the most economical solution. Probably closer to $100 per unit. Foscams have probably become better and cheaper since last I looked. Personally I'd rather have more control over my setup. Like how the housing is ventilated. Plus all the fun of building and figuring things out. Of course I don't get night vision, but I figured it is better to trigger a relay to turn on some floodlights or whatnot that will give intruders some warning. No use being sneaky about it.
          But yes, it would be really interesting if someone could come up with a really cheap battery powered solution.
            @axillent
            @Moshe-Livne
            Mickey
            @bjornhallberg said:
            @axillent
            @Moshe-Livne
            openwrt as battery powered solution wont last much but they can be attach to cheap 5v solar pannel by day and run on lipo by night so no need for external power source. also
            Its possible to install Motion on thoes modules and have state of the art motion sensors.
            • M Mickey
              @axillent
              @Moshe-Livne
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @Mickey how quickly do they boot up? might boot it when pir is triggered.
                Mickey
                I thought about it but openwrt is a full linux and it takes 15-20 seconds to boot up so it will be half a minute delay between trigger and response
                • bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  Speaking of battery powered cameras, there already are commercial products such as Arlo and Homeboy:
                  http://www.cnet.com/products/netgear-arlo-smart-home-security-kit/
                  http://www.cnet.com/products/homeboy/
                  Not cheap enough, and battery times will surely vary depending on use, but they are a nice proof of concept.
                  • M Mickey
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @Mickey they are so small!!!!
                      Mickey
                      what is so small?
                      • Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        the tiny 3g routers from aliexpress. just got one. do you happen to have the openwrt firmware pre-compiled?
                          Mickey
                          which one exactly did you buy?
                          • M Mickey
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @Mickey http://www.aliexpress.com/item/LYNEW-Portable-Mini-Wireless-wifi-Router-3G-4G-Hotspot-Wifi-Hotspot-support-3G-USB-modems/32257312139.html
                              Mickey
                              start from here:
                              http://wiki.openwrt.org/toh/unbranded/a5-v11
                              • Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                Been there.... just wasn't keen on compiling it. Oh well.
                                  Mickey
                                    Mickey
                                    #41
                                    https://github.com/sternlabs/RT5350F-cheap-router/tree/master/openwrt
                                    http://www.digitalinferno.com/wiki/attach/Mini3G4GUSBRouterOpenWrtExternalUSB/openwrt-ramips-rt305x-a5-v11-squashfs-sysupgrade.bin
                                    https://www.digitalinferno.com/wiki/Wiki.jsp?page=Mini3G4GUSBRouterOpenWrtExternalUSB
                                    • M Mickey
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @Mickey Thanks. will give it a try!
