  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.8k Views 30 Watching
  • scalzS scalz
    Hi.
    I am trying to design some boards. And I would like to have a little precision.
    If I understand right, as signing is included in rfm69 radiohead library with mysensors, I don't need atsha? Atsha recommanded with nrf?
    AnticimexA
    AnticimexA
    Anticimex
    @scalz
    Well, it depends on what you want. In the first post I have outline my stance on the matter. I prefer signing before anything. RF69 offer optional encryption, not signing. If you are happy with just encryption, then you don't need ATSHA but have to use RF69 (or another circuit).
      @Anticimex : you are right. I confused two different things!! So I think the best is combination of both.
      Thank you for your precision and for sharing your work.
      • scalzS scalz
        AnticimexA
        AnticimexA
        Anticimex
        @scalz
        Thanks and you are welcome :)
        • scalzS scalz
          AnticimexA
          AnticimexA
          Anticimex
          @scalz
          For the record, I share your opinion on using a combination. I will probably go for that myself when I fully deploy my sensornetwork. RF69 with AES encryption on RF level, and ATSHA authentication on protocol level should be enough to protect against most deliberate non-physical mischief.
            @Anticimex : I totally agree with you. I am still defining my needs too. I have only some nrf nodes but I think Mysensors + RFM + Atsha + ota=Zwave killer! it might eliminate repeater needs.
            On my designs I put nrf and rfm footprints but I think I will move to rfm as soon as I can. I will share my designs when it will be tested. Hope there will be lots of boards for mysensors in the future.
            Have a good day!
            AnticimexA 1 Reply Last reply
            • scalzS scalz
              Have a good day!
              AnticimexA
              AnticimexA
              Anticimex
              @scalz
              I have actually designed a board that supports both radios. I have just received them but have not mounted them with components yet so I have not been able to verify the design. But I will post it on the forum as soon as I have. It will be pin-compatible with Sensbender Micro but also support RF69. It is not intended to be replacing that board nor is it an "official" MySensor board. I have just designed it to fit my personal preferences and to serve as a generic multi-purpose sensor backend (it relies on modules and has a lot of headers to support many sensors in parallel on both 3.3 and 5V rails).
                #83
                wow. can't wait to see your creations! Seems interesting. Your board could be very helpful.
                I love Sensebender. But 0402, it was difficult to solder for me! So I am trying to use 0805 in my designs, easier for me.
                I am finishing to modify a moteino (0805 so a little bigger) to add nrf and atsha. I am waiting for others boards (not received yet) : uCurrent module, one power management optimization board (based on ulpnode idea), esp8266-07 with nrf, rfm and atsha (I will try to make sort of mqtt gateway), and a mysensors relay board. I have others idea too: dimmer for one main, hb100 (for barrier security), mgc3030 (for gesture. lot of stuff on this one I think). But before I must finish what I started. Hihi, mysensors and automation is addictive!
                I read in previous post that you advised not to use A6,A7 for atsha. But I imagine that I can use others pin (if i take care of datasheet of course)? I think it is doable, just have to modify pin ref in code next, isn't it? Anyway, I always try to keep mysensors reference design (A3), it is just for personal info.
                • scalzS scalz
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @scalz
                  Then you'll be happy to hear that my board uses 0805 and 1206 and also has enlarged pads for hand soldering on all SMD footprints :)
                  It also features a jumper for current measurement, three power connection options, switchable regulators for super low standby currents and some other features. But I will give the details in a separate post.
                  • scalzS scalz
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @scalz
                    Regarding pin, yes. You can freely choose any digital IO for ATSHA. A6 and A7 are not digital IO so they cannot be used. They are pure analog.
                      #86
                      Very interesting. So your board will be a great addition. I will follow your work for sure!
                      Thank you very much for your help.
                      • O
                        O
                        otto001
                        Hi @all!
                        First off all: thanks for your great work :-)
                        I am about to compile the ethernet gw with software signing, but unfortunately I am getting some compile errors.
                        Does anyone maybe have a sketch handy and would up it here?
                        Thanks in advance and best regards,
                        Otto
                        • O otto001
                          Hi @all!
                          Otto
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @otto001
                          Sorry, but that is not possible on Arduino Nano. There is not enough flash available to support both ethernet and software signing. You have to use ATSHA for an ethernet gw.
                          • O
                            O
                            otto001
                            @Anticimex:
                            Thanks, but I am trying to compile it for an UNO R3?! That should do it. Nevertheless: Using nanos only for nodes should work with sw signing, shouldnt it?
                            • O otto001
                              @Anticimex:
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @otto001
                              Yep. It is the ethernet stack that costs the most.
                              I need you to post the compiler error you get though in order to help you.
                              • O
                                O
                                otto001
                                I used the latest devel-branch from github.
                                This is the error:
                                In file included from /home/otto/sketchbook/libraries/MySensors/MyTransportNRF24.h:26:0,
                                                 from /home/otto/sketchbook/libraries/MySensors/MySensor.h:28,
                                                 from ms_gw_neu.ino:42:
                                /home/otto/sketchbook/libraries/MySensors/utility/RF24.h:51:11: error: 'SOFT_SPI_MISO_PIN' was not declared in this scope
                                   SoftSPI<SOFT_SPI_MISO_PIN, SOFT_SPI_MOSI_PIN, SOFT_SPI_SCK_PIN, SPI_MODE> spi;
                                /home/otto/sketchbook/libraries/MySensors/utility/RF24.h:51:30: error: 'SOFT_SPI_MOSI_PIN' was not declared in this scope
                                /home/otto/sketchbook/libraries/MySensors/utility/RF24.h:51:49: error: 'SOFT_SPI_SCK_PIN' was not declared in this scope
                                /home/otto/sketchbook/libraries/MySensors/utility/RF24.h:51:75: error: template argument 1 is invalid
                                /home/otto/sketchbook/libraries/MySensors/utility/RF24.h:51:75: error: template argument 2 is invalid
                                /home/otto/sketchbook/libraries/MySensors/utility/RF24.h:51:75: error: template argument 3 is invalid
                                In file included from ms_gw_neu.ino:43:0:
                                /home/otto/sketchbook/libraries/MySensors/MyGateway.h:39:28: error: 'DEFAULT_CE_PIN' was not declared in this scope
                                   MyGateway(uint8_t _cepin=DEFAULT_CE_PIN, uint8_t _cspin=DEFAULT_CS_PIN, uint8_t _inclusion_time = 1, uint8_t _inclusion_pin = 3, uint8_t _rx=6, uint8_t _tx=5, uint8_t _er=4);
                                /home/otto/sketchbook/libraries/MySensors/MyGateway.h:39:59: error: 'DEFAULT_CS_PIN' was not declared in this scope
                                ms_gw_neu.ino:80:31: error: no matching function for call to 'MyGateway::MyGateway(MyTransportNRF24&, MyHwATMega328&, MySigningAtsha204Soft&)'
                                ms_gw_neu.ino:80:31: note: candidates are:
                                /home/otto/sketchbook/libraries/MySensors/MyGateway.h:39:3: note: MyGateway::MyGateway(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)
                                /home/otto/sketchbook/libraries/MySensors/MyGateway.h:39:3: note:   no known conversion for argument 1 from 'MyTransportNRF24' to 'uint8_t {aka unsigned char}'
                                /home/otto/sketchbook/libraries/MySensors/MyGateway.h:20:7: note: MyGateway::MyGateway(const MyGateway&)
                                 class MyGateway : public MySensor
                                /home/otto/sketchbook/libraries/MySensors/MyGateway.h:20:7: note:   candidate expects 1 argument, 3 provided
                                and this is the sketch - I am not sure, if everything is right (I am not deep into mysensors yet):
                                 * Copyright (C) 2013 Henrik Ekblad <henrik.ekblad@gmail.com>
                                 * Contribution by a-lurker
                                 * COMPILING WIZNET (W5100) ETHERNET MODULE
                                 * > Edit RF24_config.h in (libraries\MySensors\utility) to enable softspi (remove // before "#define SOFTSPI").
                                 * COMPILING ENC28J60 ETHERNET MODULE
                                 * > Use Arduino IDE 1.5.7 (or later)
                                 * > Disable DEBUG in Sensor.h before compiling this sketch. Othervise the sketch will probably not fit in program space when downloading.
                                 * > Remove Ethernet.h include below and include UIPEthernet.h
                                 * > Remove DigitalIO include
                                 * Note that I had to disable UDP and DHCP support in uipethernet-conf.h to reduce space. (which means you have to choose a static IP for that module)
                                 * VERA CONFIGURATION:
                                 * LED purposes:
                                #include <DigitalIO.h>     // This include can be removed when using UIPEthernet module
                                #include <MyGateway.h>
                                #include <stdarg.h>
                                #include <MyConfig.h>
                                // Use this if you have attached a Ethernet ENC28J60 shields
                                //#include <UIPEthernet.h>
                                // Use this fo WizNET W5100 module and Arduino Ethernet Shield
                                #include <Ethernet.h>
                                #define RADIO_CE_PIN        5  // radio chip enable
                                #define RADIO_SPI_SS_PIN    6  // radio SPI serial select
                                #define RADIO_ERROR_LED_PIN 7  // Error led pin
                                #define RADIO_TX_LED_PIN    9  // the PCB, on board LED
                                #define IP_PORT 5003        // The port you want to open
                                IPAddress myIp (192, 168, 1, 66);  // Configure your static ip-address here    COMPILE ERROR HERE? Use Arduino IDE 1.5.7 or later!
                                byte mac[] = { 0xCE, 0x0D, 0xBE, 0xEF, 0xFE, 0xED };  // DEAD BEEF FEED
                                // a R/W server on the port
                                EthernetServer server = EthernetServer(IP_PORT);
                                MyTransportNRF24 radio;  // NRFRF24L01 radio driver
                                MyHwATMega328 hw; // Select AtMega328 hardware profile
                                MySigningAtsha204Soft signer(false); // Select ATSHA204A software signing backend
                                MyGateway gw(radio, hw, signer);
                                // No blink or button functionality. Use the vanilla constructor.
                                // old MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME);
                                // Uncomment this constructor if you have leds and include button attached to your gateway
                                //MyGateway gw(RADIO_CE_PIN, RADIO_SPI_SS_PIN, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                                char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                                int inputPos = 0;
                                  Ethernet.begin(mac, myIp);
                                  // give the Ethernet interface a second to initialize
                                  delay(1000);
                                  gw.begin(RF24_PA_LEVEL_GW, RF24_CHANNEL, RF24_DATARATE, writeEthernet);
                                  server.begin();
                                // This will be called when data should be written to ethernet
                                void writeEthernet(char *writeBuffer) {
                                  server.write(writeBuffer);
                                  // if an incoming client connects, there will be
                                  // bytes available to read via the client object
                                  EthernetClient client = server.available();
                                  if (client) {
                                      Serial.print("bytes");
                                      // if got 1 or more bytes
                                      if (client.available()) {
                                         // read the bytes incoming from the client
                                         char inChar = client.read();
                                         if (inputPos<MAX_RECEIVE_LENGTH-1) {
                                           // if newline then command is complete
                                           if (inChar == '\n') {
                                              // a command was issued by the client
                                              // we will now try to send it to the actuator
                                              inputString[inputPos] = 0;
                                              // echo the string to the serial port
                                              Serial.print(inputString);
                                              gw.parseAndSend(inputString);
                                              // clear the string:
                                              inputPos = 0;
                                             // add it to the inputString:
                                             inputString[inputPos] = inChar;
                                             inputPos++;
                                           inputPos = 0;
                                   gw.processRadioMessage();
                                Thanks for your help in advance!
                                Otto
                                • O otto001
                                  This is the error:
                                   * LED purposes:
                                  #include <stdarg.h>
                                  int inputPos = 0;
                                    delay(1000);
                                    server.begin();
                                    if (client) {
                                                inputPos = 0;
                                               inputPos++;
                                             inputPos = 0;
                                  Otto
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @otto001
                                  Hm. Looks like you have a problem with your settings for soft SPI. The errors are not related to the signing backend.
                                  I suspect a problem in MyConfig.h but I have not been up to speed with the changes on development nor have I dabbled with soft SPI. I run "hardware" SPI. @hek maybe knows what setting is wrong for your problem to occur. Could be that the soft SPI driver does not take UNO boards into account?
                                  • O
                                    O
                                    otto001
                                    wrote on last edited by otto001
                                    #93
                                    @Anticimex:
                                    Thanks anyway! I will try again without signing. Maybe there is a problem in the recent devel-branch. With stable 1.4 it compiled without any issues...
                                    /update: does not compile with the "standard" ethernet-gw sketch too.... not related to signing...
                                    • O otto001
                                      @Anticimex:
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @otto001
                                      Alright. Thanks for confirming. I had a rough period on development with the signing support when I was developing it. Other commits kept breaking it (not intentionally but because there was other changes to the init sequences and such which did not take signing into account). And I have been busy doing other things so I have not refreshed my own sketches to HEAD on development for a couple of months so I am uncertain on the working state at the moment, but I trust @hek to let me know if something breaks again :)
                                      I will get back on track soon I hope but project :baby: is coming up and is sure to mess quite a bit with my schedule :) so I trust others to keep me informed if signing support should fail.
                                      • F
                                        F
                                        franklin216
                                        I do not understand how to set the Backend in the myconfig.h.
                                        "you need to decide what signing backend to use. This is done in MyConfig.h"
                                        But how? Just by commenting out the Pin Define?
                                        • AnticimexA
                                          AnticimexA
                                          Anticimex
                                          My post is not really up2date with the code at the moment (at least on development branch). You now pick you backend by argument to the MySensor constructor. I will check with @hek how we should handle this post when master and development are diverging.
