  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.5k Views 69 Watching
  • DidiD
    DidiD
    Didi
    wrote on last edited by Didi
    @petewill said:
    Does anyone know of any 120V AC to 5V DC transformers that are safe to put in a wall electrical box?
    here you go
    http://www.recom-international.com/pdf/Powerline-AC-DC/RAC03-SCR_277.pdf
    http://www.tracopower.com/products/tiw.pdf
    • petewillP petewill
      Does anyone know of any 120V AC to 5V DC transformers that are safe to put in a wall electrical box? I have been using old cell phone chargers for most of my projects but I was recently pondering putting something right in the wall. Since shipping can take so long I thought I'd ask now before I even start on the project.
      I did some searching and couldn't find anything so I thought I'd ask the experts here.
      Thanks in advance!
      EDIT 9/7/2016
      Watch out for Fakes! Read more here: https://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers/355
      If in doubt you can get them directly from the vendor here: http://www.hlktech.net/product.php?CateId=10
      EDIT 12/28/2015
      After MUCH discussion on this here are the findings of this thread (as of now):
      Here is the diagram for how things should be wired:
      These are the parts I ordered. I haven't tested any of these parts yet as this project has been put on the back burner for now :(. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
      Also, see these posts for more discussion/ideas if interested:
      http://forum.mysensors.org/topic/1540/110v-230v-ac-to-mysensors-pcb-board
      http://forum.mysensors.org/topic/2488/in-wall-pcb
      Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
      250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
      HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
      Pete
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @petewill got these http://www.aliexpress.com/item/Free-Shippingn-2pcs-lot-HLK-PM01-AC-DC-220V-to-5V-mini-power-supply-module-intelligent/32296988259.html in the mail today. not as sexy as the ones @Didi lists but maybe cheaper? Haven't tried them yet.
        I have ordered same as @Moshe. I think those @Didi listed are larger and expensive. It is not very easy to find something small and cheap, or it needs to make your own.
        • scalzS scalz
          Moshe LivneM
          Moshe LivneM
          Moshe Livne
          @scalz I actually ordered the same as you :relaxed:
          they look very well made. I am not equipped to test any of the parameters but i am sure that for me they will do.
            @Moshe Livne : yep! it is the smallest and cheapest I have found. What could be great would be to find cheap and little core transformer to make custom step down.
            • sundberg84S
              sundberg84S
              As long as they dont catch fire and deliver 5v im happy! :fearful:
              DidiD 1 Reply Last reply
              • scalzS scalz
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @scalz How do you connect these to the mains? direct soldering and heatshrink over?
                • sundberg84S sundberg84
                  DidiD
                  DidiD
                  Didi
                  That´s the problem i see with the cheap ones
                  • DidiD Didi
                    here you go
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @Didi These are huge... they are 5x5cm. Do you have any idea of their pricing?
                    • Moshe LivneM Moshe Livne
                      DidiD
                      DidiD
                      Didi
                      @Moshe-Livne
                      About 20-25 euro
                      • DidiD Didi
                        @Moshe-Livne
                        About 20-25 euro
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @Didi ouch!
                          @Didi ouch!
                          DidiD
                          DidiD
                          Didi
                          @Moshe-Livne said:
                          @Didi ouch!
                          Yes,but they have over temperature protection :wink:
                          • DidiD Didi
                            @Moshe-Livne said:
                            @Didi ouch!
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @Didi it is cheaper to buy better fire and life insurance :wink:
                              DidiD
                              DidiD
                              Didi
                              That´s a good point :joy:
                                @Moshe Livne: it is ordered, I have not them yet. I hope it will be good quality.I don't know.
                                I agree with you for fire and co. But I think in commercial products they don't use big things.
                                As we can see on some picture here : http://www.aliexpress.com/store/product/Free-Shipping-Livolo-Luxury-White-Crystal-Glass-Switch-Panel-EU-Standard-VL-C701-11-110-250V/500715_512886492.html
                                Sure it is maybe not top quality, but I think in fibaro or other it's near the same thing. but I am not sure as I have none. And of course they have enclosure (maybe flame retardant).
                                Maybe I am not enough paranoid...or you can for example put an onboard temperature sensor for additional security.
                                But of course, ac is very dangerous, you must know what you do if you don't want to die. You have to take all securities like you said.
                                • petewillP
                                  petewillP
                                  petewill
                                  Thanks for the quick replies! I am torn. The ones @Didi posted look great but they are large and expensive. The ones @Moshe-Livne and @scalz ordered look appealing because of cost and size but I don't want to sacrifice safety for cost. It looks like they have temperature protection but I don't know enough about electronics to test for safety. Hmm...
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @petewill
                                    I wonder if you could open one of these and solder to the USB power leads...
                                    petewillP 1 Reply Last reply
                                      @petewill
                                      petewillP
                                      petewillP
                                      petewill
                                      @BulldogLowell Yeah I was thinking about that too. I'm really trying to keep costs down though. When I hit the $25 price point it's almost as much as a standard z-wave switch when all the other parts and time are included.
                                      • RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        My only recommendation; (if you are going to put this in side a utility box, in the wall) might want to find a solution that has the 3 standard safety features. (OTP, OVP, SCP)
                                        These work well, but you need to follow the data-sheet for noise and ripple control.
                                        RJ_Make
                                        • RJ_MakeR RJ_Make
                                          petewillP
                                          petewillP
                                          petewill
                                          @ServiceXp Thanks! I wonder if I can steal one of those from an existing device. Any idea what those would be used on?
                                          (OTP, OVP, SCP)
                                          Also, is that Over Temp Protection, Over Voltage Protection and Short Circuit Protection??
                                          These say they are certified and have temp, voltage and short circuit protection. Think it can be trusted?
                                          http://www.ebay.com/itm/351418782712?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                          Moshe LivneM RJ_MakeR 2 Replies Last reply
