  3. Solar Pannel and LiOn or Lipo
52 Posts 5 Posters 50.4k Views 9 Watching
  • epierreE
    epierreE
    epierre
    @ceech thanks a lot for this clear view on how to do it ! So bad there is not one module to make it all.
    For the solar panel, I guess it is a security to use the DC-C converter.
    For the battery charger, the voltage protection on it is not used in this configuration, right ?
    What arduino would work here, some 3V3 @ 8Mhz ?
    z-wave - Vera -> Domoticz
    C 1 Reply Last reply
    • epierreE epierre
      C
      C
      ceech
      wrote on last edited by ceech
      @epierre
      But there is a module that can do all that. This is it:
      http://www.ebay.com/itm/331601644681?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1587.l2649
      The voltage protection IS used in the above configuration and a 3V3 Arduino would work.
      • epierreE
        epierreE
        epierre
        @ceech yes I saw this one, but I have some hardware to use yet ;-)
        do you have an idea of the power of the pannel and the load duration for a CR123 or 18650 that we could consider on making a project ? that would be a good knowledge base for all !
        I am also searching for a casing that would be related to the panel size !
        • epierreE epierre
          C
          C
          ceech
          @epierre
          I'm sorry, I don't understand your question.
          • epierreE
            epierreE
            epierre
            In fact I've found my answer
            "Facts on Battery Charging :
            The thumb rule for charging Ni Mh batteries is 1/10th (commonly known as C/10). To charge the battery pack at 1/10th its rated current requires 16 hours of charge time( You can see the picture).The solar panel receives optimal sunlight for only four hours per day, from 10 a.m. to 2 p.m. Thus, a totally ideal system would require four days to fully charge the battery pack.
            What is C/10 ?
            For example we have a 2xAA–sized 1300mAh battery pack that is rated at 1.2 volts per cell. With cells in series, our pack outputs 2.4 volts and 1300mAh.
            Here capacity C =1300mAh
            C/10 means 1300/10 =130mAh
            So to charge the above battery pack we need a higher voltage ( 2.4 to 3 V) with a maximum current of 130mAh.
            As per C/10 rule it requires 16 hours to fully charge the battery pack.
            You must be ask,what will happen if we increase the current (>130mAh) ?No doubt your battery will charge faster.But the life of the battery will be reduce.So my advice is to keep the current bellow the C/10 value."
            Choosing a panel:
            "The main source for powering the sensor module is solar panel.So it must be able to provide current for powering the arduino as well as current to charge the battery pack during the day.As per my experience it is the most challenging part for a novice user.
            Don't worry these are the following tricks which can help you to buy a right solar panel.
            1. Voltage : Choose 1.5 times the battery pack voltage
              2.Current : Current taken by the Arduino + current for charging (should be
            Example :
            A battery pack is made of 2 AA Ni Mh battery.
            Battery voltage = 1.2 x 2= 2.4V
            So required voltage for solar panel =2.4 x 1.5 = 3.6V
            By taking some margin we can choose a 4V solar panel for it.
            The sensor module along with arduino taking 100mAh current.
            Battery capacity is 1300mAh
            C/10 = 130mAh
            Solar panel have to provide current 100mAh for arduino along with a current not more than 130mAh.
            Lets take 100 mAh for charging the battery
            Total current required = 100+100=200mAh
            From the above calculation it is clear that we need a solar panel of 4V and 200mAh.
            The following table shows the solar system configuration relationship between storage batteries and mini solar panels.
            Battery ----> Solar Panel
            1.2V ------> 2V ~ 2.5V
            2.4V ------> 3.5V ~ 4V
            3.6V ------> 5V ~ 6V
            6V ------> 7.5V ~ 9V
            12V ------>15V ~ 18V
            Note : It is not the strict rule for choosing the exact rating solar panel, rather it is approximate rating .I write as per my experience"
            • C ceech
              Here, this is how you connect things:
              The second item from the left is a DC-DC converter. It is used when the solar panel voltage exceeds 5V. Otherwise it is not needed.
              The red board is battery charger. Note that the battery is connected to Batt connections and the Arduino is connected to Out connections, so that the battery protection circuit can do its job.
              Arduino is there as an example, I do not think that UNO will even work with such low voltage.
              epierreE
              epierreE
              epierre
              Now I have the item, so:
              - B+/B- connected to the voltage regulator of the pannel.
              • usb port connected to the 18650 / CR123
              • +/- near the usb port to the input voltage of the arduino ? or is that out+/out- ?
              subsidiary question: what would be the device to use to load a LiFePO4 ?
              • epierreE epierre
                C
                C
                ceech
                @epierre -B/+B to the battery, USB port is NOT connected. + and - near the USB port are inputs from the solar cell. out+/out- is for Arduino.
                • epierreE
                  epierreE
                  epierre
                  so bad, none worked for a long even with a 6800mAh... it was arduino mini pro ith a 1 W solar panel...
                  I've moed to your boards to see if I can do better...
                  • epierreE
                    epierreE
                    epierre
                    @ceech same issue ith your solar / battery board... sleep time is 300 * 1000, it starts up and then nothing anymore even with a fully charged 18650 6800mAh LIOn...
                    • C
                      C
                      ceech
                      @epierre
                      Does the basic functionality work? Do you receive any data from LTC4067?
                      Here is an example of RAW analogRead data from LTC4067.
                      Notice the /CHRG change from High to Low. That indicates charging.
                      analog input A1 on ATmega 328 is /CHRG signal from LTC4067
                      analog input A0 on ATmega328 is battery voltage
                      analog input A2 is solar cell voltage
                      analog input A6 is input current ( I=V/R x 1000 )
                      analog input A7 is battery charge current ( I=V/Rprog x 1000 )
                      • epierreE
                        epierreE
                        epierre
                        Here is the code based on the other around:
                          Vera Arduino BH1750FVI Light sensor
                          communicate using I2C Protocol
                          this library enable 2 slave device addresses
                          Main address  0x23
                          secondary address 0x5C
                          connect the sensor as follows :
                          VCC  >>> 5V
                          Gnd  >>> Gnd
                          ADDR >>> NC or GND
                          SCL  >>> A5
                          SDA  >>> A4
                          Contribution: idefix/epierre for ceech
                        #include <Wire.h> 				// I2C
                        #include <BH1750.h>
                        #define LTC4067_CHRG_PIN	A1		//analog input A1 on ATmega 328 is /CHRG signal from LTC4067
                        #define batteryVoltage_PIN	A0		//analog input A0 on ATmega328 is battery voltage ( /2)
                        #define solarVoltage_PIN	A2		//analog input A2 is solar cell voltage (/ 2)
                        #define solarCurrent_PIN	A6		//analog input A6 is input current ( I=V/Rclprog x 1000 )
                        #define batteryChargeCurrent_PIN	A7		//analog input A7 is battery charge current ( I=V/Rprog x 1000 )
                        #define LTC4067_SUSPEND_PIN	9		//digital output D9 - drive it high to put LTC4067 in SUSPEND mode
                        const float VccMin        = 1.0*3.5;  // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
                        const float VccMax        = 1.0*4.2;  // Maximum expected Vcc level, in Volts.
                        #define LIGHT_SENSOR_ANALOG_PIN 3   // Digital input did you attach your soil sensor.
                        #define CHILD_ID_LIGHT 0   // Id of the sensor child
                        #define BATT_CHILD_ID 10
                        #define SOLAR_CHILD_ID 11
                        // PIN Radio
                        #define RADIO_CE_PIN    7       // radio chip enable
                        #define RADIO_SS_PIN    8      // CS SS serial select
                        float lastBattVoltage;
                        float lastBattCurrent;
                        float lastSolarVoltage;
                        float lastSolarCurrent;
                        int lastBattPct = 0;
                        uint16_t lastlux;
                        float VccReference = 3.3 ;				// voltage reference for measurement, definitive init in setup
                        BH1750 lightSensor;
                        MySensor  gw(RADIO_CE_PIN, RADIO_SS_PIN);;
                        unsigned long SLEEP_TIME = 300*1000;  // sleep time between reads (seconds * 1000 milliseconds)
                        MyMessage batteryVoltageMsg(BATT_CHILD_ID, V_VOLTAGE);		// Battery voltage (V)
                        MyMessage batteryCurrentMsg(BATT_CHILD_ID, V_CURRENT);		// Battery current (A)
                        MyMessage solarVoltageMsg(SOLAR_CHILD_ID, V_VOLTAGE);		// Solar voltage (V)
                        MyMessage solarCurrentMsg(SOLAR_CHILD_ID, V_CURRENT);		// Solar current (A)
                        int lastSoilValue = -1;
                          gw.begin();
                          gw.sendSketchInfo("Light Lux Sensor", "1.0");
                          gw.present(BATT_CHILD_ID, S_POWER);						// Battery parameters
                          gw.present(SOLAR_CHILD_ID, S_POWER);					// Solar parameters
                          // use VCC (3.3V) reference
                          analogReference(DEFAULT);								// default external reference = 3.3v for Ceech board
                          VccReference = 3.323 ;									// measured Vcc input (on board LDO)
                          pinMode(LTC4067_SUSPEND_PIN, OUTPUT);					// suspend of Lion charger set
                          digitalWrite(LTC4067_SUSPEND_PIN,LOW);   			//  active (non suspend) at start
                          lightSensor.begin();
                          sendVoltage();
                          Serial.println(lux);
                          if (lux != lastlux) {
                              gw.send(msg.set(lux));
                              lastlux = lux;
                          // Power down the radio
                          gw.sleep(SLEEP_TIME);
                        void sendVoltage(void)
                        // battery and charging values
                        	// get Battery Voltage & charge current
                        	float batteryVoltage = ((float)analogRead(batteryVoltage_PIN)* VccReference/1024) * 2;	// actual voltage is double
                        	Serial.print("Batt: ");
                        	Serial.print(batteryVoltage);
                        	Serial.print("V ; ");
                        	float batteryChargeCurrent = ((float)analogRead(batteryChargeCurrent_PIN) * VccReference/1024)/ 2.5 ; // current(A) = V/Rprog(kohm)
                        	Serial.print(batteryChargeCurrent);
                        	Serial.println("A ");
                        	// get Solar Voltage & charge current
                        	float solarVoltage = ((float)analogRead(solarVoltage_PIN)/1024 * VccReference) * 2 ;		// actual voltage is double
                        	Serial.print("Solar: ");
                        	Serial.print(solarVoltage);
                        	// get Solar Current
                        	float solarCurrent = ((float)analogRead(solarCurrent_PIN)/1024 * VccReference)/ 2.5;		// current(A) = V/Rclprog(kohm)
                        	Serial.print(solarCurrent);
                        	Serial.print(" A; charge: ");
                        	Serial.println(digitalRead(LTC4067_CHRG_PIN)?"No":"Yes");
                        	// send battery percentage for node
                        	int battPct = 1 ;
                        	if (batteryVoltage > VccMin){
                        		battPct = 100.0*(batteryVoltage - VccMin)/(VccMax - VccMin);
                        	Serial.print("BattPct: ");
                        	Serial.print(battPct);
                        	Serial.println("% ");
                        	gw.send(batteryVoltageMsg.set(batteryVoltage, 3));  		// Send (V)
                        	gw.send(batteryCurrentMsg.set(batteryChargeCurrent, 6));  	// Send (Amps)
                        	gw.send(solarVoltageMsg.set(solarVoltage, 3));  			// Send (V)
                        	gw.send(solarCurrentMsg.set(solarCurrent, 6));  			// Send (Amps)
                        	gw.sendBatteryLevel(battPct);
                        • epierreE
                          epierreE
                          epierre
                          Batt: 3.94V ; 0.00A
                          Solar: 0.18V ; 0.00 A; charge: No
                          BattPct: 62%
                          Batt: 4.10V ; 0.00A
                          Solar: 0.55V ; 0.00 A; charge: No
                          BattPct: 85%
                          • epierreE
                            epierreE
                            epierre
                            #21
                            an idea maytbe, if I put sleep at 30 * 1000 it works, at 60 * 1000 infinite sleep... any idea ?
                            (I observed that on both units). It also loas the battery ...
                            Batt: 3.96V ; 0.00A
                            BattPct: 65%
                            send: 14-14-0-0 s=10,c=1,t=38,pt=7,l=5,st=ok:3.959
                            send: 14-14-0-0 s=10,c=1,t=39,pt=7,l=5,st=ok:0.000000
                            send: 14-14-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:0.545
                            send: 14-14-0-0 s=11,c=1,t=39,pt=7,l=5,st=ok:0.000000
                            send: 14-14-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:65
                            22
                            send: 14-14-0-0 s=0,c=1,t=23,pt=3,l=2,st=ok:22
                            Batt: 3.97V ; 0.00A
                            Solar: 0.48V ; 0.00 A; charge: No
                            BattPct: 66%
                            send: 14-14-0-0 s=10,c=1,t=38,pt=7,l=5,st=ok:3.966
                            send: 14-14-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:0.480
                            send: 14-14-0-0 s=255,c=3,t=0,pt=1,l=1,st=ok:66
                            21
                            send: 14-14-0-0 s=0,c=1,t=23,pt=3,l=2,st=ok:21
                            • epierreE epierre
                              Batt: 3.96V ; 0.00A
                              BattPct: 65%
                              22
                              Batt: 3.97V ; 0.00A
                              BattPct: 66%
                              21
                              C
                              C
                              ceech
                              @epierre
                              Solar voltage seems a bit low. Can you raise it? And see if the charging takes place?
                              • epierreE
                                epierreE
                                epierre
                                #23
                                sleep is the problem, it loads at 30s never above...
                                Batt: 4.06V ; 0.00A
                                Solar: 2.56V ; 0.00 A; charge: No
                                BattPct: 79%
                                Batt: 4.05V ; 0.00A
                                Solar: 3.38V ; 0.00 A; charge: No
                                BattPct: 78%
                                on the other:
                                2015-07-05 20:32:40 14 10 1 0 38 4.024
                                2015-07-05 20:32:40 14 10 1 0 39 0.001298
                                2015-07-05 20:32:41 14 11 1 0 38 3.991
                                2015-07-05 20:32:42 14 11 1 0 39 0.000000
                                2015-07-05 20:32:42 14 255 3 0 0 74
                                2015-07-05 16:24:08 14 10 1 0 38 3.953
                                2015-07-05 16:24:08 14 10 1 0 39 0.001298
                                2015-07-05 16:24:09 14 11 1 0 38 4.731
                                2015-07-05 16:24:10 14 11 1 0 39 0.015577
                                2015-07-05 16:24:10 14 255 3 0 0 64
                                2015-07-05 18:55:40 14 10 1 0 38 4.050
                                2015-07-05 18:55:40 14 10 1 0 39 0.061008
                                2015-07-05 18:55:40 14 11 1 0 38 4.212
                                2015-07-05 18:55:42 14 11 1 0 39 0.066200
                                2015-07-05 18:55:42 14 255 3 0 0 78
                                One one of the two units I have issues on radio:
                                Batt: 4.05V ; 0.00A
                                Solar: 1.80V ; 0.00 A; charge: No
                                BattPct: 78%
                                send: 15-15-0-0 s=10,c=1,t=38,pt=7,l=5,st=fail:4.050
                                send: 15-15-0-0 s=10,c=1,t=39,pt=7,l=5,st=fail:0.001298
                                send: 15-15-0-0 s=11,c=1,t=38,pt=7,l=5,st=ok:1.804
                                send: 15-15-0-0 s=11,c=1,t=39,pt=7,l=5,st=fail:0.000000
                                send: 15-15-0-0 s=255,c=3,t=0,pt=1,l=1,st=fail:78
                                • epierreE epierre
                                  Batt: 4.06V ; 0.00A
                                  BattPct: 79%
                                  Batt: 4.05V ; 0.00A
                                  BattPct: 78%
                                  on the other:
                                  Batt: 4.05V ; 0.00A
                                  BattPct: 78%
                                  C
                                  C
                                  ceech
                                  @epierre I'll ask @AWI, he may help.
                                  • AWIA
                                    AWIA
                                    AWI
                                    Your circuit seems to be working correctly. I cannot figure out why the sleep time should influence the metering. I suggest you first test it with a minimal sketch to figure out this sleep issue.
                                    • epierreE
                                      epierreE
                                      epierre
                                      @AWI What should I keep as minimal ? also any idea about the radio hazard ? I've changed several antennae and it is either half wrong or "check wire"
                                      AWIA 1 Reply Last reply
                                      • epierreE epierre
                                        AWIA
                                        AWIA
                                        AWI
                                        @epierre in a minimal sketch I would remove have it only send one message and give it enough println's to debug via serial. Check the voltages with a meter and let it run with an increasing sleep time. It could be one of those 'bad radios' which are discussed here on the forum.
                                        For the charging part: it only charges a partly empty cell and the charge voltage should be high enough to let it happen.
                                        Debugging is where the fun starts (if you are able to solve it)..
                                        • epierreE
                                          epierreE
                                          epierre
                                          so the same without sensor nor mysensors... 30 secs fine 40 secs dead...
                                          I've removed the radio chipset, same behavior...
                                          // PIN Radio
                                          uint16_t lastlux;
                                          unsigned long SLEEP_TIME = 40*1000;  // sleep time between reads (seconds * 1000 milliseconds)
                                            sendVoltage();
                                           delay(SLEEP_TIME);
                                          	int battPct = 1 ;
                                          12.5k
