  3. Sensor board w/ liPo charger and fuel gauge +BMP180 +HTU21
37 Posts 10 Posters 27.0k Views 5 Watching
  • C ceech
    Finally managed to put all things together and made the first two test boards. They look like this:
    Main new features are LTC4067 lithium battery charger and XC6210, a low consumption voltage regulator.
    The board comes with a Torex XC6210 3.3V voltage regulator . It has low power consumption of 35μA, while delivering at least 700mA. Voltage drop is 50mV @ 100mA.
    LTC4067 battery charger with Automatic Battery Charging/Load Switchover
    It provides power for the circuit and charges the backup single-cell lithium battery while greatly extends battery life. You can monitor the voltages and currents. It has suspend mode, which reduces current consumption to around 40μA. The power source is a small, 5V solar cell. Connections:
    analog input A1 on ATmega 328 is FAULT signal from LTC4067
    analog input A0 on ATmega328 is battery voltage
    analog input A2 is solar cell voltage
    analog input A6 is input current ( I=V/R x 1000 )
    analog input A7 is battery charge current ( I=V/R x 1000 )
    digital output A9 - drive it high to put LTC4067 in SUSPEND mode
    The two trimmer potentiometers are used to determine the current for both the input side - to better match the internal resistance of the solar cell - and for the battery charge current. At shipping they are both set to about 2.5kOhm, which set both currents to about 75mA. Please refer to technical data sheet of LTC4067 for more information. It is available here:
    Official web page for LTC4067
    Or, ask me.
    This is the back side of the board with place for BMP180, HTU21 and EEPROM chip:
    SparkmanS
    SparkmanS
    Sparkman
    @ceech Looks great! When do you expect to have them available for sale?
    Al
    • sj44kS
      sj44kS
      sj44k
      @ceech Some impressive work you are pulling off here! I am also interested so keep us posted when you have it available !
      • L lafleur
        It need an RFM69 radio on the board....??
        C
        C
        ceech
        @lafleur The board is meant to be used with either NRF24l01+, or ESP8266 radio modules. @hawk_2050 The price will be around 14EUR for the version without sensors, and 19EUR for the fully populated one. @Sparkman and @sj44k some boards will be available as soon as next week. Those are the test ones and since everything seem to work excellent, I'll make them available for purchase.
        • C
          C
          ceech
          wrote on last edited by ceech
          #31
          For those interested, here is a link with more detailed description of this board:
          http://www.ebay.com/itm/331641400414?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
          We will probably offer a bit less complex version here, on mysensors.org.
          Enjoy.
            MikeF
            I've just built a version of this, using the solar cell from the Solar Motion Light identified in this project: Solar Powered Mini-Weather Station. I'm using Domoticz as the controller.
            I'm trying to understand what the solar and battery currents represent (I had to scale these by 1000, as Domoticz will only display currents in amps). Also, at what battery voltage level will the battery start to charge? and what level of solar voltage is required? I'm also concerned that the solar cell voltage can exceed 6V in bright sunlight - is there a need for overvoltage protection on the LTC4067?
            (I'll post details and pics in My Projects shortly.)
            C 1 Reply Last reply
            • M MikeF
              C
              C
              ceech
              #33
              Here:
              float readVcc()
                signed long resultVcc;
                float resultVccFloat;
                delay(10);                           // Wait for Vref to settle
                ADCSRA |= _BV(ADSC);                 // Convert
                resultVcc = ADCL;
                resultVcc |= ADCH<<8;
                resultVcc = 1126400L / resultVcc;    // Back-calculate AVcc in mV
                resultVccFloat = (float) resultVcc / 1000.0; // Convert to Float
                return resultVccFloat;
              int current = A6;
              int chrg = A1;
              int cell = A2;
              int lipo = A0;
              int batterycurrent = A7;
                Serial.begin(9600);
                float napetost = readVcc();
                float tok = ((analogRead(current) * napetost / 1024 ) / 2500) * 1000000; // convert the ADC value to miliamps
                float tokbaterija = ((analogRead(batterycurrent) * napetost / 1024 ) / 2500) * 1000000; // convert the ADC value to miliamps
                float panel = ( analogRead(cell) * napetost / 1024 ) * 2; // measuring input voltage
                float baterija = ( analogRead(lipo) * napetost / 1024 ) * 2; // measuring battery voltage
                int polnjenje = analogRead(chrg);
                Serial.print("Vcc = ");
                Serial.print(napetost);
                Serial.println("V");
                delay(400);
                Serial.print("Input current = ");
                Serial.print(tok);
                Serial.println("mA");
                delay(400);
                Serial.print("Charge current = ");
                Serial.print(tokbaterija);
                delay(400);
                Serial.print("Solar cell voltage = ");
                Serial.print(panel);
                delay(400);
                Serial.print("Battery voltage = ");
                Serial.print(baterija);
                delay(400);
                Serial.print("CHRG = ");
                Serial.println(polnjenje);
                Serial.println("----------------------------");
                delay(2000);
              Improving accuracy:
              To do so, simply measure your Vcc with a voltmeter and with our readVcc() function. Then, replace the constant 1107035L with a new constant:
              scale_constant = internal1.1Ref * 1024 * 1000
              where
              internal1.1Ref = 1,1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
              Example:
              For instance, I measure 3,43V from my FTDI, the calculated value of Vref is 1,081V.
              So (1,081 x 1000 x 1024) = 1107034,95 or 1107035L rounded up.
              Source: http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
              and
              https://code.google.com/p/tinkerit/wiki/SecretVoltmeter
                MikeF
                @Ceech Thanks, I'll give this a try; I need to make some hardware mods first - I'm thinking of including a MOSFET in series with IN, as per datasheet.
                • M MikeF
                  C
                  C
                  ceech
                  #35
                  @MikeF Sure, if you think it's necessary. OVI pin on the PCB is already connected to input power source. How do you plan to connect the gate of the mosfet to the OVP pin?
                    MikeF
                    @Ceech I guess I'm concerned that the solar cell voltage Vin might exceed 7V - which the datasheet says is the absolute max. (and the max. overvoltage threshold Vovth is 6.2V). I've been getting >6.5V, with the solar cell not pointing directly at the sun (i.e., not due south / azimuth). I'll take some measurements with the solar cell disconnected. I can see that it would be very difficult to interrupt the IN connection (pin 12); is there another way of limiting the solar cell voltage?
                    • M MikeF
                      C
                      C
                      ceech
                      #37
                      @MikeF Well not limiting, but reducing. Connect one or two ordinary diodes in series with the input, and you will reduce the voltage for 0.7V for every diode.
