  3. My first multisensor daughter board
14 Posts 5 Posters 8.3k Views 7 Watching
  • S Offline
    Hi!
    I am happy to present my first daughter board for MyTinyCamel (my other board in progress).
    All this work is in progress, but I like to share my work and it was rather lot of work ! but I think I will have something small&modular finally :smiley:
    I have made another version of MyTinyCamel with onboard sensors, but what about if I need a PIR sensor, or a gesture sensor. and want to keep things small. So I made this little daughter board.
    And a small vid to see how it looks with MyTinyCamel and 2xaaa:
    https://youtu.be/4ULY3P-F-Fo
    Technical descriptions (all optional):
    • 0805 NTC thermistor for temperature
    • SI7021 : temperature and humidity
    • BMP180 : pressure, barometer
    • VEML6070 : UV
    • TSL2561: ambiant light & IR
    • APDS-9960 : ambiant light & RGB & Gesture
    • PIR motion with mini lens (schematic is based on HC-SR501), with H-pad & trimmer footprint for sensibility
    • PIR can be enabled/disabled by onboard mosfet on daugther board
    • enlarged footprints for sensors (I hope to be able to handsolder them by adding a small drop of paste and heating the pad, otherwise I will have to build a reflow oven...)
    • solder jumper for each sensor to choose : VCC3 from MyTinyCamel or VCC_Sensors from Mytinycamel by mosfet
    There are 2 footprints for PIR. Why? because MyTinyCamel can have RFM69 or NRF24 smd. When nrf24 is used as you can see in the vid, it is a little wider. I wanted PIR sensor centered on top of a custom enclosure, in each case, so...
    Some notes :
    • as it is small, you can't use Gesture chip and PIR motion in same time. it is selectable by jumper. This jumper let you use : PIR or Gesture or External IO (smd pad).
    • When Gesture chip is soldered (APDS-9960), the onboard mosfet is used to enable/disable the internal IR led of the sensor. But it can still sense ambiant light by its VCC.
    • if it works well, I will make another version of this daugther boad for @Anticimex motherboard. I have thought a lot about I could make this compatible but I needed to stick to MyTinyCamel for this rev...
    I ordered one set of board to see, at oshpark... But your feedback are welcome of course, as now I need to design a small custom enclosure for this..
    And it gives me lot of other idea, like a micro-usb connector for usb powered or Hi-link AC-DC step down for something in wall mounted...
    See you soon!
    • G Offline
      G Offline
      GertSanders
      Very nice!!! How do you make the 3D views of your boards ?
      Gert
      • S Offline
        @GertSanders: thx :)
        I use Sketchup. It is easier to use with Eagle (lots of tuts on internet). I find the models everywhere I can (sparkfun, 3d sketchup market...) then I make changes if needed or create some (like the lens). I would prefer Solidworks, easier for me, but I can't export eagle to Solidworks, so..
        • S Offline
          just some ideas, but it's so fast with SolidW :smile:
          Do you want some salt??
          I need a 3d printer, aaargh :satisfied:
          • A Offline
            A Offline
            Anticimex
            For PIR, there is a low power design proposal by ST here. Perhaps something to consider? I would like to make one myself, but I do not have the time for that right now. Could be useful for battery-driven PIR.
            • S Offline
              @Anticimex : it seems very interesting. Something I was searching for.. I have found some others links different, but not easier to implement as your link. A low power PIR could be great, this is something missing in our battery powered sensors toolbox. I will look at this asap. Thx for share :smiley:
              A 1 Reply Last reply
              • S scalz
                A Offline
                A Offline
                Anticimex
                @scalz No problem :) I would replace the 4-resistor voltage dividers with potentiometers instead. Fewer components and much more tunable :)
                • S Offline
                  @Anticimex: yes, good idea. I am still waiting my D203s pir sensors. asa I get them, I try your link on breadboard and give you some news. thx. see you soon :smiley:
                  • S scalz
                    A Offline
                    A Offline
                    Anticimex
                    @scalz Great!
                    • D Offline
                      Dylano
                      @scalz said:
                      D203s pir sensors
                      Can i buy his board?
                      Domoticz, with a lot of working hardware, include mysensors :-)
                      OpenPLI, RuneAudio, Solarmeter, etc......
                      Not a great builder of software and hardware, more a user...
                      Only i try to do my best :-(
                      • S Offline
                        @Dylano: thx for interest :). I am comparing few pcbas, waiting my reflow oven much for small batch and boost prototyping than selling. I would prefer to have a good quotation or deal like limited partnership maybe...
                        In fact I have other boards in progress maybe you would prefer..
                        This one is based on mytinycamel, a board I made for ultra low power <1uA + booster, and for the exercise of power sequence&mosfets.... but it is better for telemetry application than PIR motion sensor.
                        Plus, here it needs a shield which add a little bit thickness, for indoor, I know it's just few mm...
                        So I made this one, better for pir (in progress, I will post pics) : http://forum.mysensors.org/topic/2951/my-mysx-multisensors-board
                        but mytinycamel is still actual because modular and enough cheap too, it works but I redraw it to add more connectors as i don't need pir on this one. rfm69 or nrf, ldo or booster+ ultra low power modee, eprom, power on/off sensors radios 2.4x5cm blabla...looks like this now with 3 connectors for common sensors.
                        Note: I have not yet this rev, this is a part of my week order ;) (with a dhl in my face please, as I am not so patient ...)
                        So for the moment nothing to sell, but in future..I would be glad :)
                        • D Offline
                          Dylano
                          I wait..
                          Hope you give a signal here when there are new possibilities..
                          And i hope you will share a stable sketch... for battery devices.
                          good luck!!
                          • alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @scalz any progress on this board? How did you like it with VELM6070 ?
                            • S Offline
                              @alexsh1
                              veml6070 works nice.
                              that's a while i've done this ulpnode board. finally i've done my coincell multisensors for indoor.
                              And now, for lot of sensors etc i use more powerful mcu.
                              That said i have a weather extension board with lot of sensors including the veml6070. will try to release when i'have time ;)
