New Raspberry Pi to NRF24l01+ Shield
@Ceech: I've just seen your Raspberry Pi to NRF24l01+ Shield on eBay here and I'm assuming that this can be used to implement a Domoticz controller and gateway, using the MySensors RPi port?
Can you publish the GPIO pin assignment for the NRF24L01, please - in particular, which pin is used for CE on a RPI 2?
I think he uses actual pin nr15 of the header. That would be GPIO22.
I use actual pin 22 on my board, which is GPIO25.
This allows me to stay within a 2x4 header format.
In his board he used a header for all 26 pins of the GPIO, so it does not matter which GPIO port he uses.
When compiling the PiSerialGateway, you will need to adapt the constant describing the pin to be used for CE, since it is now set to GPIO25 (pin 22) instead GPIO22 (pin 15) in the latest MySensors/Raspberry git.
Nope, I was wrong: he also uses GPIO25 (pin 22), so the latest version of MySensors\Raspberry should work for this board also.
(I just traced his board based on the pictures).
This shield actually has a few nice extra's my board does not have (buzzer, prototyping area). I just needed a power adapter and connector (and would also prefer no wires).
Here is my setup :-)
@ceech thanks for the board - arrived via eBay today! Looking forward to tinkering!
