  3. MyNodes.NET
  4. MyNetSensors (closed)
Scheduled Pinned Locked Moved MyNodes.NET
29 Posts 9 Posters 18.6k Views 5 Watching
  • derwishD
    derwishD
    derwish
    @ch3b7 said:
    what visual studio version? im make a controller in .net with visual studio 2010
    VS2015
    • derwishD
      derwishD
      derwish
      @gregl said:
      Great work @derwish
      • derwishD
        derwishD
        derwish
        @gbfromhb said:
        I have installed your source and have gotten to compile. I may not be able to jump on it right away, but I will see how it goes with Window IoT on Raspberry PI.
        How's it going? Got it to run?
        • G
          G
          gbfromhb
          wrote on last edited by gbfromhb
          @derwish sorry about the delay in getting back to you. I have it running on a Raspberry PI 2 with a 5" screen running at 800x480. I have a serial gateway plugged into Raspberry PI and there is no devices found. I suspected that this would happen there is a whole bunch of adventures with serial ports on the Raspberry PI with Windows 10 IoT.
          It may be a while before I can get to this again, but I will see what I can come up with.
          • G
            G
            gbfromhb
            Here is that latest update on getting it to work on the Raspberry PI. The Raspberry PI is having issues with FTDI USB to Serial. There is currently no drivers officially available. It looks like some people have gotten to work with in the foreground which this app is, but not in the background (headless). I so far have not gotten it to work with MyNetSensors.
            Here are the best links I have found on this issue so far.:
            http://embedded101.com/Blogs/David-Jones/entryid/695/Win-10-IoT-Core-FTDI-Serial-Driver-Headless-Startup-Task-problem
            http://embedded101.com/Blogs/David-Jones/entryid/702/Win-10-IoT-Core-FTDI-Issue-Update
            • Z
              Z
              Zelenaar
              @gbfromhb :
              Could it be that the FTDI USB to Serial issue is solved with the latest version ?
              http://embedded101.com/Blogs/David-Jones/entryid/705/Win-10-IoT-Core-Raspberry-PI-2-Native-Serial-is-Live-
              • derwishD
                derwishD
                derwish
                I have suspended development of this program, focusing on the web version of this project. Currently, this program is inferior to the web controller in functionality. If you show interest in this project, as a separate program for Raspberry or Windows 10 standalone, I will continue its development.
                G 1 Reply Last reply
                • derwishD derwish
                  G
                  G
                  gbfromhb
                  @derwish no. I was having the same concern about putting any time in this. I think you made the right choice. Have you looked into node.js and angular?
                  • derwishD
                    derwishD
                    derwish
                    @gbfromhb So far, I was looking at node.js only superficially. How can I use node in this project? If only to completely abandon IIS?
                    • G
                      G
                      gbfromhb
                      @derwish Yes it would replace IIS. One of the big things is the small footprint and it would run anywhere. Microsoft seems to be putting a lot effort into getting it into the Visual Studio world. Which you know how working in Visual Studio is a great deal. Using Node.js, Express, TypeScript, Bootstrap & Angular to name a few looks very interesting to me. As you may know I'm messing around with Windows 10 IoT (core) on a Raspberry Pi. It just seems like it could turn into a nice Automation Hub, but if this is done right it could work on a lot of platforms. You could start with a headless Raspberry Pi and make it as powerful as you need.
                      • G
                        G
                        gbfromhb
                        @derwish I have downloaded you new code. Very nice work.
                        derwishD 1 Reply Last reply
                        • G gbfromhb
                          derwishD
                          derwishD
                          derwish
                          @gbfromhb Thank you. One of the reasons why I began to write code in .NET - there is hope that when will come out the ASP.NET5, this project will work on any OS. I am interested to deal with it. Besides, I somehow nicer to program in C# than in JavaScript.
                          • G
                            G
                            gbfromhb
                            It's very interesting out there with the whole JavaScript adventure. Its use is sky rocketing and is being used across the whole stack. One thing that is very interesting to watch is the adaptation of Microsoft's TypeScript and I read something the other day that the Google V8 JavaScript engine that is what Node.JS uses will have an option to use Strong data Typing. Having the data strong typed makes it a lot easier for IDE applications like Visual Studio to provide all the features you get using C#.
                            • G
                              G
                              gbfromhb
                              @Zelenaar Yes the latest build of Windows IoT has opened up those pins to help with getting more flexibility when working with Serial ports. Rumor has it that if I follow this example:
                              https://ms-iot.github.io/content/en-US/win10/samples/SerialSample.htm
                              and use the latest build it could work. I now have all the hardware I need. I have not yet gotten around to testing this yet. Thanks for the input.
                              • G gbfromhb
                                derwishD
                                derwishD
                                derwish
                                @gbfromhb Well, let's see how the situation will develop. I'm interested in node.js but now I'm more invested in ASP.NET5.
                                  sky.s.kay
                                  I downloaded MyNetSensors v1.1.1 but I couldn't run "Web Server". Also I couldn't open all project code and database... I have Windows 10 Pro, Visual Studio 2015 Enterprise Edition, SQL Server 2008 Express, SQL Server 2012 and SQL Server 2014 on my computer. How can I run and see all modules of project?
                                  • pelleP
                                    pelleP
                                    pelle
                                    In order to get the webserver part to work you will have to run either the console or the service (i think) i had to change some stuff in the confog files to get it working. For instance the com port was set to 9 but im using com3. I also had to add localhost to thesoftnodes and webserver urls. I also changed the "defaultconnection" in the applicationdbcontex to use the webserverdbconnectionstring in the webconfig for the webserver. But without any error messages its hard to give exact help. Mabye u can set some breakpoints and narrow it down to where it goes wrong?
                                    • S sky.s.kay
                                      derwishD
                                      derwishD
                                      derwish
                                      @sky.s.kay Follow the installation instructions http://www.mynetsensors.com/Software/Install. Email info@mynetsensors.com at what stage of installation you have a problem.
                                      • F
                                        F
                                        fran52
                                        Hardware pinouts, (missing firmware on GitHub) Arduino code? and nothing compiles in VS2015 HELP???
                                        derwishD 2 Replies Last reply
                                        • F fran52
                                          derwishD
                                          derwishD
                                          derwish
                                          @fran52 Now I am working on version 2.0 (on Github). It will be completely redesigned. To compile the alpha version, you need ASP.NET5.
