  3. MySensors shield and RGBW Controller
66 Posts 16 Posters 41.8k Views 21 Watching
  • L
    L
    LastSamurai
    Yeah :sparkles: my PCBs from dirtypcbs finally arrived! So I instantly had to open the package and I must say: these pcbs are really well made (for that price). Here are pics. As you can see I designed them so that 2 fit on one 5x5cm pcb. So I have gotten myself 24 potential "smart" sensors now :smiley:
    I haven't gotten all components yet for multiple sensors but I started with one test sensor anyways. It has through hole resistors instead of some smd ones, no capacitor and no DHT22 yet. But once I get the components I will add them on the prototype. For now it's up and running with a demo sketch that just sends random values.
    And everything seems to be working nicely. Yeah^^
    Next step is to finalize the components and test some other components as arduino shield like components on the two pin headers I added for that one. And I already found some small things that I could still improve.
    Once that's all done I will finalize the RGBW ones and send them of for production.
    Love to hear your feedback and tipps guys!
    PS can I somehow add these pictures as thumbnails? They are quite big...
    • L
      L
      LastSamurai
      My test sensorboard has been successfully running for over a week now :sparkles:
      It's only reporting fake values because my new sensors (DHT22) did not yet arrive but this looks good already.
      This night there was an "accident" though. Suddenly the sensor stoped sending data. When I took it from its "hiding"spot I saw that the second LED on the board was constantly on. Do you guys knwo what that is for?
      When I connected my serial to usb adapter to check the node's status the sensor powered up again and is since working perfectly again. The adapter does also power the board though. The battery levels are still reported as 3.4V so this should not be a problem. Any idea what the problem could be?
      I haven't added the capacitor yet... might that be the problem?
      • L
        L
        LastSamurai
        Ok, the same thing just happened again. Before the unit shut down it did restart about 3 times (thats whats in the log from my domoticz). Might this be the brownout shutdown? Voltage with external multimeter is at aboud 2.7-2.8V. So do I have to change my fuse settings? Or perhaps use the mysensor bootloader...
        I also realized that I did connect my batteries directly to the VCC pins, not the raw pin. This means that the voltage converter on the board isn't used (right?). Should I change that, or what's happening with the 3.3V converter if it gets input voltages lower than 3V?
        I also realise that my usb to serial converter might be running at 5V so I might have killed my NRF (and possibly the arduino too) :disappointed:
        How do you guys handle this?
        • A
          activemind
          Is it available for other people yet? I am very interested in LED strip drivers connected to mySensor network and your PCB seems to fit the bill nicely.
          Good job.
          -AM
          • L
            L
            LastSamurai
            wrote on last edited by LastSamurai
            Not yet, although the designs are above. I have to work out the errors in my normal pcb yet. Then I can easily switch over to the RGB(W) one.
            PS: Good part: both nrf and arduino are still working. Bad part: They shut down again after about a second. So it has to be a power issue. What are the right settings/fuses/things to keep the arduino pro mini (3.3V) running with batteries at 2.8V and lower?
            • A
              activemind
              Thanks for the response. I will be watching your progress closely as I am very interested in this.
              -AM
              • L
                L
                LastSamurai
                It's a little sad that it took me so long but I finally managed to find a few minutes to "finalize" and test my sketch.
                Here is my working code for an RGBW node that is based on MySensors and works with domoticz (other controllers might send different strings => so you would have to change one part of the sketch).
                The sketch smoothly fades between colors and seemed to be stable in my test. What I still want to add is some kind of saved last values for possible restarts or loss of connection.
                I am gratefull for any feedback.
                Next I will finalize my (test) pcb design and order that.
                • the cosmic gateT
                  the cosmic gateT
                  the cosmic gate
                  i would like to test this RGWB also, are the PCB gerber files available ?
                  There's more than meets the eye
                  • L
                    L
                    LastSamurai
                    I was finally able to get my PCB designs done. They are currently being produced by dirtypcbs.com
                    I switched to big(ger) mosfets to be able to drive a longer LED strip and easier to use through hole components instead of SMD. My breadboard test worked great so I am really curious to see this in action.
                    I also updated my github repo with the Target3001 based design, XGerber export and a eagle file export (although I am not really sure how that works, I never really used eagle myself).
                    If you simply want to try these unchanged PCBs yourself here is a link where you can buy them: http://dirtypcbs.com/view.php?share=14600&accesskey=e4f6cec8b8aadb845d51076b0f1aaab0
                    Although I warn you, they are not tested yet!
                    Love to hear your feedback guys!
                    DwaltD J 2 Replies Last reply
                    • L LastSamurai
                      DwaltD
                      DwaltD
                      Dwalt
                      @LastSamurai
                      Nice work! Do you have a BOM for the RGBW board?
                      • L LastSamurai
                        J
                        J
                        jeti
                        @LastSamurai: I would also be really interested in the BOM!
                        • L
                          L
                          LastSamurai
                          I will post a real BOM on my github repo when I find the time for it (hopefully soon). It's not very complicated though:
                          • Arduino Pro mini
                          • NRF24L01+
                          • The rectangle on the bottom right side is a step down converter like e.g. this
                          • 4 10k stepup resistors and 4 mosfets
                          • 2 caps, one to smooth the 3.3 voltage line and one for the NRF. I guess it should work without them too most of the time
                          • J
                            J
                            jeti
                            Cool thanks! What MOSFETs do you use?
                            Thanks again for you effort!!!
                            • korttomaK
                              korttomaK
                              korttoma
                              @LastSamurai You have an error on your RGBW board! The PWM pins for a Pro Mini are not 3,4,5 and 6! They should be according to this:
                              PWM: 3, 5, 6, 9, 10, and 11. Provide 8-bit PWM output with the analogWrite() function.
                              • Tomas
                              L 1 Reply Last reply
                              • korttomaK korttoma
                                L
                                L
                                LastSamurai
                                #24
                                Ah yes, thanks for the reminder! I knew this at design time (though I forgot it myselft now). Pins 9-11 are already used by the nrf module, so there aren't enough pins left for 4x PWM. RGB channels are using the pins 3,5,6 in my design and white the "normal" pin 4. This isn't a huge problem because at least in domitcz all that the white channel does is on/off anyways (or mostly). I guess I have to update the texts though.
                                Do you guys know if there is a way to free up one additional pwm pin so that true 4 way pwm is possible? If thats not possible there is software pwm (although that might be a problem when using the network..?!).
                                @jeti For my tests I am using IRFZ44N, but that really only depends on how many leds you want to be able to drive.
                                DwaltD 1 Reply Last reply
                                • L LastSamurai
                                  DwaltD
                                  DwaltD
                                  Dwalt
                                  @LastSamurai To free up an additional pin for PWM, I believe you can change the CE and CS pins in the GW constructor. Use pin 4 for for CE to the radio and reroute the MOSFET to pin 9. And then designate the change in the GW constructor:
                                  MyTransportNRF24 transport(4, 10);
                                  MySensor gw(transport);
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    @Dwalt is absolutely right. I have been using this kind of setup for a looong time allready.
                                    https://codebender.cc/sketch:44740
                                    • Tomas
                                    • L
                                      L
                                      LastSamurai
                                      I finally found the time to really test my RGBW boards and I found another error: 2 pins of the mosfets are switched. To test it anyways I just took the mosfets and bend some legs to get them to the right connectors on the pcb. Aside from that I tested it for some days and it works beautifully. Dimming, on/off, color changing and the rgb/white switching works.
                                      I will try to create a second version soon that uses 4 pwm pins (so that white can be dimmed to) and fixes the mosfet's pins. Perhaps i'll switch to a barebone atmega 328p too because the full pro mini is kinda overkill here and I might be able to make smaller pcbs then.
                                      After I found out that my problems with programming the pro minis comes from FTDI's newest driver "features" (always prints "NON GENUINE DEVICE FOUND!" on the serial port) I can now also try my normal sensors boards again with some low power modifications.
                                      What's annoying me at the moment is that my raspberry pi (running my domoticz) controller won't restart at the moment. I'll have to fix that first.
                                      As always any input is welcome and I'll try to post updates and pictures as soon as possible.
                                      • L
                                        L
                                        LastSamurai
                                        Good news (I guess ;) ). I already redid my raspberry pi controller (where I kinda killed the old sd card :expressionless: ) and also fixed the 2 errors in my pcb.
                                        Sometimes in the next few days I'll try out a smaller pcb with the barebone arduino and test my sensor nodes again.
                                        • V
                                          V
                                          vil1driver
                                          wrote on last edited by vil1driver
                                          #29
                                          hi,
                                          nice work,
                                          I not understand why you said 2 pins of the mosfets are switched, for me it's ok,
                                          I see G to arduino pins, S at center, and D to leds.. I miss something ?
                                          I think I will buy some of them for testing
                                          ps: maybe you can add your project on openhardware.io
                                          sry for my english
