Why can't I assign a static NODE_ID in one sketch; but not the other?
I'm trying to assign a static NODE_ID to the standard Motion Sensor Example sketch, but I am getting compile errors. The code I am using is
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - Henrik Ekblad * * DESCRIPTION * Motion Sensor example using HC-SR501 * http://www.mysensors.org/build/motion * */ #include <MySensor.h> #include <SPI.h> unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds) #define NODE_ID 6 #define DIGITAL_INPUT_SENSOR 3 // The digital input you attached your motion sensor. (Only 2 and 3 generates interrupt!) #define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway) #define CHILD_ID 1 // Id of the sensor child MySensor gw; // Initialize motion message MyMessage msg(CHILD_ID, V_TRIPPED); void setup() { gw.begin (msg, NODE_ID) ; // Send the sketch version information to the gateway and Controller gw.sendSketchInfo("Motion Sensor", "1.0"); pinMode(DIGITAL_INPUT_SENSOR, INPUT); // sets the motion sensor digital pin as input // Register all sensors to gw (they will be created as child devices) gw.present(CHILD_ID, S_MOTION); } void loop() { // Read digital motion value boolean tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH; Serial.println(tripped); gw.send(msg.set(tripped?"1":"0")); // Send tripped value to gw // Sleep until interrupt comes in on motion sensor. Send update every two minute. gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME); }What I don't understand about all of this is, I have another sketch that I can and have manually set the NODE_ID for, and it is not that much different from what I have. The code for the working node I have with a set manual ID is:
/** * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2015 Sensnology AB * Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* * * REVISION HISTORY * Version 1.0 - 6-December-2015, Derrick Rockwell * * DESCRIPTION *This sketch uses two 30 bulb, 3mm LED holiday light strings. These *can usually be found in most dollar stores/hardware stores and are *battery powered. This sketch uses digital pins 3 and 4 to power two *a string of lights each. Ex, one can control white lights the other *could control multi-colour lights. */ #define SN "HolidayLEDDeskLights" #define SV "1.0" #include <MySensor.h> #include <SPI.h> #define MLED_PIN 3 // Pin Multi-Coloured LED's will attached to #define WLED_PIN 5 // Pin White-Coloured LED's will attached to #define FADE_DELAY 10 // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim) #define NODE_ID 4 #define CHILD_ID0 0 #define CHILD_ID1 1 MySensor gw; static int currentLevelM = 0; // Current dim level... static int currentLevelW = 0; // Current dim level... MyMessage dimmerMsgM(MLED_PIN, V_DIMMER); MyMessage lightMsgM(MLED_PIN, V_LIGHT); MyMessage dimmerMsgW(WLED_PIN, V_DIMMER); MyMessage lightMsgW(WLED_PIN, V_LIGHT); /*** * Dimmable LED initialization method */ void setup() { Serial.println( SN ); Serial.println( SV ); gw.begin( incomingMessage, NODE_ID ); // Register the LED Dimmable Light with the gateway gw.present( MLED_PIN, S_DIMMER ); gw.present( WLED_PIN, S_DIMMER ); gw.sendSketchInfo(SN, SV); // Pull the gateway's current dim level - restore light level upon sendor node power-up gw.request( MLED_PIN, V_DIMMER ); gw.request( WLED_PIN, V_DIMMER ); } /*** * Dimmable LED main processing loop */ void loop() { gw.process(); } //For Multi Coloured Lights void incomingMessage(const MyMessage &message) { if (message.type == V_LIGHT || message.type == V_DIMMER) { // if (message.sensor <= 2) { //0: All Dimmers //1: LED 1 //2: LED 2 // Retrieve the power or dim level from the incoming request message int requestedLevel = atoi( message.data ); // Adjust incoming level if this is a V_LIGHT variable update [0 == off, 1 == on] requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 ); if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){ fadeToLevel ( requestedLevel, MLED_PIN, ¤tLevelM ); // Inform the gateway of the current DimmableLED's SwitchPower1 and LoadLevelStatus value... gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0)); gw.send(dimmerMsgM.set(requestedLevel) ); } if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){ fadeToLevel( requestedLevel, WLED_PIN, ¤tLevelW ); // Inform the gateway of the current DimmableLED's SwitchPower1 and LoadLevelStatus value... gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0)); gw.send(dimmerMsgW.set(requestedLevel) ); } } } } /*** * This method provides a graceful fade up/down effect */ // For Multi Coloured Lights void fadeToLevel( int toLevel, int pin, int *currentLevel ) { int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1; while ( (*currentLevel) != toLevel ) { (*currentLevel) += delta; analogWrite( pin, (int)((*currentLevel) / 100. * 255) ); delay( FADE_DELAY ); } }can anyone help me? I checked out the API page when starting the library, but i'm still drawing blanks.
In your first sketch, the node accepts incoming messages.
The second sketch does not have a function for incoming messages, so you have no function to give gw.begin as argument. You tried giving ge.begin a message instead, but that's not what gw.begin expects so you got a warning.
When you don't want to use incoming messages you simply give NULL to gw.begin, as ericvdb suggested.
